  2. Announcements
  3. πŸ’¬ Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
  • mfalkviddM
    Replacing all
    unsigned long
    with
    uint32_t
    makes the sketch compile fine, but I don't know if that is the correct solution.
    • mfalkviddM
      I created an issue for this, https://github.com/mysensors/MySensors/issues/910
        The problem with "unsigned long" is that it can have different size based on platform it's compiled on.
        Like @mfalkvidd says, use int32_t, uint32_t, int16_t and uint16_t which has a fixed width.
          I was suspecting something like that, but I was not sure if changing variable type would affect something else
            Ok, I got it working. On wemos it doesn't count pulses though. On domoticz does it have to configured as the value computed or from device? I'm asking because if you disconnect the sensor, on domoticz I keep seeing the same power reading
              BTW, is there a way to have the pulse meter running on gateway? I got stuck because at startup it asks the controller the last count value and since the controller is not yet connected it just doesn't work.
              A rejoe2R 2 Replies Last reply
                arifuleee
                @gohan for the first time use only the watt value....that time oldcounts will not bother.....
                  What do you mean? And how do I keep the count of the pulses if I don't get it from controller?
                    @hek is it me or the WATT readings are never sent? What could it be? Only V_VAR1 and V_KWH are sent.
                      rejoe2R
                      rejoe2R
                      rejoe2
                      @gohan How about
                      #define MY_TRANSPORT_WAIT_READY_MS 2000
                      This will start up your code so you won't miss any pulses until controller is ready.
                      You may ask for the last known Value in presentation(), then it will be fetched as soon as the controller is really there after startup. This could/should be combined with a bool pcReceived, so you may decide to either add the value received from controller to the counts the node meassured in between or just use the received value (starting from second time value is received from controller).
                        That actually is not that critical, as I am going to move to MQTT and that should be working anyway. Right now it is working on a UNO with NRF24, but my biggest issue is the WATT reading that it is missing
                          Any more suggestions on the Watt issue?
                            Did you by any chance change SLEEP_MODE to true?
                            gohanG 1 Reply Last reply
                              No, I get every pulse reported as soon as it is detected.
                                wrote on last edited by gohan
                                #113
                                I think I found a problem: the WATT calculation is returning values over 172000 watts and since I put 10000 as the max value, it was not sending anything. I double checked my energy meter and indeed it is 1000 pulses per KWH and this is what I set in sketch
                                  @hek I said I found the problem, I didn't say I know how to solve it πŸ˜…
                                    Here is the log I get from node
                                    7230 TSF:MSG:READ,0-0-250,s=1,c=2,t=24,pt=0,l=7,sg=0:1682675
                                    rece
                                    Received last pulse count from gw:1682675
                                    11817 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:528
                                    Watt:528
                                    Watt:197065
                                    21820 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682677
                                    21913 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6770
                                    Watt:196807
                                    36824 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682679
                                    36917 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6790
                                    Watt:197368
                                    51827 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682681
                                    51920 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6810
                                    Watt:196850
                                    Am I the only one using this sketch?
                                      mickecarlsson
                                      Please post you sketch.
                                        it is the one in https://www.mysensors.org/build/pulse_power
                                          mickecarlsson
                                          wrote on last edited by mickecarlsson
                                          #118
                                          How is the pulse counter set up? Is it connected to the S0 port?
                                          Edit:
                                          If you are using S0 it is vital that you use a pull down resistor, if you dont’t have that you get false pulses.
                                          pulse connection
                                          With your input, this post could be even better πŸ’—
