  3. RGB LED strip
RGB LED strip
70 Posts 22 Posters 44.1k Views 27 Watching
  • T
    Tinnyt
    Geat Work
    • C
      C
      chorob
      Great project! I could use some help getting this to work. I am using the newbie PCB, just a regular RGB LED for testing and Homeassistant as my controller. Hass adopts the node but I get this error message everytime I restart the node and the switch does not appear on my frontend.
      "Not a valid message: Not valid message sub-type: 40 for dictionary value @ data['sub_type']"
      I am running '2.0' in my hass config file. I have tried '2.1.' and '2.1.1' with no success. Homeassistant version .60.
      I have several temperature sensor nodes talking to hass just fine. Any ideas? I assume I am just missing something simple as I am relatively new to homeassistant and mysensors.
      Thank you in advance for your help!
      • maghacM maghac
        @moskovskiy82 I'll see if I'll have time to work on it this week, I'll post an update when I have something.
        maghacM
        maghacM
        maghac
        Well, it took some time, but here is v1.8 at last!
        I have modified the code to handle RGBW strips, since I realized that the white light from RGB strips is very uncomfortable and not really suitable for general illumination. It should be fairly easy to convert it back to RGB though. Adding the W channel means that I now need 4 PWM pins, and therefore it was necessary to redefine one of the pins that the radio is connected to - the sketch now expects CE to be connected to pin 8 instead of 9 which is the default (a pro mini only has 3 free PWM pins if you use the default setup).
        I've also completely changed now programs/modes are implemented so it should be easier to add new programs. Feel free to experiment with this and let me know what you think.
         * LED STRIP sketch for Mysensors
         * 1.0
         *   Based on the example sketch in mysensors
         * 1.1
         *   prgspeed parameter (send as V_VAR1 message)
         *   HomeAssistant compatible (send status to ack)
         * 1.2
         *   OTA support
         * 1.3
         *   Power-on self test
         * 1.4
         *   Bug fix
         * 1.5
         *   Other default values
         * 1.6
         *   Repeater feature
         * 1.7
         *   Multitasking. Alarm and RELAX modes.
         * 1.8
         *   Reengineered programs/modes logic.
         *   RGBW variant. Requires 4 PWM pins, so we need to move use a different pin for one of radio connections.
        #define MY_OTA_FIRMWARE_FEATURE
        #define MY_NODE_ID AUTO
        // Normally the radio uses pin 9 for CE
        #define MY_RF24_CE_PIN  8
        #define CHILD_ID_LIGHT 1
        #define SN "LED Strip"
        #define SV "1.8"
        MyMessage lightMsg(CHILD_ID_LIGHT, V_LIGHT);
        MyMessage rgbwMsg(CHILD_ID_LIGHT, V_RGBW);
        MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
        MyMessage prgspeedMsg(CHILD_ID_LIGHT, V_VAR1);
        MyMessage programMsg(CHILD_ID_LIGHT, V_VAR2);
        #define RR 0
        #define GG 1
        #define BB 2
        #define WW 3
        byte current[] = {255, 255, 255, 255};
        byte target[] = {255, 255, 255, 255};
        byte save[] = {0, 0, 0, 0};
        byte temp[] = {0, 0, 0, 0};
        float delta[] = {0.0, 0.0, 0.0, 0.0};
        char rgbwstring[] = "000000ff";
        int on_off_status = 0;
        int dimmerlevel = 100;
        int prgspeed = 20;
        unsigned long last_update = 0;
        unsigned long tick_length = 5;
        int fade_step = 0;
        int program_timer;
        int program_cycle;
        int program_step;
        // Make sure these are PWM pins
        #define REDPIN 6
        #define GREENPIN 5
        #define BLUEPIN 3
        #define WHITEPIN 9
        #define LIGHT_NORMAL 0
        #define LIGHT_FADING 1
        #define PROGRAM_NOP 0
        int light_mode = LIGHT_NORMAL;
        int program_mode = PROGRAM_NOP;
        #define SET 0
        #define SET_AND_WAIT 1
        #define SET_RANDOM 2
        #define SET_RANDOM_AND_WAIT 3
        #define FADE 4
        #define FADE_RANDOM 5
        #define WAIT 6
        typedef struct rgb_cmd {
          byte cmd;
          int p;
          byte rgbw[4];
        } rgb_cmd;
        rgb_cmd program_ALARM[] = {
          {SET_AND_WAIT, 25, {255, 255, 255, 0}},
          {SET_AND_WAIT, 25, {0, 0, 0, 0}},
          {SET_AND_WAIT, 25, {0, 0, 0, 255}},
        rgb_cmd program_RELAX[] = {
          {FADE, 1000, {255, 32, 0, 0}},
          {FADE, 1000, {255, 32, 16, 0}},
          {FADE, 1000, {255, 16, 32, 0}},
          {FADE, 1000, {255, 128, 0, 0}},
          {FADE, 1000, {255, 32, 32, 0}},
          {FADE, 1000, {255, 0, 32, 0}}
        rgb_cmd program_PARTY[] = {
          {SET_AND_WAIT, 10, {255, 0, 0, 0}},
          {SET_AND_WAIT, 10, {0, 0, 0, 255}},
          {SET_AND_WAIT, 10, {255, 0, 0,0}},
          {FADE_RANDOM, 50, {255, 255, 255, 0}},
          {SET_AND_WAIT, 50, {0, 0, 255, 0}},
          {SET_AND_WAIT, 50, {0, 255, 255 ,0}},
          {SET_AND_WAIT, 50, {255, 255, 0, 0}},
          {SET_AND_WAIT, 50, {0, 255, 0, 0}},
        rgb_cmd* programs[] = {
          &program_ALARM[0], &program_RELAX[0], &program_PARTY[0]
        const int program_steps[] = {
          sizeof(program_ALARM)/sizeof(rgb_cmd),
          7,
          22
          // Fix the PWM timer. Without this the LEDs will flicker.
          TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00);
          // Output pins
          pinMode(REDPIN, OUTPUT);
          pinMode(GREENPIN, OUTPUT);
          pinMode(BLUEPIN, OUTPUT);
          pinMode(WHITEPIN, OUTPUT);
        	sendSketchInfo(SN, SV);
        	present(CHILD_ID_LIGHT, S_RGBW_LIGHT);
        void selftest() {
          on_off_status = 1;
          current[RR] = 255;
          current[GG] = 0;
          current[BB] = 0;
          current[WW] = 0;
          set_hw_status();
          wait(200);
          current[RR] = 0;
          current[GG] = 255;
          set_hw_status();
          wait(200);
          current[GG] = 0;
          current[BB] = 255;
          set_hw_status();
          wait(200);
          current[BB] = 0;
          current[WW] = 255;
          set_hw_status();
          wait(200);
          current[RR] = 0;
          current[GG] = 0;
          current[BB] = 0;
          set_hw_status();
          wait(200);
          on_off_status = 0;
          static bool first_message_sent = false;
          if ( first_message_sent == false ) {
            selftest();
            set_hw_status();
            send(rgbwMsg.set(rgbwstring));
            send(lightMsg.set(on_off_status));
            send(dimmerMsg.set(dimmerlevel));
            send(prgspeedMsg.set(prgspeed));
            send(programMsg.set(program_mode));
            first_message_sent = true;
          unsigned long now = millis();
          // Maybe we wrapped around? Then reset last_update to 0.
          if (now < last_update) {
            last_update = 0;
          if (now - last_update > tick_length) {
            last_update = now;
            // If we're fading, finish that before we do anything else
            if (light_mode == LIGHT_FADING) {
              calc_fade();
              if (program_mode > PROGRAM_NOP) {
                handle_program();
          set_hw_status();
          int val;
        	if (message.type == V_RGBW) {
            for (int i=0; i<=3; i++) {
              temp[i] = hextoint(message.data[i*2]) * 16 + hextoint(message.data[i*2+1]);
            // Save old value
            strcpy(rgbwstring, message.data);
            init_fade(prgspeed, temp);
        	} else if (message.type == V_LIGHT || message.type == V_STATUS) {
            val = atoi(message.data);
            if (val == 0 or val == 1) {
              on_off_status = val;
          } else if (message.type == V_PERCENTAGE) {
            if (val >= 0 and val <=100) {
              dimmerlevel = val;
          } else if (message.type == V_VAR1 ) {
            if (val >= 0 and val <= 2000) {
              prgspeed = val;
              send(prgspeedMsg.set(val));
          } else if (message.type == V_VAR2 ) {
            if (val == PROGRAM_NOP) {
              stop_program();
              send(programMsg.set(val));
              init_program(val);
        		return;
        void execute_step(rgb_cmd cmd) {
          if (cmd.cmd == SET) {
            set_rgb(cmd.rgbw);
          } else if (cmd.cmd == SET_AND_WAIT) {
            set_rgb(cmd.rgbw);
            program_timer = cmd.p;
          } else if (cmd.cmd == SET_RANDOM) {
            set_rgb_random(cmd.rgbw);
          } else if (cmd.cmd == SET_RANDOM_AND_WAIT) {
          } else if (cmd.cmd == FADE) {
            init_fade(cmd.p, cmd.rgbw);
          } else if (cmd.cmd == FADE_RANDOM) {
            init_fade_random(cmd.p, cmd.rgbw);
          } else if (cmd.cmd == WAIT) {
        void init_program(int program) {
          program_mode = program;
          program_step = 0;
          program_timer = 0;
          save_state();
          execute_step(programs[program_mode-1][0]);
        void handle_program() {
          if (program_timer > 0) {
            program_timer--;
          if (program_timer == 0) {
            program_step++;
            if (program_step == program_steps[program_mode-1]) {
              program_step = 0;
            execute_step(programs[program_mode-1][program_step]);
        void stop_program() {
          restore_state();
        void save_state() {
          memcpy(save, current, 4 );
        void restore_state() {
          memcpy(current, save, 4 );
        void set_rgb (byte rgbw[]) {
          memcpy(current, rgbw, 4);
        void set_rgb_random (byte rgbw[]) {
          for (int i=0; i <= 3; i++){
            current[i] = random(rgbw[i]);
        void init_fade(int t, byte rgbw[]) {
          light_mode = LIGHT_FADING;
          fade_step = t;
          memcpy(target, rgbw, 4);
            delta[i] = (target[i] - current[i]) / float(fade_step);
        void init_fade_random(int t, byte rgbw[]) {
          fade_step = t;
            target[i] = random(rgbw[i]);
        void calc_fade() {
          if (fade_step > 0) {
            fade_step--;
             current[i] = target[i] - delta[i] * fade_step;
        void set_hw_status() {
          analogWrite(REDPIN, on_off_status * (int)(current[RR] * dimmerlevel/100.0));
          analogWrite(GREENPIN, on_off_status * (int)(current[GG] * dimmerlevel/100.0));
          analogWrite(BLUEPIN, on_off_status * (int)(current[BB] * dimmerlevel/100.0));
          analogWrite(WHITEPIN, on_off_status * (int)(current[WW] * dimmerlevel/100.0));
        byte hextoint (byte c) {
           if ((c >= '0') && (c <= '9')) return c - '0';
           if ((c >= 'A') && (c <= 'F')) return c - 'A' + 10;
           if ((c >= 'a') && (c <= 'f')) return c - 'a' + 10;
           return 0;
        mfalkviddM Y vladimirV 3 Replies Last reply
        • maghacM maghac
           * 1.0
           * 1.1
           * 1.2
           *   OTA support
           * 1.3
           * 1.4
           *   Bug fix
           * 1.5
           * 1.6
           *   Repeater feature
           * 1.7
           * 1.8
          #define SV "1.8"
          #define RR 0
          #define GG 1
          #define BB 2
          #define WW 3
          int prgspeed = 20;
          int fade_step = 0;
          int program_timer;
          int program_cycle;
          int program_step;
          #define REDPIN 6
          #define GREENPIN 5
          #define BLUEPIN 3
          #define WHITEPIN 9
          #define SET 0
          #define FADE 4
          #define WAIT 6
            byte cmd;
            int p;
            byte rgbw[4];
          } rgb_cmd;
            7,
            22
            // Output pins
          void selftest() {
            on_off_status = 1;
            current[RR] = 255;
            current[GG] = 0;
            current[BB] = 0;
            current[WW] = 0;
            set_hw_status();
            wait(200);
            current[RR] = 0;
            current[GG] = 255;
            set_hw_status();
            wait(200);
            current[GG] = 0;
            current[BB] = 255;
            set_hw_status();
            wait(200);
            current[BB] = 0;
            current[WW] = 255;
            set_hw_status();
            wait(200);
            current[RR] = 0;
            current[GG] = 0;
            current[BB] = 0;
            set_hw_status();
            wait(200);
            on_off_status = 0;
              selftest();
              set_hw_status();
              last_update = 0;
              last_update = now;
                calc_fade();
                  handle_program();
            set_hw_status();
            int val;
              // Save old value
                dimmerlevel = val;
                prgspeed = val;
                stop_program();
                init_program(val);
          		return;
              set_rgb(cmd.rgbw);
              set_rgb(cmd.rgbw);
            program_step = 0;
            program_timer = 0;
            save_state();
              program_timer--;
              program_step++;
                program_step = 0;
            restore_state();
          void save_state() {
            fade_step = t;
            fade_step = t;
          void calc_fade() {
              fade_step--;
             return 0;
          #48
          @maghac I have used the rgbww (warm white) version. Have not compared it with the normal version, but ww is supposed to give a more pleasant tone. By mixing in a lot of red, some green and very little blue I was able to match our existing halogen bulbs very close to 100%.
          https://www.openhardware.io/view/122/Dimmable-LED-kitchen-light-Arduino-APDS-9960-RGBWW-led
          • bgunnarbB
            bgunnarbB
            bgunnarb
            @maghac I have implemented your 1.8 and I am impressed with the good structure and the performance of your code! Kudos!
            I have never been so busy since I retired!
            maghacM 1 Reply Last reply
            • D
              dmonty
              Just finished a similar project using WS2812B.
              • MySensors/Domoticz support.
              • Infrared Remote support (common 44 key color picker)
              • Color change & fade animations ++.
              https://github.com/dmonty2/ir_remote_leds/tree/mysensors
              • bgunnarbB bgunnarb
                maghacM
                maghacM
                maghac
                @bgunnarb said in RGB LED strip:
                Thanks! Let me know if you have any problems with it - I am still facing some issues actually. After some time (a couple of days or so), the LED strip does not respond to on/off commands any longer. I've implemented a debug feature to try to diagnose the cause of it (I send the node a V_TEXT message and it responds with a series of V_TEXT messages containing the values of variables).
                bgunnarbB 1 Reply Last reply
                • D dmonty
                  maghacM
                  maghacM
                  maghac
                  @dmonty said in RGB LED strip:
                  Cool. I've played with WS2812B and FastLed in another project. But I'm not sure if they are good enough for general illumination though?
                  D 1 Reply Last reply
                  • maghacM maghac
                    bgunnarbB
                    bgunnarbB
                    bgunnarb
                    @maghac
                    No, I have not experienced loss of response like that. At least not since I upgraded my GW to 2.2.0.
                    One thing happened though: I was testing the relax, alarm and party modes several times. After that, when fading from one colour to the next in normal mode, it looked like the program first wanted to fade through a number of colours before reaching the final value. This happened a few times and after that it became unresponsive. Cycling power made it go back to normal. I have not been able to repeat the behaviour.
                    • maghacM maghac
                      dmonty
                      wrote on last edited by dmonty
                      #54
                      @maghac
                      Yes, the WS2812B are most definitely accent-style lighting with beautiful animations.
                      The code also drives a relay switch to turn on my larger light. It shows up in Domoticz as two lights.
                      • ikkeTI
                        ikkeTI
                        ikkeT
                        Thanks a lot for sharing this! I already did the Arduino and MySensors stuff, and started thinking of writing program for it. I'm glad I found this, it fit exactly what I was doing. Here's your code a bit modified, and added some different kind of lamps for the next one looking for references: https://github.com/ikke-t/Arduino-RGB-leds-and-lightbulbs/blob/master/README.md
                        The additional piece here is how to command this from OpenHAB, as that's my controller. One needs to modify the RGB info via rules, it's there for reference:
                        https://github.com/ikke-t/Arduino-RGB-leds-and-lightbulbs/raw/master/src/rgb.rules
                        There are links within that file to references for how to create similar rules for RGB mangling.
                        • maghacM maghac
                           * 1.0
                           * 1.1
                           * 1.2
                           *   OTA support
                           * 1.3
                           * 1.4
                           *   Bug fix
                           * 1.5
                           * 1.6
                           *   Repeater feature
                           * 1.7
                           * 1.8
                          #define SV "1.8"
                          #define RR 0
                          #define GG 1
                          #define BB 2
                          #define WW 3
                          int prgspeed = 20;
                          int fade_step = 0;
                          int program_timer;
                          int program_cycle;
                          int program_step;
                          #define REDPIN 6
                          #define GREENPIN 5
                          #define BLUEPIN 3
                          #define WHITEPIN 9
                          #define SET 0
                          #define FADE 4
                          #define WAIT 6
                            byte cmd;
                            int p;
                            byte rgbw[4];
                          } rgb_cmd;
                            7,
                            22
                            // Output pins
                          void selftest() {
                            on_off_status = 1;
                            current[RR] = 255;
                            current[GG] = 0;
                            current[BB] = 0;
                            current[WW] = 0;
                            set_hw_status();
                            wait(200);
                            current[RR] = 0;
                            current[GG] = 255;
                            set_hw_status();
                            wait(200);
                            current[GG] = 0;
                            current[BB] = 255;
                            set_hw_status();
                            wait(200);
                            current[BB] = 0;
                            current[WW] = 255;
                            set_hw_status();
                            wait(200);
                            current[RR] = 0;
                            current[GG] = 0;
                            current[BB] = 0;
                            set_hw_status();
                            wait(200);
                            on_off_status = 0;
                              selftest();
                              set_hw_status();
                              last_update = 0;
                              last_update = now;
                                calc_fade();
                                  handle_program();
                            set_hw_status();
                            int val;
                              // Save old value
                                dimmerlevel = val;
                                prgspeed = val;
                                stop_program();
                                init_program(val);
                          		return;
                              set_rgb(cmd.rgbw);
                              set_rgb(cmd.rgbw);
                            program_step = 0;
                            program_timer = 0;
                            save_state();
                              program_timer--;
                              program_step++;
                                program_step = 0;
                            restore_state();
                          void save_state() {
                            fade_step = t;
                            fade_step = t;
                          void calc_fade() {
                              fade_step--;
                             return 0;
                          Y
                          Y
                          yoshida
                          @maghac A friend just showed me your 1.8 version sketch, and for me so far this is the best working sketch even though I have one issue under Domoticz. (setup: raspberry with mysensors 2 serial gateway, node is arduino pro mini, and 4 mosfet, right now only on breadborad. )
                          So I can't control the white and the RGB leds independently. If I adjust the brightness for the W-led, like raise up, the RGB leds will lower their brightness in the same ammount. Same for the RGB, if I raise up the RGB brightness, the W led lowers itself.
                          Also the turn on/off seems to be strange if I want to turn on/off the RGB and W independently.
                          Are these features, or bugs width Domoticz? :)
                          I assumed that I will be able to control independently the W and the RGB channel, in domoticz I have two device, one RGB light device, and one White lamp device.
                          Can you please help, if all ok with this behaviour, or something needs to be adjusted for Domoticz in the sketch?
                          Yoshi
                          • maghacM
                            maghacM
                            maghac
                            yes, W is just another channel and it works the same way as the RGB channels. There is one single on/off and dimmer amount for all 4 channels. In Home Assistant this works as expected - there is one single unit which has a color selector for RGB values and a slider for the W value.
                            Not sure why Domoticz shows it as two separate units - perhaps you can check if there is an option to modify this behaviour?
                            • vladimirV
                              vladimirV
                              vladimir
                              wrote on last edited by vladimir
                              #58
                              Hello everybody! The connected LED strip lights up, but for some reason the Atmega chip heats up very quickly and strongly. Has anyone come across this?
                              My connection scheme:
                              • vladimirV vladimir
                                sundberg84S
                                sundberg84S
                                @vladimir - why inputing 5v to RAW? This pin can handle 6-12v only. Try inputing the 5v output from LM2940CT-5 to VCC instead.
                                vladimirV 1 Reply Last reply
                                • sundberg84S sundberg84
                                  vladimirV
                                  vladimirV
                                  vladimir
                                  #60
                                  @sundberg84 I have version 3.3B. I always thought that this is the correct power connection if the source voltage is more than 3.3 V. And with this power connection I wanted to avoid using a separate voltage regulator for the radio module. If I feed 5V to the VCC input, will there be a logic signal on the terminals 3.3V or 5V? And will not this be detrimental to the controller?
                                    sundberg84S
                                    sundberg84S
                                    #61
                                    @vladimir - ah sorry, my misstake. Didnt see the 3.3v there.
                                    Strange your chip is getting hot... is there some solder-bridge that shorts something? A bad capacitor? Can you measure resistance between VCC and GND?
                                      vladimirV
                                      vladimirV
                                      vladimir
                                      #62
                                      @sundberg84 said in RGB LED strip:
                                      I completely rebuilt the whole scheme, I used the new components. This time I used Arduino Nano. Connect power to terminal 5V. The situation is repeated again, the microcontroller becomes very hot. But only when the light is on.
                                      Honestly, I never measured the resistance. I hope everything was done right.
                                        sundberg84S
                                        sundberg84S
                                        #63
                                        @vladimir not sure about this. Make sure you connected the digital pins to the gate (left pin on irlz44). I don't know why the IC should get hot unless you draw alot of current.
                                          vladimirV
                                          vladimirV
                                          vladimir
                                          @sundberg84 Sorry... I incorrectly connected IRLZ44.:man-facepalming: :smile: But last time they were connected correctly. Now everything works well. Only LM2940 slightly heats up, according to my subjective sensations, up to 60-70 degrees. This is normal?
                                          I am very grateful for your help!:raised_hands:
