  3. Using nrf24l01+ with other devices together on one SPI-Bus.
12 Posts 7 Posters 14.0k Views 6 Watching
  • BartEB
    BartEB
    BartE
    wrote on last edited by BartE
    Yes, i've managed to have communication with a second SPI device next to the NRF24L01+ module. I have connected a Mifare RC522 RFID reader using the SPI bus.
    The NRF24L01+ is connect as suggested on the MySensors site.
    • pin 2 IRQ
    • pin 9 CE
    • pin 10 CSN/CS
    • pin 11 MOSI
    • pin 12 MISO
    • pin 13 SCK
    The RC522 module shares pin
    • pin 11 MOSI
    • pin 12 MISO
    • pin 13 SCK
    and uses
    • pin 7 (iso 9) for CE
    • pin 8 (iso 10) for CSN/CS
      If your SPI module needs an IRQ also use a different pin for pin 2 (IRQ) as well
    The pin CE and CS will make sure that only one SPI slave will communicate over the SPI bus.
    What i had to do before gw.begin() is called (i initialize MySensors before the RC522) is setting both the CE (pin 7) and CSN (pin 8 ) to LOW so the RC522 is disconnected from the SPI bus.
    #define RST_PIN		7
    #define SS_PIN		8
        // First make sure mfrc is releasing the SPI bus
        pinMode(RST_PIN, OUTPUT);
        digitalWrite(RST_PIN, LOW);
        pinMode(SS_PIN, OUTPUT);
        digitalWrite(SS_PIN, LOW);
        // Init mysensors library
        gw.begin(incomingMessage);
         // Init MFRC RFID sensor
        SPI.begin();			// Init SPI bus
        mfrc522.PCD_Init();		// Init MFRC522
        // do some more init stuff
    • barduinoB
      barduinoB
      barduino
      Very interesting.
      I've tryied to connect an adafruit cc3000 shield with no success.
      I guess its time to try it again.
      • OitzuO
        OitzuO
        Oitzu
        @barduino let us know whats your results.
        The big question is: Why is the rf24 changing bitrate, mode and clockdivider if this doesn't seem necessary? Or is it necessary in some cases?
          Interesting question. Maybe you could check with @TMRh20Project over at github?
          He know the in and outs of the RF24 library.
          • OitzuO
            OitzuO
            Oitzu
            TMRh20/RF24#134
            • BartEB BartE
              • pin 2 IRQ
              • pin 9 CE
              • pin 10 CSN/CS
              • pin 11 MOSI
              • pin 12 MISO
              • pin 13 SCK
              • pin 11 MOSI
              • pin 12 MISO
              • pin 13 SCK
              and uses
              #define RST_PIN		7
              #define SS_PIN		8
              Michał Owsianka
              @BartE Can you tell me where connect SDA, RST from RC522 module? i cant find information about alternative names on that pins... also can you share code for nrf24+rc522?
              • BartEB
                BartEB
                BartE
                @Michał-Owsianka Yes
                Pin 7 CE == RST
                Pin 8 CSN/CS == SDA
                The init part of the code can be found in my earlier post
                The rest of the library is taken from the mfrc522 example code. https://github.com/miguelbalboa/rfid
                To share my Sketch i do need to cleanup and test again the Sketch because it does (much) more. Like reading temperature and air pressure.
                • BartEB BartE
                  Pin 7 CE == RST
                  Pin 8 CSN/CS == SDA
                  Michał Owsianka
                  Pin 7 CE == RST
                  Pin 8 CSN/CS == SDA
                  Thanks a lot!
                  • BartEB
                    BartEB
                    BartE
                    @Michał-Owsianka : i cleaned the code and uploaded the full sketch here: http://forum.mysensors.org/topic/2439/rfid-garage-door-opener
                    • N
                      N
                      ni_fe
                      I was trying to make NRF24 and ADXL345 work on the same SPI bus. Each device worked ok individually, but not together, when used by the same program. After some investigation, using a logic analyzer (listening to the SPI pins and to the CS pins of both devices), I managed to solve the problem. What I found was:
                      • NRF24 (TMRH20 library) sets SPI settings before each SPI transaction it makes. It uses SPI_MODE0, MSBFIRST, SPI speed up to 10 MHz (not 100% sure about the max speed).
                      • ADXL (SparkFun library) does not change existing SPI settings before its transactions. It seems to do it only once when creating an instance of the device ADXL345 adxl = ADXL345(ADXL_ChipSelect_PIN); Therefore, the first NRF24 transaction modifies SPI settings, disabling the ADXL345. ADXL345 uses SPI_MODE3. MSBFIRST. SPI speed up to 5 MHz, according to the specs.
                      So, here is how I made them work together: In the code, before each ADXL transaction I insert: SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE3)); and SPI.endTransaction(); at the end of each transaction. The detailed description can be found here. I didn’t have to use SPI settings before NRF24 SPI transactions because, as already mentioned above, the RF24 library does it.
                      Here is an exemplary code, which seems to work fine.
                      #include <nRF24L01.h>
                      #include <RF24.h>
                      #include <SparkFun_ADXL345.h>
                      ADXL345 adxl = ADXL345(10);
                      RF24 radio(8, 9);
                      const byte address[6] = "00001";
                      SPI.begin();
                        radio.begin();
                        radio.openWritingPipe(address);
                        radio.setPALevel(RF24_PA_MIN);
                        radio.stopListening();
                      SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE3)); //SPI seetings for ADXL
                        adxl.powerOn();
                        adxl.setRangeSetting(2);
                        adxl.setRate(3200);
                        adxl.setSpiBit(0);
                      SPI.endTransaction(); //SPI seetings for ADXL
                        int x,y,z;
                      SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE3));//SPI seetings for ADXL
                         adxl.readAccel(&x, &y, &z);
                      SPI.endTransaction();//SPI seetings for ADXL
                      int val = x;
                        radio.write(&val, sizeof(val));
                        		delay(500);
                      Here is the logic analyzer view of the working SPI communication of both devices. One can see SPI modes changing before each transaction.
                      And I didn’t delete the 3 lines, mentioned by Oitzu in the beginning of this post. If I did, NRF24 would not be able to set SPI the way it needs (namely MODE0) before each transaction. I guess, the devices of Oitzu were using the same mode, therefore deleting the SPI settings didn’t harm in that particular case. Please correct me if I’m wrong.
                      I hope it helps.
