1.1k Posts 105 Posters 795.9k Views 98 Watching
  • sinczeS sincze
    @dakipro we use kodi on al lgl tvs. The libreelec TV box has cec and can turn on the TV via hdmi. If TV is on I am able to control the volume via the LG webserver. Kodi (api) can display the notifications for Me :). Not that fancy but it works like a charm.
    bjacobseB
    bjacobseB
    bjacobse
    @sincze
    If it works like a charm - it's fancy ;-)
    • sundberg84S
      sundberg84S
      Back to topic! Last night I made some changes to my ATX Power supply because the variable settings was to sensitive:
      0_1511953574080_upload-c7feca62-d22d-435e-9c73-9599ca0c9044
      0_1511953586756_upload-3bb65a38-91b8-4dc8-9dd7-3a0af6fd45f9
      • sundberg84S sundberg84
        zboblamontZ
        zboblamontZ
        zboblamont
        @sundberg84 Did you find that taking the cover off improved the accuracy at all ?
        :laughing:
        • maghacM
          maghacM
          maghac
          I built a lithophane lamp for my grandson. The electronics is basically only a pro mini and 36 neopixels. Sadly this version is not mysensorized but maybe I'll do that in version 2 :)
          • maghacM maghac
            #133
            @maghac Cool. How were you able to convert the photos into that embossed material (or whatever it is)? Is that a CNC process, or something else? It seems to have very good resolution.
              I have seen a video where you can convert your pictures and print them using a 3D printer
              maghacM 1 Reply Last reply
                maghacM
                maghacM
                maghac
                @gohan said in What did you build today (Pictures) ?:
                Correct, these are 3D printed lithophanes (https://en.wikipedia.org/wiki/Lithophane). I used http://3dp.rocks/lithophane/ to convert jpg files to STL files for printing.
                • Nca78N
                  wrote on last edited by Nca78
                  #136
                  After failing to assemble a completely functional version of my new livolo switch board, I assembled a first prototype of my new "22" sensor board. Unfortunately I didn't receive the sensors yet so it only has a switch, a hall sensor for door and a led, but that's enough for the first testing.
                  Board is made to cut headers when it will be finished, but meanwhile I can use the headers to make it a breakout board for the nrf51 module or for each of the sensors.
                    #137
                    @Nca78 nice :+1: it looks like familiar to me, i don't know why ;) I agree with you, I prefer rounded square shape as it fits more easily everywhere than circles
                    Nca78N 1 Reply Last reply
                      #138
                      :+1: Have you settled yet on what kind of connector you're going to use on future boards?
                      • scalzS scalz
                        #139
                        @scalz said in What did you build today (Pictures) ?:
                        Not sure which one you're talking about, as it's some kind of child between @NeverDie 's board (same nrf51 module and small size) and your aeos (shape, on board sensors). But it's more like a challenge to me, make the smallest board possible (22*22mm) with as many sensors as possible (at the moment, door, TH, light, accelerometer) and I have a bit of margin to add more like the leak detection from @NeverDie it's really nice to be able to do it with such a tiny sensor.
                        I'll do a more complete and flexible 33 board later, I will try to make it some kind of a hand-solderable version of aeos ;)
                          #140
                          As far as minimizing size goes, I think you're right: square (or some kind of rectangle) is going to be better. I end up throwing away a lot of useable space going from square to circle, which, unfortunately, forced me into increasing the diameter (i.e. the size). So, in the end, square/rectangular is probably better. :) I think the allure of the circle is to try to fit the whole thing perfectly onto a coincell (which acts as a kind of limit on how small you can ultimately go), but unfortunately that can't happen with any of the coincell holders I've seen so far....
                            #141
                            @Nca78
                            It was just a private joke :) If I inspire some people, then I'm glad! Because like you said, aeos is different (better mcu, more ios&sensors, and latest unpublished revision is..more generous).
                            But, if you're trying to make a "aeos" (same sensors for instance) in future, then i don't get the point..why reinventing the wheel? Your board has qfn/dfn footprints too, so I don't see how it's easier to handsolder.
                            If this is related to Ic's price, there are lot of different ways to get them cheaper.
                            You should maybe use stencils (maybe you already do it) that will save your day ;)
                            Keep the good work
                            @NeverDie yep, agree with you
                            NeverDieN Nca78N 2 Replies Last reply
                            • scalzS scalz
                              @Nca78
                              Keep the good work
                              #142
                              @scalz We're not going to get much software being written (such as, for instance, an OTA booloader that we can all use or cool self-destructing crypto wizardy) until there's worthwhile nRF5 hardware available, so anything you can do to speed up the release of your designs would really help. I've been trying to Johnny Appleseed this, without getting much apparent traction on people adopting it. People seem to like your stuff, which looks very professional. If you can, try to make it available so people can start writing software, integrating it, etc. As the saying goes, a rising tide lifts all boats. :)
                              gohanG 1 Reply Last reply
                                @NeverDie said in What did you build today (Pictures) ?:
                                What have you been trying to do? 😅
                                  #144
                                  I posted a lot of nRF5 PCB's hoping that others would find some appealing and jump on the nRF5 bandwagon, but so far not much seems to have happened. Aside from some helpful feedback/suggestions from @nca78, I'm not really any better off than if I hadn't bothered. I'm not sure what motivates other PCB posters, but the feedback/suggestions have been the only real payoff for me. Unfortunately, most PCB postings have garnered zero, even if there appear to have been a lot of downloads.
                                    @NeverDie @scalz To get the nRF5 series adopted by MySensors and its users I think we should start with a single board. We have to make sure it is easy to obtain/replicate (by using a ready available module, or using a hardware partner where people can just order the board) and supply the required getting started docs.
                                    I really appreciate all the work done on the nRF5 support, but now we have to take the leap from prototype to 'production' to get it adopted by the community.
                                    • YveauxY Yveaux
                                      @Yveaux agreed
                                      @NeverDie don't let you down, not everybody knows how to design PCBs or provide suggestions in that matter.
                                        @Yveaux agreed
                                        #147
                                        @Yveaux said in What did you build today (Pictures) ?:
                                        I think that's a good idea. A standardized reference platform would really help in building some forward momentum. How about you start a thread saying exactly what it is that you'd want the board to be like, and maybe it will gather some consensus and someone will make it. Like I say, I've launched numerous trial balloons, and it's just not an efficient way to get there from here. My guess is it will be some kind of multi-sensor board, maybe even the same as what @scalz and/or @nca78 are already doing.
                                        • scalzS scalz
                                          @Nca78
                                          Keep the good work
                                          @Nca78
                                          Bigger board won't have those QFN and LGA footprints of course ;)
                                          As you say I don't want to reinvent the wheel, especially one that'll look square compared to yours :D
                                          But I think it's important we still have a DIY option available for those who don't like soldering LGA or 0402, an equivalent of using the pro mini for the nrf5 world.
