  3. MYSBootloader 1.3.0-beta.3
182 Posts 44 Posters 94.9k Views 42 Watching
  • tekkaT tekka
    @Mark-Swift I haven't tested that with OSX - maybe somebody can help here?
    A Former User
    @tekka for OSX, the sequencing of flags matters. So, line 45 can be:
    $(PROJECT).o: $(PROJECT).c
    "$(BINPATH)avr-gcc" $(CFLAGS) -I$(INCLUDES) $< -o $@
    can be improved to
    "$(BINPATH)avr-gcc" -I$(INCLUDES) $(CFLAGS) $< -o $@
    and it all works.
    Also, if anyone is getting error for "avr-gcc" not found, then just add the path to avr-gcc in your path.
    tekkaT 1 Reply Last reply
    • ? A Former User
      can be improved to
      and it all works.
      tekkaT
      tekkaT
      tekka
      @Bhavin-Doshi Thanks for reporting - could you prepare a PR?
      https://github.com/mysensors/MySensorsBootloaderRF24
      ? 1 Reply Last reply
      • tekkaT tekka
        A Former User
        @tekka Submitted https://github.com/mysensors/MySensorsBootloaderRF24/pull/20.
        • ? A Former User
          tekkaT
          tekkaT
          tekka
          @Bhavin-Doshi PR merged. Thank you!
          N 1 Reply Last reply
          • tekkaT tekka
            N
            N
            nagurao.basude
            @tekka, I am planning to move from MySensors v2.0.0 to v2.1.1, do I need to use the updated MYSBootloader? Currently I am using MYSBootloader 1.3 pre-relase (https://forum.mysensors.org/topic/3453/mysbootloader-1-3-pre-release-myscontroller-1-0-0beta).
            Can you please also help me understand the differences in the low_fuses and high_fuses values in the older version of bootloader and the latest version?
            • N nagurao.basude
              tekkaT
              tekkaT
              tekka
              wrote on last edited by tekka
              #131
              @nagurao.basude no, you don't need to but the new version has some stability improvements. The fuse differences are to better match HW (osc type) & clearing eeprom.
              AVR fuse calculator: http://www.engbedded.com/fusecalc/
              • Nca78N
                Hello, has someone used the 1MHz precompiled bootloader ? If yes what baud rate did you use to communicate via serial ?
                I flashed it on a node but I can't upload any script ("not in sync" error). If I believe HW.h it should be 9600 bauds but I have tried hat and nearly every baudrate with no luck.
                I had no problem using the 8MHz version.
                The only way I could use the 1MHz bootloader at the moment is to flash the hex file containing both bootloader and script.
                Sorry to ask this stupid question, I wanted to compile the bootloader but Internet connection is nearly down and I can't even download Atmel Studio :(
                • tekkaT tekka
                  N
                  N
                  nagurao.basude
                  @tekka Thank you very much for the response. I will just start migrating my existing nodes to MySensors v2.1.1library.
                  • Mark SwiftM
                    Mark SwiftM
                    Mark Swift
                    @tekka try as I might, I can't get the nodes to respond to the new 'signal report' option in MYS Controller, any ideas why?
                    • Mark SwiftM Mark Swift
                      tekkaT
                      tekkaT
                      tekka
                      @Mark-Swift This feature only works on MySensors >=2.2.0
                      Mark SwiftM 1 Reply Last reply
                      • tekkaT tekka
                        Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @tekka said in MYSBootloader 1.3.0-beta.3:
                        @tekka I'm using the latest dev branch on all my nodes and gateway...
                          tekkaT
                          tekkaT
                          tekka
                          @Mark-Swift Hmm, that's odd - just tested it here with the latest dev and all is ok. Can you post the logs + node sketch?
                          • J
                            J
                            jacikaas
                            wrote on last edited by jacikaas
                            #138
                            I have notice strange behavior with MYSBootloaderV13pre.hex 8MHz internal bootloader.
                            Problem: When I burn MYSBootloaderV13pre.hex 8MHz internal bootloader to my Standalone Atmega328p i testing it with Arduino Blink and Fade sketches. Problem is that theese sketches doesn't work on this bootloader. LED is just always ON.
                            I also tested the same sketches, same wiring, same Arduino Uno (5V when programming), same FTDI programmer (3.3V), same PC with Win 10 with same drivers, same Atmega328p with Nick Gammon Atmega Board Programmer when I burn Lilypad bootloader and then upload Blink and Fade sketches, they perfectly working.
                            I tried same uploading with Arduino IDE 1.6.5 and also with the newest version 1.8.5.
                            As a programmer I using Arduino as ISP. I theese tests when burning bootloader I don't connect external oscilator.
                            With Nick Gammon software I also checked fuses for both Lilypad and MYSBootloader settings, becose i was thought it is becose of them. Once I configure wrong fuses and it had a lot of time to reset it to default value.
                            Question: So now before changing fuses I want to ask maybe someone have been faced with similar problem?
                            I paste below info about Lilipad and MYSBootloader 8MHz internal oscilator boards fuse settings:
                            Lilypad bootloader
                            Atmega fuse calculator.
                            Written by Nick Gammon.
                            Version 1.11
                            Compiled on Nov 30 2017 at 17:36:58 with Arduino IDE 10805.
                            Attempting to enter programming mode ...
                            Entered programming mode OK.
                            Signature = 0x1E 0x95 0x0F
                            Processor = ATmega328P
                            Flash memory size = 32768
                            LFuse = 0xE2
                            HFuse = 0xDA
                            EFuse = 0xFD
                            Lock byte = 0xEF
                            Clock calibration = 0x8E
                            External Reset Disable.................. [ ]
                            Debug Wire Enable....................... [ ]
                            Enable Serial (ICSP) Programming........ [X]
                            Watchdog Timer Always On................ [ ]
                            Preserve EEPROM through chip erase...... [ ]
                            Boot into bootloader.................... [X]
                            Divide clock by 8....................... [ ]
                            Clock output............................ [ ]
                            Bootloader size: 2048 bytes.
                            Start-up time: SUT0: [X]  SUT1: [ ] (see datasheet)
                            Clock source: calibrated internal oscillator.
                            Brownout detection at: 2.7V.
                            MYSBootloaderV13pre bootloader
                            Version 1.11
                            Compiled on Nov 30 2017 at 19:48:16 with Arduino IDE 10805.
                            LFuse = 0xE2
                            HFuse = 0xD2
                            EFuse = 0xFE
                            Lock byte = 0xFF
                            Preserve EEPROM through chip erase...... [X]
                            Brownout detection at: 1.8V.
                            I appreciate any helpful info!
                            EDIT: I think I already found that there is newer MYSBootloader files of development version which working without problems. I will test it if I write good fuses :)
                            • tekkaT tekka
                              Mark SwiftM
                              Mark SwiftM
                              Mark Swift
                              @tekka, just tried again, perhaps I'm missing something obvious?
                              I have the gateway and node using the latest dev branch, I click the node in MYS and then request a signal report - I see a tx in the log but nothing further? Do I need anything in the node sketch or the gateway? Does this work with the NRF's?
                                tekkaT
                                tekkaT
                                tekka
                                #140
                                • J
                                  J
                                  jacikaas
                                  #141
                                  Q1: Does anybody was able to succesfully use 8MHz MYSBootloader 1.3.0-beta.3 on standalone Atmega328p?
                                  All bootloaders I testing with Arduino BLINK example.
                                  Arduino 1.8.5
                                  I was testing 8MHz internal oscilator MYSBootloader 1.3.0-beta.3 with fuses on 2 different Atmega328p standalone but I can't upload sketch to it and test it. Arduino avrdude says that:
                                  avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4a
                                  Used fuses:
                                  proMYSBL8.bootloader.extended_fuses=0x06 / 07
                                  proMYSBL8.bootloader.lock_bits=0x3F / 0F
                                  Before that, I was burned my Atmega328p with 1MHz internal oscilator MYSBootloader 1.3.0-beta.3 bootloader and it was working.
                                  Also I was testing 8MHz internal oscilator MYSBootloader 1.3pre2 with fuses on 2 different Atmega328p standalone and I can upload sketch to it and test it.
                                  Used fuses:
                                  Q2: I noticed that with 8MHz internal oscilator MYSBootloader 1.3pre2 LED blinks not continuosly it like (* led ON; - led OFF):
                                  *** --- *** --- *** --- ** - * - * - * - [cycle ends, then repeats again] *** --- *** --- *** --- ** - * - * - * - ...
                                  And this one cycle of *** --- *** --- *** --- ** - * - * - * - takes ~8 seconds. Could it be something with watchdog timer? I not very know about this setting.
                                  Thank You for help!
                                  • J jacikaas
                                    Arduino 1.8.5
                                    Used fuses:
                                    Used fuses:
                                    Thank You for help!
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Mark-Swift said in MYSBootloader 1.3.0-beta.3:
                                    Did you try with 1.3.0-beta.4? https://github.com/mysensors/MySensorsBootloaderRF24/tree/development
                                    Mark SwiftM J V 3 Replies Last reply
                                    • tekkaT tekka
                                      Mark SwiftM
                                      Mark SwiftM
                                      Mark Swift
                                      @tekka that did it, it's now working... now to figure out what the returned signal report numbers mean :)
                                      • tekkaT tekka
                                        J
                                        J
                                        jacikaas
                                        @tekka thank You for the answer. I'm not sure is answer was dedicated for me or for Mark, but I tested 1.3.0-beta.4 in the same way I described before:
                                        • Tested with 2 different Atmega328p
                                        • First try was with 1MHz - working on both Atmega328p
                                        • Second try with 8MHz - same situation as with beta 3, skecth won't upload and I get answer from Arduino Avrdude (this time I post full log after uploading):
                                        avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
                                                 Overriding Baud Rate          : 38400
                                        avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf1
                                        avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf1
                                        avrdude done.  Thank you.
                                        It would be best if someone also could try to burn same bootloader on standalone Atmega328p and post results to be sure all wiring and steps I did is without mistakes.
                                        Strange if I I burn 1.3pre2 8MHz bootloader - it works.
                                        What troubleshooting I could make?
                                        J 1 Reply Last reply
                                        • tekkaT tekka
                                          V
                                          V
                                          vikasjee
                                          wrote on last edited by vikasjee
                                          #145
                                          @tekka, Thanks for the link to the beta.4. bootloader. I have tried burning nodes using these and tested them by uploading the FW using MySController 1.0beta_b3316 (latest update meant for MySensors2.2.0) with SerialGatewaySketches using both MySensors2.2.0_rc1 and MySensrs2.2.0_pre1 libraries.
                                          MysController doesn't seem to even recognize the Beta.4 bootloaded Nodes (Promini 5V16Mhz with default provided fuse settings from Makefile). The extra nRF chip wiring checks and precautions (0.01uF and 100uF Caps) have been taken. What might be the problem? How to debug when SerialMontitor cant be used? Any Network Sniffer link if that helps...
                                          I guess the MySensors library version of the SerialGateway sketch may be posing a problem. Can you please help me with a link of the correct MySensors library version to use with beta.4 bootloaded nodes?
                                          Any help will be appreciated...
                                          V 1 Reply Last reply
