  3. nRF5 action!
nRF5 action!
  • JokgiJ Jokgi
    @NeverDie I am not sure about all the boards for sell on that site. but I would have to say that any J-link programmer that is packaged as such for $12-$40 dollars is probably counterfeit. Updating these items with newer J-link firmware would more then likely disable them. (On purpose) You may wish to contact Segger in Boston prior to spending money on these potential clones. I would be interested to hear what experiences other people have had with the products from that site.
    The genuine J-link and j-link plus programmers are over $400.00 as you can see on the Digi-Key website. Per the Segger license agreements, the only J-link 0B devices that are able to be sold are to be bundled with a Evaluation / Development kit such as the nRF52-DK, ST, Rigato, and other semiconductor / module manufacture's dev kits.
    When would I need to upgrade the firmware? At least for now it seems to work just fine.
    • JokgiJ Jokgi
      Yes they are of course counterfeit, and using old firmware. You have a message when you use them with Segger software asking you to upgrade to newer firmware and if you accept your programmer is disabled (web is full of solutions to reflash a firmware).
      But if you don't upgrade the firmware it works fine as a SWD programmer, at least for basic use (programming). I have not tried any debugging.
      JokgiJ 1 Reply Last reply
      • Nca78N Nca78
        JokgiJ
        JokgiJ
        Jokgi
        @Nca78 Corrrect. It seems to me that a < 50 dollar Nordic nRF52 based Dev kit (or similar) which can be updated would be much less hassle.
          #902
          Are we limited to using RTC0? I've tried switching to RTC1 and RTC2, and I get the sense there are conflicts with both of them and the MySensors code if they're used.
          d00616D 1 Reply Last reply
            d00616D
            d00616D
            d00616
            RTC1 is blocked by arduino (nRF5/delay.c) and RTC0 (nRF51) and RTC2 (nRF52) is used in MySensors (hal/architecture/MyHwNRF5.cpp)
              #904
              Success. I now have a "listen mode" for the nRF52832 radio that's completely controlled by the PPI while the MCU sleeps. Presently, it wakes up the radio every 100ms and listens for 1ms. This means no wasted power from oversight by the MCU. Using just the PPI, I can control to within about 30us over how long to make the cycle period and/or the listening duration.
              The scope shots show the current drawn. Scale: 1mv=1ma. As you can see, the DCDC regulator is engaged.
              Next step will be to have packet receipt wake up the MCU via an ISR, so that the packet can be processed. After that, I'll see how narrow I can make the receive window and still receive packets reliably. I think under 100us will be possible. Maybe even less than 60us if the bitrate is 2mbps. :)
                JokgiJ
                JokgiJ
                Jokgi
                @NeverDie Great Job!!!! Suggestion... If you are going to use the BTLE Softdevice you will have a smaller receive window if you use the external 32khz crystal option rather then the internal 32khz RC one. (+/- 20ppm with the crystal vs +/- 250 or 500ppm with the RC.
                  #906
                  At the extreme, one of the questions that will need answering is: what's the minimum number of bytes in a transmitted frame that you really do need before the receiver starts receiving garbage packets? For instance, a 10 byte frame, which should be more than adequate, would take 40us of airtime to either transmit or receive at 2mbps bitrate. One could get to a lower number by maybe sending a null packet as a wake-up packet, in which case maybe you also don't need CRC. So, that leaves you with some preamble, a network ID, and maybe a destination ID--or about 5 bytes. So, that would be around 20us of airtime. One could shrink that further by reducing the number of network ID bytes, but too much of that and possibly one starts to receive garbage packets.
                  The RFM69 doesn't try to decode packets whose RSSI is below a specific programmable threshhold. I don't believe the nRF52 radio uses RSSI as a filter in that way though. It seems that the nRF52832 radio tries to decode whatever it's receiving, regardless of the RSSI. Or, at least, that's how I remember it. Anyone else played around with it?
                    @d00616
                    I adapted your RTC0 code for handling IRQ's, and it looks like this:
                      NRF_RADIO->INTENSET = B100;  //interrupt MCU if a payload is received.
                      // Enable interrupt
                      NVIC_SetPriority(RADIO_IRQn, 15);
                      NVIC_ClearPendingIRQ(RADIO_IRQn);
                      NVIC_EnableIRQ(RADIO_IRQn);
                    #if __CORTEX_M == 0x04
                            event = 0;        \
                            (void)event
                    // This must be in one line
                    extern "C" { void RADIO_IRQHandler(void) {packetCounter++; NRF5_RESET_EVENT(NRF_RADIO->EVENTS_PAYLOAD); NRF_RADIO->EVENTS_PAYLOAD=0; }}
                    Question: Is
                    doing anything more than
                    is?
                      #908
                      The good news is that I can now literally "see" that the listen-mode is receiving packets, because I've programmed the PPI to toggle an LED every time a packet is received (and it only toggles the LED if and only if I know that I'm sending the node packets from a different node). The bad news is that--so far, anyway--it doesn't appear to trigger an IRQ event that wakes up the MCU and runs the ISR.
                        @NeverDie it seems like the preamble can be configured to be either 8 or 16 bits. Not sure if that's of any use, but I've been thinking about adjusting the LoRa preamble to get better sleep times. Maybe that could be applicable for nrf as well.
                          #910
                          It turns out that using just the standard radiohead packet/frame structure, I'm able to 100% reliably receive a two byte string (in this case, the letter "H" followed by a zero as the termination character) using the above PPI solution with a receive window of about 200ms. That includes preamble, CRC, and a long network ID number.
                          I'm pleased with that result. It's vastly better than without the PPI solution.
                            #911
                            OK, I'm going to start with this, which works:
                            //A simplified re-mix of code mostly written by d00616
                            #include <nrf.h>
                            int interrupt = 0;
                            uint32_t theCounter;
                            int8_t myHwSleep(unsigned long ms)
                              hwSleepPrepare(ms);
                              //while (nrf5_rtc_event_triggered == false) {
                                hwSleep();
                              hwSleepEnd(ms);
                              return MY_WAKE_UP_BY_TIMER;
                              Serial.begin(250000);
                              Serial.println("Start");
                              // Configure RTC
                              NRF_RTC0->TASKS_STOP = 1;
                              NRF_RTC0->PRESCALER = 32;
                              NRF_RTC0->CC[0] = NRF_RTC0->COUNTER + (655);  //comparison for when to turn off the Rx.
                              NRF_RTC0->EVTENSET = RTC_EVTENSET_COMPARE0_Msk;
                              NRF_RTC0->INTENSET = RTC_INTENSET_COMPARE0_Msk;
                              NRF_RTC0->TASKS_START = 1;
                              NRF_RTC0->EVENTS_COMPARE[0] = 0;
                              // Enable interrupt
                              NVIC_EnableIRQ(RTC0_IRQn);
                              Serial.println();
                              Serial.println();
                              Serial.print(millis());
                              Serial.print(" ");
                              Serial.print(theCounter);
                              Serial.print(" ");
                              Serial.println(interrupt);
                              myHwSleep(5000000);
                             * Reset events and read back on nRF52
                             * http://infocenter.nordicsemi.com/pdf/nRF52_Series_Migration_v1.0.pdf
                                    event = 0;        \
                                    (void)event
                            extern "C" { void RTC0_IRQHandler(void) {   theCounter=NRF_RTC0->COUNTER; NRF5_RESET_EVENT(NRF_RTC0->EVENTS_COMPARE[0]); interrupt++; NRF_RTC0->TASKS_CLEAR = 1; }}
                            and see if I can generate equivalent code which triggers on a pin change instead of an RTC event. If I can get that to work, then I'll take another stab at getting it to work based on the radio receiving a packet.
                              #912
                              I was only partially done with the code, but I decided to run it anyway. Oddly enough, even though there is no reference to " RTC0_IRQHandler(void)" as being the event handler, it gets fired off anyway whenever I press the button (pin P0.16):
                              #include <nrf.h>
                              int interrupt = 0;
                                hwSleepPrepare(ms);
                                 hwSleep();
                                hwSleepEnd(ms);
                                //Configure GPIOTE
                                NRF_GPIOTE->CONFIG[0]=0x31001;  // Toggle Event; Pin P0.16; Event Mode
        //So, any pin change on P0.16 will trigger an event.
        //On the Nordic nRF52 DK, Pin 0.16 is a button.
                                NRF_GPIOTE->CONFIG[1]=0x131203;  //Initial setting: HIGH; Toggle Task; Pin P0.18; Task Mode
        //On the Nordic nRF52 DK, Pin 0.18 is an LED.
        //Note: initial setting of HIGH means that the LED will be initially OFF.
                                NRF_GPIOTE->INTENSET=1;  //Enable an event on Pin P0.16 to trigger an interrupt.
                                NRF_PPI->CH[0].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0];  //P0.16 pin change occured.
                                NRF_PPI->CH[0].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[1]; //Toggle LED on pin P0.18.
                                NRF_PPI->CHENSET=B1; //enable Channel 0.
                                // Enable interrupt
                                NVIC_SetPriority(GPIOTE_IRQn, 15);
                                NVIC_ClearPendingIRQ(GPIOTE_IRQn);
                                NVIC_EnableIRQ(GPIOTE_IRQn);
                                Serial.println();
                                Serial.println();
                                Serial.print(" ");
                                Serial.print(" ");
                                myHwSleep(5000000);
                                      event = 0;        \
                                      (void)event
                              So, it looks as though, at present, there can be only a single ISR for an entire sketch?
                                #913
                                Interesting result. I eliminated most of the sample code, and it actually manages to work even without an ISR! Instead of running an ISR, it appears to simply wake up from exactly where it last fell asleep. Then it continues running until it's put to sleep again:
                                #include <nrf.h>
                                uint32_t buttonPressCounter=0;
                                  hwSleepPrepare(ms);
                                  hwSleep();
                                  hwSleepEnd(ms);
                                  //Configure GPIOTE
                                  // Enable interrupt
                                  Serial.println();
                                  Serial.println();
                                  Serial.print("time=");
                                  Serial.print(", buttonPressCounter=");
                                  Serial.println(buttonPressCounter++);
                                  myHwSleep(5000000);
                                  @d00616
                                    // Enable interrupt
                                          event = 0;        \
                                          (void)event
                                  Question: Is
                                  is?
                                  d00616D
                                  d00616D
                                  d00616
                                  Question: Is
                                  is?
                                  Yes. It reads back the register. http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52/dita/nrf52/migration/functional.html?cp=2_4_0
                                    Whenever I use:
                                    on the nRF52832, there is around a 10 second delay between the end of "void startup()" and the beginning of "loop()". Why is that, and what is the MySensors library doing during that interval?
                                    mfalkviddM d00616D 2 Replies Last reply
                                      Whenever I use:
                                      @NeverDie it depends on the value of MY_TRANSPORT_WAIT_READY_MS
                                      See https://github.com/mysensors/MySensors/issues/927 for a discussion on what happens when - we're trying to clarify the documentation.
                                      • d00616D d00616
                                        If your goal is to minimize the RX-on time, then you can trigger the RX start and stop by a timer for your minimal window where the frame must be start. Then use the bitcounter top stop the timer in case a packet is received. A shortcut to the end is disabling the RX mode. You can wakeup the CPU with the END event.
                                        P.S.: you can reduce the RX/TX time by enabling fast ramp up in MODECNF0 if you haven't to care about nRF51 compatibility.
                                        #917
                                        Thanks for the tip. I tried it both ways. The first scope capture below is taken without MODECNF0 enabled on bit 0, and the second is with it enabled on bit 0.
                                        I don't really see any difference. Do you?
                                        Scale: 1mv=1ma. Scope captures of current drawn.
                                        Maybe @jokgi can comment? His bio says he's a Senior Field Application Engineer at Nordic Semiconductor.
                                        Maybe he sees (or knows) something that's not apparent about the fast ramp enable bit?
                                          Whenever I use:
                                          d00616D
                                          d00616D
                                          d00616
                                          Whenever I use:
                                          As an alternative, you can define '#define MY_CORE_ONLY' and use ' transportInit(); transportSetAddress(MY_NODE_ID);' to initialize the radio. This dosn't work at the moment with the nRF5. I'm currently looking what the reason is. All radio registers are equal when it's initialized after MySensors normal and my setup(). It's not able to send or receive packages.
                                          Maybe someone has an idea about the reason. Here is my code for nRF5 and other with nRF24.
                                          // Undefine to work in gateway mode
                                          #define MY_NODE_ID (0)
                                          // Enable debug
                                          #define MY_DEBUG_VERBOSE_RF24
                                          #define MY_DEBUG_VERBOSE_NRF5_ESB
                                          #ifndef ARDUINO_ARCH_NRF5
                                          #define MY_RADIO_NRF5_ESB
                                          #include <nrf.h>
                                          //#define MY_RADIO_RFM95
                                          #ifndef MY_CORE_ONLY
                                          #define MY_GATEWAY_SERIAL
                                          void state() {
                                          #ifdef ARDUINO_ARCH_NRF5
                                           Serial.println("----------------------------------");
                                           Serial.print("NRF_RADIO->STATE  ");
                                           Serial.println(NRF_RADIO->STATE, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_READY  ");
                                           Serial.println(NRF_RADIO->EVENTS_READY, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_ADDRESS  ");
                                           Serial.println(NRF_RADIO->EVENTS_ADDRESS, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_PAYLOAD  ");
                                           Serial.println(NRF_RADIO->EVENTS_PAYLOAD, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_END  ");
                                           Serial.println(NRF_RADIO->EVENTS_END, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_DISABLED  ");
                                           Serial.println(NRF_RADIO->EVENTS_DISABLED, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_DEVMATCH  ");
                                           Serial.println(NRF_RADIO->EVENTS_DEVMATCH, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_DEVMISS  ");
                                           Serial.println(NRF_RADIO->EVENTS_DEVMISS, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_RSSIEND  ");
                                           Serial.println(NRF_RADIO->EVENTS_RSSIEND, HEX);
                                           Serial.print("NRF_RADIO->EVENTS_BCMATCH  ");
                                           Serial.println(NRF_RADIO->EVENTS_BCMATCH, HEX);
                                           Serial.print("NRF_RADIO->CRCSTATUS  ");
                                           Serial.println(NRF_RADIO->CRCSTATUS, HEX);
                                           Serial.print("NRF_RADIO->RXMATCH  ");
                                           Serial.println(NRF_RADIO->RXMATCH, HEX);
                                           Serial.print("NRF_RADIO->RXCRC  ");
                                           Serial.println(NRF_RADIO->RXCRC, HEX);
                                           Serial.print("NRF_RADIO->DAI  ");
                                           Serial.println(NRF_RADIO->DAI, HEX);
                                           Serial.print("NRF_RADIO->PACKETPTR  ");
                                           Serial.println(NRF_RADIO->PACKETPTR, HEX);
                                           Serial.print("NRF_RADIO->FREQUENCY  ");
                                           Serial.println(NRF_RADIO->FREQUENCY, HEX);
                                           Serial.print("NRF_RADIO->TXPOWER  ");
                                           Serial.println(NRF_RADIO->TXPOWER, HEX);
                                           Serial.print("NRF_RADIO->MODE  ");
                                           Serial.println(NRF_RADIO->MODE, HEX);
                                           Serial.print("NRF_RADIO->PCNF0  ");
                                           Serial.println(NRF_RADIO->PCNF0, HEX);
                                           Serial.print("NRF_RADIO->PCNF1  ");
                                           Serial.println(NRF_RADIO->PCNF1, HEX);
                                           Serial.print("NRF_RADIO->BASE0  ");
                                           Serial.println(NRF_RADIO->BASE0, HEX);
                                           Serial.print("NRF_RADIO->BASE1  ");
                                           Serial.println(NRF_RADIO->BASE1, HEX);
                                           Serial.print("NRF_RADIO->PREFIX0  ");
                                           Serial.println(NRF_RADIO->PREFIX0, HEX);
                                           Serial.print("NRF_RADIO->PREFIX1  ");
                                           Serial.println(NRF_RADIO->PREFIX1, HEX);
                                           Serial.print("NRF_RADIO->TXADDRESS  ");
                                           Serial.println(NRF_RADIO->TXADDRESS, HEX);
                                           Serial.print("NRF_RADIO->RXADDRESSES  ");
                                           Serial.println(NRF_RADIO->RXADDRESSES, HEX);
                                           Serial.print("NRF_RADIO->CRCCNF  ");
                                           Serial.println(NRF_RADIO->CRCCNF, HEX);
                                           Serial.print("NRF_RADIO->SHORTS  ");
                                           Serial.println(NRF_RADIO->SHORTS, HEX);
                                           Serial.print("NRF5_RADIO_TIMER->MODE ");
                                           Serial.println(NRF5_RADIO_TIMER->MODE);
                                           Serial.print("NRF5_RADIO_TIMER->BITMODE ");
                                           Serial.println(NRF5_RADIO_TIMER->BITMODE);
                                           Serial.print("NRF5_RADIO_TIMER->SHORTS ");
                                           Serial.println(NRF5_RADIO_TIMER->SHORTS);
                                           Serial.print("NRF5_RADIO_TIMER->PRESCALER ");
                                           Serial.println(NRF5_RADIO_TIMER->PRESCALER);
                                            // Reset compare events
                                          #ifdef NRF51
                                            for (uint8_t i=0;i<4;i++) {
                                            for (uint8_t i=0;i<6;i++) {
                                           Serial.print("NRF5_RADIO_TIMER->EVENTS_COMPARE[");
                                           Serial.print(i);
                                           Serial.print("] ");
                                           Serial.println(NRF5_RADIO_TIMER->EVENTS_COMPARE[i]);
                                            #ifdef MY_CORE_ONLY
                                            transportInit();
                                            delay(1000);
                                            state();
                                            #ifdef MY_CORE_ONLY
                                            // Check for packages
                                            if (transportAvailable()) {
                                              uint8_t buffer[256];
                                              uint8_t num = transportReceive(&buffer);
                                              for (int i=0;i<num;i++) {
                                                if (buffer[i]<0x10) Serial.print("0");
                                                Serial.print(buffer[i], HEX);
                                                Serial.print(" ");
                                              Serial.println();
                                            // Pause
                                            //sleep(1000); don't use this on SAMD. The device must be restored with reset doubleclick
                                            delay(1000);
                                            // Send data
                                            //transportSend(MY_NODE_ID, "abcd", 4, false);
                                          Have you checked the MODECNF0 register after ramp up? Maybe the register must be changed in a specific state?
