1.1k Posts 105 Posters 793.0k Views 98 Watching
    The value on a dryer is even more tangible: the sooner you get your clothes out, the less wrinkly they get.
    dbemowskD 1 Reply Last reply
      dbemowskD
      dbemowskD
      @NeverDie All good points that I hadn't thought of.
      sinczeS 1 Reply Last reply
      • dbemowskD dbemowsk
        sinczeS
        sinczeS
        sincze
        MySensors Evangelist
        @dbemowsk while you are at it..consider :)
        The dishwasher can be added as well. My devices dishwasher / washing machine / dryer send messages to all tvs that are turned on. Identifying themselves and invite you to come and clean them :). It comes in handy and absolutely jaw dropping on your visitors.
        If you turn on the stove air circulation system in the kitchen... Why not greet the wife with automatically start the TV in the kitchen and play her favourite radio channel at her preferred volume...
          #116
          Back to the OP topic, I made a micro-usb OTG cable (bottom cable below) that passes through all 5 pins:
          This will replace the more fragile cable above it in the next generation of my nRF5 micro-usb programming/debug adapter.
          It turns out you can't buy this cable. At least, I couldn't find any for sale. Instead, I had to make it myself. Fortunately, Adafruit sells a little DIY kit that helped tremendously:
          https://www.adafruit.com/product/1826
          YveauxY zboblamontZ 2 Replies Last reply
            @NeverDie So much heat shrink tubing -- makes my eyes hurt :sob:
              zboblamontZ
              zboblamontZ
              zboblamont
              @NeverDie So many colours of nations offended... Have you thought of going for President ?
                #119
                Actually, this was the very first time I've used shrink tubing. How could I do it better?
                Mostly I didn't want there to be much bending, which might lead to tearing loose the solder connections. I wanted the finished cable to be a "once and done." Now that it's done, the connections should go very easy.
                  scalpel
                  wrote on last edited by scalpel
                  #120
                  I use raspberry for watching television, movies etc. Today I build raspberry hat to turn on from remote control. Attiny85 recognizes programmed remote code and by optocoupler short circuit on pins.
                  • S scalpel
                    rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    wrote on last edited by rozpruwacz
                    #121
                    @scalpel how do You program the ir code for the power button ? can it be programed from the linux running in the rpi ? or it is just hardcoded into atiny code ?
                      scalpel
                      Hardcoded In attiny. Learn arduino irremote library.
                      Pozdrawiam / regards
                      • S scalpel
                        rozpruwaczR
                        rozpruwaczR
                        rozpruwacz
                        @scalpel yeah, I did this kind of project also and I wonder if there is a software for that :) It would be fun to be able to set the wakeup ir code from the linux os, with for example i2c or 1-wire interface.
                        gohanG 1 Reply Last reply
                        • rozpruwaczR rozpruwacz
                          @rozpruwacz how often would you need to change the IR code for that?
                          • rozpruwaczR
                            rozpruwaczR
                            rozpruwacz
                            rarely, but still it would be fun to make such thing :)
                            • sinczeS sincze
                              dakipro
                              @sincze said in What did you build today (Pictures) ?:
                              @sincze hi, could you elaborate a bit more the TV messages, do you have any link with more info? Was that the LG tv with Mqtt that was mentioned on the forum?(or I mixed forums)
                              • D dakipro
                                sinczeS
                                sinczeS
                                sincze
                                @dakipro we use kodi on al lgl tvs. The libreelec TV box has cec and can turn on the TV via hdmi. If TV is on I am able to control the volume via the LG webserver. Kodi (api) can display the notifications for Me :). Not that fancy but it works like a charm.
                                bjacobseB 1 Reply Last reply
                                • wallyllamaW
                                  wallyllamaW
                                  wallyllama
                                  Side note. I did a quick search, there is a cec library for arduino!
                                  https://github.com/stefslon/cec-arduino
                                  • sinczeS sincze
                                    bjacobseB
                                    bjacobseB
                                    bjacobse
                                    @sincze
                                    If it works like a charm - it's fancy ;-)
                                    • sundberg84S
                                      sundberg84S
                                      Back to topic! Last night I made some changes to my ATX Power supply because the variable settings was to sensitive:
                                      0_1511953574080_upload-c7feca62-d22d-435e-9c73-9599ca0c9044
                                      0_1511953586756_upload-3bb65a38-91b8-4dc8-9dd7-3a0af6fd45f9
                                      • sundberg84S sundberg84
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @sundberg84 Did you find that taking the cover off improved the accuracy at all ?
                                        :laughing:
                                        • maghacM
                                          maghacM
                                          maghac
                                          I built a lithophane lamp for my grandson. The electronics is basically only a pro mini and 36 neopixels. Sadly this version is not mysensorized but maybe I'll do that in version 2 :)
