  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
    I'll try it, but I have strong doubts that it's going to work.
    FWIW, here's the pin mapping currently being supplied by digitalPinToInterrupt(..) for the nRF5:
    Digital pin 0 = interrupt pin 0
    Digital pin 1 = interrupt pin 1
    Digital pin 2 = interrupt pin 2
    Digital pin 3 = interrupt pin 3
    Digital pin 4 = interrupt pin 4
    Digital pin 5 = interrupt pin 5
    Digital pin 6 = interrupt pin 6
    Digital pin 7 = interrupt pin 7
    Digital pin 8 = interrupt pin 8
    Digital pin 9 = interrupt pin 9
    Digital pin 10 = interrupt pin 10
    Digital pin 11 = interrupt pin 11
    Digital pin 12 = interrupt pin 12
    Digital pin 13 = interrupt pin 13
    Digital pin 14 = interrupt pin 14
    Digital pin 15 = interrupt pin 15
    Digital pin 16 = interrupt pin 16
    Digital pin 17 = interrupt pin 17
    Digital pin 18 = interrupt pin 18
    Digital pin 19 = interrupt pin 19
    Digital pin 20 = interrupt pin 20
    Digital pin 21 = interrupt pin 21
    Digital pin 22 = interrupt pin 22
    Digital pin 23 = interrupt pin 23
    Digital pin 24 = interrupt pin 24
    Digital pin 25 = interrupt pin 25
    Digital pin 26 = interrupt pin 26
    Digital pin 27 = interrupt pin 27
    Digital pin 28 = interrupt pin 28
    Digital pin 29 = interrupt pin 29
    Digital pin 30 = interrupt pin 30
      #85
      The last I heard, from @d00616 , we had to supply code such as:
          // Enable interrupt
        NVIC_EnableIRQ(RTC0_IRQn);
      and
      // This must be in one line
      extern "C" { void RTC0_IRQHandler(void) {rtcInterruptCounter++; NRF5_RESET_EVENT(NRF_RTC0->EVENTS_OVRFLW); NRF_RTC0->EVENTS_OVRFLW=0; }}
      to get interrupts to work. Even with that approach, though, I haven't gotten it to support any interrupts in addition to a timed sleeping, though I have gotten it to support one interrupt that's separate from a timed sleeping (basically, sleeps indefinitely until the interrupt happens).
        #86
        OK, I just now tried:
          sleep(3,CHANGE,3000);
        and, as I suspected, it does nothing but sleep for 3 seconds. It's not responsive to any changes on pin P03 on an nRF52.
        @scalz Are you getting a different result? It seems like there's a strong disconnect somewhere between what you're recommending and what I am experiencing.
        scalzS 1 Reply Last reply
          #87
          @NeverDie said in 💬 MySensors NRF5 Platform:
          I didn't give any recommandation, you misread. I just said the regular way to use sleep feature in mysensors, for users, is with sleep(..). But I agree, I misread you too! when you were asking for the specific nrf52 case I guess :)
          That said, I got this working when I made my recessed node for door (accelerometer and hall effect sensor with sleeping). Maybe things have changed in the lib?? or not. I'm struggling between different version of the lib, and some are different from the dev branch.. I'll recheck this asap (not sure for this evening).
            #88
            I tried toying around with it a bit, and I got a useful result:
            #define MY_CORE_ONLY
            #include <nrf.h>
            const byte ledPin = LED_BUILTIN;
            const byte interruptPin = 3;
            volatile byte state = LOW;
                for (int i=0;i<pulses;i++) {
                  wait(20);
                  wait(100);
                  wait(500);
              hwPinMode(interruptPin, INPUT);
              attachInterrupt(digitalPinToInterrupt(interruptPin), blink, RISING);
              blinkityBlink(2,1);  //signify power-on and start of main loop
            volatile bool buttonPressed=false;
              state = !state;
              digitalWrite(ledPin, state);
              sleep(digitalPinToInterrupt(interruptPin), RISING, 3000);
              wait(20);  //wait 20 milliseconds for button to debounce if it was pressed
              if (digitalRead(interruptPin)) { //if button is pressed
                blinkityBlink(2,1);
              if (buttonPressed) {
                blinkityBlink(20,1);
            void blink() {
              buttonPressed=true;
            So, with this approach, pushing the button on pin 3 does wake up the nRF52 from sleep, whereupon the button press can still be detected and serviced, but it also demonstrates that the ISR per se isn't working.
            Anyhow, with this I'm able to get the PIR or leak sensor or magnet sensor or light sensor doing useful things in a timely manner, even if it isn't ideal. That puts me further ahead than I was before. :)
            rmtuckerR 1 Reply Last reply
              #include <nrf.h>
                    wait(20);
                    wait(100);
                    wait(500);
                state = !state;
                  blinkityBlink(2,1);
              void blink() {
                buttonPressed=true;
              rmtuckerR
              rmtuckerR
              rmtucker
              This is a test program that wakes up from either that i was using some time ago.
                 REVISION HISTORY
                 Version 1.0 - Henrik EKblad
                 DESCRIPTION
                 This sketch provides an example how to implement a distance sensor using HC-SR04
                 Use this sensor to measure KWH and Watt of your house meeter
                 You need to set the correct pulsefactor of your meeter (blinks per KWH).
                 The sensor starts by fetching current KWH value from gateway.
                 Reports both KWH and Watt back to gateway.
                 Unfortunately millis() won't increment when the Arduino is in
                 sleepmode. So we cannot make this sensor sleep if we also want
                 to calculate/report watt-number.
                 http://www.mysensors.org/build/pulse_power
              // Enable debug prints
              //#define MY_RADIO_NRF24
              #define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              #include <Wire.h> // must be included here so that Arduino library object file references work
              #include <RtcDS3231.h>
              RtcDS3231<TwoWire> Rtc(Wire);
              #define DIGITAL_INPUT_SENSOR 2  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
              //#define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
              unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
              double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour
              //bool pcReceived = false;
              volatile unsigned long kwh = 0;
              unsigned long oldWatt = 0;
              double oldKwh;
              unsigned long lastSend;
              MyMessage wattMsg(CHILD_ID, V_WATT);
              MyMessage kwhMsg(CHILD_ID, V_KWH);
                Rtc.Begin();
                Rtc.Enable32kHzPin(false);
                Rtc.SetSquareWavePinClockFrequency(DS3231SquareWaveClock_1Hz);
                Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeClock);
                attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
                //pcReceived = true;
                lastSend = millis();
                present(CHILD_ID, S_POWER);
                unsigned long now = millis();
                if (sendTime) {
                  if (watt != oldWatt) {
                    if (watt < ((unsigned long)MAX_WATT)) {
                    Serial.print("Watt:");
                    Serial.println(watt);
                    oldWatt = watt;
                  // Pulse count has changed
                  //kwh = pulseCount;
                  //double kwh = ((double)pulseCount / ((double)PULSE_FACTOR));
                  send(kwhMsg.set(pulseCount));  // Send kwh value to gw
                  Serial.print("Wh = ");
                  Serial.println(pulseCount);
                  pulseCount = 0;
                  lastSend = now;
                sleep(SEND_FREQUENCY);
              void onPulse()
                unsigned long interval = newBlink - lastBlink;
                if (interval < 50000L) { // Sometimes we get interrupt on RISING
                  return;
                watt = (3600000000.0 / interval) / ppwh;
                lastBlink = newBlink;
                pulseCount++;
                #90
                Well, that's interesting. In the sketch I posted, I invoked sleep with:
                which caused the mcu to wake up immediately after I press the button, but it didn't process the ISR.
                Using an invocation like yours in the sketch you just posted above:
                  sleep(3000);
                the ISR executes and then terminates when I press the button, but the MCU doesn't wake and continue with the loop as it did with the prior incantation. Instead, it has to wait for the timer cycle to finish.
                What I want is for it to wake up, do the ISR, and continue with the loop where it left off until it is explicitly put back to sleep again. How do I do that?
                • d00616D
                  d00616D
                  d00616
                  @NeverDie I have checked the sleep routine in all three variants. It's working with my setup.
                  There is no API stopping the sleep() by another ISR. Sleep only ends at one of the given conditions.
                  When you use the MY_CORE_ONLY define, please add "hwInit();" into the setup() routine.
                  • d00616D d00616
                    Would you please post the three demo code examples that you tested?
                      OK, I just now did that, but I'm not getting any difference in the results.
                        In any case, I'm sure the question will ultimately turn from "How do I wake up based on a pin change?" to "How do I wake up based on the LPCOMP output, which has that pin as its input?" The reason: as covered earlier in this thread, much lower current consumption while sleeping if doing it via LPCOMP rather than the more straightforward pin monitoring.
                        d00616D 1 Reply Last reply
                          d00616D
                          d00616D
                          d00616
                          It's a good question about, how to design the API to do this. I have no good idea.
                          Until an API, you can set MY_HW_RTC->CC[0] to (MY_HW_RTC->COUNTER+2). This ends sleep with some latency.
                            #96
                              #97
                                  #99
                                  Is it just me, or does the myBoardNrf5 cause I2c to fail during initialization? I have code which worked fine on mNrf5Board but which now hangs during initialization when using myBoardNrf5. :( Is it working for anyone else?
                                    #100
                                    I've re-installed everything and am still getting no joy using I2C currently. The non-I2C stuff seems to be working fine though.
                                    So, before I spin more cycles trying to figure it out, is i2c working for anyone else right now using the latest builds and myBoardNrf5? Or, is I2C currently broken?
                                      #101
                                      It appears that the place where it hangs is this line here in Wire_nRF52.cpp:
                                        while(!_p_twim->EVENTS_LASTTX && !_p_twim->EVENTS_ERROR);
                                      This is too bad, as I2C seemed to work fine prior to around a couple weeks ago. I think maybe (?) the latest update somehow broke it.
                                      Please advise.
                                        #102
                                        Well, since I'm dead in the water as things stand, I moved the code over to run on an nRF52 DK. Then, usingy Sandeep's code and none of the mysensors code, I was able to get the nRF52 DK to read an attached Si7021 temperature-humidity sensor. i.e. that worked without hanging.
                                        So, it would appear that there's something about the mysensors code that is causing the problems. @d00616 Can we please get it fixed?
                                          d00616D
                                          d00616D
                                          d00616
                                          I have no I2C Hardware for testing, but I take a look into the I2C and MySensors code soon.
