  3. 💬 Wall Socket Insertable Node
rfm69atsha204amysensorsrelaypower supply
77 Posts 21 Posters 33.9k Views 27 Watching
  • KoreshK Koresh
    @DavidZH Sorry for such long delay with this question. I will try to explain it carefully now.
    I think it is not possible to buy ready transformer on ali or anywhere else. You can only derive it yourself according to your schematic and produce it at any factory according to your requirements.
    This board has flyback power supply so you can use any flyback transformer design guide, or use as similar as possible reference design. I used EBC10010 reference design to produce the required transformer.
    The main difficulty is the difference between theoretical transformers and produced transformers, so we should tune our schematic to produced transformer a little. Now I have a small batch of transformers almost all of which are soldered on the boards. When I place an order for the next batch of transformers (may be a larger one), I can who send it to anyone who is interested (of course with a tuned schematic if the next batch is different).
    DavidZH
    @Koresh Thanks for the explanation.
    I've been searching for a power solution for my nodes. And that's quite the task.... For now I'm working with the HLK, but that's a tight squeeze. And when I want to make a dimmer, I could use a zero cross circuit. I've been looking into Vigortronix, who have a supply similar to the HLK, but with an extra pulse output for the zero-X. Too bad they are WIDE. They won't leave any proper room for a relay or connection terminal.
    I'll take a look at your link and see if I can make that work in my case, and may come back to you for some magnetics.
    • KoreshK
      KoreshK
      Koresh
      Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-low-profile-220v-10a-relay-rfm69hw-433-mhz-radio-156694939.htm
      • jeremushkaJ
        jeremushkaJ
        jeremushka
        in case you want to use the wall plug manually when a device is connected (without mysensors), it will not work at all in case the relay has been switched ? How do you manage external usage ?
        Y 1 Reply Last reply
        • jeremushkaJ jeremushka
          Y
          Y
          yury
          @jeremushka
          Assume you need to use it with some kind of momentary or rocker switch in case you lose connection to the gateway. Use JST connector and enable A2 internall pullup. JST connector pins are A2 and ground.
          jeremushkaJ 1 Reply Last reply
          • Y yury
            @jeremushka
            jeremushkaJ
            jeremushkaJ
            jeremushka
            @yury i have built a system quite simular but still big mess in the connections. However, i am trying to have a detection when an equipment is plugged in into the wall plug to automatically activate the relay?
            You may ask why? Simple reason. At home my wife doesnt use the automation system. If she plug in a device (charger, coffee machine, etc, it should work automatically without to have to switch the node via the mysensors controller. Normal usage of the plug should in my case be working.
            kalinaK 1 Reply Last reply
              kalinaK
              kalinaK
              kalina
              #63
              @jeremushka In my opinion you should have two modes - automatic (with mysensors) and manualy (without). In manualy case the wall plug must be always under the voltage and you don't need detect plug a device. But how are you going to switch mode - this is a question...
              KoreshK jeremushkaJ 2 Replies Last reply
              • kalinaK kalina
                KoreshK
                KoreshK
                Koresh
                @kalina said in 💬 Wall Socket Insertable Node:
                Long button pressure for example :)
                • kalinaK kalina
                  jeremushkaJ
                  jeremushkaJ
                  jeremushka
                  @kalina agree with you. By pressing a button in that case better not to insert the system in the wall. To get outside plug. Something like the fibaro plug which is working with these two modes.
                  • Y
                    Y
                    yury
                    0_1511423252215_upload-58b63f65-387b-4f09-8ecc-8e502167df7c
                    0_1511423242157_upload-b3e8f1c1-6885-49a9-bc85-9a031bec40a6
                    make sense?
                    sketch is here
                    https://github.com/EasySensors/WallSocketInsertableNode/blob/master/WallSocketInsertableNode.ino
                    but no LED support there, but easy to add.
                    Yes, it will work if no gateway around.
                    • Y yury
                      make sense?
                      sketch is here
                      jeremushkaJ
                      jeremushkaJ
                      jeremushka
                      @yury Yes, this is perfect :) Great job !!!
                      Have you ever had feature as power meter?
                        Y
                        Y
                        yury
                        @jeremushka said in 💬 Wall Socket Insertable Node:
                        there is ACS712ELCTR-20A AC current sensing chip on the board. but Atmega ADC not very accurate at low currents reported from ACS712 - 20A. 15W loads or less can be difficult to recognize.
                        BTW another idea for LED indication . There is installed pixel LED on-board. check pictures. it is bright enough
                        0_1511469223333_upload-577ef824-0975-464f-bf71-01508746a49f
                        0_1511468966659_upload-959c7ab7-b86d-47bc-b50f-84bb42d7f16b
                        0_1511469249412_upload-ac69c082-8e14-4fb8-9e2f-0f45acc58f7a
                        0_1511469335265_upload-34073147-3f54-409c-a7cc-1999a990b7f8
                        • Y yury
                          kalinaK
                          kalinaK
                          kalina
                          #69
                          @yury What do you think about capacitive button "On/Off" to the right corner from led? Look at the pic below...
                          0_1511511651983_upload-94807368-e9e7-4f89-97ea-1d5f8ac468ff
                          • jeremushkaJ
                            jeremushkaJ
                            jeremushka
                            @yury said in 💬 Wall Socket Insertable Node:
                            That will be great! for the current sensor, i am trying to check accurancy with another component HLW8012, it is used by Xiaomi as well. I don't know if it is good or not yet.
                            KoreshK 1 Reply Last reply
                              KoreshK
                              KoreshK
                              Koresh
                              wrote on last edited by Koresh
                              #71
                              HLW8012
                              Very interesting solution. Except for one thing... According to HLW8012 appnote we need additional 5V power supply if we want to implement safety isolation between low voltage arduino circuit and high voltage circuit.
                              • KoreshK Koresh
                                HLW8012
                                jeremushkaJ
                                jeremushkaJ
                                jeremushka
                                @Koresh could we reuse the 5V DC at the output of the transformer ? We have the isolation at this point. and the current will be enough for the the circuit.
                                  KoreshK
                                  KoreshK
                                  Koresh
                                  #73
                                  @jeremushka Sorry but I don't understand... In current version of board ACS712 uses 5v DC from the transformer, but ACS output and power circuit are isolated from measure circuit. HLW8012 outputs and power are not isolated from measure circuit, so we should use circuit like this:
                                  And of cource we need additional power supply.
                                  • kalinaK kalina
                                    Y
                                    Y
                                    yury
                                    Looks cool! Do you have experience with capacities switches? I did not play much with them. afraid to use close to AC interference though...
                                    kalinaK Nca78N 2 Replies Last reply
                                    • Y yury
                                      kalinaK
                                      kalinaK
                                      kalina
                                      #75
                                      @yury I have a little experience with AD7148 and 7150 chips in one of my projects . You are right, there wasn't a high voltage traces.
                                      • KoreshK Koresh
                                        Z
                                        Z
                                        zurajm
                                        @koresh Hi, I'm interested in the transformers. Do you have some to spare? I like your design very much because is so low profile. I will try to assemble some on my own to test the design but I have no idea where to find/order adequate transformer for it (you mentioned that you order them custom made). Thank you very much for the answer.
                                        • Y yury
                                          You need to use a capacitive IC with active shielding, basically you have an extra electrode around your touch electrode and the touch IC will compare capacitive change of the touch electrode with capacitive change from the shield electrode. If the change is due to electrical interference then both electrodes will be changed in a similar way and the IC will not trigger.
