  3. nRF5 action!
nRF5 action!
    #1150
    Gosh, I'm wishing now that I hadn't ordered the PDK. I guess I'll just return it for a refund. Since it sounds like literally no one else is presently using the 840, I'd rather move forward on the 832. I'm more interested in the 2mbps datarate anyway (for the reason below). And I'm pretty sure PA versions of the nRF52832 will beat the range of an unamplified nRF52840.
    scalzS 1 Reply Last reply
    • d00616D d00616
      Now listening every 100ms yields a 10F supercap voltage measured decline of just 9mv per hour. i.e. a decline of 0.108v by the end of 12 hours.
      Great job. If I'm not wrong the method allows nearly 1 year of listening time with a CR2032.
      #1151
      Yup, based on the latest measurements, I estimate an average current drain of about 25 microamps. So, assuming a CR2032 has 240mah of useable current, that comes out to about 1.1 years of listening time. Or more than 13 years on a pair of Energizer Lithium AA's. Pretty cool. :) And that's listening for a packet once every 100ms. It could last much longer if it were to listen less often.
        #1152
        I looked at the fanstel modules a while ago, but like guys said above, these are beta mcus with errata. And not arduino uptodate for the same reason i guess.
        I have one 840pdk too. for tests :) with apache mynewt. Because I have only one 840 board I can't tell you about the range because it needs two boards for checking that, two boards with full BLE5 Long range (and 832 is not BLE5 full range).
        No idea about 840 vs 832+PA but 840 is already PA integrated which is pretty cool. It also has some other nice features. Range tests regarding BLE5 long range are impressive imho, indoor or not, and from different mcu manufacturers (some have nice parts).
        I'm not sure though, if 840, is compatible with NRF24. And, as I'm talking about BLE, I prefer to say it again, for others.. BLE is not MySensors :)
          Are there any examples of how to control the potential BLE5 capabilities of this chip using code developed in the Arduino IDE? I recognize that it's presently a separate thing from MySensors, which is using the proprietary modes to ensure backward compatability to the nRF24, but surely getting some hooks into BLE5--even if it's just high level stuff--would be beneficial wouldn't it?
            #1154
            For instance, how hard would it be to create a simple serial bridge so view serial output on your bluetooth phone, the way @sundberg84 is doing with a specialized bluetooth module: https://forum.mysensors.org/topic/6340/debug-to-a-sd-card-module
            d00616D 1 Reply Last reply
              d00616D
              d00616D
              d00616
              For similar functionality, there is an MY_DEBUG_OTA feature in MySensors development branch. You can send log messages to any node in the MySensors network.
              The NRF5 MySensors port is running directly on the MCU hardware. Using the SoftDevice is like running an Operating System. There are limitations using the Hardware and APIs have to use. You are loosing control over the Radio, some Timers and RTC, Crypto components and the memory layout.
              The reason the SoftDevice isn't supported is the old licence model. This model is changed with SDK14.
              In my opinion with MySensors 2.x it isn't meaningful to play with the multiplexing of the radio module. I think this requires more changes in MySensors to handle the time when the MCU is in BLE mode.
              If you are interested implementing a dual stack software, then I think the Arduino Primo port is a good point to start. This is based on the NRF5 SDK. The Primo port has no support for NRF51 devices.
              If you are not restricted to Arduino, you can also see MyNewt or Zephyr. Both have BLE Open Sorurce implementations for the NRF5 MCUs.
                #1156
                I agree with @d00616 points above.
                And, sure bluetooth would be nice for interacting or debugging.
                In my opinion, maybe I'm wrong, for my network, I would prefer MySensors NRF ESB, in general.
                • "more secure" than bluetooth. "harder" to access Mysensors ESB than bluetooth for example, plus some security issue that can happen with bluetooth, phones..
                • more devices in a network
                Nca78N 1 Reply Last reply
                  @d00616 What do you foresee regarding the nRF52840? It's presently unsupported.
                    #1158
                    For those who haven't seen it, this Fanstel nRF52832 module is impressively small:
                    Looks as though it even includes the antenna!
                      #1159
                      Good news. The Fanstel 832X (https://static1.squarespace.com/static/561459a2e4b0b39f5cefa12e/t/59a5a03d579fb36451a25f01/1504026688443/BlueNor_BT832X_datasheets.pdf) module contains the sky66112 (http://www.skyworksinc.com/Product/3152/SKY77927-11z-. which has a PA and an LNA on it. The Rx gain is 11dB, and the TX gain is 22dB. So, this should make for a very good gateway module.
                        Toyman
                        @NeverDie they even provide a piece of code to properly activate it
                          d00616D
                          d00616D
                          d00616
                          In those places where it was obvious, I took the design of the NRF52840 into consideration. I think, when an Arduino port supporting Sketches without SoftDevices is available, then porting is simple. At the moment, I have no plans to expedite an Arduino port.
                          T NeverDieN 2 Replies Last reply
                          • d00616D d00616
                            Toyman
                            when an Arduino port supporting Sketches without SoftDevices is availableI
                            I doubt it will ever happen as all 3 major nrf5 arduino implementations all rely on Softdevice (Primo, Adafruit and Sandeep)
                            • T Toyman
                              #1163
                              I don't follow what you mean. Aren't we already running the MySensors code without installing the softdevice on the nrf51822 and the nrf52832?
                                Toyman
                                @NeverDie Sorry, I meant "BLE implementation without Softdevice"
                                • d00616D d00616
                                  Is it Sandeep who does that port, or you, or...? I don't have a clear picture as to how many people are working on it, or even who is doing what.
                                  • T Toyman
                                    #1166
                                    I guess the way I read this fog of tea leaves is that nothing is going to happen before final silicon on the nRF52840, and even then there's not much motivating an Arduino port for it. And someday it may happen. i.e. I guess the folks who are doing the heavy lifting are generally happy with the nRF52832 and its capabilities? I probably wouldn't be comfortable relying purely on the nRF52832 if it weren't for the amplified modules that fill the gap. I haven't tried the Fanstel one, but on paper it looks like it's probably good enough for my modest needs.
                                      Toyman
                                      wrote on last edited by Toyman
                                      #1167
                                      @NeverDie Are you talking about MYS or in general? Because, currently there are two completely different approaches to nrf-arduino. One is based on softdevice (or in broader terms, on SDK) while another works direcly with hardware.
                                      For MYS, our only hope is d00616, if he doesn't do it, chances somebody will apapt 52840 to MYS are negligible.
                                      Frankly, MYS don't need it, but that's just my opinion.
                                      • T Toyman
                                        d00616D
                                        d00616D
                                        d00616
                                        Please don't be so pessimistic. I expect some very small changes to MySensors to support the NRF52840 platform when arduino-nrf5 is ported to the new NRF5 MCU generation. When arduino-nrf5 supports the NRF52840 platform, I do some tests with the 840DK, I already have.
                                        Looking back to the NRF52832, I think in 6-9 month we can buy NRF52840 modules with production ready chips. I think there is no reason for panic.
                                          @Toyman
                                          D00616's explanation increases my optimism considerably because: the people doing the NRF-arduino port care a lot about bluetooth. They'll want to see it through for that reason, because the 840 has much more bluetooth capabilities. Then, once they get that part done, like D00616 says, it will be ripe for porting to MYS. So really, all the interests are aligned. I don't think it will languish. At least, that's the narrative I'm going with.
