  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.0k Views 37 Watching
    That actually is not that critical, as I am going to move to MQTT and that should be working anyway. Right now it is working on a UNO with NRF24, but my biggest issue is the WATT reading that it is missing
      Any more suggestions on the Watt issue?
        Did you by any chance change SLEEP_MODE to true?
        gohanG 1 Reply Last reply
          No, I get every pulse reported as soon as it is detected.
            wrote on last edited by gohan
            #113
            I think I found a problem: the WATT calculation is returning values over 172000 watts and since I put 10000 as the max value, it was not sending anything. I double checked my energy meter and indeed it is 1000 pulses per KWH and this is what I set in sketch
              @hek I said I found the problem, I didn't say I know how to solve it 😅
                Here is the log I get from node
                7230 TSF:MSG:READ,0-0-250,s=1,c=2,t=24,pt=0,l=7,sg=0:1682675
                rece
                Received last pulse count from gw:1682675
                11817 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=17,pt=5,l=4,sg=0,ft=0,st=OK:528
                Watt:528
                Watt:197065
                21820 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682677
                21913 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6770
                Watt:196807
                36824 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682679
                36917 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6790
                Watt:197368
                51827 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=24,pt=5,l=4,sg=0,ft=0,st=OK:1682681
                51920 TSF:MSG:SEND,250-250-0-0,s=1,c=1,t=18,pt=7,l=5,sg=0,ft=0,st=OK:1682.6810
                Watt:196850
                Am I the only one using this sketch?
                  mickecarlsson
                  Please post you sketch.
                    it is the one in https://www.mysensors.org/build/pulse_power
                      mickecarlsson
                      wrote on last edited by mickecarlsson
                      #118
                      How is the pulse counter set up? Is it connected to the S0 port?
                      Edit:
                      If you are using S0 it is vital that you use a pull down resistor, if you dont’t have that you get false pulses.
                      pulse connection
                        I'm using the lm393 light detector. Domoticz is able to do a calculation from the pulses to give a Watt value and it is correct but it does it every 5 minutes and it is too slow for me
                          sundberg84S
                          sundberg84S
                          @gohan - is Domoticz updating anything (except switches) faster than 5 min? I dont think so...
                          S 1 Reply Last reply
                            If you send the watt reading faster it updates like the switch, anyway I need the watt values for node-red also
                              Could it be the Light sensor is triggering more interrupts from each pulse?
                              • NiklasON NiklasO
                                Just changed from 1-wire counter to MySensors for logging my power consumption. Using the same LED detector as I did when using 1-wire. Also changed watt limit to 20 000 (my heat pump likes to use 9-10kW sometimes). The wires from the old 1-wire net now provide power for the new MySensors-sensor. I have 10 000 led blinks per kWh. Had som crazy counter values with 1-wire that totally messed up the graphs and haven't seen anything like that with this sketch. Let's hope it stays that way. ;) Dumping data to Domoticz. This sensor gives me higher resolution as a bonus. The 1-wire counter was read every minute, this every 20-sec. ;-)
                                My old 1-wire counter with one crazy value messing upp all the graphs:
                                I know that you can hold shift and click the value that is crazy to make the graphs show up good but you loose the data for the full day. That's not good. ;-)
                                henninneH
                                henninneH
                                henninne
                                @niklaso
                                Hi Niklas,
                                I know this is a very old post, but its worth a try. How did you get out the daily Kwh usage? As default my sensor only gives Watts and Kwh (accumulated from start), I have tried to run a Scene in Vera UI7 where there are a function in the sensor called resetKWh(), but it looks like it doesn't do anything. Any tips would be great, thanks.
                                Henning
                                • sundberg84S sundberg84
                                  smilvert
                                  @gohan I think it is a little tricky to update domoticz every minute but try update the sql-file, see the domoticz forum
                                  https://www.domoticz.com/forum/viewtopic.php?t=10183
                                    The main issue is the fact that the sensor is not calculating the instant power correctly
                                    xydixX 1 Reply Last reply
                                    • D
                                      DaTim69
                                      I created this kWh sensor with the TCRT5000 IR Barrier Line Track Sensor.
                                      My powermeter is a ferarrismeter with 375 rotations per kWh.
                                      I also had the problem with spikes in the power usage. But after long...too long investigation I solved the problem.
                                      At my config it was a double issue.
                                      Issue 1.
                                      The problem is the pulse width of the rotation.
                                      The pulse are at night ( low power) much wider that during the day when more power is consumed. At night the spikes in power usage where huge.
                                      Issue 2.
                                      Switching on/off the halogen light causes spikes and related to also strange power measurement.
                                      Solution:
                                      I added a second arduino mini pro as a pulse regulator between the TCRT5000 and the power meter arduino.
                                      this arduino triggers on Rising and will always give a 100ms puls. Als debounce is handled (spikes).
                                      I don't upload the sketch here, I'm a beginning programmer on arduino. It's made on " trail and error" but it functions as it supposed to do.
                                      If someone wants a copy feel free to contact mee
                                        xydixX
                                        xydixX
                                        xydix
                                        @gohan Did you solve this?
                                        I get very high watt usage as well. Sometimes like 40 000 - 130 000 watt if I check the serial monitor.
                                        Of course, those values will never be sent to the controler.
                                          Nope, I am looking at other things now. Very little time available for too many things. I'm looking at buying CT clamp and do a more direct measurement.
