  3. Has anyone tried software reset of an Arduino?
21 Posts 8 Posters 12.6k Views 9 Watching
  • TheoLT TheoL
    @Koresh I haven't seen assembler for a while. Do you use that on all of your projects?
    KoreshK
    KoreshK
    Koresh
    @TheoL
    In general - no. Only for such tricks :) Of course these tricks are not invented by me.
    TheoLT 1 Reply Last reply
    • KoreshK Koresh
      @TheoL
      TheoLT
      TheoLT
      TheoL
      @Koresh I understand my friend ;-) Although I have deep respect for people who are able to code completely in assembly. For me that was ages ago, almost in another life.
      • KoreshK Koresh
        @Yveaux
        Watchdog is used by sleep() function in mysensors, so it is not possible to use it. Also it is not safe to use it on arduino boards with standard bootloader. If I need watchdog on standard arduino boards (without mysensors library) with standard bootloader I use next ISR to handle WDT interrupt
        // Watchdog Timer interrupt service routine. This routine is required
        // to allow automatic WDIF and WDIE bit clearance in hardware.
        ISR (WDT_vect)
        	// WDIE & WDIF is cleared in hardware upon entering this ISR
        	wdt_disable();
        	asm volatile ("  jmp 0");
        This ISR prevents bootloop.
        If I need just soft reset arduino I use the technique very similar to TheoL's
        asm volatile ("  jmp 0"); //call anywhere
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        Not sure what you are referring to, sleep() uses WDIE (wdt interrupt before reset, see here) whereas the reboot functionality is implemented via wdt reset (see here).
        Can you elaborate why?
        KoreshK 1 Reply Last reply
          @Koresh @TheoL i use wdt with mysensors..but i cheated a bit :)
          • you can use your own sleep and then handle wdt, but then careful if really need mysensors sleep(x ms) as it resets wdt.
          • or as i do too, i have added a weak empty function in mysensors lib to have isr wdt available from sketch ;), temporarily I will submit a pr for the few features i have added locally..
          • tekkaT tekka
            KoreshK
            KoreshK
            Koresh
            @tekka
            Standard bootloader can fail to switch off wdt after reboot (on the boards with most chips) and it will cause bootloop. After rebooting watchog is still working and it is very important to disable it. We can use modified bootloader or bootloader like optiboot.
              @tekka I am not sure I will let answer, but if i remember well it was related to a problem that some old bootloader version were not handling properly wdt irq resulting in bootloader loop.
              ISR (WDT_vect) is used by mysensors lib if using mysensors sleep.
              but you can do something like:
              in MyHwATMega328.h
              void MY_WDT_Callback() __attribute__((weak));
              in MyHwATMega328.cpp, just add this in the wdt isr function
              if (MY_WDT_Callback) MY_WDT_Callback();
              and finally in your sketch you can use MY_WDT_Callback() which will be fired at every wdt irq. Something like
                wdt_reset(); // or do what you want
                irqWdt = true;
              maybe there are better ways. another note, is I don't advice to do too much change locally without pr because then..arrghh :pensive: :scream:
              • TheoLT
                TheoLT
                TheoL
                I when you thought you finally knew a bit about the Arduino, there comes a topic like this ;-) Thanx to you all. I understand to I have still much to learn.
                • bjacobseB
                  bjacobseB
                  bjacobse
                  Hi, as I remember about watchdog is to set it to 8S, so there is enough time to upload an sketch (8 seconds) before the Arduino will reboot. WDT0_time_in_seconds. If using WDT08S Always call the wdt_reset() no later than 7 seconds to avoid reset/reboot. This is usually used in case that the Arduino/avr is "hanging" in an infinite loop and stopped responding to actions, then this will automatically reset/reboot
                  Include this in your sketch:
                  #include <avr/wdt.h>
                  setup ();{
                  // WDTO_1S
                  // WDTO_2S
                  // WDTO_4S
                  // WDTO_8S
                  wdt_enable(WDTO_8S);
                  loop (){
                  wdt_reset(); // You must call this within less seconds set as WDT0_8S
                  • T
                    ToniA
                    For whatever strange reason, the Arduino stock bootloader is broken, so that it will not disable the watchdog on startup, causing just an infinite reset loop. I'd recommend updating the bootloader with something like MYSBootloader or Optiboot.
                    • D
                      donnacarter0103
                      Banned
                      Hey Buddy,
                      [spam post removed by moderator]
                      bjacobseB 1 Reply Last reply
                      • D donnacarter0103
                        Hey Buddy,
                        bjacobseB
                        bjacobseB
                        bjacobse
                        @donnacarter0103
                        The third way to reset an Arduino is to use watchdog (Need to flash another bootloader as the default have disabled watchdog), enable watchdog, and remember to reset it often in your code, else it will reste the Arduino
