  2. Announcements
    I am trying to get the gateway to run the RFM69W radio but when I issue the "make" command I get this
    In file included from ./MySensors.h:318:0,
                     from examples_linux/mysgw.cpp:83:
    ./drivers/RFM69/new/RFM69_new.cpp:658:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function]
     LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI)
    It is latest beta.
    #629
    @gohan what configure command did you use? Knowing that would make it easier to reproduce the problem...
    Does this warning cause any problem?
      Just simple rfm69w 433 with default options. It compiles but I get no communication with nodes and 100% processor, but maybe I did a bad wiring
        @gohan debug output could be useful ;-)
          wrote on last edited by gohan
          #632
          I would have posted it but it just shows as no nodes are trying to connect and nodes are unable to find a parent of course. I'm using the rfm2nrf pcb in order to have the pins to connect to the raspberry.
          PS here is the log of the startup
           __  __       ____
                  |___/                      2.2.0-beta
          mysgw: TSF:LRT:OK
          mysgw: TSM:INIT
          mysgw: TSF:WUR:MS=0
          mysgw: TSM:INIT:TSP OK
          mysgw: TSM:INIT:GW MODE
          mysgw: MCO:REG:NOT NEEDED
          mysgw: MCO:BGN:STP
          mysgw: MCO:BGN:INIT OK,TSP=1
          mysgw: Client 0 connected
          mysgw: Client 0: 0;0;3;0;2;
            On my test RPI3 it is working.... I have to double check the other one.
              you need to either delete or rename the Mysensors folder :)
              Richard van der PlasR
              @gohan Hi there updated to the latest dev, but i still have to restart the service after a few days, this is the message in the log:
              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Closing socket at ('192.168.1.115', 5003).#033[0m
              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Socket closed at ('192.168.1.115', 5003).#033[0m
              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] No response. Disconnected.#033[0m
              Sep 17 20:31:51 raspberrypi hass[17999]: #033[32m2017-09-17 20:31:51 INFO (Thread-13) [mysensors.gateway_tcp] Trying to connect to ('192.168.1.115', 5003)#033[0m
              checking with top, i see high CPU utilization:
              20921 root      20   0   20036    872    784 R  CPU ->99,5  0,1 682:53.59 mysgw
              • C ccy
                @Grubstake: Thanks. I have tried to follow "NRF24L01+ Radio" pin out connection. I have double / triple check my wiring is correct. But I still get the same fail message in mysgw debug mode:
                [root@alarmpi bin]# ./mysgw -d
                mysgw: Starting gateway...
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: !TSM:INIT:TSP FAIL
                mysgw: TSM:FAIL:CNT=1
                mysgw: TSM:FAIL:PDT
                mysgw: TSM:FAIL:RE-INIT
                mysgw: TSM:INIT
                mysgw: TSM:FAIL:CNT=2
                mysgw: TSM:FAIL:PDT
                mysgw: TSM:INIT
                mysgw: TSM:FAIL:CNT=3
                mysgw: TSM:FAIL:PDT
                mysgw: Received SIGINT
                Here is my /boot/config.txt:
                gpu_mem=64
                initramfs initramfs-linux.img followkernel
                dtparam=spi=on
                and the spi dev:
                # ls /dev/spidev0.*
                I am using ArchLinuxARM:
                # uname -a
                Linux alarmpi 4.9.13-3-ARCH #1 SMP Fri Mar 3 18:45:16 MST 2017 armv7l GNU/Linux
                I only wiring 7 pins (1-7) on NRF24l01+.
                Raspberry Pi 2 hardware information:
                # cat /proc/cpuinfo
                processor       : 0
                model name      : ARMv7 Processor rev 5 (v7l)
                BogoMIPS        : 38.40
                Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm
                CPU implementer : 0x41
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                processor       : 1
                BogoMIPS        : 38.40
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                processor       : 2
                BogoMIPS        : 38.40
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                processor       : 3
                BogoMIPS        : 38.40
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                Hardware        : BCM2835
                Revision        : a21041
                Serial          : 00000000475d18a4
                # cat /sys/firmware/devicetree/base/model
                Raspberry Pi 2 Model B Rev 1.1
                Output from MySensors configure:
                # ./configure
                ./configure: line 111: warning: command substitution: ignored null byte in input
                [OK] Finished.
                I finally find out my raspberry pi board isn't detected properly in configure. I change the function detect_machine:
                function detect_machine {
                    case $hardware in
                    BCM2835)
                        soc="BCM2835"
                        if [[ $machine == "Raspberry"* ]]; then
                            local rev=($(detect_rpi_revision))
                            if [[ $rev == "a02082" || $rev == "a22082" ]]; then
                                tp="RPi3"
                                tp="Rpi2"
                            fi
                        fi
                make mysgw again, and I get this finally:
                # ./mysgw -d
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                J
                J
                jacikaas
                @ccy
                Hello, I'm also have issue with this question. My Raspberry Pi 2 type is a01041, but by the original "configure" file it is not recognized:
                Maybe someone could explain why it is not recognized?
                "Configure" file lines:
                    case $hardware in
                    BCM2835)
                        soc="BCM2835"
                                tp="RPi3"
                                tp="Rpi2"
                            fi
                        fi
                My Raspberry Pi 2 info:
                processor       : 0
                BogoMIPS        : 38.40
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                processor       : 1
                BogoMIPS        : 38.40
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                processor       : 2
                BogoMIPS        : 38.40
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                processor       : 3
                BogoMIPS        : 38.40
                CPU architecture: 7
                CPU variant     : 0x0
                CPU part        : 0xc07
                CPU revision    : 5
                Hardware        : BCM2835
                Revision        : a01041
                Serial          : 0000000049a14619
                • TriXwooDT
                  TriXwooDT
                  TriXwooD
                  Double radio or alternative pin for spi1:
                  https://forum.mysensors.org/topic/7702/double-spi-radio-raspberry-pi/2
                  • A
                    arraWX
                    I followed the instructions carefully. However I get an error. Can someone help?
                    cd MySensors
                    ./configure --my-transport=nrf24 --my-gateway=ethernet
                    This results in a warning:
                      [WARNING] No supported SPI driver detected.
                    When I run make I get the follwing error:
                    ./MySensors.h:254:2: error: #error No support for nRF24 radio on this platform
                                     from ./MySensors.h:290,
                    compilation terminated.
                    Makefile:114: recipe for target 'build/examples_linux/mysgw.o' failed
                    Hope someone can help. Thanks.
                    • skywatchS
                      skywatchS
                      skywatch
                      Maybe you didn't enable SPI on the pi.
                      From command prompt type 'sudo raspi-config', then select option 5 from the menu. This takes you to where you can enable the SPI bus on the pi. Then try again.
                      S>
                      • A
                        arraWX
                        @skywatch Thank you! That solved my problem.
                        • Sefi NinioS
                          Sefi NinioS
                          Sefi Ninio
                          wrote on last edited by Sefi Ninio
                          #640
                          Hello friends,
                          Reading the instructions for building a RaspberryPi Gateway using RFM69, it states that one should use the development branch and not master, since the Pi is using a different version of the driver.
                          Anyone knows when this will be merged to master branch?
                          Also, since this forces all nodes to use development branch as well to be able to communicate with the gateway, assuming I use the development branch now and it is later on merged into master, is there an easy way to upgrade nodes remotely to the new code?
                          I am planning to use Wall Switch Insertable Node, and Mini Relay Mode - Both support OTA updates, am I correct to assume this will allow upgrading without taking the nodes out of where they are located?
                          Sefi
                            Like all nodes, you need to change the bootloader in order to enable ota.
                            • llegoffL
                              llegoffL
                              llegoff
                              hello, is there a inclusion mode planned for the raspberry pi gateway ?
                              • R
                                R
                                ricorico94
                                wrote on last edited by ricorico94
                                #643
                                This seems a great job, but despite I had a look at many posts (yes, many out of the dozens of pages.. ;-) ), I still can't figure out some questions..
                                • Beyond the obvious advantage of saving an arduino (and power supply, space..), is there an advantage for having the gateway hosted by the raspberry PI hosting my Domoticz ? (like more CPU available for handling communications or for signing ? or on the opposite more risks to overload the PI CPU -despite only a couple persons have complained about high CPU load))
                                • the default setup is Ethernet. What are the pros and cons of ethernet vs serial setup ? (speed? reliability ? possibility to move to other gateway?..)
                                • Is signing now implemented in this setup ? I didn't see it explicitely described, but some posts seem related to signing.
                                • if I want to use an external antenna and the high power NRF24, should I use an aother power source than raspberry PI ? (or maybe sharing the same USB charger, but diverting the power in parallel of the PI ?)
                                • is there a tutorial somewhere detailing how to uninstall and migrate to an external gateway ? During such migration, would I need to "touch" again my sensors and would I lose history logs of these sensors in Domoticz ?
                                Sorry for all these questions..
                                br,
                                Ricorico94
                                • R ricorico94
                                  br,
                                  Ricorico94
                                  #644
                                  @ricorico94 said in 💬 Building a Raspberry Pi Gateway:
                                  Not really. Cpu usage is normally 0-2% so it doesn't affect either way.
                                  Switching between different gateway types (serial, ethernet, mqtt) can be easier since there is no need to re-wire anything, just reconfigure and recompile. But that could be done with a all-in-one Arduino setup as well.
                                  Remote debug might be a benefit, since logging in to the raspberry pi to view log files can be done remotely. Remote debug for Arduino is possible, but usually requires additional hardware.
                                  The raspberry pi has room for more logging, which can help troubleshooting.
                                  The biggest downside is that a raspberry pi environment is infinitely more complex than an Arduino, which could affect reliability and make troubleshooting harder. On the other hand, there are more debugging tools available which might make troubleshooting easier.
                                  No difference in speed. No difference in reliability.
                                  Ethernet can easily be made accessible over the network. Doing that with serial can be done but is a bit tricky.
                                  Some controllers don't have support for all gateway types. See https://www.mysensors.org/controller for details.
                                  Yes. See the help text produced by running ./configure --help
                                  Yes. See the note on https://www.mysensors.org/build/raspberry#wiring
                                  See my answer in the question you posted yesterday.
                                  No worries. Except for posting one of the questions again (which wastes people's time and confuses people when they read only one of the places), you are very welcome to post as many questions as you like. Asking questions is usually the next best way to learn.
                                  • R
                                    R
                                    ricorico94
                                    Thanks a lot for your clear explanations ! Very useful !
                                    and.. bravo ! for all your work
                                    • R
                                      R
                                      ricorico94
                                      #646
                                      I'm trying to install the gateway on a Raspberry Pi 2 hosting Domoticz already (I had used the standard Domoticz image).
                                      I receive an error message on the make step, but maybe I've not properly understood instructions (not very friendly with raspberry and linux environment).
                                      First, I wired the NRF24 with PA (meaning I used an adapter and the 5V physical PIN#4) and the IRQ (wired on physical pin #15)
                                      Then I logged into my raspberry and staid in initial directory (pi@raspberrypi )
                                      I then typed:
                                      pi@raspberrypi ~ $ git clone https://github.com/mysensors/MySensors.git --branch master
                                      Cloning into 'MySensors'...
                                      remote: Counting objects: 14895, done.
                                      remote: Compressing objects: 100% (8/8), done.
                                      remote: Total 14895 (delta 0), reused 5 (delta 0), pack-reused 14887
                                      Receiving objects: 100% (14895/14895), 12.17 MiB | 1.68 MiB/s, done.
                                      Resolving deltas: 100% (9022/9022), done.
                                      pi@raspberrypi ~ $ cd MySensors
                                      pi@raspberrypi ~/MySensors $ ./configure --help
                                      Hopefully I did it in adequate folder ? (now I see a Mysensors folder in my /home/pi folder).
                                      Then I typed:
                                      pi@raspberrypi ~/MySensors $ --my-transport=nrf24
                                      -bash: --my-transport=nrf24 : commande introuvable
                                      pi@raspberrypi ~/MySensors $ ./configure --my-transport=nrf24
                                        [OK] machine detected: SoC=BCM2836, Type=Rpi2, CPU=armv7l.
                                        [OK] SPI driver detected:BCM.
                                        [OK] init system detected: sysvinit.
                                      [OK] Finished.
                                      So far, no error.. but should I have typed "./configure --my-transport=nrf24 --my-rf24-irq-pin=15" to implement the IRQ ? If yes, can I retype that command with new settings without issue ?
                                      Then I understaood I had to run make command:
                                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/RPi -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
                                      cc1: error: bad value (cortex-a7) for -mtune switch
                                      Makefile:118: recipe for target 'build/drivers/Linux/log.o' failed
                                      But errors... :anguished:
                                      I tried to search on forum, and saw someone else meniotning a smilar error, but people were answering about OrangePI, whereas I use a Rasp PI 2.
                                      I probably misunderstood some steps.. Could someone help me ?
                                      Note: in instructions, there's a statement I don't understand for ethernet gateway: "To set the gateway as a client that connects to a controller, use:--my-gateway=ethernet --my-controller-url-address=YOUR-CONTROLLER-ADDRES" . IN which case do we need that ? (as said, I plan to simply use this gateway on My dodmoticz rasp PI).
                                      br,
                                      Ricorico94
                                        That is fine, no need to add extra parameters as by defaults it will configure as ethernet gateway. Also try using the development branch as it has lots of bugs fixed.
                                        • A
                                          arraWX
                                          @ricorico94 Yesterday I managed to make a working rpi gateway. I am on rpi3, use a socket adapter board for the radio and use domoticz. I posted all the details here: https://forum.mysensors.org/topic/7793/nrf24l01-problems-in-2-1-1-and-2-2-0-beta/24
