  3. 💬 Smart Alarm Clock
💬 Smart Alarm Clock
alarmled ring lightspeakerdomoticzmysensorsclock
37 Posts 10 Posters 14.7k Views 12 Watching
  • micahM
    micahM
    micah
    I've finally settled on an enclosure design for my first (of 3) clock. This one is for my 10 year old son, I think he's going to love it.
    I originally found this on pintrest....
    fake bomb clock
    Fake bomb clock
    I'm going to use the bomb idea but modify it to fit all my existing design elements.
    I'm currently awaiting some parts from aliexpress and I'm still trying to find materials for the dynamite sticks. Hopefully I'll have everything I need soon so I can start to build it
    • micahM micah
      fake bomb clock
      Fake bomb clock
      @micah very cool idea. Just don't bring it when you travel by air ;-)
      • ben999B
        ben999B
        ben999
        wrote on last edited by ben999
        Awesome! I like that!
        I have ordered some parts to have a go myself with Nokia 5110 screen and rotary encoder :)
        May i have a look at your .ino file please ? Pretty sure i am not able to start from scratch...
        • N
          N
          Newzwaver
          How do you transfer this to the arduino?
          • N
            N
            Newzwaver
            Hi Can someone point me in the direction of the Ardunio code for this project? I have everything built and can get any code to work with the liquid crystal lib?
            • N Newzwaver
              @Newzwaver are the files in the sources tab insufficient? If so, could you clarify what is missing?
              • N
                N
                Newzwaver
                thanks for the reply and I might be missing it but the Arduino file is not posted under the code tab.
                • N Newzwaver
                  @Newzwaver could you be a bit more specific? Which file is missing?
                  There should be some file ending in .ino? So that's what is missing?
                  • N
                    N
                    Newzwaver
                    Yes the file ending in .ino is missing as you can see by your post above.
                    • mfalkviddM
                      Thanks. Hopefully micahbowerbank kan reply.
                      • N
                        N
                        Newzwaver
                        SO does anyone have any code for this project? I need the arduino code. Thanks in advance, excellent project btw.
                        • micahM
                          micahM
                          micah
                          Hey everyone.
                          Sorry, had a computer crash and file loss issue a few months ago.
                          I can't find my final code file, but I did find an older version (incomplete) called ClockRebuild.ino and I uploaded it to the project.
                          Hopefully that helps
                          One day I'll come back and truly finish this project, life just keeps getting in the way
                          • N
                            N
                            Newzwaver
                            Thanks for the arduino code, i will give it a shot.
                            • dbemowskD
                              dbemowskD
                              I am just curious why you did your switch board the way you did? You can do a similar style switch setup using all the same value resistors. Then you don't have to buy so many different resistor values. Something like this:
                              0_1508986754912_upload-8f7eb5ee-6fac-4bb8-8ef7-c5a3c6f82e0c
                              In this approach, whichever button you press, the resistor values, being in series, add up giving you a different voltage on your analog pin. With your approach, you use different resistor values on each switch which gives you your different voltage. My approach is only slightly different than yours. I am just wondering if there is an advantage one way or another.
                              Nca78N 1 Reply Last reply
                              • dbemowskD dbemowsk
                                @dbemowsk said in 💬 Smart Alarm Clock:
                                I guess it is useful in the case when user pushes more than one button ?
                                dbemowskD micahM 2 Replies Last reply
                                • Nca78N Nca78
                                  dbemowskD
                                  dbemowskD
                                  @Nca78 said in 💬 Smart Alarm Clock:
                                  I hadn't thought about that, but you are right. In my example, you couldn't press more than one button.
                                  • Nca78N Nca78
                                    micahM
                                    micahM
                                    micah
                                    @Nca78
                                    exactly correct.
                                    I originally went with the same resistor value so that it was easy. But then when I thought about how many button combinations I wanted (thinking about a real clock where you hold down the alarm set button then press the hour button) I went with different values.
                                    My implementation still isn't perfect, since I'm a bloody amateur... lol. I think 1 or 2 of the combinations I never got working.
                                    But for the most part it accomplished what I wanted... provided many buttons and combinations on a single input pin, since I was quickly running out of them
                                    • micahM
                                      micahM
                                      micah
                                      I found a library online.... #include <AnalogMatrixKeypad.h>
                                      I made some modifications (although I can't quite remember what they were), I think about the number of buttons, or combinations, or target values.
                                      But generally the library provided the 1 wire, resistor ladder and debouncing functionality I needed
                                      dbemowskD 1 Reply Last reply
                                      • micahM
                                        micahM
                                        micah
                                        I often wish our fancy mysensor nRF chips only used 1 arduino wire :(
                                        • micahM micah
                                          dbemowskD
                                          dbemowskD
                                          @micah Picking resistor values based on the number of switches you have shouldn't be too terribly difficult. You ar just creating a voltage divider circuit. When pushing multiple buttons, you just have to look at the resistor values for the buttons you have and calculate out the parallel resistance. Then you just have to figure out the analog value for any key combinations you want to use and create IF or Switch/Case statements to perform your logic.
