  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    it should pop up as ttyACM0 or ttyACM1 (if you have another usb device that enumerates first and gets ttyACM0)
    I added the following to /etc/udev/rules.d/10-local.rules file:
    ACTION=="add", ATTRS{idVendor}=="1209", ATTRS{idProduct}=="6949", SYMLINK+="ttyNRF24"
    What that does is to create a symlink from the real device to ttyNRF24, so regardless of what I add to my rPI, i always know that ttyNRF24 is for my gateway.
    (and then I use /dev/ttyNRF24 for the serial port in my controller)
    stefaanvS 1 Reply Last reply
    • tbowmoT tbowmo
      stefaanvS
      stefaanvS
      stefaanv
      @tbowmo Definately ttyACM0
      However, the setserial command returns information that doesn't look good : port0 and IRQ0. Does the board need a driver under Linux ?
      stefaan@home:~$ sudo setserial /dev/ttyACM0
      /dev/ttyACM0, UART: unknown, Port: 0x0000, IRQ: 0, Flags: low_latency```
      • tbowmoT
        tbowmoT
        tbowmo
        @stefaanv
        No, it doesn't need a driver..
        I get the same for mine, if I use setserial:
        thomas at jarvis in ~
        >sudo setserial /dev/ttyNRF24
        /dev/ttyNRF24, UART: unknown, Port: 0x0000, IRQ: 0, Flags: low_latency
        >ll /dev/ttyNRF24
        lrwxrwxrwx 1 root root 7 nov 11 13:39 /dev/ttyNRF24 -> ttyACM1
        Btw. the permission problem.. You are logged in using your normal user (stefaan) and then you set permissions for openhab user? (see below). Have you tried setting the permissions for your user, and then cat /dev/ttyACM0?
        @stefaanv said in 💬 Sensebender Gateway:
        There seems to be a premissions problem om the port :
        stefaan@home:~$ cat /dev/ttyACM0
        cat: /dev/ttyACM0: Permission denied
        doing 'sudo usermod -a -G dialout openhab' doesn't help
        Anyone any ideas ?
        • tbowmoT tbowmo
          @stefaanv
          >ll /dev/ttyNRF24
          Anyone any ideas ?
          stefaanvS
          stefaanvS
          stefaanv
          @tbowmo OK, is working now after restarting the bundle in OH.
          Must have been the permission problem after all.
          Thanks for your help !!
          • rzyliusR
            rzyliusR
            rzylius
            When I try to compile SensebenderGW sketch with signing features, I receive a bunch of errors. What am I missing?
            Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Sensebender Gateway"
            In file included from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:88:0:
            C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
            static uint8_t device_pin;
            In file included from C:\Users\rzylius\Documents\Arduino\libraries\MySensors/MySensors.h:131:0,
                         from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:86:
            C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
            C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
            C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
            static void swi_set_signal_pin(uint8_t is_high)
            C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: 'void swi_set_signal_pin(uint8_t)' previously defined here
            and the same type of errors reoccurs multiple times.
            AnticimexA 1 Reply Last reply
            • rzyliusR rzylius
              AnticimexA
              AnticimexA
              Anticimex
              @rzylius I think you have an #include in the sketch for the atsha driver. Try to remove that #include from the sketch.
              • rzyliusR
                rzyliusR
                rzylius
                @Anticimex yes, when I delete #include atsha driver line, it compiles well. thanks.
                • tbowmoT tbowmo
                  @Fabien legacy, unless you would reflash all your nodes with the new driver as well. (they are not compatible)
                  F
                  F
                  Fabien
                  @tbowmo After 2 month on the dev version, no more problem with the gateway. Perhaps it's time to made a new stable release ?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Fabien
                    It's on the todo list.. :)
                      I am looking for Gateway that will get me the results to MQTT but will support encryption + signing. That mean it should be easy to add new signatures (recompile/reflash) the module
                      I suppose if I use Sensebender with LAN module it will be a pain to do that
                      Is this doable if I use Orange zero as USB host for the Sensbender and let it act as serial gateway, then convert serial to mqtt with software on the Linux side? Also is it possible to reflash it easily this way? I do not want to rewire the hardware each time a add new node.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @8667
                        Is it over the air encryption / signing that you are aiming after? Then that is possible with the gateway, it has the ATSHA204 onboard for signing capabilities. And it also works with the W5100 module attached. The Gateway have 256Kb of flash onboard, so it has "enough" room for both network stack, and signing.
                        • rzyliusR
                          rzyliusR
                          rzylius
                          Are there performance limitations to be considered for mysensors and SensebenderGW specifically. Will the gateway handle the load of signed communications if rules will be firing messages to different sensors like 1-2-5-10 per second?
                          • rzyliusR rzylius
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @rzylius if you use the atsha204a chip, it is the single wire interface that limits your throughput. I have no figures, so best is to just test how fast you can push messages through. Of course there is overhead in the OTA handshaking as well. That would probably be the bottleneck if you use software based signing.
                            • rzyliusR
                              rzyliusR
                              rzylius
                              I see in logs, that the whole process of signing and communicating to the node takes a bit more than one second. I do not know how to make a stress test properly, so I hoped that somebody else did it :) my question is if gateway will handle load by putting messages in some pipeline, or I should try to make sure that messages are fired with some spaces.
                              • rzyliusR rzylius
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @rzylius The signing process is blocking, so it should not accept messages if a signed message exchange is in progress. But I have not tested that extensively with "aggressive" controllers.
                                • Mitja BlazinsekM
                                  Mitja BlazinsekM
                                  Mitja Blazinsek
                                  im trying to program in arduino ide, installed board... bu when compiling it write mi an error 'The current selected board needs the core 'arduino:arduino' that is not installed.'
                                  • Mitja BlazinsekM Mitja Blazinsek
                                    #348
                                    @mitja-blazinsek You'll need to install the Arduino SAMD board as well. I have just now updated the readme.
                                    • D
                                      dklinkman
                                      wrote on last edited by dklinkman
                                      #349
                                      Just got my Sensebender GW and soldered it up. Adapted the serial sketch to Ethernet and it almost worked. Found some posts on this topic that helped me locate and fix my config error. Now all is well. Thanks! --edit-- added photo
                                      -d
                                      • D
                                        dklinkman
                                        #350
                                        @dklinkman said in 💬 Sensebender Gateway:
                                        Sensebender
                                        And I got a Sensebender Micro soldered up and running also!! Just temp and humid so far. Too cool
                                        --edit-- picture
                                        • SoloamS
                                          SoloamS
                                          Soloam
