  3. Strange behaviour with mysensors + RFLink
18 Posts 5 Posters 5.0k Views 4 Watching
    Mysensors has some "service" traffic maybe it is what you are seeing (I am not into RF su I don't know how to read the debug messages you get)
    K 1 Reply Last reply
      K
      K
      knop
      @gohan said in Strange behaviour with mysensors + RFLink:
      Thanks gohan, very Interesting, if you have more information about that (how to deactivate it etc..), it should be great ;-)
      • F
        F
        Fabien
        It's probabley a request to find parent (t=07)
        • F Fabien
          K
          K
          knop
          @Fabien
          Thanks for feedback,
          I'm not an expert, I just want to know if is it normal behavior to have packets send by mysensors lib in empty project ?
          Thanks for your clarification
          Chris
          gohanG F 2 Replies Last reply
          • K knop
            @Fabien
            Chris
            @knop maybe it is your neighbour node? or a node you forgot somewhere? :D
            • K
              K
              knop
              Good remark :-)
              But I've checked this point ;-), I've disconnected one wire of my NRF24L01 and no more packets received on RFLink ;-)
              • K knop
                @Fabien
                Chris
                F
                F
                Fabien
                @knop With an empty sketch, you have some packets from node to find parent (gateway).
                • K
                  K
                  knop
                  Little update. So I need as you said a serial gateway. The question is : does rflink is equivalent to mysensors gateway ?
                  If not i need to build a serial gw and connect it on usb port of my raspberry and declare it on domoticz interface. If yes how to configure domoticz to manage rflink + others protocol ? (Declare 2 gateways (rflink and traditionnal gw) on same usb port?
                  Thanks for your help.
                  Chris
                    @knop
                    RFLink is not equivalent to a MySensors gw, and won't be. You should better use a MySensors gw.
                    Else i would wish them good luck to handle the full Mysensors lib (and updates), plus some others protocol, without loosing packets etc..
                    I don't use a RFLink, but what I'm pretty sure is, actually, :
                    • it can only receive MySensors nodes, as RFLink is sort of sniffer. It can't be a part of the MySensors network, with id etc, so it can't send commands to MySensors nodes.
                    • If MySensors encryption is enabled, or also signing, then it would become even more difficult for the RFLink to listen something (its basic task)
                    • especially, because RFLink doesn't use MySensors GW code. Make sense it just sniff/listen.
                    When using a MySensors GW, you can also benefit:
                    • sending commands of course
                    • the full MySensors protocol and features
                    • MySensors library updates
                    • controllers (like domoticz etc.) have dedicated plugins for using MySensors, which make this even more friendly to use compared to a generic sniffer (because the plugin is customized for MySensors features)
                    I'm pretty sure there are others relevant point, but I hope this clarifies :)
                    • F
                      F
                      Fabien
                      And with RFLink, you can only use 2.4GHz frequency. It doesn't work with RFM69.
                      Actually I have a MySensors Gateway and a RFLink (not for the same usage)
                      • K
                        K
                        knop
                        wrote on last edited by knop
                        Ok thanks you guys, I will try to make a Serial GW with Arduino Uno + NRF24L01
                        And to connect this GW to my Raspberry Pi3.
                        But I very disappointed about RFLink, and do not understand why there is an option "MySensors" on it !
                        Thanks again for clarifications.
                        Chris
                          You can connect nrf24 directly on the rpi, there is no need for the UNO
