  3. Easy/Newbie PCB for MySensors
257 Posts 37 Posters 177.4k Views 38 Watching
  • sinczeS sincze
    @sundberg84 @dbemowsk Thank you guys for still trying to help me. I almost gave up on using a Dallas Termp sensor o n a pro mini. As said I even tried connecting the temp sensor directly to the pins with same results. If I connect the pins to my nano, it is being detected and transmitting temp values. I even used a different sketch.. Just for the temp sensor. link found_here. Changed it to use Pin 3 ofcourse. I even connected the whole thing to D2 (resistor back in the wires)... without being succesful either.
    dbemowskD
    dbemowskD
    @sincze Are you sure you sure you got correct power on the GND and VCC pins on the MySX connector?
    sinczeS 1 Reply Last reply
    • dbemowskD dbemowsk
      sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      @dbemowsk I had those thoughts as well.
      The voltage should be okay. I can solder a new Arduino Pro Mini and see if that one wants to work with me ;-)
      • sundberg84S
        sundberg84S
        Dallas temp sensors needs 3.3v VCC if I remember right. Not 5v.
        • sundberg84S sundberg84
          sinczeS
          sinczeS
          sincze
          wrote on last edited by sincze
          #201
          @sundberg84 haha yes i was wondering that myself so tried it connecting it to 3,3v as well. However on the 5v nano working just fine. Technical specs tell me: Power supply range is 3.0V to 5.5V
          also mysensors link
          Pretty strange huh.
          sundberg84S zboblamontZ 2 Replies Last reply
          • sinczeS sincze
            also mysensors link
            Pretty strange huh.
            sundberg84S
            sundberg84S
            @sincze my mistake. Really strange this... Should work just fine. Can you upload a better resolution picture of your hardware and the sketch you are using?
            • sinczeS sincze
              also mysensors link
              Pretty strange huh.
              zboblamontZ
              zboblamontZ
              zboblamont
              @sincze I have 10 of these DS18B20s strung over approximately 12m monitoring all rooms on both floors of my house and two side lofts, all running on 3.22v from a Pro-Mini. Never have skipped a beat, reporting every 5 minutes, well, aside from a telephone socket which pins went walkabout (the chips are crimped to RJ11s).
              There is something not right with the physical arrangement if you can get the same circuit to report at 5v...
                sinczeS
                sinczeS
                sincze
                #204
                @sundberg84 I just soldered a myself a new out of the box pro mini using the same sketch..
                10246 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=OK:21.0
                250560 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:21.1
                255019 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:22.3
                259476 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:23.8
                263934 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:25.3
                268393 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.5
                272851 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.6
                277310 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.1
                281768 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.4
                290677 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.3
                295136 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:28.1
                299594 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.8
                304053 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.6
                308511 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.3
                312970 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:27.1
                317428 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.8
                321887 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.6
                326345 TSF:MSG:SEND,8-8-25-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:26.4
                Victory... :)
                  Was the pro mini defective or just the pin you were using?
                    sinczeS
                    sinczeS
                    sincze
                    @gohan Don't know. Pin3 could be used to drive the led tx without problems. It only did not work with the temp sensors. I moved the temp sensor to d2.... modified the sketch and it did not work as well. and d2 was driveing rx led. So well root cause unknown... solution: solder a new pro mini and keep the other one for different purpose.
                    • sinczeS sincze
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @sincze Did you use D2+D3 on all the same devices?
                        I'd try the other digital pins too
                        • zboblamontZ zboblamont
                          sinczeS
                          sinczeS
                          sincze
                          @zboblamont @gohan The Sensor with the replaced Pro Mini is in production now ;-). I'll start soldering a new Easy/Newbie PCB, because once you know how to do it... it is Easy and test the individual pins with a door/window sensor.
                          • BarnaB
                            BarnaB
                            Barna
                            Hi Sundberg84,
                            What could you advise for battery powering (remove led and regulator too) if I would like to use Mini 5V and measure the battery level too ?
                            thx
                            Barna
                            sundberg84S gohanG 2 Replies Last reply
                            • BarnaB Barna
                              Hi Sundberg84,
                              thx
                              Barna
                              sundberg84S
                              sundberg84S
                              @Barna the 5v pro mini are running a 16mhz crystal as default and this needs higher voltage to be stable compred to 8mhz (3.3v pro mini).
                              I have never tried this so can't give much advice but I would probably take the effort of reprogramming the fuses and bootloader to a internal 1mhz and run the hardware as that (the hardware is the same on 5v except the regulator and crystal )
                              • BarnaB Barna
                                Hi Sundberg84,
                                thx
                                Barna
                                @Barna why do you want to use a 5v arduino?
                                • BarnaB
                                  BarnaB
                                  Barna
                                  Hi Sundberg84,
                                  I have used this step up booster
                                  https://www.ebay.com/itm/181612513907?rmvSB=true
                                  but found this (2nd),
                                  https://www.ebay.com/itm/10Pcs-Mini-2-in-1-1-8V-5V-to-3-3V-DC-Step-Down-Step-Up-Converter-Power-For-Ardu/182793323053?hash=item2a8f54c22d:g:PJMAAOSwYL9ZzAXC
                                  It has lower noise, so I could connect the radio to the Mini. What do you think ?
                                  • BarnaB Barna
                                    Hi Sundberg84,
                                    sundberg84S
                                    sundberg84S
                                    #214
                                    @barna lower noice is better but I can not confirm this module is better. You have to try. Yes you can connect this to EasyPCB just like the first one.
                                    • T
                                      Tommas
                                      Hi All!
                                      Could someone suggest me an elegant way to extend the mysx connector? SO i would like to multiple the A4 A5 pins onto another prototype board to use more I2C devices....
                                      • T Tommas
                                        Hi All!
                                        sundberg84S
                                        sundberg84S
                                        @tommas just add a wire on the back side to the prototyping area ? You could design a MysX daughter board as well 😉
                                        T 2 Replies Last reply
                                          Tommas
                                          @sundberg84
                                          Unofrtunately i havent got the skills and free time for a daughter board.:(. But doesnt have someone else a daughterboard?:)
