  3. RPI Gateway - !TSM:INIT:TSP FAIL
19 Posts 6 Posters 8.2k Views 5 Watching
    @maxdor looks like the same problem as reported in https://github.com/mysensors/MySensors/issues/955
    Add --extra-cxxflags="-D__STDC_FORMAT_MACROS" to the configure command
    tchoblond59
    @mfalkvidd I have the same issue. Even with --extra-cxxflags="-D__STDC_FORMAT_MACROS".
    • T tchoblond59
      @tchoblond59 could you post the full configure command you used and info on what system you are trying to build on?
      gcc -v |& grep 'gcc version'
      grep PRETTY_NAME /etc/os-release
      • T
        tchoblond59
        wrote on last edited by tchoblond59
        @mfalkvidd
        ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --extra-cxxflags="-D__STDC_FORMAT_MACROS"
        gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1)
        PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
          Do you get same error even if you compile as ethernet gateway?
          • T
            tchoblond59
            make clean
            ./configure --my-gateway=ethernet --my-port=5003
            make
            Same error after this.
            • T tchoblond59
              @mfalkvidd
              @tchoblond59 thanks. So far, it seems your system that is unable to compile is the same as the system I was able to compile cleanly on. I wonder were the difference is.
              • T
                tchoblond59
                I open an issue on github
                https://github.com/mysensors/MySensors/issues/980
                Hope i will be able to fix it. I will try to reinstall a raspbian when i have some times
                Thanks for the help
                • T
                  tchoblond59
                  For the moment i am able to compile by going to previous commit
                  git checkout 9e5a1e32
                  make
                  (I haven't test with a nrf24 but i can launch mysgw )
                  • I
                    I
                    Inso
                    I chave the exact same issue. Made the installation of Raspi and MySensors quite often last days because of problems with the NRF24. Now, as it finally worked, the installation of my clean final version crashes -.-.
                      mickecarlsson
                      wrote on last edited by mickecarlsson
                      Same error here.
                      gcc version 4.9.2 (Raspbian 4.9.2-10)
                      PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
                      Replacing
                      printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
                      with
                      printf("bcm2835_delayMicroseconds %lld\n", micros);
                      in file drivers/BCM/bcm2835.c fixed the issue.
                      EDIT:
                      It did compile, but it segfaults when I try to start mysgw
                      Time to get a fresh copy from git
                      EDIT2:
                      Fix from commit in bug report fixed it.
