1.1k Posts 105 Posters 790.4k Views 98 Watching
  • mfalkviddM
    Today I learned how to cut and merge video clips on the command line using ffmpeg (and strip the audio which only contains my breathing), producing this video:
    https://youtu.be/5CIWxZEt9NE
    I also learned that maybe I shouldn't recond at 50fps using the highest quality codec, because uploading videos take a lot of time.
    • mfalkviddM
      Today's build is a new raspberry pi gateway to assist troubleshooting in this thread. I use the connectors that I created earlier. Great to be able to switch radio module in the connector.
      The binder clips to the left are great for keeping network and power cables in place.
        @mfalkvidd
        Is your use of cables for temporary testing, or is it permanent as far as you're concerned? If the later, I'm surprised you haven't yet found a PCB solution openhardware.io that you prefer.
          @mfalkvidd
          @NeverDie I guess it could be considered permanent by now. I have been using MySensors for more than 2 years and I've never gotten round to using any of the pcbs.
          gohanG 1 Reply Last reply
            @mfalkvidd in fact if nobody is going to touch the area around the raspberry, jumper wires just work fine. I'm waiting for the result on the double radio pcb hat for raspberry.
            • tbowmoT
              tbowmoT
              tbowmo
              I'm in the mid of building a more complex sensor setup for the chicken coop, where I use dupont cables all over (actually, it's more or less the first sensor that I use them in..) I do not expect to poke around in the wires, after I have mounted it in the chicken coop at some point in time. So I recon it's going to be ok.. (And it will be hot glued into a large weatherproof junction box)
                Rule #1 from what I've read is to keep connections as short as possible, especially when radio is involved. However, if you're not suffering from using long wires, then, well, I guess why not? If this is a prevailing belief, then maybe it does at least partially explain the remarkably low uptake of openhardware.io projects.
                  I personally use only short dupont wires as they give you some flexibility but without too much "spaghetti" wiring 😁
                    Guys, you are deviating from the OPs thread "rules" ;)
                    • sundberg84S
                      sundberg84S
                      I guess the thread can evolve the way it does - but in the same time, if there are a interesting ongoing discussion all mods are more than welcome to lift that discussion out for a own thread and if so we can keep this thread as intended?
                      • micahM
                        micahM
                        micah
                        Here is a project I finished this weekend.... 5m LED strip controller (the cover is off for the photo)
                        I think you can say I've come quite far since my first ever arduino build... lol
                        • sundberg84S
                          sundberg84S
                          Last night i continued improving my Logger (mostly protecting the serial input and make sure it can handle incoming serial logic from everything from 2.5v to 5v into my 3.3v system). I finally bought myself a oscilloscope so now I have the longest list possible of things I want to improve... (EasyPCB series, Booster performance?, some relays... the list goes on).
                          0_1508830436618_upload-c1713104-7660-4530-b88e-7a8a7cadc109
                          • sundberg84S
                            sundberg84S
                            Tonight I changed the mechanic trigger to a optocoupler on my doorbell node. I went with some sort of half good solution.
                            8v AC (Doorbell activated) -> Diode (Not a full bridge, just a support capacitor) -> Voltage divider -> optocoupler > D3. Worked out great, but might be one of the ugliest nodes I have :)
                            Testing/Soldering/Deployment:
                            0_1508867567585_upload-f1e406e5-6af9-4433-8108-07badff5200d
                              I changed the form of my integrated nRF52832-protoboard:
                              Previously, I was using: https://www.openhardware.io/view/472/Ebyte-nRF52832-Prototyping-Board
                              • sundberg84S
                                sundberg84S
                                Today I made some small changes to a battery node. Once again I had copy/pasted all battery code but forgot the internalReference in setup() (since I copy from another node sketch). So I now created a dedicated file for battery code I can use to copy from... and once again I remembered I'm not a coder... But it works.
                                https://github.com/sundberg84/MySensors2.0.0/blob/master/BatteryMeasurer/BatteryMeasurer.ino
                                dbemowskD 1 Reply Last reply
                                • sundberg84S sundberg84
                                  dbemowskD
                                  dbemowskD
                                  @sundberg84 Not to be critical or get off topic, but it's percent, not procent
                                  • R
                                    R
                                    robosensor
                                    Simple RS485 gateway and node for two BME280 sensors:
                                      Made a small tool to simplify the extraction of serial debug data from a 10-pin IDC connector and reading it from a typical 6-pin FTDI module.
                                      The 10-pin IDC connector is what's most commonly used for programming nRF5x modules.
                                      • mfalkviddM
                                        #26
                                        Not really MySensors-related, but I found a nice logging library for Arduino that I'm using in a project. The library was orphaned some time ago, but now has a new maintainer. I assisted with an update of the documentation and some source code cleanup.
                                        0_1509023431067_upload-51ff881d-811a-461d-ab1a-7a6189debe28
                                          #27
                                          I made an nRF52832 board today with 5 different colored LED's on it: red, green, yellow, orange, and blue. Mostly I think it may be useful while debugging code. All the LED's except for blue emit light all the way down to 1.8v source voltage, so it's good for battery powered operation also. The blue lights up all the way down to 2.4v, and I had to grapple with a 0403 LED to get that low of a voltage for a blue LED. In the end it was so tiny that I couldn't see the polarity of it, so I hit on the idea of running a blink program and seeing whether it would light up just before I soldered it in place. That worked. :)
                                          Also, this board channels its serial output over the 10-pin IDC connector, so I used the tool I posted yesterday to read it. Works great, and now I don't have a six pin FTDI connector cluttering up the PCB. :)
