  3. 💬 Smart Alarm Clock
💬 Smart Alarm Clock
alarmled ring lightspeakerdomoticzmysensorsclock
37 Posts 10 Posters 15.0k Views 12 Watching
  • N
    N
    Newzwaver
    How do you transfer this to the arduino?
    • N
      N
      Newzwaver
      Hi Can someone point me in the direction of the Ardunio code for this project? I have everything built and can get any code to work with the liquid crystal lib?
      • N Newzwaver
        @Newzwaver are the files in the sources tab insufficient? If so, could you clarify what is missing?
        • N
          N
          Newzwaver
          thanks for the reply and I might be missing it but the Arduino file is not posted under the code tab.
          • N Newzwaver
            @Newzwaver could you be a bit more specific? Which file is missing?
            There should be some file ending in .ino? So that's what is missing?
            • N
              N
              Newzwaver
              Yes the file ending in .ino is missing as you can see by your post above.
              • mfalkviddM
                Thanks. Hopefully micahbowerbank kan reply.
                • N
                  N
                  Newzwaver
                  SO does anyone have any code for this project? I need the arduino code. Thanks in advance, excellent project btw.
                  • micahM
                    micahM
                    micah
                    Hey everyone.
                    Sorry, had a computer crash and file loss issue a few months ago.
                    I can't find my final code file, but I did find an older version (incomplete) called ClockRebuild.ino and I uploaded it to the project.
                    Hopefully that helps
                    One day I'll come back and truly finish this project, life just keeps getting in the way
                    • N
                      N
                      Newzwaver
                      Thanks for the arduino code, i will give it a shot.
                      • dbemowskD
                        dbemowskD
                        I am just curious why you did your switch board the way you did? You can do a similar style switch setup using all the same value resistors. Then you don't have to buy so many different resistor values. Something like this:
                        0_1508986754912_upload-8f7eb5ee-6fac-4bb8-8ef7-c5a3c6f82e0c
                        In this approach, whichever button you press, the resistor values, being in series, add up giving you a different voltage on your analog pin. With your approach, you use different resistor values on each switch which gives you your different voltage. My approach is only slightly different than yours. I am just wondering if there is an advantage one way or another.
                        Nca78N 1 Reply Last reply
                        • dbemowskD dbemowsk
                          @dbemowsk said in 💬 Smart Alarm Clock:
                          I guess it is useful in the case when user pushes more than one button ?
                          dbemowskD micahM 2 Replies Last reply
                          • Nca78N Nca78
                            dbemowskD
                            dbemowskD
                            @Nca78 said in 💬 Smart Alarm Clock:
                            I hadn't thought about that, but you are right. In my example, you couldn't press more than one button.
                            • Nca78N Nca78
                              micahM
                              micahM
                              micah
                              @Nca78
                              exactly correct.
                              I originally went with the same resistor value so that it was easy. But then when I thought about how many button combinations I wanted (thinking about a real clock where you hold down the alarm set button then press the hour button) I went with different values.
                              My implementation still isn't perfect, since I'm a bloody amateur... lol. I think 1 or 2 of the combinations I never got working.
                              But for the most part it accomplished what I wanted... provided many buttons and combinations on a single input pin, since I was quickly running out of them
                              • micahM
                                micahM
                                micah
                                I found a library online.... #include <AnalogMatrixKeypad.h>
                                I made some modifications (although I can't quite remember what they were), I think about the number of buttons, or combinations, or target values.
                                But generally the library provided the 1 wire, resistor ladder and debouncing functionality I needed
                                dbemowskD 1 Reply Last reply
                                • micahM
                                  micahM
                                  micah
                                  I often wish our fancy mysensor nRF chips only used 1 arduino wire :(
                                  • micahM micah
                                    dbemowskD
                                    dbemowskD
                                    @micah Picking resistor values based on the number of switches you have shouldn't be too terribly difficult. You ar just creating a voltage divider circuit. When pushing multiple buttons, you just have to look at the resistor values for the buttons you have and calculate out the parallel resistance. Then you just have to figure out the analog value for any key combinations you want to use and create IF or Switch/Case statements to perform your logic.
                                    • dbemowskD
                                      dbemowskD
                                      So, I didn't look the sketch over for this, but I am planning on building one of these and I have some questions. Does this show in 12 hour or 24 hour format? If it is 12 hour, how do you indicate AM or PM? Also, do you have a way of indicating that alarms are set? I may add some LEDs for these features.
                                      micahM 1 Reply Last reply
                                      • dbemowskD
                                        dbemowskD
                                        Here is my start on this. No speaker yet and I haven't added the LEDs for AM/PM and alarms, but that will come.
                                        0_1509333312144_upload-29d46ab7-e40a-49b9-aa1e-330beede8488
                                        I will need to make a bunch of modifications to the sketch. Mainly because I am using a different RTC module (DS1307). It is one that I have had laying around in my parts bin for years. I get a bunch of compile errors when I try to include the RTC library for this module.
                                        0_1509333483010_upload-75b8f66d-d692-412f-9171-d0175ea0402d
                                        Here is the board layout so far.
                                        0_1509333525901_upload-7777b1c8-2200-4300-aae8-c0a94786b7c8
                                          micahM
                                          micahM
                                          micah
                                          @dbemowsk
                                          To use a 24 hour clock switch the following bool
                                          bool Screen_HourFormat24 = false;
                                          I think I used the colon to signify that an alarm was set, I think I flashed it on and off. in the Update_Screen method
                                             if ((Alarm1_Enabled) && (!Keys_ShowAlarmOnScreen)){
                                                if(Screen_ClockPoint)ledScreen.point(POINT_ON);
                                                else ledScreen.point(POINT_OFF);
                                              } else
                                          12.5k
