  3. I have great problem with raspberry and domoticz and mysensors gateway !
42 Posts 6 Posters 13.2k Views 6 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Reza
    Continuous writes to a SD card, will make it fail at some point in time, it's just a question of time!.. And thus it will make the rpi fail.
    Another thing can also be powering issues. (and even combined with a failing SD Card..)
    R 1 Reply Last reply
    • tbowmoT tbowmo
      @Reza
      R
      R
      Reza
      thank you dear @tbowmo
      so this (fail cpu or rpi board) can related to write in cd card ? because i am confused .i can not found why suddenly... . i tested power and didn't have problem(if power of my house have problem so first power supply of raspberry should to fail). my rpi was working for 7-8 month without any access people to it and i dont any install new app or program. just power on rpi and put on my table !
      in rpi was just domoticz and mysensors gateway. i used this just for smart home.
      now i want just found reason of problem and solve this :(
      do you think this problem (rpi fail) can related to sd card ? (According to the above description)
      if yes , so for resolve , what is your suggest ? use a usb memory ? or read only (i want use rpi just for domoticz and mysensors gateway and devices)?with read only i can not see any report in domoticz log ?
      thank you
      tbowmoT 1 Reply Last reply
      • R Reza
        thank you
        tbowmoT
        tbowmoT
        tbowmo
        @Reza
        In it's default setup, domoticz writes log files and other data to the SD card all the time, and this can (over time) wear the SD card down, and eventually make it fail!
        F.ex. everytime my domoticz instance receives a message from the MySensors gateway, it writes a log entry, describing which node it received the data from. (I have my log file stored on a ram disk though, so not writing directly to the SD card)
        • tbowmoT tbowmo
          @Reza
          R
          R
          Reza
          @tbowmo
          now you use a external memory for log ? and have not any problem ?
          can you give me a Training link for setup step by step usb memory for write log ?
          • tbowmoT
            tbowmoT
            tbowmo
            No, I do not use external memory.. I have a ram disk (I take some of the RAM memory of the RPI and converts it into a "disk")
            See this link for more info http://bfy.tw/Dlkf
            R gohanG 2 Replies Last reply
            • tbowmoT tbowmo
              R
              R
              Reza
              @tbowmo you was helper for me always . thank you for this .
              i found this :
              https://www.domoticz.com/wiki/Setting_up_a_RAM_drive_on_Raspberry_Pi
              this is help me for dont happen fail again ?
              again thank you for help
              • tbowmoT
                tbowmoT
                tbowmo
                @Reza
                It will not totally prevent these things of happening, but it might help reduce the risk of it happening again..
                • tbowmoT tbowmo
                  @Reza
                  R
                  R
                  Reza
                  @tbowmo thank you again my dear friend.
                  • tbowmoT tbowmo
                    @tbowmo How big did you make the RAMdisk?
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @gohan
                      63Mb. The sd card was made for my old 512Mb RPI B, now it runs on my 1024Mb RPI2, and have been working fine for more than a year.
                      • tbowmoT tbowmo
                        @gohan
                        R
                        R
                        Reza
                        wrote on last edited by Reza
                        #28
                        @tbowmo do you know how i can stop domoticz.sh (after i compile source domoticz) for change log...
                        i see this topic. (https://www.domoticz.com/wiki/Moving_Log_and_Temporary_Files_To_a_RAM_Drive)
                        but this is for standard install. i use source and i can not how stop and change and start again....
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Reza
                          I think you can find information here http://bfy.tw/Dn2q
                          • tbowmoT tbowmo
                            @Reza
                            R
                            R
                            Reza
                            @tbowmo i search about this and i test this code before:
                            Start Domoticz
                            sudo service domoticz.sh start
                            Stop Domoticz
                            sudo service domoticz.sh stop
                            Check if Domoticz is running
                            sudo service domoticz.sh status
                            but this is dont work for domoticz that compile from source.
                            this is result:
                            pi@raspberrypi:~ $ sudo service domoticz.sh stop
                            Failed to stop domoticz.service: Unit domoticz.service not loaded.
                            pi@raspberrypi:~ $ sudo service domoticz.sh status
                            ● domoticz.service
                               Loaded: not-found (Reason: No such file or directory)
                               Active: inactive (dead)
                            pi@raspberrypi:~ $
                            for this i had to question from you :(
                            sundberg84S gohanG 2 Replies Last reply
                            • R Reza
                              Start Domoticz
                              Stop Domoticz
                              this is result:
                              ● domoticz.service
                              pi@raspberrypi:~ $
                              sundberg84S
                              sundberg84S
                              #31
                              @Reza you can run ps to see current services running. Maybe its named something else when compiled from source - or its not just running? Did you try to start it before stopping it?
                              • R Reza
                                Start Domoticz
                                Stop Domoticz
                                this is result:
                                ● domoticz.service
                                pi@raspberrypi:~ $
                                @Reza why are you running it from source and not from standard install?
                                • sundberg84S sundberg84
                                  R
                                  R
                                  Reza
                                  @sundberg84
                                  thank you friend. domoticz now is working for me.but when run ps i dont see domoticz:
                                  pi@raspberrypi:~ $ ps
                                    PID TTY          TIME CMD
                                   1000 pts/0    00:00:00 bash
                                   1026 pts/0    00:00:00 Xtightvnc
                                   1031 pts/0    00:00:00 xstartup
                                   1034 pts/0    00:00:00 lxsession
                                   1066 pts/0    00:00:00 dbus-launch
                                   1084 pts/0    00:00:00 openbox
                                   1086 pts/0    00:00:00 lxpolkit
                                   1088 pts/0    00:00:00 lxpanel
                                   1090 pts/0    00:00:01 pcmanfm
                                   1134 pts/0    00:00:00 start-pulseaudi
                                   1135 pts/0    00:00:00 xprop
                                   1585 pts/0    00:00:01 Xtightvnc
                                   1589 pts/0    00:00:00 xstartup
                                   1592 pts/0    00:00:00 lxsession
                                   1624 pts/0    00:00:00 dbus-launch
                                   1643 pts/0    00:00:00 openbox
                                   1645 pts/0    00:00:00 lxpolkit
                                   1647 pts/0    00:00:00 lxpanel
                                   1649 pts/0    00:00:02 pcmanfm
                                   1693 pts/0    00:00:00 start-pulseaudi
                                   1694 pts/0    00:00:00 xprop
                                   2546 pts/0    00:00:00 ps
                                  this is files after compile . and i put "/home/pi/rayan/domoticz" to "rc.local" for up after startup.
                                    R
                                    R
                                    Reza
                                    @gohan because i wanted change some things. for example font , theme , icons and etc...
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Reza
                                      Once again, try this link http://bfy.tw/DnCc
                                      (Hint.. try looking for answers by using google!)
                                      R 2 Replies Last reply
                                      • tbowmoT tbowmo
                                        @Reza
                                        R
                                        R
                                        Reza
                                        @tbowmo thank you . i will search about this issue
                                        • tbowmoT tbowmo
                                          @Reza
                                          R
                                          R
                                          Reza
                                          @tbowmo thanks for all guide. i could do it. thank you
                                          My friend just one question . i want know if i choose for example 20mb for ram driver (tmpfs). after full this memory (if i dont clear this), so what happen ? raspberry will be crash ? or not happen and I dont have any new log and report ? or again write on ago log ? thank you for all help
                                          12.5k
