  2. Announcements
    Have you tried both ethernet or mqtt?
      @Richard-van-der-Plas what version are you using?
      Richard van der PlasR
      @gohan the latest stable version i guess. Where can i check?
      gohanG 1 Reply Last reply
      • Richard van der PlasR Richard van der Plas
        @Richard-van-der-Plas try the 2.2 beta, it usually works better
        Richard van der PlasR 1 Reply Last reply
          @gohan just checked it's 2.1.1, is it easy to upgrade?
            @Richard-van-der-Plas just clone the 2.2 dev instead of the stable, the rest is the same
              @gohan fatal: destination path 'MySensors' already exists and is not an empty directory. It goes wrong with the first command, could you please give me some pointers ?
                you need to either delete or rename the Mysensors folder :)
                • llegoffL
                  llegoffL
                  llegoff
                  I designed a PCB for rfm or nrf -> raspberry pi
                  https://www.openhardware.io/view/470/MySensors-Gateway-for-Raspberry-PI
                    I am trying to get the gateway to run the RFM69W radio but when I issue the "make" command I get this
                    In file included from ./MySensors.h:318:0,
                                     from examples_linux/mysgw.cpp:83:
                    ./drivers/RFM69/new/RFM69_new.cpp:658:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function]
                     LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI)
                    It is latest beta.
                      It is latest beta.
                      #629
                      @gohan what configure command did you use? Knowing that would make it easier to reproduce the problem...
                      Does this warning cause any problem?
                        Just simple rfm69w 433 with default options. It compiles but I get no communication with nodes and 100% processor, but maybe I did a bad wiring
                          @gohan debug output could be useful ;-)
                            wrote on last edited by gohan
                            #632
                            I would have posted it but it just shows as no nodes are trying to connect and nodes are unable to find a parent of course. I'm using the rfm2nrf pcb in order to have the pins to connect to the raspberry.
                            PS here is the log of the startup
                             __  __       ____
                                    |___/                      2.2.0-beta
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: TSM:INIT:TSP OK
                            mysgw: TSM:INIT:GW MODE
                            mysgw: MCO:REG:NOT NEEDED
                            mysgw: MCO:BGN:STP
                            mysgw: MCO:BGN:INIT OK,TSP=1
                            mysgw: Client 0 connected
                            mysgw: Client 0: 0;0;3;0;2;
                              On my test RPI3 it is working.... I have to double check the other one.
                                @gohan Hi there updated to the latest dev, but i still have to restart the service after a few days, this is the message in the log:
                                Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Closing socket at ('192.168.1.115', 5003).#033[0m
                                Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Socket closed at ('192.168.1.115', 5003).#033[0m
                                Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] No response. Disconnected.#033[0m
                                Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.115', 5003)#033[0m
                                checking with top, i see high CPU utilization:
                                20921 root      20   0   20036    872    784 R  CPU ->99,5  0,1 682:53.59 mysgw
                                • C ccy
                                  @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
                                  [root@alarmpi bin]# ./mysgw -d
                                  mysgw: Starting gateway...
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: !TSM:INIT:TSP FAIL
                                  mysgw: TSM:FAIL:CNT=1
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:FAIL:RE-INIT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=2
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: TSM:INIT
                                  mysgw: TSM:FAIL:CNT=3
                                  mysgw: TSM:FAIL:PDT
                                  mysgw: Received SIGINT
                                  Here is my /boot/config.txt:
                                  gpu_mem=64
                                  initramfs initramfs-linux.img followkernel
                                  dtparam=spi=on
                                  and the spi dev:
                                  # ls /dev/spidev0.*
                                  I am using ArchLinuxARM:
                                  # uname -a
                                  Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
                                  I only wiring 7 pins (1-7) on NRF24l01+.
                                  Raspberry Pi 2 hardware information:
                                  # cat /proc/cpuinfo
                                  processor       : 0
                                  model name      : ARMv7 Processor rev 5 (v7l)
                                  BogoMIPS        : 38.40
                                  Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
                                  CPU implementer : 0x41
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  processor       : 1
                                  BogoMIPS        : 38.40
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  processor       : 2
                                  BogoMIPS        : 38.40
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  processor       : 3
                                  BogoMIPS        : 38.40
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  Hardware        : BCM2835
                                  Revision        : a21041
                                  Serial          : 00000000475d18a4
                                  # cat /sys/firmware/devicetree/base/model
                                  Raspberry Pi 2 Model B Rev 1.1
                                  Output from MySensors configure:
                                  # ./configure
                                  ./configure: line 111: warning: command substitution: ignored null byte in input
                                  [OK] Finished.
                                  I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
                                  function detect_machine {
                                      case $hardware in
                                      BCM2835)
                                          soc="BCM2835"
                                          if [[ $machine == "Raspberry"* ]]; then
                                              local rev=($(detect_rpi_revision))
                                              if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                                                  tp="RPi3"
                                                  tp="Rpi2"
                                              fi
                                          fi
                                  make mysgw again, and I get this finally:
                                  # ./mysgw -d
                                  mysgw: TSF:LRT:OK
                                  mysgw: TSM:INIT
                                  mysgw: TSF:WUR:MS=0
                                  mysgw: MCO:BGN:STP
                                  J
                                  J
                                  jacikaas
                                  @ccy
                                  Hello, I'm also have issue with this question. My Raspberry Pi 2 type is a01041, but by the original "configure" file it is not recognized:
                                  Maybe someone could explain why it is not recognized?
                                  "Configure" file lines:
                                      case $hardware in
                                      BCM2835)
                                          soc="BCM2835"
                                                  tp="RPi3"
                                                  tp="Rpi2"
                                              fi
                                          fi
                                  My Raspberry Pi 2 info:
                                  processor       : 0
                                  BogoMIPS        : 38.40
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  processor       : 1
                                  BogoMIPS        : 38.40
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  processor       : 2
                                  BogoMIPS        : 38.40
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  processor       : 3
                                  BogoMIPS        : 38.40
                                  CPU architecture: 7
                                  CPU variant     : 0x0
                                  CPU part        : 0xc07
                                  CPU revision    : 5
                                  Hardware        : BCM2835
                                  Revision        : a01041
                                  Serial          : 0000000049a14619
                                  • TriXwooDT
                                    TriXwooDT
                                    TriXwooD
                                    Double radio or alternative pin for spi1:
                                    https://forum.mysensors.org/topic/7702/double-spi-radio-raspberry-pi/2
                                    • A
                                      arraWX
                                      I followed the instructions carefully. However I get an error. Can someone help?
                                      cd MySensors
                                      ./configure --my-transport=nrf24 --my-gateway=ethernet
                                      This results in a warning:
                                        [WARNING] No supported SPI driver detected.
                                      When I run make I get the follwing error:
                                      ./MySensors.h:254:2: error: #error No support for nRF24 radio on this platform
                                                       from ./MySensors.h:290,
                                      compilation terminated.
                                      Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                                      Hope someone can help. Thanks.
                                      • skywatchS
                                        skywatchS
                                        skywatch
                                        Maybe you didn't enable SPI on the pi.
                                        From command prompt type 'sudo raspi-config', then select option 5 from the menu. This takes you to where you can enable the SPI bus on the pi. Then try again.
                                        S>
                                        • A
                                          arraWX
                                          @skywatch Thank you! That solved my problem.
