  3. πŸ’¬ Wall Switch Insertable Node
contest2017rfm69atsha204amysensorslonglifeswitchbatterycoincell
37 Posts 15 Posters 17.0k Views 17 Watching
  • KoreshK
    KoreshK
    Koresh
    Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-coincell-powered-switch-controller-rfm69cw-433-mhz-radio-156694971.htm
    • KoreshK
      KoreshK
      Koresh
      wrote on last edited by Koresh
      #24
      I've prepared several kits for true soldering amateurs :wink:
      • jeremushkaJ
        jeremushkaJ
        jeremushka
        Which kind of switches can we plug? normally losed or any kind of light switches already installed in the house?
        KoreshK 1 Reply Last reply
        • jeremushkaJ jeremushka
          KoreshK
          KoreshK
          Koresh
          @jeremushka We can use any switches\buttons with this board. So you can use both ON/OFF and momentary switches.
          jeremushkaJ 1 Reply Last reply
          • KoreshK Koresh
            jeremushkaJ
            jeremushkaJ
            jeremushka
            @Koresh interesting. What about the battery life? how did you optimize your code in order to have at least battery life 1 year ?
              KoreshK
              KoreshK
              Koresh
              @jeremushka
              There are no problems with battery drain in this circuit. The MCU sleeps between buttons action. Any changes of button state cause rising edge on the interrupt pin and intterruption routine calling (both of open and close events). We check buttons state only during interuption routine. If you use ON-OFF buttons each of buttons in closed state will increase current consumption by ~3uA. Which is not very critical ;)
              • KoreshK Koresh
                @jeremushka
                jeremushkaJ
                jeremushkaJ
                jeremushka
                @Koresh indeed 3uA is nothing. However, the light can always be on or off if the circuit has some problems. Because no action on light switch will be possible.
                Y 1 Reply Last reply
                  Y
                  Y
                  yury
                  @jeremushka said in πŸ’¬ Wall Switch Insertable Node:
                  " if the circuit has some problems"
                  Could please elaborate more on your findings? Did you notice any bugs in the code or in schematics?
                  • Sefi NinioS
                    Sefi NinioS
                    Sefi Ninio
                    Hello @yury and @Koresh ,
                    I am not sure how to connect the switch in the wall to this board.
                    My house has Gewiss switches, but J1-J4 expects 2 wires - so I am not sure how they connect... Can you help?
                    • Sefi NinioS Sefi Ninio
                      Y
                      Y
                      yury
                      wrote on last edited by yury
                      #32
                      @Sefi-Ninio
                      Hi Sefi,
                      if you like to put some additional extra switch somewhere you can use this funny way:
                      https://www.youtube.com/watch?v=-vJRF8ByBZU&feature=youtu.be
                      if you like to use the one in the wall, this way may work for you:
                      In both ways you need to have something that receives signal from the switch - a relay node.
                      3 easy steps as usual ))))
                      1. Π‘onnect any connector (J1-J4) to a switch terminals and glue them together with self adhesive or Velcro or glue gun....
                      2. Connect wires from the wall together. Now you power up the Relay node which controls a bulb in the ceiling.
                      3. Install the switch and the switch node back into the wall.
                      let me know if it is clear for you. I mean the Relay node part.
                      safety first - power down the switch before removing it.
                      • Sefi NinioS
                        Sefi NinioS
                        Sefi Ninio
                        Hey @yury , thanks for the reply!
                        The pictures were very helpful :)
                        Does this board come flashed with the alternate bootloader that supports OTA updates?
                          Y
                          Y
                          yury
                          @Sefi-Ninio said in πŸ’¬ Wall Switch Insertable Node:
                          yes, comes with dualoptiboot. but the code is very basic and sends to sleep right after button pressed. So need some additional code to keep it awake to wait for OTA to receive.
                            mardah
                            Would it be possible to skip the 74HC86D and use a pin change interrupt instead? And still support on/off switches?
                            KoreshK 2 Replies Last reply
                            • M mardah
                              KoreshK
                              KoreshK
                              Koresh
                              @mardah
                              If you want to routine only one switch. Otherwise you should use this schematic or any other variant.
                              • M mardah
                                KoreshK
                                KoreshK
                                Koresh
                                @mardah oh... you mean pin change system, not extint. You can use it of course.
                                With your input, this post could be even better πŸ’—
