  3. RGB LED strip
RGB LED strip
70 Posts 22 Posters 43.7k Views 27 Watching
  • bgunnarbB
    bgunnarbB
    bgunnarb
    Hi!
    I'm doing some further development based on the sketch by @maghac and @DrJeff above and I have found two potential bugs that could create some unexpected behaviour.
    The first is that if you have #DEFINE RELAX_SPEED 50 in the sketch and then set fadespeed (V_VAR1) to anything greater than 650 or so, you will get an overflow when you call the function init_fade (t, r, g, b ) since t is defined as int in init_fade.
    fadespeed can be set between 0 and 2000 in the sketch. So then the resulting fadespeed could be anything, even negative.
    init_fade(fadespeed * RELAX_SPEED,
                    program_param_RELAX[program_cycle][0],
                    program_param_RELAX[program_cycle][1],
                    program_param_RELAX[program_cycle][2]);
    Also in this function there is a potential risk of a "divide by zero" crash since the input variable t is used as fade_step to divide in order to get the size of each step in the fade cycle.
    void init_fade(int t, int r, int g, int b) {
      Serial.print( "Init fade" );
      light_mode = LIGHT_FADING;
      target_r = r;
      target_g = g;
      target_b = b;
      fade_step = t;
      delta_r = (target_r - current_r) / float(fade_step);
      delta_g = (target_g - current_g) / float(fade_step);
      delta_b = (target_b - current_b) / float(fade_step);
    It might be that this function is never called with fadestep = t = 0 but since this is a value allowed in the input check of V_VAR1 nasty things may happen.
    Part from this I am impressed by the sketch. Once I have debugged my own additions I will post the project here.
    I have never been so busy since I retired!
    maghacM 1 Reply Last reply
    • bgunnarbB bgunnarb
      Hi!
        target_r = r;
        target_g = g;
        target_b = b;
        fade_step = t;
      maghacM
      maghacM
      maghac
      @bgunnarb Thanks. As program space is limited, I chose not to put too much effort in input data validation, instead relying on the controller to not submit incorrect values. Maybe a quick range check would not waste so many bytes though.
      Right now I am however experiencing some strange behavior - I can turn the the lamp on and off and I can dim it, but I cannot change the color of the strip. Also, the RELAX program does not work but the ALARM program works fine. So there are some other bugs that need to be ironed out :)
      • M moskovskiy82
        After some investigating it wasn't a timer issue but a range issue with a node (it was hard to figure out). So went ahead and built another node with your code. But being lazy - just bought an rgb strip drive from aliexpress (too much soldering of mosfets for me).
        It uses some RGBdriver.h library https://github.com/letsgoING/Libraries/tree/master/LEDStripDriver
        fe
        All i had to change was
        void set_rgb(int r, int g, int b) {
          Driver.begin();
          Driver.SetColor(r, g, b);
          Driver.end();
        And it worked. Except that fading/RELAX don't work out for me. Instead just get a flashing of white light. So i thought you might know some other parts must be adjusted as my arduino knowledge is not there yer
        maghacM
        maghacM
        maghac
        @moskovskiy82 said in RGB LED strip:
        That's the alarm program you are seeing. Perhaps it doesn't decode the incoming messages properly - I'll have to take a second look at the code.
          moskovskiy82
          Thanks. Will await eagerly for v1.8 as it seems this is the only great RGB code left for mysensors
          • micahM
            micahM
            micah
            @maghac Great project.
            I've made something similar, Arduino Pro Mini 5v, 5m LED strip (non-addressable), nrf24L01+ and MOSTFETs
            I know it took me awhile to find code examples, so I figured I would share my code incase it helps anyone else.
            I use Domoticz as a controller. This code talks to:
            • Switch - to control turning my color cycle fade effect on
            • Dimmer - to control the speed of the color cycle fade effect
            • RGB switch - to control having only a single color turned on and the brightness of the string.
            Much of my code is standard stuff, using FastLED analogue, but I'm particularly proud of the brightness part, since I bashed my head against the keyboard several times trying to figure it out
            //## INCLUDES ##
            #define MY_NODE_ID 20
            #include <FastLED.h>
            #define cID_RGB_SELECTOR 0
            #define cID_CYCLE_EFFECT 1
            #define cID_CYCLE_EFFECT_SPEED 2
            #define PIN_RED   5
            #define PIN_GREEN 6
            #define PIN_BLUE  3
            //## VARIABLES ##
            // MySensors
            #define MySensors_SketchName      "RGB LED Strip"
            #define MySensors_SketchVersion   "v0.3"
            MyMessage MySensors_MSG_Last_Color(cID_RGB_SELECTOR,V_VAR1);
            MyMessage MySensors_MSG_RGB_Selector(cID_RGB_SELECTOR, V_LIGHT);
            MyMessage MySeonsors_MSG_CYCLE_EFFECT(cID_CYCLE_EFFECT, V_LIGHT);
            MyMessage MySensors_MSG_CYCLE_EFFECT_SPEED(cID_CYCLE_EFFECT_SPEED, V_DIMMER);
            bool MySensors_RequestACK = false;
            // Single color
            int Solid_RGB_Active=0;
            char Solid_RGB_Color[] = "000000";
            uint16_t Solid_RGB_Brightness = 0xFF;
            // Cycle effect
            int Cycle_Effect_Active=0;
            unsigned long Cycle_Effect_pMillis = 0;
            long Cycle_Effect_Speed = 20;
            static uint8_t Cycle_Effect_Current_Hue;
            // Supporting
            bool Status_Change = false;
            bool Print_Debug = false;
            // ## Primary flow control
              while (!Serial) ;
              Serial.print("compiled: ");Serial.print(__DATE__);Serial.println(__TIME__);
              pinMode(PIN_RED,   OUTPUT);
              pinMode(PIN_GREEN, OUTPUT);
              pinMode(PIN_BLUE,  OUTPUT);
              Event_ColorTestBars();
              request(cID_RGB_SELECTOR, V_VAR1);
              request(cID_RGB_SELECTOR, V_LIGHT);
              request(cID_CYCLE_EFFECT, V_LIGHT);
              request(cID_CYCLE_EFFECT_SPEED, V_DIMMER);
              if (Cycle_Effect_Active == 1){
                Event_RunCycleEffect(currentMillis);
              } else if (Status_Change){
                  #ifdef MY_DEBUG
                    if (Print_Debug) {Serial.println("STATUS CHANGE");}
                if (Solid_RGB_Active == 0){
                  Event_SetLEDColors( CRGB::Black );
                }else if (Solid_RGB_Active == 1){
                  CHSV colorHSV = rgb2hsv_approximate(str2CRGB(Solid_RGB_Color));
                  Event_SetLEDColors(CHSV(colorHSV.h, colorHSV.s, Solid_RGB_Brightness));
            // ## MySensors Methods
            void presentation()  {
              sendSketchInfo(MySensors_SketchName, MySensors_SketchVersion);
              present(cID_RGB_SELECTOR, S_RGB_LIGHT, "RGB Color Selector", MySensors_RequestACK);
              present(cID_CYCLE_EFFECT, S_LIGHT, "RGB Cycle Effect", MySensors_RequestACK);
              present(cID_CYCLE_EFFECT_SPEED, S_DIMMER, "RGB Cycle Effect Speed", MySensors_RequestACK);
            void receive(const MyMessage &message){
              #ifdef MY_DEBUG
                if (message.isAck()){
                  Serial.println("Got ack from gateway");
              if (message.type == V_LIGHT){
                #ifdef MY_DEBUG
                  if (Print_Debug) {Serial.println("message v_light");}
                int current_Light_State = message.getString()[0] == '1';// Incoming on/off command sent from controller ("1" or "0")
                if (message.sensor==cID_CYCLE_EFFECT){// is Cycle Message
                  if (current_Light_State==1){//turn cycle on
                    Event_LightCycle(true, true, false);
                    Event_SolidColor(false, false, true);
                  } else {//turn cycle off
                    Event_LightCycle(false, true, false);
                } else if (message.sensor==cID_RGB_SELECTOR){// is RGB Message
                  if (current_Light_State==1){//turn RGB on
                    Event_SolidColor(true, true, false);
                    Event_LightCycle(false, false, true);
                  } else {//turn RGB off
                    Event_SolidColor(false, true, false);
                  #ifdef MY_DEBUG
                    Serial.print("UNKNOWN Light - Message:");
                    Serial.print(message.getString());
                    Serial.print(" - Sensor:");
              } else if (message.type == V_RGB){
                #ifdef MY_DEBUG
                  if (Print_Debug) {Serial.println("message v_rgb");}
                String szMessage=message.getString();
                strcpy(Solid_RGB_Color, getValue(szMessage,'&',0).c_str());
                Solid_RGB_Active = 1;
              }else if (message.type == V_DIMMER) {// if DIMMER type, adjust brightness
                #ifdef MY_DEBUG
                  if (Print_Debug) {Serial.println("message v_dimmer");}
                if (message.sensor==cID_RGB_SELECTOR){// is single Message
                  if (Solid_RGB_Active==1){//turn RGB on
                  Solid_RGB_Brightness = map(message.getLong(), 0, 100, 0, 255);
                  CRGB colorRGB = str2CRGB(Solid_RGB_Color);
                  CHSV colorHSV = rgb2hsv_approximate(colorRGB);
                  colorHSV = CHSV(colorHSV.h, colorHSV.s, Solid_RGB_Brightness);
                  Event_SetLEDColors(colorHSV);
                  #ifdef MY_DEBUG
                    if (Print_Debug) {
                      Serial.print("colorHSV.h:");
                      Serial.println(colorHSV.h);
                      Serial.print("colorHSV.s:");
                      Serial.println(colorHSV.s);
                      Serial.print("colorHSV.v:");
                      Serial.println(colorHSV.v);
                  Event_SendLastColor();
                } else if (message.sensor==cID_CYCLE_EFFECT_SPEED){// is Speed dimmer Message
                  Cycle_Effect_Speed = map(message.getLong(), 0, 100, 1, 202);
                  #ifdef MY_DEBUG
                    if (Print_Debug) {
                      Serial.print("Cycle_Effect_Speed: ");
                      Serial.println(Cycle_Effect_Speed);
              }else if (message.type == V_STATUS) {           // if on/off type, toggle brightness
                #ifdef MY_DEBUG
                  if (Print_Debug) {Serial.println("message v_status");}
                Solid_RGB_Active = message.getInt();
                Cycle_Effect_Active = 0;
                  if (Print_Debug) {Serial.println("Strip OFF");}
                }else{
                  if (Print_Debug) {Serial.println("Strip ON");}
                  Event_SetLEDColors(strtol(Solid_RGB_Color, NULL, 16));
                //Event_SendLastColor();
              }else if (message.type==V_VAR1) {            // color status
                #ifdef MY_DEBUG
                  if (Print_Debug) {
                    Serial.println("message v_var1");
                    Serial.println(szMessage);
              Status_Change = true;
            // ## Events
            void Event_LightCycle(bool t, bool s, bool u) {
              Cycle_Effect_Active = (t) ? 1 : 0;
              if (u){
                send(MySeonsors_MSG_CYCLE_EFFECT.set(Cycle_Effect_Active),MySensors_RequestACK);
            void Event_SolidColor(bool t, bool s, bool u) {
              Solid_RGB_Active = (t) ? 1 : 0;
              if (u){
                send(MySensors_MSG_RGB_Selector.set(Solid_RGB_Active),MySensors_RequestACK);
            void Event_SetLEDColors( const CRGB& rgb){
              analogWrite(PIN_RED,   rgb.r );
              analogWrite(PIN_GREEN, rgb.g );
              analogWrite(PIN_BLUE,  rgb.b );
            void Event_SendLastColor(){
              String current_status=Solid_RGB_Color+String("&")+String(Solid_RGB_Brightness)+String("&")+String(Solid_RGB_Active);
              send(MySensors_MSG_Last_Color.set(current_status.c_str()),MySensors_RequestACK);
            void Event_RunCycleEffect(unsigned long theMills){
              if (theMills - Cycle_Effect_pMillis >= Cycle_Effect_Speed){
                Cycle_Effect_pMillis = theMills;
                Cycle_Effect_Current_Hue = Cycle_Effect_Current_Hue + 1;
                Event_SetLEDColors( CHSV( Cycle_Effect_Current_Hue, 255, 255) );
            void Event_ColorTestBars(){// Event_ColorTestBars: flashes Red, then Green, then Blue, then Black. Helpful for diagnosing if you've mis-wired which is which.
              Event_SetLEDColors( CRGB::Red );   delay(500);
              Event_SetLEDColors( CRGB::Green ); delay(500);
              Event_SetLEDColors( CRGB::Blue );  delay(500);
              Event_SetLEDColors( CRGB::Black ); delay(500);
            // ## Helper Functions
            String getValue(String data, char separator, int index){
             int found = 0;
              int strIndex[] = {0, -1};
              int maxIndex = data.length()-1;
              for(int i=0; i<=maxIndex && found<=index; i++){
                if(data.charAt(i)==separator || i==maxIndex){
                  found++;
                  strIndex[0] = strIndex[1]+1;
                  strIndex[1] = (i == maxIndex) ? i+1 : i;
              return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
            int x2i(char *s) {
              int x = 0;
              for(;;) {
                char c = *s;
                if (c >= '0' && c <= '9') {
                  x *= 16;
                  x += c - '0';
                }else if (c >= 'A' && c <= 'F') {
                  x *= 16;
                  x += (c - 'A') + 10;
                }else {
                s++;
              return x;
            char* str2char(String command){
                if(command.length()!=0){
                    char *p = const_cast<char*>(command.c_str());
                    return p;
            CRGB str2CRGB(String s){
              String r = str2char(s.substring(0,2));
              String g = str2char(s.substring(2,4));
              String b = str2char(s.substring(4,6));
              uint8_t red = x2i(r.c_str());
              uint8_t green = x2i(g.c_str());
              uint8_t blue = x2i(b.c_str());
              #ifdef MY_DEBUG
                if (Print_Debug) {
                  Serial.print("r:");
                  Serial.println(r);
                  Serial.print("g:");
                  Serial.println(g);
                  Serial.print("b:");
                  Serial.println(b);
                  Serial.print("red:");
                  Serial.println(red);
                  Serial.print("green:");
                  Serial.println(green);
                  Serial.print("blue:");
                  Serial.println(blue);
              CRGB colorRGB = CRGB(red, green, blue);
              return colorRGB;
            Hopefully this proves useful to someone :)
            • micahM
              micahM
              micah
              Here is a photo of my actual device with the cover off
              • M moskovskiy82
                maghacM
                maghacM
                maghac
                @moskovskiy82 I'll see if I'll have time to work on it this week, I'll post an update when I have something.
                PlantexP maghacM 2 Replies Last reply
                • maghacM maghac
                  PlantexP
                  PlantexP
                  Plantex
                  @maghac
                  Hello
                  I need some help !
                  I've ordered few IRLZ44N Mosfets to play with Dimmable LED Actuator project.
                  Adafruit RGB LED stripe uses IRLB8721
                  Could You please tell me if I could use mentioned IRLZ instead of IRLB in case of described RGB project ?
                  Thank You in advance.
                  • bgunnarbB
                    bgunnarbB
                    bgunnarb
                    @Plantex
                    In my opinion that should work just fine. The specs are fairly similar. I am using the IRLZ44N myself to drive a five meter long RGBW LED-strip and they do not get warm, even without a heat sink. Total current consumption at 24V is just above 2A when all LEDs are lit.
                    Schematics below:
                    0_1511539204888_LEDstrip_sch.pdf
                    • T
                      Tinnyt
                      Geat Work
                      • C
                        C
                        chorob
                        Great project! I could use some help getting this to work. I am using the newbie PCB, just a regular RGB LED for testing and Homeassistant as my controller. Hass adopts the node but I get this error message everytime I restart the node and the switch does not appear on my frontend.
                        "Not a valid message: Not valid message sub-type: 40 for dictionary value @ data['sub_type']"
                        I am running '2.0' in my hass config file. I have tried '2.1.' and '2.1.1' with no success. Homeassistant version .60.
                        I have several temperature sensor nodes talking to hass just fine. Any ideas? I assume I am just missing something simple as I am relatively new to homeassistant and mysensors.
                        Thank you in advance for your help!
                        • maghacM maghac
                          maghacM
                          maghacM
                          maghac
                          Well, it took some time, but here is v1.8 at last!
                          I have modified the code to handle RGBW strips, since I realized that the white light from RGB strips is very uncomfortable and not really suitable for general illumination. It should be fairly easy to convert it back to RGB though. Adding the W channel means that I now need 4 PWM pins, and therefore it was necessary to redefine one of the pins that the radio is connected to - the sketch now expects CE to be connected to pin 8 instead of 9 which is the default (a pro mini only has 3 free PWM pins if you use the default setup).
                          I've also completely changed now programs/modes are implemented so it should be easier to add new programs. Feel free to experiment with this and let me know what you think.
                           * LED STRIP sketch for Mysensors
                           * 1.0
                           *   Based on the example sketch in mysensors
                           * 1.1
                           *   prgspeed parameter (send as V_VAR1 message)
                           *   HomeAssistant compatible (send status to ack)
                           * 1.2
                           *   OTA support
                           * 1.3
                           *   Power-on self test
                           * 1.4
                           *   Bug fix
                           * 1.5
                           *   Other default values
                           * 1.6
                           *   Repeater feature
                           * 1.7
                           *   Multitasking. Alarm and RELAX modes.
                           * 1.8
                           *   Reengineered programs/modes logic.
                           *   RGBW variant. Requires 4 PWM pins, so we need to move use a different pin for one of radio connections.
                          #define MY_OTA_FIRMWARE_FEATURE
                          #define MY_NODE_ID AUTO
                          // Normally the radio uses pin 9 for CE
                          #define MY_RF24_CE_PIN  8
                          #define CHILD_ID_LIGHT 1
                          #define SN "LED Strip"
                          #define SV "1.8"
                          MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
                          MyMessage rgbwMsg(CHILD_ID_LIGHT, V_RGBW);
                          MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
                          MyMessage prgspeedMsg(CHILD_ID_LIGHT, V_VAR1);
                          MyMessage programMsg(CHILD_ID_LIGHT, V_VAR2);
                          #define RR 0
                          #define GG 1
                          #define BB 2
                          #define WW 3
                          byte current[] = {255, 255, 255, 255};
                          byte target[] = {255, 255, 255, 255};
                          byte save[] = {0, 0, 0, 0};
                          byte temp[] = {0, 0, 0, 0};
                          float delta[] = {0.0, 0.0, 0.0, 0.0};
                          char rgbwstring[] = "000000ff";
                          int on_off_status = 0;
                          int dimmerlevel = 100;
                          int prgspeed = 20;
                          unsigned long last_update = 0;
                          unsigned long tick_length = 5;
                          int fade_step = 0;
                          int program_timer;
                          int program_cycle;
                          int program_step;
                          // Make sure these are PWM pins
                          #define REDPIN 6
                          #define GREENPIN 5
                          #define BLUEPIN 3
                          #define WHITEPIN 9
                          #define LIGHT_NORMAL 0
                          #define LIGHT_FADING 1
                          #define PROGRAM_NOP 0
                          int light_mode = LIGHT_NORMAL;
                          int program_mode = PROGRAM_NOP;
                          #define SET 0
                          #define SET_AND_WAIT 1
                          #define SET_RANDOM 2
                          #define SET_RANDOM_AND_WAIT 3
                          #define FADE 4
                          #define FADE_RANDOM 5
                          #define WAIT 6
                          typedef struct rgb_cmd {
                            byte cmd;
                            int p;
                            byte rgbw[4];
                          } rgb_cmd;
                          rgb_cmd program_ALARM[] = {
                            {SET_AND_WAIT, 25, {255, 255, 255, 0}},
                            {SET_AND_WAIT, 25, {0, 0, 0, 0}},
                            {SET_AND_WAIT, 25, {0, 0, 0, 255}},
                          rgb_cmd program_RELAX[] = {
                            {FADE, 1000, {255, 32, 0, 0}},
                            {FADE, 1000, {255, 32, 16, 0}},
                            {FADE, 1000, {255, 16, 32, 0}},
                            {FADE, 1000, {255, 128, 0, 0}},
                            {FADE, 1000, {255, 32, 32, 0}},
                            {FADE, 1000, {255, 0, 32, 0}}
                          rgb_cmd program_PARTY[] = {
                            {SET_AND_WAIT, 10, {255, 0, 0, 0}},
                            {SET_AND_WAIT, 10, {0, 0, 0, 255}},
                            {SET_AND_WAIT, 10, {255, 0, 0,0}},
                            {FADE_RANDOM, 50, {255, 255, 255, 0}},
                            {SET_AND_WAIT, 50, {0, 0, 255, 0}},
                            {SET_AND_WAIT, 50, {0, 255, 255 ,0}},
                            {SET_AND_WAIT, 50, {255, 255, 0, 0}},
                            {SET_AND_WAIT, 50, {0, 255, 0, 0}},
                          rgb_cmd* programs[] = {
                            &program_ALARM[0], &program_RELAX[0], &program_PARTY[0]
                          const int program_steps[] = {
                            sizeof(program_ALARM)/sizeof(rgb_cmd),
                            7,
                            22
                            // Fix the PWM timer. Without this the LEDs will flicker.
                            TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00);
                            // Output pins
                            pinMode(REDPIN, OUTPUT);
                            pinMode(GREENPIN, OUTPUT);
                            pinMode(BLUEPIN, OUTPUT);
                            pinMode(WHITEPIN, OUTPUT);
                          	sendSketchInfo(SN, SV);
                          	present(CHILD_ID_LIGHT, S_RGBW_LIGHT);
                          void selftest() {
                            on_off_status = 1;
                            current[RR] = 255;
                            current[GG] = 0;
                            current[BB] = 0;
                            current[WW] = 0;
                            set_hw_status();
                            wait(200);
                            current[RR] = 0;
                            current[GG] = 255;
                            set_hw_status();
                            wait(200);
                            current[GG] = 0;
                            current[BB] = 255;
                            set_hw_status();
                            wait(200);
                            current[BB] = 0;
                            current[WW] = 255;
                            set_hw_status();
                            wait(200);
                            current[RR] = 0;
                            current[GG] = 0;
                            current[BB] = 0;
                            set_hw_status();
                            wait(200);
                            on_off_status = 0;
                            static bool first_message_sent = false;
                            if ( first_message_sent == false ) {
                              selftest();
                              set_hw_status();
                              send(rgbwMsg.set(rgbwstring));
                              send(lightMsg.set(on_off_status));
                              send(dimmerMsg.set(dimmerlevel));
                              send(prgspeedMsg.set(prgspeed));
                              send(programMsg.set(program_mode));
                              first_message_sent = true;
                            unsigned long now = millis();
                            // Maybe we wrapped around? Then reset last_update to 0.
                            if (now < last_update) {
                              last_update = 0;
                            if (now - last_update > tick_length) {
                              last_update = now;
                              // If we're fading, finish that before we do anything else
                              if (light_mode == LIGHT_FADING) {
                                calc_fade();
                                if (program_mode > PROGRAM_NOP) {
                                  handle_program();
                            set_hw_status();
                            int val;
                          	if (message.type == V_RGBW) {
                              for (int i=0; i<=3; i++) {
                                temp[i] = hextoint(message.data[i*2]) * 16 + hextoint(message.data[i*2+1]);
                              // Save old value
                              strcpy(rgbwstring, message.data);
                              init_fade(prgspeed, temp);
                          	} else if (message.type == V_LIGHT || message.type == V_STATUS) {
                              val = atoi(message.data);
                              if (val == 0 or val == 1) {
                                on_off_status = val;
                            } else if (message.type == V_PERCENTAGE) {
                              if (val >= 0 and val <=100) {
                                dimmerlevel = val;
                            } else if (message.type == V_VAR1 ) {
                              if (val >= 0 and val <= 2000) {
                                prgspeed = val;
                                send(prgspeedMsg.set(val));
                            } else if (message.type == V_VAR2 ) {
                              if (val == PROGRAM_NOP) {
                                stop_program();
                                send(programMsg.set(val));
                                init_program(val);
                          		return;
                          void execute_step(rgb_cmd cmd) {
                            if (cmd.cmd == SET) {
                              set_rgb(cmd.rgbw);
                            } else if (cmd.cmd == SET_AND_WAIT) {
                              set_rgb(cmd.rgbw);
                              program_timer = cmd.p;
                            } else if (cmd.cmd == SET_RANDOM) {
                              set_rgb_random(cmd.rgbw);
                            } else if (cmd.cmd == SET_RANDOM_AND_WAIT) {
                            } else if (cmd.cmd == FADE) {
                              init_fade(cmd.p, cmd.rgbw);
                            } else if (cmd.cmd == FADE_RANDOM) {
                              init_fade_random(cmd.p, cmd.rgbw);
                            } else if (cmd.cmd == WAIT) {
                          void init_program(int program) {
                            program_mode = program;
                            program_step = 0;
                            program_timer = 0;
                            save_state();
                            execute_step(programs[program_mode-1][0]);
                          void handle_program() {
                            if (program_timer > 0) {
                              program_timer--;
                            if (program_timer == 0) {
                              program_step++;
                              if (program_step == program_steps[program_mode-1]) {
                                program_step = 0;
                              execute_step(programs[program_mode-1][program_step]);
                          void stop_program() {
                            restore_state();
                          void save_state() {
                            memcpy(save, current, 4 );
                          void restore_state() {
                            memcpy(current, save, 4 );
                          void set_rgb (byte rgbw[]) {
                            memcpy(current, rgbw, 4);
                          void set_rgb_random (byte rgbw[]) {
                            for (int i=0; i <= 3; i++){
                              current[i] = random(rgbw[i]);
                          void init_fade(int t, byte rgbw[]) {
                            fade_step = t;
                            memcpy(target, rgbw, 4);
                              delta[i] = (target[i] - current[i]) / float(fade_step);
                          void init_fade_random(int t, byte rgbw[]) {
                            fade_step = t;
                              target[i] = random(rgbw[i]);
                          void calc_fade() {
                            if (fade_step > 0) {
                              fade_step--;
                               current[i] = target[i] - delta[i] * fade_step;
                          void set_hw_status() {
                            analogWrite(REDPIN, on_off_status * (int)(current[RR] * dimmerlevel/100.0));
                            analogWrite(GREENPIN, on_off_status * (int)(current[GG] * dimmerlevel/100.0));
                            analogWrite(BLUEPIN, on_off_status * (int)(current[BB] * dimmerlevel/100.0));
                            analogWrite(WHITEPIN, on_off_status * (int)(current[WW] * dimmerlevel/100.0));
                          byte hextoint (byte c) {
                             if ((c >= '0') && (c <= '9')) return c - '0';
                             if ((c >= 'A') && (c <= 'F')) return c - 'A' + 10;
                             if ((c >= 'a') && (c <= 'f')) return c - 'a' + 10;
                             return 0;
                          mfalkviddM Y vladimirV 3 Replies Last reply
                          • maghacM maghac
                             * 1.0
                             * 1.1
                             * 1.2
                             *   OTA support
                             * 1.3
                             * 1.4
                             *   Bug fix
                             * 1.5
                             * 1.6
                             *   Repeater feature
                             * 1.7
                             * 1.8
                            #define SV "1.8"
                            #define RR 0
                            #define GG 1
                            #define BB 2
                            #define WW 3
                            int prgspeed = 20;
                            int fade_step = 0;
                            int program_timer;
                            int program_cycle;
                            int program_step;
                            #define REDPIN 6
                            #define GREENPIN 5
                            #define BLUEPIN 3
                            #define WHITEPIN 9
                            #define SET 0
                            #define FADE 4
                            #define WAIT 6
                              byte cmd;
                              int p;
                              byte rgbw[4];
                            } rgb_cmd;
                              7,
                              22
                              // Output pins
                            void selftest() {
                              on_off_status = 1;
                              current[RR] = 255;
                              current[GG] = 0;
                              current[BB] = 0;
                              current[WW] = 0;
                              set_hw_status();
                              wait(200);
                              current[RR] = 0;
                              current[GG] = 255;
                              set_hw_status();
                              wait(200);
                              current[GG] = 0;
                              current[BB] = 255;
                              set_hw_status();
                              wait(200);
                              current[BB] = 0;
                              current[WW] = 255;
                              set_hw_status();
                              wait(200);
                              current[RR] = 0;
                              current[GG] = 0;
                              current[BB] = 0;
                              set_hw_status();
                              wait(200);
                              on_off_status = 0;
                                selftest();
                                set_hw_status();
                                last_update = 0;
                                last_update = now;
                                  calc_fade();
                                    handle_program();
                              set_hw_status();
                              int val;
                                // Save old value
                                  dimmerlevel = val;
                                  prgspeed = val;
                                  stop_program();
                                  init_program(val);
                            		return;
                                set_rgb(cmd.rgbw);
                                set_rgb(cmd.rgbw);
                              program_step = 0;
                              program_timer = 0;
                              save_state();
                                program_timer--;
                                program_step++;
                                  program_step = 0;
                              restore_state();
                            void save_state() {
                              fade_step = t;
                              fade_step = t;
                            void calc_fade() {
                                fade_step--;
                               return 0;
                            #48
                            @maghac I have used the rgbww (warm white) version. Have not compared it with the normal version, but ww is supposed to give a more pleasant tone. By mixing in a lot of red, some green and very little blue I was able to match our existing halogen bulbs very close to 100%.
                            https://www.openhardware.io/view/122/Dimmable-LED-kitchen-light-Arduino-APDS-9960-RGBWW-led
                            • bgunnarbB
                              bgunnarbB
                              bgunnarb
                              @maghac I have implemented your 1.8 and I am impressed with the good structure and the performance of your code! Kudos!
                              • D
                                dmonty
                                Just finished a similar project using WS2812B.
                                • MySensors/Domoticz support.
                                • Infrared Remote support (common 44 key color picker)
                                • Color change & fade animations ++.
                                https://github.com/dmonty2/ir_remote_leds/tree/mysensors
                                  maghacM
                                  maghacM
                                  maghac
                                  @bgunnarb said in RGB LED strip:
                                  Thanks! Let me know if you have any problems with it - I am still facing some issues actually. After some time (a couple of days or so), the LED strip does not respond to on/off commands any longer. I've implemented a debug feature to try to diagnose the cause of it (I send the node a V_TEXT message and it responds with a series of V_TEXT messages containing the values of variables).
                                  bgunnarbB 1 Reply Last reply
                                  • D dmonty
                                    maghacM
                                    maghacM
                                    maghac
                                    @dmonty said in RGB LED strip:
                                    Cool. I've played with WS2812B and FastLed in another project. But I'm not sure if they are good enough for general illumination though?
                                    D 1 Reply Last reply
                                    • maghacM maghac
                                      bgunnarbB
                                      bgunnarbB
                                      bgunnarb
                                      @maghac
                                      No, I have not experienced loss of response like that. At least not since I upgraded my GW to 2.2.0.
                                      One thing happened though: I was testing the relax, alarm and party modes several times. After that, when fading from one colour to the next in normal mode, it looked like the program first wanted to fade through a number of colours before reaching the final value. This happened a few times and after that it became unresponsive. Cycling power made it go back to normal. I have not been able to repeat the behaviour.
                                      • maghacM maghac
                                        dmonty
                                        wrote on last edited by dmonty
                                        #54
                                        @maghac
                                        Yes, the WS2812B are most definitely accent-style lighting with beautiful animations.
                                        The code also drives a relay switch to turn on my larger light. It shows up in Domoticz as two lights.
                                        • ikkeTI
                                          ikkeTI
                                          ikkeT
                                          Thanks a lot for sharing this! I already did the Arduino and MySensors stuff, and started thinking of writing program for it. I'm glad I found this, it fit exactly what I was doing. Here's your code a bit modified, and added some different kind of lamps for the next one looking for references: https://github.com/ikke-t/Arduino-RGB-leds-and-lightbulbs/blob/master/README.md
                                          The additional piece here is how to command this from OpenHAB, as that's my controller. One needs to modify the RGB info via rules, it's there for reference:
                                          https://github.com/ikke-t/Arduino-RGB-leds-and-lightbulbs/raw/master/src/rgb.rules
                                          There are links within that file to references for how to create similar rules for RGB mangling.
