1.1k Posts 105 Posters 792.9k Views 98 Watching
    Non the less, if we start having a more standardized environment on the mysx connector, it would be best. But we are going OT.
      Put together this pro mini nRF24 shield for testing...
      S 1 Reply Last reply
        shabba
        @NeverDie Neat! All I need is a rfm69 version :-)
        Where you get pcb?
        • S shabba
          Where you get pcb?
          @shabba said in What did you build today (Pictures) ?:
          Where you get pcb?
          https://www.openhardware.io/view/480/Compact-nRF24L01-Pro-Mini-Bottom-Shield
            #51
            I just now put together the final test configuration:
            It's meant to be a "universal" shield that can accept any of the most common nRF24L01 modules, whether they be SMD or the 8-pin variety.
            What I want people to know though is that as nice and compact as it is, it's actually much larger and not even as capable as the new nRF51 or nRF52 series. For instance, this nRF51 is quite affordable, and yet is both much smaller, is more energy efficient, and generally packs far more capability (including better range) than an atmega328p+nRF24L01 combo:
            https://www.aliexpress.com/item/nRF51822-04-BLE4-0-Wireless-Bluetooth-Module-TTL-Low-Power-Consumption/32832511551.html?ws_ab_test=searchweb0_0&aff_platform=aaf&cpt=1509659805775&sk=rvbiMby&aff_trace_key=624250e1222041ebad3af56b86b62771-1509659805775-02431-rvbiMby&terminal_id=29bfb7ff18284b7f96acb3c3884390ce
            The way I see it, there's not really much reason to continue using the nRF24L01's, except maybe already existing familiarity.
            [Edit: the one area that the nRF24L01's do still hold an edge, though, is in pricing on the PA+LNA versions. Some of those are still comparatively inexpensive compared to what's currently available in PA+LNA nRF5x series.
            Luckily, the above shield will work with them too. :) ]
            • ileneken3I
              ileneken3I
              ileneken3
              One advantage to the "atmega328p+nRF24L01 combo" is the simplicity of choices. A pro-mini is pretty much a pro-mini, etc. Having so many choices makes it hard for a beginner with nrf51.
              I really appreciate the recommendation for a reasonably priced nrf51 that can be used for battery powered nodes. Can I also ask for a recommendation on a piece of hardware to program it? (Again, lots of choices).
              Thanks ahead of time.
              • ileneken3I ileneken3
                #53
                @ileneken3 said in What did you build today (Pictures) ?:
                I've tried/attempted a number of different ones, and I've settled on using the nRF52 DK as being the best for programming external modules (at least in my experience). Just be sure you power the modoule independently from the nRF52 DK, because the DK mostly senses the voltage on the module rather than powers it.
                • mfalkviddM
                  Protecting a ds18b20 tempersture sensor to measure soil temperature for a prototype node.
                  sundberg84S NeverDieN 2 Replies Last reply
                    sundberg84S
                    sundberg84S
                    @mfalkvidd what is that in the background - some sort of PCB ruler?
                      Yes, I have one too. It has all the form factors of chips, wire gauges, etc
                        #57
                        @mfalkvidd said in What did you build today (Pictures) ?:
                        You may already know this, but it's easy to find ds18b20's that are enclosed in sealed metal probes. I've used some, and they don't seem to leak, even when left submerged in water.
                        • R
                          R
                          robosensor
                          wrote on last edited by robosensor
                          #58
                          Good ruler, I have such ruler too :)
                          Today's power part of my RGBW dimmer node (four LED channel PWM inputs, 12V input, +12V sense, +5V, +3.3V outputs). Dimmer is controlled by MySensors and also by conventional Samsung TV remote control (five presets, ability to record color presets, autofade from one preset to another, control of each LED channel brightness, gamma correction and so on).
                            One PCB to ruler them all ;)
                              scalpel
                              0_1509872915905_1509872882027363077820.jpg 0_1509872936514_1509872919572628002459.jpg
                              Just simple, small temperature node.
                              • S scalpel
                                @scalpel
                                Nice. Waht kind of CNC machine did you use to make the PCB?
                                  @NeverDie I would bet on chemicals instead cnc..
                                  • scalzS scalz
                                    @scalz Yes. After looking at it more closely, I bet you're right.
                                      scalpel
                                      Yes. Iron and B327 method 👍
                                      • dbemowskD
                                        dbemowskD
                                        Does ferric chloride get used much any more?
                                        • mfalkviddM
                                          #66
                                          Today I finally got to work on the nrf51822 that I bought some months ago. Using the Arduino IDE and my st-link v2 clone I was able to flash a softdevice and load an example sketch.
                                          It seems to have worked, but I don't know how to communicate with the device yet. Serial? Swd? Some app on my iphone? Will need to do some reading tomorrow. Recommendations are welcome.
