  3. A smart home vs an automated home
59 Posts 8 Posters 24.6k Views 8 Watching
    The question may turn out to be whether people are willing to accept less than perfect performance in exchange for occasionally more capability (when it works). I think Z-wave and x-10 were good examples (of unreliability) showing that's not what people want. People seem to prefer less capability, but have it work 100% of the time the way it's supposed to. At the very least, WAF is low on unreliable things.
    • wallyllamaW
      wallyllamaW
      wallyllama
      wrote on last edited by wallyllama
      http://people.csail.mit.edu/fadel/wivi/
      Ok this is the one I was looking for
      http://witrack.csail.mit.edu/witrack2-paper.pdf
      dbemowskD 1 Reply Last reply
      • wallyllamaW wallyllama
        dbemowskD
        dbemowskD
        @wallyllama interesting.
        • dbemowskD
          dbemowskD
          This sounds like a very do-able basic solution to counting the number of people in a room.
          http://cocoontech.com/forums/topic/18483-room-occupancy-counters-need-help/
          As the guy asks, how do you make it look nice. Would there be another way of doing the two beams? Small laser pointer modules perhaps?
          If you put these on every doorway in your house, you could get the logic down to where it would know a fairly exact count of how many people are in a room at any given time.
          wallyllamaW 1 Reply Last reply
          • dbemowskD dbemowsk
            wallyllamaW
            wallyllamaW
            wallyllama
            @dbemowsk search "see through walls with wifi". I suspect it could be mounted to the wall and covered with art or something transparent at 10ghz, or with loss of sensitivity in the wall itself.
              dbemowskD
              dbemowskD
              @wallyllama Though I see future potential in this, I don't see it as anything that can be put into operation easily at this stage.
                https://www.oshpark.com/shared_projects/fAVBnmO7
                  wallyllamaW
                  wallyllamaW
                  wallyllama
                  @NeverDie nice! Sparkfun has a breakout that is 20% cheaper than just the omron sensor. This is is getting closer to my price range, the radar modules are cheap and might be fun, but this would likely yield a working solution sooner.
                    @wallyllama said in A smart home vs an automated home:
                    Is this the one you found? https://www.sparkfun.com/products/14289
                    • wallyllamaW
                      wallyllamaW
                      wallyllama
                      Once a method of sensing people is selected/found, then mySenors can be used as the transport layer. This leads to the question of the actual "smarts". The various mysensors supported packages seem to track state, allow control, and have scenes, which are good data and tools for the smarts to work on, but dont seem to be smart themselves. Am I overlooking something?
                      Commercial products use the 'cloud' to gather a lot of data from local devices, and create an AI of sorts that local devices then query for the appropriate response to specifuc conditions. I'm not interested in sending all my data to the cloud, so Im interested in completely local solutions.
                      Again this doesn't currently exist(that I know of), but many pieces do. Some are just pieces (hadoop for storing data e,g), some are partway there (mycroft ai e.g.), some have large backers (movidius ai accelerator). Some assembly required.
                      Are there more complete solutions that I may not know of?
                      What goals do others have?
                        wallyllamaW
                        wallyllamaW
                        wallyllama
                        @NeverDie no it was an amg8833 breakout and at adafruit not sparkfun sorry, $39us. Mouser and digikey have just the sensor form$22us in small quantities.
                        https://www.adafruit.com/product/3538
                        • wallyllamaW
                          wallyllamaW
                          wallyllama
                          The amg8833 has an 8x8 grid, and a 60° field of view, so if you have 8' (2.4m) ceiling that will cover a square with 14' (4m) sides at the floor. One pixel will be about 1' 9" ( 44cm) at the floor. That should be plenty of resolution even without interpolation. I suspect interpolation could give an effective grid of 16x16 at least, maybe more.
                          Careful planning and mounting in a corner or on a wall would have some trade offs, but might allow for covering a larger area with one sensor.
                          One trade off is identification. Is that heat blob a person or @gohan 's cat? That might be doable, but is it Mom or Dad, or teenager would probably need supplemental information.
                          Stationary heat sources, lamps, vents etc, could be filtered out, in probably several different ways. I have some large windows that may blur the data, but this isnwhere situational awareness wouldmc9me in. E.g. if (curtains == open && tod == daytime) then apply filter to pixels x through z, maybe time of year etc.
                          Other obstacles would probably look like cold spots and unless they are large wouldn't affect detection of people. They might dim a bit, so maybe a filter would be needed here.
                          This is quite doable. I've been thinking about it for a while and seeing usable sensors for effectivley 1/2 price has me a bit excited. I appologize if I have monopolized the podium a bit.
                            You are pretty much facing the same problems as all the engineers working on self driving cars or whatever is using computer vision (which is going to be tricky to be handled by an arduino alone, and that is why many services are relying on cloud computing)
                              wallyllamaW
                              wallyllamaW
                              wallyllama
                              @gohan true for the larger goals, but this sensor is 64 pixels (256 w/interpolation) and we need to track a dot, i think an arduino could gather the data, do a bit of preprocessing, and (the mysensors part) transmit the data to a raspberry pi for "whole house" tracking.
                              This is pretty low res and I think a pi could handle it. If not, Intel has a movidius usb stick meant for computer vision/ai acceleration, I believe opencv has been ported to it. So while this is on the edge, some of the blood has dried.
                              The other plus is houses move slower than cars, unless people are running indoors, a 2 to 3 second refresh rate should be accurate enough.
                              This is a large project and mysensors would only be a portion of it, so for now I'll try to limit myself to talking about how a node based on this sensor would work and if it fits into mysensors properly or not. There is plenty there to discuss.
                              @dbemowsk again sorry for hijacking your thread, I'm going to look at the guides for submitting a node to openhardware.io, i dont promise I'll be fast so dont stop working your own ideas.
                              NeverDieN gohanG 2 Replies Last reply
                                @wallyllama
                                To what degree will detection range be an issue with these sensors?
                                  @wallyllama I think an easier way to do tracking of people in the house would be through BT tags, this way you have also identification. Image preprocessing on Arduino I think would be hard to achieve, maybe on a pi zero.
                                    @wallyllama
                                    wallyllamaW
                                    wallyllamaW
                                    wallyllama
                                    @NeverDie data sheet says 7 meters max, there is probably enough margin, at least for typical room sizes in the US. I think the 60° fov will be the bigger issue, getting coverage. Imagine you place the sensor in the center of your ceiling. The room is square, 14ft on a side and 8 ft high (~4X2.4 M), the sensors field of view would exactly cover the floor, but it is shaped like a pyramid with the sensor at the peak, so if you stand flat against a wall, only your feet would be in view.
                                    @gohan's suggestion of bluetooth tags doesnt have that problem, it can be seen anywhere the signal gets to. You can have multiple detectors for coverage and triangulation. If you have a smartwatch or phone you always carry then youndont even need a separate tag. It is relatively cheap and simple, and most of the tech is done already.
                                    (Now here is where I loop around and start spinning in circles) I dont want to have to carry anything, it should be possible to detect my presence by all the signals bouncing off me already, like light, or ir, or wifi, or radar, then the googling happens......
                                    • alowhumA
                                      alowhumA
                                      alowhum
                                      Perhaps an alternative definition of smart home could be whether it connects to the cloud? Or whether it uses Big Data / Machine Learning / aggregation of the habits of many households to find solutions to things?
                                      Yet another, for me, is whether smart means 'ethical'. For example, a cloud connected home that shared my life patterns with third parties (which is most devices these days..) should never be called smart.
                                      gohanG 1 Reply Last reply
                                      • alowhumA alowhum
                                        @alowhum well... it all goes to the point "do you have enough money/time/skills to invest in a homemade Big Data / Machine learning project"? Do you even have an idea of how complicated that system would be to setup and maintain later on?
                                          #34
                                          Instead of going off on wild tangents about privacy and the like, I suggest we re-focus by asking what good or useful thing we might accomplish if we could make the thermal 8x8 pixel sensor work. After all, this is the first thread to consider it, and it would be a shame to waste the opportunity.
                                          12.5k
