  3. Strange behaviour with mysensors + RFLink
18 Posts 5 Posters 5.0k Views 4 Watching
    Could it be some noise? How far are from each other?
    • K
      K
      knop
      I think it is not noise, I've tried with 10meters between my RFLink and Arduino+NRF24 and same packets received on RFLink
      • K
        K
        knop
        Furthermore I did not change MyConfig.h and some others files in MySensors (no DEBUG etc..), I'm using MySensors V2.1.1
        I'm using RF24 lib from TMRh20 version 1.3.0
        • Y
          Y
          yos2000
          Same here:
          20;76;MySensors;ID=03;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1d0303ff020307ff;
          This is a DHT22 sending temp en hum. It worked on a mysensors gateway, but is see these logs when I try to read it with the RFlink. (Firmware 46 & 47)
          K 1 Reply Last reply
          • Y yos2000
            Same here:
            K
            K
            knop
            @yos2000 said in Strange behaviour with mysensors + RFLink:
            Same here:
            Thx for your reply
            In your sketch to manage the DHT22 you have send(msg...) to transmit temp/hum ?
            In my case there is nothing in setup() and loop(), if I remove "#include <MySensors.h>" in my sketch there is not packet receive in RFLink. The behaviour seems to come from MySensors library which send itself some packets !
              Mysensors has some "service" traffic maybe it is what you are seeing (I am not into RF su I don't know how to read the debug messages you get)
                K
                K
                knop
                @gohan said in Strange behaviour with mysensors + RFLink:
                Thanks gohan, very Interesting, if you have more information about that (how to deactivate it etc..), it should be great ;-)
                • F
                  F
                  Fabien
                  It's probabley a request to find parent (t=07)
                  • F Fabien
                    K
                    K
                    knop
                    @Fabien
                    Thanks for feedback,
                    I'm not an expert, I just want to know if is it normal behavior to have packets send by mysensors lib in empty project ?
                    Thanks for your clarification
                    Chris
                    gohanG F 2 Replies Last reply
                    • K knop
                      @Fabien
                      Chris
                      @knop maybe it is your neighbour node? or a node you forgot somewhere? :D
                      • K
                        K
                        knop
                        Good remark :-)
                        But I've checked this point ;-), I've disconnected one wire of my NRF24L01 and no more packets received on RFLink ;-)
                        • K knop
                          @Fabien
                          Chris
                          F
                          F
                          Fabien
                          @knop With an empty sketch, you have some packets from node to find parent (gateway).
                          • K
                            K
                            knop
                            Little update. So I need as you said a serial gateway. The question is : does rflink is equivalent to mysensors gateway ?
                            If not i need to build a serial gw and connect it on usb port of my raspberry and declare it on domoticz interface. If yes how to configure domoticz to manage rflink + others protocol ? (Declare 2 gateways (rflink and traditionnal gw) on same usb port?
                            Thanks for your help.
                            Chris
                              @knop
                              RFLink is not equivalent to a MySensors gw, and won't be. You should better use a MySensors gw.
                              Else i would wish them good luck to handle the full Mysensors lib (and updates), plus some others protocol, without loosing packets etc..
                              I don't use a RFLink, but what I'm pretty sure is, actually, :
                              • it can only receive MySensors nodes, as RFLink is sort of sniffer. It can't be a part of the MySensors network, with id etc, so it can't send commands to MySensors nodes.
                              • If MySensors encryption is enabled, or also signing, then it would become even more difficult for the RFLink to listen something (its basic task)
                              • especially, because RFLink doesn't use MySensors GW code. Make sense it just sniff/listen.
                              When using a MySensors GW, you can also benefit:
                              • sending commands of course
                              • the full MySensors protocol and features
                              • MySensors library updates
                              • controllers (like domoticz etc.) have dedicated plugins for using MySensors, which make this even more friendly to use compared to a generic sniffer (because the plugin is customized for MySensors features)
                              I'm pretty sure there are others relevant point, but I hope this clarifies :)
                              • F
                                F
                                Fabien
                                And with RFLink, you can only use 2.4GHz frequency. It doesn't work with RFM69.
                                Actually I have a MySensors Gateway and a RFLink (not for the same usage)
                                • K
                                  K
                                  knop
                                  wrote on last edited by knop
                                  Ok thanks you guys, I will try to make a Serial GW with Arduino Uno + NRF24L01
                                  And to connect this GW to my Raspberry Pi3.
                                  But I very disappointed about RFLink, and do not understand why there is an option "MySensors" on it !
                                  Thanks again for clarifications.
                                  Chris
                                    You can connect nrf24 directly on the rpi, there is no need for the UNO
