  3. RPI Gateway - !TSM:INIT:TSP FAIL
19 Posts 6 Posters 8.2k Views 5 Watching
  • M maxdor
    Thanks for the help.
    I have made a new install with developement branch, but after the "make", I get this error:
    gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s                        -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINU                       X_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I.                        -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/dri                       vers/BCM/bcm2835.o
    drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
    drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
       printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
    drivers/BCM/bcm2835.c:441:37: warning: spurious trailing ‘%’ in format [-Wformat                       =]
    Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
    make: *** [build/drivers/BCM/bcm2835.o] Error 1
    sudo: ./bin/mysgw: command not found
    SPI is activated.
    @maxdor looks like the same problem as reported in https://github.com/mysensors/MySensors/issues/955
    Add --extra-cxxflags="-D__STDC_FORMAT_MACROS" to the configure command
      tchoblond59
      @mfalkvidd I have the same issue. Even with --extra-cxxflags="-D__STDC_FORMAT_MACROS".
      • T tchoblond59
        @tchoblond59 could you post the full configure command you used and info on what system you are trying to build on?
        gcc -v |& grep 'gcc version'
        grep PRETTY_NAME /etc/os-release
        • T
          tchoblond59
          wrote on last edited by tchoblond59
          @mfalkvidd
          ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --extra-cxxflags="-D__STDC_FORMAT_MACROS"
          gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1)
          PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
            Do you get same error even if you compile as ethernet gateway?
            • T
              tchoblond59
              make clean
              ./configure --my-gateway=ethernet --my-port=5003
              make
              Same error after this.
              • T tchoblond59
                @mfalkvidd
                @tchoblond59 thanks. So far, it seems your system that is unable to compile is the same as the system I was able to compile cleanly on. I wonder were the difference is.
                • T
                  tchoblond59
                  I open an issue on github
                  https://github.com/mysensors/MySensors/issues/980
                  Hope i will be able to fix it. I will try to reinstall a raspbian when i have some times
                  Thanks for the help
                  • T
                    tchoblond59
                    For the moment i am able to compile by going to previous commit
                    git checkout 9e5a1e32
                    make
                    (I haven't test with a nrf24 but i can launch mysgw )
                    • I
                      I
                      Inso
                      I chave the exact same issue. Made the installation of Raspi and MySensors quite often last days because of problems with the NRF24. Now, as it finally worked, the installation of my clean final version crashes -.-.
                        mickecarlsson
                        wrote on last edited by mickecarlsson
                        Same error here.
                        gcc version 4.9.2 (Raspbian 4.9.2-10)
                        PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
                        Replacing
                        with
                        printf("bcm2835_delayMicroseconds %lld\n", micros);
                        in file drivers/BCM/bcm2835.c fixed the issue.
                        EDIT:
                        It did compile, but it segfaults when I try to start mysgw
                        Time to get a fresh copy from git
                        EDIT2:
                        Fix from commit in bug report fixed it.
