  3. RPI Gateway - !TSM:INIT:TSP FAIL
19 Posts 6 Posters 8.2k Views 5 Watching
    Try development branch
      maxdor
      Thanks for the answer.
      Sorry, I'm new to Mysensors and I don't understand what is meaning with "development branch".
      gohanG 1 Reply Last reply
        mickecarlsson
        You have run ./configure twice, run it like this:
        ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003
        • M maxdor
          @maxdor when you do the git clone replace master with development: it's also written in the guide.
            mickecarlsson
            git clone https://github.com/mysensors/MySensors.git --branch development
            ./configure
            make
            sudo make install
            sudo /usr/local/bin/mysgw -d
            This is how I did it on a Raspberry Pi 3.
              maxdor
              Thanks for the help.
              I have made a new install with developement branch, but after the "make", I get this error:
              gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s                        -mfpu=vfp -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINU                       X_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_PORT=5003  -Ofast -g -Wall -Wextra  -I.                        -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/dri                       vers/BCM/bcm2835.o
              drivers/BCM/bcm2835.c: In function ‘bcm2835_delayMicroseconds’:
              drivers/BCM/bcm2835.c:441:40: error: expected ‘)’ before ‘PRIu64’
                 printf("bcm2835_delayMicroseconds %" PRIu64 "\n", micros);
              drivers/BCM/bcm2835.c:441:37: warning: spurious trailing ‘%’ in format [-Wformat                       =]
              Makefile:102: recipe for target 'build/drivers/BCM/bcm2835.o' failed
              make: *** [build/drivers/BCM/bcm2835.o] Error 1
              sudo: ./bin/mysgw: command not found
              SPI is activated.
                @hek do you think it is a compiler issue or a bug?
                • M maxdor
                  SPI is activated.
                  @maxdor looks like the same problem as reported in https://github.com/mysensors/MySensors/issues/955
                  Add --extra-cxxflags="-D__STDC_FORMAT_MACROS" to the configure command
                    tchoblond59
                    @mfalkvidd I have the same issue. Even with --extra-cxxflags="-D__STDC_FORMAT_MACROS".
                    • T tchoblond59
                      @tchoblond59 could you post the full configure command you used and info on what system you are trying to build on?
                      gcc -v |& grep 'gcc version'
                      grep PRETTY_NAME /etc/os-release
                      • T
                        tchoblond59
                        wrote on last edited by tchoblond59
                        @mfalkvidd
                        ./configure --my-transport=nrf24 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --extra-cxxflags="-D__STDC_FORMAT_MACROS"
                        gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1)
                        PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
                          Do you get same error even if you compile as ethernet gateway?
                          • T
                            tchoblond59
                            make clean
                            ./configure --my-gateway=ethernet --my-port=5003
                            make
                            Same error after this.
                            • T tchoblond59
                              @mfalkvidd
                              @tchoblond59 thanks. So far, it seems your system that is unable to compile is the same as the system I was able to compile cleanly on. I wonder were the difference is.
                              • T
                                tchoblond59
                                I open an issue on github
                                https://github.com/mysensors/MySensors/issues/980
                                Hope i will be able to fix it. I will try to reinstall a raspbian when i have some times
                                Thanks for the help
                                • T
                                  tchoblond59
                                  For the moment i am able to compile by going to previous commit
                                  git checkout 9e5a1e32
                                  make
                                  (I haven't test with a nrf24 but i can launch mysgw )
                                  • I
                                    I
                                    Inso
                                    I chave the exact same issue. Made the installation of Raspi and MySensors quite often last days because of problems with the NRF24. Now, as it finally worked, the installation of my clean final version crashes -.-.
                                      mickecarlsson
                                      wrote on last edited by mickecarlsson
                                      Same error here.
                                      gcc version 4.9.2 (Raspbian 4.9.2-10)
                                      PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
                                      Replacing
                                      with
                                      printf("bcm2835_delayMicroseconds %lld\n", micros);
                                      in file drivers/BCM/bcm2835.c fixed the issue.
                                      EDIT:
                                      It did compile, but it segfaults when I try to start mysgw
                                      Time to get a fresh copy from git
                                      EDIT2:
                                      Fix from commit in bug report fixed it.
