  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.1k Views 69 Watching
  • K
    K
    ksya
    Is using a genuine HLK-PM01 safe when directly connected to mains? I see here that they used extra components for safety.
    • MiKaM
      MiKaM
      MiKa
      Varistor and fuse is always good to use as a protection ;)
      Its lot of cases of start the fire in house from cheap AC/DC converters.
      Regards,
      MiKa
      • dbemowskD
        dbemowskD
        I have not only been adding a standard 0.75 amp fuse and MOV in my projects, but a thermal fuse also for added protection. I have been finding the thermal fuses a bit hard to work with as I have burned out a couple just with the heat of the soldering iron. They are good added protection though.
        • dbemowskD
          dbemowskD
          I find it crazy that in all the googling I have been doing on these, I have not found ONE review of how well they work or don't. The claim is that they are a replacement for the HLK-PM01 modules.
          0_1497566454517_upload-a7b7ea51-e26b-43a8-a3f8-4428d9f13192
          • dbemowskD dbemowsk
            @dbemowsk said in Safe In-Wall AC to DC Transformers??:
            How good is your Russian? https://youtu.be/qnk4jksXdO4
            dbemowskD 1 Reply Last reply
            • YveauxY Yveaux
              dbemowskD
              dbemowskD
              @Yveaux I skipped that class in grade school......LOL
              alexsh1A 1 Reply Last reply
                alexsh1A
                alexsh1A
                alexsh1
                @dbemowsk this is a good review - go ahead and try them
                • alexsh1A alexsh1
                  dbemowskD
                  dbemowskD
                  @alexsh1 Thanks, they are a bit cheaper than the HLK-PM01s and they appear to be a pin compatible replacement for them.
                  • P
                    P
                    Pete357
                    Hi all,
                    I have used MEAN WELL IRM-10-5, 5V/2A/10W for some of my projects, since they were available in my local store. They are ok, robust, good quality.
                    But as they are much bigger, 10W and cost me 7,5 EUR per piece I wanted to try HLKs for some projects.
                    This was my 1st order of HLKs. As I had no experience and wanted to avoid fakes I used ebay link from Power Sources at MySensors Store, this one:
                    http://rover.ebay.com/rover/1/711-53200-19255-0/1?ff3=4&pub=5574962087&toolid=10001&campid=5337834143&customid=nodebb&mpre=http%3A%2F%2Fwww.ebay.com%2Fitm%2F261985573055
                    BTW it is the same seller and store as mentioned by some other members here on forum.
                    I was impatiently waiting for them. Finally yeasterday (after 3 weeks) I found the package on my desk. First look when I unpacked it indicates something is not ok. Came back to this thread to see how to check the fakes ... unpleasant findings ... poor enclosure, thinner pins, every at different lenghts, non blocking mechanism on pins, no quality labels, no bar codes, no dot mark on top, different markings on top...
                    These ones look much worse as I could even expect from fakes:
                    3_1510045929288_IMG_7585-001.jpg 2_1510045929288_IMG_7584-001.jpg 1_1510045929288_IMG_7583-001.jpg 0_1510045929288_IMG_7579-001.jpg
                    Please can somebody more experienced with HLKs recommend really reliable source where to buy the right modules?
                    Pete
                    ferroF dbemowskD 2 Replies Last reply
                    • P Pete357
                      Hi all,
                      Pete
                      ferroF
                      ferroF
                      ferro
                      @Pete357 said in Safe In-Wall AC to DC Transformers??:
                      To be sure you get genuine module buy it directly from the vendor:
                      http://www.hlktech.net/product.php?CateId=10
                      P 1 Reply Last reply
                      • ferroF ferro
                        P
                        P
                        Pete357
                        @ferro Thank you, didnt know they have own eshop. I should have been looking for it before.
                        I suggest to put this link into MySensors Store instead of that ebay link, for others looking where to buy it and not to make the same mistake as I did.
                        Pete
                        Nca78N 1 Reply Last reply
                        • P Pete357
                          Pete
                          Very ugly modules indeed, I'm not familiar with ebay but you should have some sort of buyer protection ?
                          I could easily get money back on Aliexpress with mines that were looking better, so on ebay it should not be a problem.
                          • P Pete357
                            Hi all,
                            Pete
                            dbemowskD
                            dbemowskD
                            @Pete357 I had an issue with some modules that I bought that were not packed well. When they arrived, I had one or two that had at least one pin bent nearly all the way over. Some had case damage that was slight, but still usable. I contacted the seller and got half my money back. I tested all the modules and they all functioned properly. I use MOVs and fuses on the input power, so I figure I should be pretty protected in the event of a failure. I am not pushing them anywhere near the limits either. Do what you feel is necessary for your case though.
                              Ok, removed the ebay link from the buying guide. If someone finds an alternative ebay seller with genuine modules, let me know.
                              • dbemowskD
                                dbemowskD
                                Sorry, I didn't mean to imply that I bought them from that link. Never the less, it sounds like those are not genuine.
                                  matz
                                  wrote on last edited by matz
                                  #397
                                  Hi Guys,
                                  What a huge topic :)
                                  Has anyone tested this 3,2 $ module ? Do you think it is safe to put it in the wall socket ?
                                  AC-DC Isolated AC 110V / 220V To DC 5V 600mA Constant Voltage Switch Power Supply Converter Module
                                  In the comments on guy disassembled it :
                                  Regards
                                  Matz
                                  korttomaK 1 Reply Last reply
                                  • M matz
                                    Hi Guys,
                                    Regards
                                    Matz
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    @matz why not use the HLK-PM01 that is known to be safe?
                                    http://www.hlktech.net/product_detail.php?ProId=54
                                    • Tomas
                                      matz
                                      Hi
                                      I understood that the HLK-PM01 can not be directly used out of the box, and that we need to solder it to a pcb with Varistor etc. but i may be wrong
                                      I dont have the skills to do that for something potentially dangerous. I need something that can be used out of the box and connect it directly to a wemos mini d1
                                      • M matz
                                        Hi
                                        wrote on last edited by Nca78
                                        #400
                                        @matz said in Safe In-Wall AC to DC Transformers??:
                                        Hi
                                        But from the pictures, it doesn't look like this is safer than an HLK... much more like the opposite.
                                        They didn't even bother to make slots to increase creepage, while high voltage and low voltage sides are clearly way too close. You can compare with layout on the HLK here, there's way more distance between the too sides of the board, but still they added a wide slot under the optocoupler (on the side, next to R6) to increase creepage.
                                        http://lygte-info.dk/pic/USB PS/P01 Hi-Link HLK-PM01/DSC_1454a.jpg
                                        There's also no filling in the enclosure for extra isolation, to even the heat generated and to protect components from environmental pollution. It should be ok for dust because opening is small but not at all for humidity...
                                        If you look at the product description of the exact same power supply (without the box) on AliExpress you can see they advise much more extra components than for the HLK: input fuse and at the output: RC filter, extra ceramic capacitor for high frequency noise, TVS diode and Y2 safety capacitor.
                                        https://www.aliexpress.com/store/product/1PCS-SANMIN-AC220V-to-DC3-3V-600MA-3W-Power-supply-Isolated-switching-power-supply-module-220V/923896_32799372973.html
                                        If you don't trust an HLK with extra safety (fuse + MOV) in your wall you shouldn't trust that thing. It doesn't seem to have much consideration for high/low voltage sides isolation and it's just been put in a plastic box like it is a complete and safe power supply, while the safety components advised by the original maker were not added...
                                        • Nca78N Nca78
                                          Hi
                                          matz
                                          @nca78
                                          Thanks a lot for this complete answer. I understand that i should use HLK but put in on a PCB and add varistor and fuse like described in the edit of the first post. The problem is that I really don't know a lot about eletronic. For arduino things in 5v or 3,3v I have no problem to try to do myself, in order to learn, but for 220v i prefer to use a finished product... Is there exist somewhere a finished product with the HLK and all necessary pieces, ready to wire to the 220 v and to the arduino/nodemcu ?
                                          Regards
                                          Matz
