  3. nRF5 action!
nRF5 action!
    #1156
    I agree with @d00616 points above.
    And, sure bluetooth would be nice for interacting or debugging.
    In my opinion, maybe I'm wrong, for my network, I would prefer MySensors NRF ESB, in general.
    • "more secure" than bluetooth. "harder" to access Mysensors ESB than bluetooth for example, plus some security issue that can happen with bluetooth, phones..
    • more devices in a network
    Nca78N 1 Reply Last reply
      @d00616 What do you foresee regarding the nRF52840? It's presently unsupported.
      d00616D 1 Reply Last reply
        #1158
        For those who haven't seen it, this Fanstel nRF52832 module is impressively small:
        Looks as though it even includes the antenna!
          #1159
          Good news. The Fanstel 832X (https://static1.squarespace.com/static/561459a2e4b0b39f5cefa12e/t/59a5a03d579fb36451a25f01/1504026688443/BlueNor_BT832X_datasheets.pdf) module contains the sky66112 (http://www.skyworksinc.com/Product/3152/SKY77927-11z-. which has a PA and an LNA on it. The Rx gain is 11dB, and the TX gain is 22dB. So, this should make for a very good gateway module.
            Toyman
            @NeverDie they even provide a piece of code to properly activate it
              d00616D
              d00616D
              d00616
              In those places where it was obvious, I took the design of the NRF52840 into consideration. I think, when an Arduino port supporting Sketches without SoftDevices is available, then porting is simple. At the moment, I have no plans to expedite an Arduino port.
              T NeverDieN 2 Replies Last reply
              • d00616D d00616
                Toyman
                when an Arduino port supporting Sketches without SoftDevices is availableI
                I doubt it will ever happen as all 3 major nrf5 arduino implementations all rely on Softdevice (Primo, Adafruit and Sandeep)
                • T Toyman
                  #1163
                  I don't follow what you mean. Aren't we already running the MySensors code without installing the softdevice on the nrf51822 and the nrf52832?
                    Toyman
                    @NeverDie Sorry, I meant "BLE implementation without Softdevice"
                    • d00616D d00616
                      Is it Sandeep who does that port, or you, or...? I don't have a clear picture as to how many people are working on it, or even who is doing what.
                      • T Toyman
                        #1166
                        I guess the way I read this fog of tea leaves is that nothing is going to happen before final silicon on the nRF52840, and even then there's not much motivating an Arduino port for it. And someday it may happen. i.e. I guess the folks who are doing the heavy lifting are generally happy with the nRF52832 and its capabilities? I probably wouldn't be comfortable relying purely on the nRF52832 if it weren't for the amplified modules that fill the gap. I haven't tried the Fanstel one, but on paper it looks like it's probably good enough for my modest needs.
                          Toyman
                          wrote on last edited by Toyman
                          #1167
                          @NeverDie Are you talking about MYS or in general? Because, currently there are two completely different approaches to nrf-arduino. One is based on softdevice (or in broader terms, on SDK) while another works direcly with hardware.
                          For MYS, our only hope is d00616, if he doesn't do it, chances somebody will apapt 52840 to MYS are negligible.
                          Frankly, MYS don't need it, but that's just my opinion.
                          • T Toyman
                            d00616D
                            d00616D
                            d00616
                            Please don't be so pessimistic. I expect some very small changes to MySensors to support the NRF52840 platform when arduino-nrf5 is ported to the new NRF5 MCU generation. When arduino-nrf5 supports the NRF52840 platform, I do some tests with the 840DK, I already have.
                            Looking back to the NRF52832, I think in 6-9 month we can buy NRF52840 modules with production ready chips. I think there is no reason for panic.
                              @Toyman
                              D00616's explanation increases my optimism considerably because: the people doing the NRF-arduino port care a lot about bluetooth. They'll want to see it through for that reason, because the 840 has much more bluetooth capabilities. Then, once they get that part done, like D00616 says, it will be ripe for porting to MYS. So really, all the interests are aligned. I don't think it will languish. At least, that's the narrative I'm going with.
                                Received this today:
                                I thought it might have the same PA-LNA as the sky66112 (which also supports antenna diversity) used on the Fanstel, but the lettering suggests otherwise.
                                  #1171
                                  Here's a better close-up of the chips themselves, which is easier to read:
                                    The chip is now owned by Skyworks: http://www.skyworksinc.com/uploads/rfx/RFX2411N_DataSheet.pdf
                                    JokgiJ 1 Reply Last reply
                                      JokgiJ
                                      JokgiJ
                                      Jokgi
                                      @NeverDie As I may have mentioned before. This was a limited run of prototypes (100 total) designed by RF AXIS and built by Xungtong.. My understanding is that this device is being deemphasized by Skyworks in favor of the SKY661xx family..
                                      • JokgiJ Jokgi
                                        @Jokgi
                                        Do you happen to have the datasheet? The closest I've been able to find is: http://www.mouser.com/ds/2/472/rfaxis_RFX2411N Eval Board Summary and Technical N-952564.pdf
                                        which isn't quite on-point, but I may have to make do with.
                                        I had thought it would somehow automagically select the better antenna for receiving, but it looks like it wants me to make that selection myself. So, this may work better with longer preambles I suppose, to give enough time to measure the RSSI on each and then decide.
                                        JokgiJ NeverDieN 2 Replies Last reply
                                          @Jokgi
                                          JokgiJ
                                          JokgiJ
                                          Jokgi
                                          @NeverDie The datasheet for the RFX2411N?
