  3. implementing multiple sensors
83 Posts 28 Posters 97.6k Views 15 Watching
  • A Offline
    A Offline
    andyuno
    Any help on implementing multiple sensors and readings on one Arduino would be appreciated.
    :) Any Help is Appreciated Thank You.
    H 1 Reply Last reply
    • hekH Offline
      hekH Offline
      You will probably have to give us some more information.
      What sensors do you want to combine?
      How far have you come combining the provided examples? Where did you stuck?
      • A Offline
        A Offline
        andyuno
        I know nothing of programming, I am comparing all the sensor sketch with each other and trying to work it out from there.
        My first one will be Motion sensor and four relay unit.
        • A andyuno
          H Offline
          H Offline
          henno
          @andyuno
          Im really no expert but I'll try to explain with a easy example. So for borked english.
          Say you want to combine a soil moisture sensor and a DHT22 temp sensor.
          Open both of the examples and look at the top part that are circled in red.
          This is where all the librarys that are needed are listed. Simply copy/paste the ones that are needed, in my example all libraries are equal except for the one circled in blue. So make sure you get all needed libraries!
          The next step is to look at the define part, circled in green. Here you copy/paste so you get all the needed parts and you must also change the pin number where your sensor is connected on the Arduino bord. So if you soldered your soil sensor on digital pin 5, change the number from 3 to 5 in #define DIGITAL_INPUT_SOIL_SENSOR 3.
          The child ID may also needed to be changed so that there isn't a conflict.
          Keep copy/paste all the way down in the sketch. Make sure that you place the code in the right place.If its inside the void setup() in one code, paste it inside the void setup() in the target code, I marked it green below. As you can see in the attached picture below in the red rectangle, Sensor gw; is in both codes so don't copy that. You only need to copy/paste the parts that are unique!
          Just keep trying! If I can do it, I'm sure you can too!
          • A Offline
            A Offline
            andyuno
            @henno
            Thanks for the pointer I'll give that a go
            • A Offline
              A Offline
              andyuno
              wrote on last edited by hek
              Well this is my first attempt of merging some senses the code compiled with no errors, and they recognised by Vera, but I get no readings or activations as if they're dead
                  ///#include <Sleep_n0m1.h>
                  #include <EEPROM.h>
                  #include <RF24.h>
                  #include <Sensor.h>
                  #include <Relay.h>   //andys Added
                  #define CHILD_ID 7   // Id of the sensor child
                  #define RELAY_1  4  //andys Added// Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                  #define NUMBER_OF_RELAYS 1 //andys Added
                  #define RELAY_ON 0  //andys Added
                  #define RELAY_OFF 1  //andys Added
                  Sensor gw;
                  //Sleep sleep;
                    EEPROM.write(EEPROM_RELAY_ID_ADDRESS, 0);
                    gw.begin();
                    gw.sendSketchInfo("Motion Sensor", "1.0");
                    gw.sendSketchInfo("Relay", "1.0");  //Andy Added
                    gw.sendSensorPresentation(CHILD_ID, S_MOTION);
                    for (int i=0; i<NUMBER_OF_RELAYS;i++) {   //Andy Added
                    gw.sendSensorPresentation(RELAY_1+i, S_LIGHT);  //Andy Added
                   // Fetch relay status    //Andy Added
                      // Make sure relays are off when starting up   //Andy Added
                      digitalWrite(RELAY_1+i, RELAY_OFF);   //Andy Added
                      // Then set relay pins in output mode   //Andy Added
                      pinMode(RELAY_1+i, OUTPUT);      //Andy Added
                      // Request/wait for relay status //Andy Added
                      gw.getStatus(RELAY_1+i, V_LIGHT);   //Andy Added
                      setRelayStatus(gw.getMessage()); // Wait here until status message arrive from gw
                    }  //Andy Added
                      if (gw.messageAvailable()) {   //Andy Added
                      message_s message = gw.getMessage();   //Andy Added
                      setRelayStatus(message);   //Andy Added
                    // Read digital motion value
                    Serial.println(tripped);
                    gw.sendVariable(CHILD_ID, V_TRIPPED, tripped?"1":"0");  // Send tripped value to gw
                    // Power down the radio.  Note that the radio will get powered back up
                    // on the next write() call.
                    delay(200); //delay to allow serial to fully print before sleep
                   // gw.powerDown();
                  //  sleep.pwrDownMode(); //set sleep mode
                  //  sleep.sleepInterrupt(INTERRUPT,CHANGE);
                  void setRelayStatus(message_s message) {
                    if (message.header.messageType==M_SET_VARIABLE &&
                        message.header.type==V_LIGHT) {
                       int incomingRelayStatus = atoi(message.data);
                       // Change relay state
                       digitalWrite(message.header.childId, incomingRelayStatus==1?RELAY_ON:RELAY_OFF);
                       Serial.print("Incoming change for relay on pin:");
                       Serial.print(message.header.childId);
                       Serial.println(incomingRelayStatus);
              I think I've overlooked something in order not for this to work
              • hekH Offline
                hekH Offline
                Remove this line:
                .. it should not be in the example (I've updated it on github).
                • A Offline
                  A Offline
                  andyuno
                  Thanks, been doing some more testing it seems as though my movement sensor interacts with the relays which wasn't my intention, and I have no control over them within Vera.
                  • hekH Offline
                    hekH Offline
                    By putting 4 spaces first on each line you get code formatting here in the forum (mark section in IDE and press tab a couple of times to indent the section before copying it here).
                    I think you also can do a "Copy for forum" in the edit-menu.
                    • E Offline
                      E Offline
                      egbertje
                      wrote on last edited by egbertje
                      Why not a default "multisensor" on the mysensors site at the example page? I see a lot of people like me who are new to arduino and looking for a multisensor sketch. For me the ultimate sensor is like the "roomnode" like a jeenode : Motion + light (LDR) + temp (ds18b20), where motion message is direct and the others once a minute or so.
                      hekH 1 Reply Last reply
                      • E egbertje
                        hekH Offline
                        hekH Offline
                        @egbertje
                        Yes, that is a good idea. Someone up for the task?
                        B 1 Reply Last reply
                        • E Offline
                          E Offline
                          egbertje
                          Im already trying, but have to learn a lot :)
                            @egbertje
                            B Offline
                            B Offline
                            BulldogLowell
                            @hek
                            Perhaps we can get a list of preferred combinations and I can work on that alongside anyone else who may wish to do that too.
                            I'd like to help but also would like it 100% debugged before we publish.
                            • hekH Offline
                              hekH Offline
                              A common multi-sensors-combination is:
                              Motion + Light (LDR or Photo resistor) + DHT (Temp+Humidity)
                              I would prefer if the example sleeps Arduino+radio while doing nothing.
                              M E 2 Replies Last reply
                                M Offline
                                M Offline
                                marceltrapman
                                +1 for that combo :)
                                Fulltime Servoy Developer
                                C 1 Reply Last reply
                                • A Offline
                                  A Offline
                                  andyuno
                                  I think this is a good basis to start. A standard set of multi-senses based on temperature, humidity, light and movement which I think would be useful in all applications
                                  • M marceltrapman
                                    C Offline
                                    C Offline
                                    clippermiami
                                    @marceltrapman I'll second that :) I'm working on combining the Light-DHT but I'd really like to get the complete set going.
                                    • B Offline
                                      B Offline
                                      BulldogLowell
                                      What would be interesting is to make the multi-sensor sketch so that if we ran it either powered or on battery it would adjust its behaviour accordingly. Something like the AEON 4-in-1.
                                      When you are on battery, it is all about conserving that power source, and while on mains, it is all about consistency of data updates and possibly adding other functionality.
                                      Plus, I wanted to work on that LED idea so that we can broadcast a 'message' to a grouping of sensors and activate an (RGB) LED in the sensor.
                                      Too much?
                                      • B BulldogLowell
                                        Too much?
                                        M Offline
                                        M Offline
                                        marceltrapman
                                        @BulldogLowell Good idea. Dunno if it is possible to recognise if it is battery powered or not.
                                        But this is the way to go imho.
                                        I think it is not a question of 'too much' but more 'is this even possible'?
                                          E Offline
                                          E Offline
                                          egbertje
                                          +1 for me !
