@Richard-van-der-Plas try the 2.2 beta, it usually works better
@gohan just checked it's 2.1.1, is it easy to upgrade?
@Richard-van-der-Plas just clone the 2.2 dev instead of the stable, the rest is the same
@gohan fatal: destination path 'MySensors' already exists and is not an empty directory. It goes wrong with the first command, could you please give me some pointers ?
I designed a PCB for rfm or nrf -> raspberry pi
https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI -
I am trying to get the gateway to run the RFM69W radio but when I issue the "make" command I get this
In file included from ./MySensors.h:318:0, from examples_linux/mysgw.cpp:83: ./drivers/RFM69/new/RFM69_new.cpp:658:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function] LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI) ^It is latest beta.
Just simple rfm69w 433 with default options. It compiles but I get no communication with nodes and 100% processor, but maybe I did a bad wiring
I would have posted it but it just shows as no nodes are trying to connect and nodes are unable to find a parent of course. I'm using the rfm2nrf pcb in order to have the pins to connect to the raspberry.
PS here is the log of the startup
__ __ ____ | \/ |_ _/ ___| ___ _ __ ___ ___ _ __ ___ | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __| | | | | |_| |___| | __/ | | \__ \ _ | | \__ \ |_| |_|\__, |____/ \___|_| |_|___/\___/|_| |___/ |___/ 2.2.0-beta mysgw: MCO:BGN:INIT GW,CP=RPNG----,VER=2.2.0-beta mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: Listening for connections on 0.0.0.0:5003 mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1 mysgw: New connection from 127.0.0.1 mysgw: Client 0 connected mysgw: Client 0: 0;0;3;0;2; mysgw: Client 0: 0;0;3;0;2;Get Version mysgw: Client 0: 0;0;3;0;18;PING mysgw: Client 0: 0;0;3;0;18;PING -
@gohan Hi there updated to the latest dev, but i still have to restart the service after a few days, this is the message in the log:
Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Closing socket at ('192.168.1.115', 5003).#033[0m Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Socket closed at ('192.168.1.115', 5003).#033[0m Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] No response. Disconnected.#033[0m Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.115', 5003)#033[0mchecking with top, i see high CPU utilization:
20921 root 20 0 20036 872 784 R CPU ->99,5 0,1 682:53.59 mysgw -
@Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
[root@alarmpi bin]# ./mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.1.1 mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1 mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=1 mysgw: TSM:FAIL:PDT mysgw: TSM:FAIL:RE-INIT mysgw: TSM:INIT mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=2 mysgw: TSM:FAIL:PDT mysgw: TSM:FAIL:RE-INIT mysgw: TSM:INIT mysgw: !TSM:INIT:TSP FAIL mysgw: TSM:FAIL:CNT=3 mysgw: TSM:FAIL:PDT mysgw: Received SIGINTHere is my
/boot/config.txt:gpu_mem=64 initramfs initramfs-linux.img followkernel dtparam=spi=onand the spi dev:
# ls /dev/spidev0.* /dev/spidev0.0 /dev/spidev0.1I am using ArchLinuxARM:
# uname -a Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/LinuxI only wiring 7 pins (1-7) on
NRF24l01+.Raspberry Pi 2 hardware information:
# cat /proc/cpuinfo processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 processor : 1 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 processor : 2 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 processor : 3 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : BCM2835 Revision : a21041 Serial : 00000000475d18a4 # cat /sys/firmware/devicetree/base/model Raspberry Pi 2 Model B Rev 1.1Output from MySensors
configure:# ./configure [SECTION] Detecting target machine. ./configure: line 111: warning: command substitution: ignored null byte in input [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l. [SECTION] Checking GPIO Sysfs. [OK] /sys/class/gpio/export found [SECTION] Detecting SPI driver. [OK] SPI driver detected:SPIDEV. [SECTION] Detecting init system. [OK] init system detected: systemd. [SECTION] Saving configuration. [SECTION] Cleaning previous builds. [OK] Finished.I finally find out my raspberry pi board isn't detected properly in
configure. I change thefunction detect_machine:function detect_machine { ... case $hardware in ... BCM2835) soc="BCM2835" if [[ $machine == "Raspberry"* ]]; then local rev=($(detect_rpi_revision)) if [[ $rev == "a02082" || $rev == "a22082" ]]; then tp="RPi3" else tp="Rpi2" fi fi ;; ...make
mysgwagain, and I get this finally:# ./mysgw -d mysgw: Starting gateway... mysgw: Protocol version - 2.1.1 mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1 mysgw: TSF:LRT:OK mysgw: TSM:INIT mysgw: TSF:WUR:MS=0 mysgw: TSM:INIT:TSP OK mysgw: TSM:INIT:GW MODE mysgw: TSM:READY:ID=0,PAR=0,DIS=0 mysgw: MCO:REG:NOT NEEDED mysgw: Listening for connections on 0.0.0.0:5003 mysgw: MCO:BGN:STP mysgw: MCO:BGN:INIT OK,TSP=1Hello, I'm also have issue with this question. My Raspberry Pi 2 type is a01041, but by the original "configure" file it is not recognized:
[SECTION] Detecting target machine. [OK] machine detected: SoC=unknown, Type=unknown, CPU=armv7l.Maybe someone could explain why it is not recognized?
"Configure" file lines:
function detect_machine { ... case $hardware in ... BCM2835) soc="BCM2835" if [[ $machine == "Raspberry"* ]]; then local rev=($(detect_rpi_revision)) if [[ $rev == "a02082" || $rev == "a22082" ]]; then tp="RPi3" else tp="Rpi2" fi fi ;; ... My Raspberry Pi 2 info: processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 processor : 1 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 processor : 2 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 processor : 3 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 38.40 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : BCM2835 Revision : a01041 Serial : 0000000049a14619 -
Double radio or alternative pin for spi1:
https://forum.mysensors.org/topic/7702/double-spi-radio-raspberry-pi/2
I followed the instructions carefully. However I get an error. Can someone help?
git clone https://github.com/mysensors/MySensors.git --branch master cd MySensors ./configure --my-transport=nrf24 --my-gateway=ethernetThis results in a warning:
[SECTION] Detecting SPI driver. [WARNING] No supported SPI driver detected.When I run
makeI get the follwing error:In file included from examples_linux/mysgw.cpp:74:0: ./MySensors.h:254:2: error: #error No support for nRF24 radio on this platform #error No support for nRF24 radio on this platform ^ In file included from ./drivers/RF24/RF24.cpp:23:0, from ./MySensors.h:290, from examples_linux/mysgw.cpp:74: ./drivers/RF24/RF24.h:52:17: fatal error: SPI.h: No such file or directory #include <SPI.h> ^ compilation terminated. Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed make: *** [build/examples_linux/mysgw.o] Error 1Hope someone can help. Thanks.
Hello friends,
Reading the instructions for building a RaspberryPi Gateway using RFM69, it states that one should use the development branch and not master, since the Pi is using a different version of the driver.
Anyone knows when this will be merged to master branch?
Also, since this forces all nodes to use development branch as well to be able to communicate with the gateway, assuming I use the development branch now and it is later on merged into master, is there an easy way to upgrade nodes remotely to the new code?
I am planning to use Wall Switch Insertable Node, and Mini Relay Mode - Both support OTA updates, am I correct to assume this will allow upgrading without taking the nodes out of where they are located?
Sefi -
