I have great problem with raspberry and domoticz and mysensors gateway !
@sundberg84
i buy a new sd card and write again os and domoticz and gateway...
now LED is ok and i have a ip for raspberry. but i think my raspberry's hardware is failure because now my commands send with a lot delay or can not send. or save and send all commands together suddenly . Do you know why?but about read only. thank you . i read this. but i have question. with this work after power off/on my sd card will not fail , is this true ? but when i do to read only , there is not any problem in Performance domoticz and my sensors and gateway? for send and receive commands ?after setup domoticz and my sensors gate way i can change to read only ? thank you
@Reza -I dont use read only because I wish to log. Instead I backup my database every day... preparing for a SD-card failure.
I have bought a class 10 8gb SanDisk and this has lasted me 2 years now with standard settings. First one was about 6-8 months with another brand.
@sundberg84 my new sd card is sandisk. setup again domoticz and mysensors gateway...
now os is ok even with power off/on. but i think my raspberry is fail . i think cpu is fail. before i compile domoticz with -j4 without any problem . but now with -j4 after 10-20% rpi is freeze. even when i compile with just make, when i want use domoticz for send command for relay , this have a a lot delay , or command can not send , or save command and after 1 min send all command. i think cpu can not work correct and have a hardware problem ! but i dont know why happen this ! after 7 month rpi was on the table and power was ok and i dont install any new software on the rpi ! suddenly happen... -
Use Berryboot AND fast USB drive to solve most of the problems related to corruption on SD card due power failures and number of write cycles. I have been using it for 2+ yrs now...
Continuous writes to a SD card, will make it fail at some point in time, it's just a question of time!.. And thus it will make the rpi fail.
Another thing can also be powering issues. (and even combined with a failing SD Card..)thank you dear @tbowmo
so this (fail cpu or rpi board) can related to write in cd card ? because i am confused .i can not found why suddenly... . i tested power and didn't have problem(if power of my house have problem so first power supply of raspberry should to fail). my rpi was working for 7-8 month without any access people to it and i dont any install new app or program. just power on rpi and put on my table !
in rpi was just domoticz and mysensors gateway. i used this just for smart home.
now i want just found reason of problem and solve this :(
do you think this problem (rpi fail) can related to sd card ? (According to the above description)
if yes , so for resolve , what is your suggest ? use a usb memory ? or read only (i want use rpi just for domoticz and mysensors gateway and devices)?with read only i can not see any report in domoticz log ?
thank you -
thank youIn it's default setup, domoticz writes log files and other data to the SD card all the time, and this can (over time) wear the SD card down, and eventually make it fail!
F.ex. everytime my domoticz instance receives a message from the MySensors gateway, it writes a log entry, describing which node it received the data from. (I have my log file stored on a ram disk though, so not writing directly to the SD card)
No, I do not use external memory.. I have a ram disk (I take some of the RAM memory of the RPI and converts it into a "disk")
See this link for more info http://bfy.tw/Dlkf
It will not totally prevent these things of happening, but it might help reduce the risk of it happening again..
63Mb. The sd card was made for my old 512Mb RPI B, now it runs on my 1024Mb RPI2, and have been working fine for more than a year.
@tbowmo do you know how i can stop domoticz.sh (after i compile source domoticz) for change log...
i see this topic. (https://www.domoticz.com/wiki/Moving_Log_and_Temporary_Files_To_a_RAM_Drive)
but this is for standard install. i use source and i can not how stop and change and start again.... -
I think you can find information here http://bfy.tw/Dn2q
@tbowmo i search about this and i test this code before:
Start Domoticz
sudo service domoticz.sh startStop Domoticz
sudo service domoticz.sh stopCheck if Domoticz is running
sudo service domoticz.sh statusbut this is dont work for domoticz that compile from source.
this is result:pi@raspberrypi:~ $ sudo service domoticz.sh stop Failed to stop domoticz.service: Unit domoticz.service not loaded. pi@raspberrypi:~ $ sudo service domoticz.sh status ● domoticz.service Loaded: not-found (Reason: No such file or directory) Active: inactive (dead) pi@raspberrypi:~ $for this i had to question from you :(
Start Domoticz
@Reza you can run ps to see current services running. Maybe its named something else when compiled from source - or its not just running? Did you try to start it before stopping it?
Start Domoticz
@sundberg84
thank you friend. domoticz now is working for me.but when run ps i dont see domoticz:pi@raspberrypi:~ $ ps PID TTY TIME CMD 1000 pts/0 00:00:00 bash 1026 pts/0 00:00:00 Xtightvnc 1031 pts/0 00:00:00 xstartup 1034 pts/0 00:00:00 lxsession 1066 pts/0 00:00:00 dbus-launch 1084 pts/0 00:00:00 openbox 1086 pts/0 00:00:00 lxpolkit 1088 pts/0 00:00:00 lxpanel 1090 pts/0 00:00:01 pcmanfm 1134 pts/0 00:00:00 start-pulseaudi 1135 pts/0 00:00:00 xprop 1585 pts/0 00:00:01 Xtightvnc 1589 pts/0 00:00:00 xstartup 1592 pts/0 00:00:00 lxsession 1624 pts/0 00:00:00 dbus-launch 1643 pts/0 00:00:00 openbox 1645 pts/0 00:00:00 lxpolkit 1647 pts/0 00:00:00 lxpanel 1649 pts/0 00:00:02 pcmanfm 1693 pts/0 00:00:00 start-pulseaudi 1694 pts/0 00:00:00 xprop 2546 pts/0 00:00:00 psthis is files after compile . and i put "/home/pi/rayan/domoticz" to "rc.local" for up after startup.
