  3. RPI Gateway - !TSM:INIT:TSP FAIL
19 Posts 6 Posters 8.2k Views 5 Watching
  • M maxdor
    Thanks for the answer.
    Sorry, I'm new to Mysensors and I don't understand what is meaning with "development branch".
    @maxdor when you do the git clone replace master with development: it's also written in the guide.
      mickecarlsson
      git clone https://github.com/mysensors/MySensors.git --branch development
      ./configure
      make
      sudo make install
      sudo /usr/local/bin/mysgw -d
      This is how I did it on a Raspberry Pi 3.
        maxdor
        Thanks for the help.
        I have made a new install with developement branch, but after the "make", I get this error:
        gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s                        -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINU                       X_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I.                        -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/dri                       vers/BCM/bcm2835.o
        drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
        drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
           printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
        drivers/BCM/bcm2835.c:441:37: warning: spurious trailing ‘%’ in format [-Wformat                       =]
        Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
        make: *** [build/drivers/BCM/bcm2835.o] Error 1
        sudo: ./bin/mysgw: command not found
        SPI is activated.
          @hek do you think it is a compiler issue or a bug?
          • M maxdor
            SPI is activated.
            @maxdor looks like the same problem as reported in https://github.com/mysensors/MySensors/issues/955
            Add --extra-cxxflags="-D__STDC_FORMAT_MACROS" to the configure command
              tchoblond59
              @mfalkvidd I have the same issue. Even with --extra-cxxflags="-D__STDC_FORMAT_MACROS".
              • T tchoblond59
                @tchoblond59 could you post the full configure command you used and info on what system you are trying to build on?
                gcc -v |& grep 'gcc version'
                grep PRETTY_NAME /etc/os-release
                • T
                  tchoblond59
                  wrote on last edited by tchoblond59
                  @mfalkvidd
                  ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --extra-cxxflags="-D__STDC_FORMAT_MACROS"
                  gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1)
                  PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
                    Do you get same error even if you compile as ethernet gateway?
                    • T
                      tchoblond59
                      make clean
                      ./configure --my-gateway=ethernet --my-port=5003
                      make
                      Same error after this.
                      • T tchoblond59
                        @mfalkvidd
                        @tchoblond59 thanks. So far, it seems your system that is unable to compile is the same as the system I was able to compile cleanly on. I wonder were the difference is.
                        • T
                          tchoblond59
                          I open an issue on github
                          https://github.com/mysensors/MySensors/issues/980
                          Hope i will be able to fix it. I will try to reinstall a raspbian when i have some times
                          Thanks for the help
                          • T
                            tchoblond59
                            For the moment i am able to compile by going to previous commit
                            git checkout 9e5a1e32
                            make
                            (I haven't test with a nrf24 but i can launch mysgw )
                            • I
                              I
                              Inso
                              I chave the exact same issue. Made the installation of Raspi and MySensors quite often last days because of problems with the NRF24. Now, as it finally worked, the installation of my clean final version crashes -.-.
                                mickecarlsson
                                wrote on last edited by mickecarlsson
                                Same error here.
                                gcc version 4.9.2 (Raspbian 4.9.2-10)
                                PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
                                Replacing
                                with
                                printf("bcm2835_delayMicroseconds %lld\n", micros);
                                in file drivers/BCM/bcm2835.c fixed the issue.
                                EDIT:
                                It did compile, but it segfaults when I try to start mysgw
                                Time to get a fresh copy from git
                                EDIT2:
                                Fix from commit in bug report fixed it.
