  3. nRF5 action!
nRF5 action!
  • d00616D d00616
    @d00616 What do you foresee regarding the nRF52840? It's presently unsupported.
    In those places where it was obvious, I took the design of the NRF52840 into consideration. I think, when an Arduino port supporting Sketches without SoftDevices is available, then porting is simple. At the moment, I have no plans to expedite an Arduino port.
    Is it Sandeep who does that port, or you, or...? I don't have a clear picture as to how many people are working on it, or even who is doing what.
    • T Toyman
      @NeverDie Sorry, I meant "BLE implementation without Softdevice"
      #1166
      I guess the way I read this fog of tea leaves is that nothing is going to happen before final silicon on the nRF52840, and even then there's not much motivating an Arduino port for it. And someday it may happen. i.e. I guess the folks who are doing the heavy lifting are generally happy with the nRF52832 and its capabilities? I probably wouldn't be comfortable relying purely on the nRF52832 if it weren't for the amplified modules that fill the gap. I haven't tried the Fanstel one, but on paper it looks like it's probably good enough for my modest needs.
        Toyman
        wrote on last edited by Toyman
        #1167
        @NeverDie Are you talking about MYS or in general? Because, currently there are two completely different approaches to nrf-arduino. One is based on softdevice (or in broader terms, on SDK) while another works direcly with hardware.
        For MYS, our only hope is d00616, if he doesn't do it, chances somebody will apapt 52840 to MYS are negligible.
        Frankly, MYS don't need it, but that's just my opinion.
        d00616D 1 Reply Last reply
        • T Toyman
          d00616D
          d00616D
          d00616
          Please don't be so pessimistic. I expect some very small changes to MySensors to support the NRF52840 platform when arduino-nrf5 is ported to the new NRF5 MCU generation. When arduino-nrf5 supports the NRF52840 platform, I do some tests with the 840DK, I already have.
          Looking back to the NRF52832, I think in 6-9 month we can buy NRF52840 modules with production ready chips. I think there is no reason for panic.
            @Toyman
            D00616's explanation increases my optimism considerably because: the people doing the NRF-arduino port care a lot about bluetooth. They'll want to see it through for that reason, because the 840 has much more bluetooth capabilities. Then, once they get that part done, like D00616 says, it will be ripe for porting to MYS. So really, all the interests are aligned. I don't think it will languish. At least, that's the narrative I'm going with.
              Received this today:
              I thought it might have the same PA-LNA as the sky66112 (which also supports antenna diversity) used on the Fanstel, but the lettering suggests otherwise.
                #1171
                Here's a better close-up of the chips themselves, which is easier to read:
                  The chip is now owned by Skyworks: http://www.skyworksinc.com/uploads/rfx/RFX2411N_DataSheet.pdf
                  JokgiJ 1 Reply Last reply
                    JokgiJ
                    JokgiJ
                    Jokgi
                    @NeverDie As I may have mentioned before. This was a limited run of prototypes (100 total) designed by RF AXIS and built by Xungtong.. My understanding is that this device is being deemphasized by Skyworks in favor of the SKY661xx family..
                    • JokgiJ Jokgi
                      @Jokgi
                      Do you happen to have the datasheet? The closest I've been able to find is: http://www.mouser.com/ds/2/472/rfaxis_RFX2411N Eval Board Summary and Technical N-952564.pdf
                      which isn't quite on-point, but I may have to make do with.
                      I had thought it would somehow automagically select the better antenna for receiving, but it looks like it wants me to make that selection myself. So, this may work better with longer preambles I suppose, to give enough time to measure the RSSI on each and then decide.
                      JokgiJ NeverDieN 2 Replies Last reply
                        @Jokgi
                        JokgiJ
                        JokgiJ
                        Jokgi
                        @NeverDie The datasheet for the RFX2411N?
                        • JokgiJ Jokgi
                          JokgiJ
                          JokgiJ
                          Jokgi
                          @Jokgi The only datasheet I have states that it is confidential. Therefore I cannot share it. However if you contact Skyworks they may be able to get you a copy. At the time I received it one needed to fill out a form on RF Axis site and then the file would be sent. Are there any particular parameters you are interested in?
                          • JokgiJ Jokgi
                            @Jokgi
                            Just which pins on the nRF52832 are connected to which control pins on the RF Front End. I just now checked with a continuity meter, and it looks like none of them are. So, it would appear that I'll need to wire the pin connections external to the PCB, which is weird, but maybe that's just how it is.
                            • scalzS scalz
                              I agree with @d00616 points above.
                              And, sure bluetooth would be nice for interacting or debugging.
                              In my opinion, maybe I'm wrong, for my network, I would prefer MySensors NRF ESB, in general.
                              • "more secure" than bluetooth. "harder" to access Mysensors ESB than bluetooth for example, plus some security issue that can happen with bluetooth, phones..
                              • more devices in a network
                              Not with bluetooth mesh, you can have thousands of nodes ;)
                              scalzS 1 Reply Last reply
                                @Jokgi
                                JokgiJ
                                JokgiJ
                                Jokgi
                                wrote on last edited by Jokgi
                                #1179
                                @NeverDie Hello, If you are referring to that Prototype Board with the Nordic logo on it then it was being controlled by GPIO and by the Bluetooth Low Energy stack (Softdevice) You can read more about it here.. https://devzone.nordicsemi.com/blogs/831/palna-support-in-s132/.
                                As I mentioned before. there is no good way to control the PA in a proprietary mode, only when using BLE. Regardless, I have asked if it is ok to share the schematic that relates to that PA board and I will let you all know. And about the question about antenna switching. This was never implemented in the Softdevice. Any antenna switching would need to be done in the application.
                                See if this chart helps.
                                • Nca78N Nca78
                                  #1180
                                  not without some latency :)
                                  but I agree, I forgot this new mode :+1:
                                  I just prefer to keep my nodes "hidden" for security. so no BLE network for me. I will just have some restricted access to it I think..
                                  • JokgiJ Jokgi
                                    @Jokgi
                                    Thanks! Yes, those three tables are exactly what I was looking for.
                                      #1182
                                      https://www.openhardware.io/view/489/BT830X-Power-Amplified-nRF52832-Remote-Control
                                        #1183
                                        I just noticed a very clever thing that Fanstel did: their nRF52 modules all have the same land pattern and pinout. That means you can upgrade from a regular nRF52832 to a power amplified version, or even an NRF52840 (when they become available), by just dropping the upgrade module into the same position on the PCB. i.e. you can run all the different modules from the same PCB design. Pretty cool. I like it. :)
                                          @NeverDie but how will you spend all the time you save by not having to create new boards all the time? ;-)
