  3. Strange behaviour with mysensors + RFLink
18 Posts 5 Posters 5.0k Views 4 Watching
  • K
    K
    knop
    I need your help to understand this strange behaviour :
    I've an Arduino Uno with NRF24L01 and with this sketch :
    #include <avr/sleep.h> // Sleep Modes
    // put your main code here, to run repeatedly:
    So this sketch is "empty" and when is loading on Arduino Uno + NRF24, I've received packets from this setup on my RFLink !! (checked with RFLinkLoader)
    (My RFLink setup is Firmware R47 and setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=ON;)
    Packets looks like :
    20;09;MySensors;ID=FF;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1cffffff020307ff;
    20;0A;MySensors;ID=FF;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1dffffff020307ff;
    20;0B;MySensors;ID=FF;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1effffff020307ff;
    20;0C;MySensors;ID=FF;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1fffffff020307ff;
    20;0D;MySensors;ID=FF;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1cffffff020307ff;
    20;0E;MySensors;ID=FF;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1dffffff020307ff;
    20;0F;MySensors;ID=FF;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1effffff020307ff;
    So how it is possible ? What is the meaning of these packets ?
    Thanks for your feedback
    Chris.
      Could it be some noise? How far are from each other?
      • K
        K
        knop
        I think it is not noise, I've tried with 10meters between my RFLink and Arduino+NRF24 and same packets received on RFLink
        • K
          K
          knop
          Furthermore I did not change MyConfig.h and some others files in MySensors (no DEBUG etc..), I'm using MySensors V2.1.1
          I'm using RF24 lib from TMRh20 version 1.3.0
          • Y
            Y
            yos2000
            Same here:
            20;76;MySensors;ID=03;Len=00;pltype=00;t=07;s=FF;DEBUG=ff1d0303ff020307ff;
            This is a DHT22 sending temp en hum. It worked on a mysensors gateway, but is see these logs when I try to read it with the RFlink. (Firmware 46 & 47)
            K 1 Reply Last reply
            • Y yos2000
              Same here:
              K
              K
              knop
              @yos2000 said in Strange behaviour with mysensors + RFLink:
              Same here:
              Thx for your reply
              In your sketch to manage the DHT22 you have send(msg...) to transmit temp/hum ?
              In my case there is nothing in setup() and loop(), if I remove "#include <MySensors.h>" in my sketch there is not packet receive in RFLink. The behaviour seems to come from MySensors library which send itself some packets !
                Mysensors has some "service" traffic maybe it is what you are seeing (I am not into RF su I don't know how to read the debug messages you get)
                  K
                  K
                  knop
                  @gohan said in Strange behaviour with mysensors + RFLink:
                  Thanks gohan, very Interesting, if you have more information about that (how to deactivate it etc..), it should be great ;-)
                  • F
                    F
                    Fabien
                    It's probabley a request to find parent (t=07)
                    • F Fabien
                      K
                      K
                      knop
                      @Fabien
                      Thanks for feedback,
                      I'm not an expert, I just want to know if is it normal behavior to have packets send by mysensors lib in empty project ?
                      Thanks for your clarification
                      Chris
                      gohanG F 2 Replies Last reply
                      • K knop
                        @Fabien
                        Chris
                        @knop maybe it is your neighbour node? or a node you forgot somewhere? :D
                        • K
                          K
                          knop
                          Good remark :-)
                          But I've checked this point ;-), I've disconnected one wire of my NRF24L01 and no more packets received on RFLink ;-)
                          • K knop
                            @Fabien
                            Chris
                            F
                            F
                            Fabien
                            @knop With an empty sketch, you have some packets from node to find parent (gateway).
                            • K
                              K
                              knop
                              Little update. So I need as you said a serial gateway. The question is : does rflink is equivalent to mysensors gateway ?
                              If not i need to build a serial gw and connect it on usb port of my raspberry and declare it on domoticz interface. If yes how to configure domoticz to manage rflink + others protocol ? (Declare 2 gateways (rflink and traditionnal gw) on same usb port?
                              Thanks for your help.
                              Chris
                                @knop
                                RFLink is not equivalent to a MySensors gw, and won't be. You should better use a MySensors gw.
                                Else i would wish them good luck to handle the full Mysensors lib (and updates), plus some others protocol, without loosing packets etc..
                                I don't use a RFLink, but what I'm pretty sure is, actually, :
                                • it can only receive MySensors nodes, as RFLink is sort of sniffer. It can't be a part of the MySensors network, with id etc, so it can't send commands to MySensors nodes.
                                • If MySensors encryption is enabled, or also signing, then it would become even more difficult for the RFLink to listen something (its basic task)
                                • especially, because RFLink doesn't use MySensors GW code. Make sense it just sniff/listen.
                                When using a MySensors GW, you can also benefit:
                                • sending commands of course
                                • the full MySensors protocol and features
                                • MySensors library updates
                                • controllers (like domoticz etc.) have dedicated plugins for using MySensors, which make this even more friendly to use compared to a generic sniffer (because the plugin is customized for MySensors features)
                                I'm pretty sure there are others relevant point, but I hope this clarifies :)
                                • F
                                  F
                                  Fabien
                                  And with RFLink, you can only use 2.4GHz frequency. It doesn't work with RFM69.
                                  Actually I have a MySensors Gateway and a RFLink (not for the same usage)
                                  • K
                                    K
                                    knop
                                    wrote on last edited by knop
                                    Ok thanks you guys, I will try to make a Serial GW with Arduino Uno + NRF24L01
                                    And to connect this GW to my Raspberry Pi3.
                                    But I very disappointed about RFLink, and do not understand why there is an option "MySensors" on it !
                                    Thanks again for clarifications.
                                    Chris
                                      You can connect nrf24 directly on the rpi, there is no need for the UNO
