  3. A smart home vs an automated home
59 Posts 8 Posters 24.6k Views 8 Watching
  • wallyllamaW wallyllama
    @dbemowsk search "see through walls with wifi". I suspect it could be mounted to the wall and covered with art or something transparent at 10ghz, or with loss of sensitivity in the wall itself.
    dbemowskD
    dbemowskD
    @wallyllama Though I see future potential in this, I don't see it as anything that can be put into operation easily at this stage.
      https://www.oshpark.com/shared_projects/fAVBnmO7
      wallyllamaW 1 Reply Last reply
        wallyllamaW
        wallyllamaW
        wallyllama
        @NeverDie nice! Sparkfun has a breakout that is 20% cheaper than just the omron sensor. This is is getting closer to my price range, the radar modules are cheap and might be fun, but this would likely yield a working solution sooner.
          @wallyllama said in A smart home vs an automated home:
          Is this the one you found? https://www.sparkfun.com/products/14289
          • wallyllamaW
            wallyllamaW
            wallyllama
            Once a method of sensing people is selected/found, then mySenors can be used as the transport layer. This leads to the question of the actual "smarts". The various mysensors supported packages seem to track state, allow control, and have scenes, which are good data and tools for the smarts to work on, but dont seem to be smart themselves. Am I overlooking something?
            Commercial products use the 'cloud' to gather a lot of data from local devices, and create an AI of sorts that local devices then query for the appropriate response to specifuc conditions. I'm not interested in sending all my data to the cloud, so Im interested in completely local solutions.
            Again this doesn't currently exist(that I know of), but many pieces do. Some are just pieces (hadoop for storing data e,g), some are partway there (mycroft ai e.g.), some have large backers (movidius ai accelerator). Some assembly required.
            Are there more complete solutions that I may not know of?
            What goals do others have?
              wallyllamaW
              wallyllamaW
              wallyllama
              @NeverDie no it was an amg8833 breakout and at adafruit not sparkfun sorry, $39us. Mouser and digikey have just the sensor form$22us in small quantities.
              https://www.adafruit.com/product/3538
              • wallyllamaW
                wallyllamaW
                wallyllama
                The amg8833 has an 8x8 grid, and a 60° field of view, so if you have 8' (2.4m) ceiling that will cover a square with 14' (4m) sides at the floor. One pixel will be about 1' 9" ( 44cm) at the floor. That should be plenty of resolution even without interpolation. I suspect interpolation could give an effective grid of 16x16 at least, maybe more.
                Careful planning and mounting in a corner or on a wall would have some trade offs, but might allow for covering a larger area with one sensor.
                One trade off is identification. Is that heat blob a person or @gohan 's cat? That might be doable, but is it Mom or Dad, or teenager would probably need supplemental information.
                Stationary heat sources, lamps, vents etc, could be filtered out, in probably several different ways. I have some large windows that may blur the data, but this isnwhere situational awareness wouldmc9me in. E.g. if (curtains == open && tod == daytime) then apply filter to pixels x through z, maybe time of year etc.
                Other obstacles would probably look like cold spots and unless they are large wouldn't affect detection of people. They might dim a bit, so maybe a filter would be needed here.
                This is quite doable. I've been thinking about it for a while and seeing usable sensors for effectivley 1/2 price has me a bit excited. I appologize if I have monopolized the podium a bit.
                  You are pretty much facing the same problems as all the engineers working on self driving cars or whatever is using computer vision (which is going to be tricky to be handled by an arduino alone, and that is why many services are relying on cloud computing)
                    wallyllamaW
                    wallyllamaW
                    wallyllama
                    @gohan true for the larger goals, but this sensor is 64 pixels (256 w/interpolation) and we need to track a dot, i think an arduino could gather the data, do a bit of preprocessing, and (the mysensors part) transmit the data to a raspberry pi for "whole house" tracking.
                    This is pretty low res and I think a pi could handle it. If not, Intel has a movidius usb stick meant for computer vision/ai acceleration, I believe opencv has been ported to it. So while this is on the edge, some of the blood has dried.
                    The other plus is houses move slower than cars, unless people are running indoors, a 2 to 3 second refresh rate should be accurate enough.
                    This is a large project and mysensors would only be a portion of it, so for now I'll try to limit myself to talking about how a node based on this sensor would work and if it fits into mysensors properly or not. There is plenty there to discuss.
                    @dbemowsk again sorry for hijacking your thread, I'm going to look at the guides for submitting a node to openhardware.io, i dont promise I'll be fast so dont stop working your own ideas.
                    NeverDieN gohanG 2 Replies Last reply
                      @wallyllama
                      To what degree will detection range be an issue with these sensors?
                        @wallyllama I think an easier way to do tracking of people in the house would be through BT tags, this way you have also identification. Image preprocessing on Arduino I think would be hard to achieve, maybe on a pi zero.
                          @wallyllama
                          wallyllamaW
                          wallyllamaW
                          wallyllama
                          @NeverDie data sheet says 7 meters max, there is probably enough margin, at least for typical room sizes in the US. I think the 60° fov will be the bigger issue, getting coverage. Imagine you place the sensor in the center of your ceiling. The room is square, 14ft on a side and 8 ft high (~4X2.4 M), the sensors field of view would exactly cover the floor, but it is shaped like a pyramid with the sensor at the peak, so if you stand flat against a wall, only your feet would be in view.
                          @gohan's suggestion of bluetooth tags doesnt have that problem, it can be seen anywhere the signal gets to. You can have multiple detectors for coverage and triangulation. If you have a smartwatch or phone you always carry then youndont even need a separate tag. It is relatively cheap and simple, and most of the tech is done already.
                          (Now here is where I loop around and start spinning in circles) I dont want to have to carry anything, it should be possible to detect my presence by all the signals bouncing off me already, like light, or ir, or wifi, or radar, then the googling happens......
                          • alowhumA
                            alowhumA
                            alowhum
                            Perhaps an alternative definition of smart home could be whether it connects to the cloud? Or whether it uses Big Data / Machine Learning / aggregation of the habits of many households to find solutions to things?
                            Yet another, for me, is whether smart means 'ethical'. For example, a cloud connected home that shared my life patterns with third parties (which is most devices these days..) should never be called smart.
                            gohanG 1 Reply Last reply
                            • alowhumA alowhum
                              @alowhum well... it all goes to the point "do you have enough money/time/skills to invest in a homemade Big Data / Machine learning project"? Do you even have an idea of how complicated that system would be to setup and maintain later on?
                                #34
                                Instead of going off on wild tangents about privacy and the like, I suggest we re-focus by asking what good or useful thing we might accomplish if we could make the thermal 8x8 pixel sensor work. After all, this is the first thread to consider it, and it would be a shame to waste the opportunity.
                                  @NeverDie I agree but it is pretty much related as I really don't think image processing could be done on a microcontroller without the help of a backend server that would actually collects all data from sensors, correlates them and then give them a meaning that can actually be used.
                                    #36
                                    In that case, I suggest @wallyllama start a new thread devoted just to the sensor and how best to make use of it. I wager something can be accomplished without resorting to full blown data fusion. Plainly if you tie your success to difficult, unsolved research problems that have long resisted solution, you will quickly bog down.
                                    The two obvious things are: direction of movement and, as has already been mentioned, a finer location granularity within a room. Since it's thermal, it could know that you're sitting on the couch even if you're not moving. That's big. Just think of all the occupancy sensors that wrongly conclude the room is empty if nothing is moving. We've all had that experience, I'm sure.
                                    • dbemowskD
                                      dbemowskD
                                      You guys are thinking of a complex solution to this that is a single package that does it all. What if you dumb down the scenario a bit. Don't try to think of making a determination using only one type of sensor. After doing some more research on the guy that did the infrared doorway sensors, he said that it was a pretty reliable way of counting room occupants. Maybe you use the infrared doorway sensors as a way of counting the number of people in an area. Now you have a reliable way of counting the number of people in an area, now you start looking at ways of identifying who those occupants are if needed. Thinking in a broad sense, putting some fuzzy logic behind data from a number of other sensors, whatever that may be, may give you some kind of fingerprint for a person that could be used to identify people. using that approach may give you a little better accuracy too depending on the sensors and logic you use.
                                      • dbemowskD dbemowsk
                                        @dbemowsk that "fuzzy logic" is what big companies are spending millions to develop and that's why I'm not expecting much from a few sensors and Arduinos
                                        dbemowskD 1 Reply Last reply
                                          dbemowskD
                                          dbemowskD
                                          @gohan I get it, but at this stage, any bits and pieces that you can put together that can even do a fraction of it is better than nothing. I figure if I can start with the counting people part and somehow layer things on from there I'll be a little ahead of the game.
                                          I don't want anyone to worry that you are hijacking my thread. Speak freely, this is how good ideas come to be. Precisely why I started this thread. I figured it would spark some creativity from the community.
                                          12.5k
