  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 1.9m Views 44 Watching
  • T
    Toyman
    Need your help, guys. I am trying to reprogram a smart socket based on nrf51 module. The schematic is:
    I successfully did it using conventional BT Arduino core (Sandeep's) and I was able to switch the relay on/off.
    However, when I tried to use Mysensors ESB5 implementation, the relay just switches On briefly and then immediately Off.
    I believe this is because the pin doesn't supply enough current for the transistor to saturate (3.3v/1k=3.3ma).
    Questions:
    a ) shall I use hwPinMode(PIN, OUTPUT_S0H1)? if yes,
    b ) why in non-MySensors sketch a simple pinMode(PIN, OUTPUT) worked?
    Does MuSensors implementation overrides Sandeep's definitions so the pin supplies less current?
    • T Toyman
      Questions:
      #1314
      @Toyman I don't know the answers, but section 20.4.1 GPIO Electrical Specification from the datasheet might give you some insight. What I notice from it is that there's quite a spread between the min and max driver current rating, with no real explanation as to why. So, for that reason, if your target currents are higher than the minimum ratings, perhaps you're better off using an nRF5 pin to control a load switch, which in turn should easily handle your desired currents?
        Toyman
        The schematic is given. I just don't understand why it worked with BLE core and why it doesn't with d0016's.
        I always thought Mysensors is an extension of vanilla nrf5 arduino core.
        d00616D 1 Reply Last reply
        • T Toyman
          d00616D
          d00616D
          d00616
          wrote on last edited by d00616
          #1316
          You have to remove the SoftDevice. The EEPROM Emulation, included in MySensors, is incompatible and the radio and RTC interrupt is blocked by the SoftDevice. The system call to disable the SoftDevice is not available in the Arduino port. Here is some example to erase the MCU.
          • d00616D d00616
            Toyman
            @d00616 everything is working EXCEPT relay control.
            So the node is recognized in Domoticz, I can switch it on and off, but the relay just doesn't switch on permanently when I send HIGH to the pin. It switches on and almost immediately off.
            • T Toyman
              d00616D
              d00616D
              d00616
              With the extended output mode, you are on the safe side, but I think this isn't the problem. Maybe domoticz sends the off command or there is something in the sketch logic. Please try to switch on the port outside the MySensors logic like in setup() or by the button.
              Your design has connected a button to P0.00 and an transistor to P0.01. These pins are for the 32kHz clock. Please check, that you have to choosen the RC oscillator as LFCKL source.
                #1319
                I received a battery clip designed to hold two CR2032's in series, but I was surprised to find how much wider it is than a single cell holder:
                Why? And, is that how they all are?
                So, at this point, I either need to increase the PCB diameter again, or else go square and hang this clip diagonally.
                You may ask, why do this at all? One of the reasons is that the AM612 PIR requires a minimum of 2.7v, and a single CR2032 doesn't leave much headroom, especially given the dippy discharge nature of coincells. I figure two CR2032's in series with a voltage regulator should, in theory, manage the issue a lot better. Indeed, with that in mind, I already have PCB's with the pads for a voltage regulator on them, but I didn't expect the battery clip to be so big.
                T 2 Replies Last reply
                  Toyman
                  @neverdie said in nRF5 Bluetooth action!:
                  else go square
                  if you ask me, go this way given the BT module itself is already beyond the circular footprint
                    Toyman
                    @neverdie frankly, I would revive CR2450 idea. 620mah vs 200mah is HUGE difference
                      I did a quick hack for testing purposes:
                      With all this extra space, I could probably add the hall sensor back in. I had taken it out so that I'd have the option of adding an extra LED, plus two pushbuttons.
                        #1323
                        I found a much better 2x battery clip made by Linx. Even though it's through-hole rather than surface mount, its footprint is much smaller. https://www.mouser.com/Search/ProductDetail.aspx?R=BAT-HLD-001-THMvirtualkey66280000virtualkey712-BAT-HLD-001-THM
                        Using it, I don't have to enlarge the diameter or go square. I can keep the same size.
                        • T Toyman
                          #1324
                          @toyman said in nRF5 Bluetooth action!:
                          If I can keep the footprint the same (and I don't see why not), I could attach a 2x battery clip for a 2450, and then you'd have the best of both worlds. I have a hunch that finding such a clip, though, won't be easy.
                          • O
                            O
                            Omemanti
                            wrote on last edited by Omemanti
                            #1325
                            @neverdie
                            maybe check out: https://www.aliexpress.com/item/5pcs-20-0mm-CR2032-2032-Battery-Button-Cell-Holder-Coin-Cell-Retainer-Battery-Holder-Through-hole/32741947070.html?spm=a2g0s.9042311.0.0.E38CWg
                            or if you need 50... :
                            https://www.aliexpress.com/item/50pcs-20-0mm-CR2032-2032-Battery-Button-Cell-Holder-Coin-Cell-Retainer-Battery-Holder-Through-hole/32739802992.html
                            price wise,, i would say, go for the second one ;)
                            • O Omemanti
                              @neverdie
                              #1326
                              @omemanti Thanks.
                              I ordered the Linx from mouser yesterday, though. It uses four smaller pins instead of two larger pins. That actually helps keep the footprint small. Also, Linx has practically identical holders for holding a single CR2032 versus holding two CR2032's. That means I can use a single PCB board and decide which configuration I want. The mouser price is quite reasonable (about 25 cents each).
                              I did try looking for a holder that can hold two CR2450's in series, but I didn't find any.
                                #1327
                                I received the Linx parts today. I like them more than any other battery holders I've yet seen, because they elevate the sides just a smidge, which eliminates any risk of short-circuiting to nearby through-holes. For instance, the ones from Aliexpress (linked above by Omemtani) don't do that. Nor do any of the other ones I've tried so far.
                                On Tuesday I should receive PCB's specifically designed to use the Linx holders. I can hardly wait.
                                  I just noticed these small and fairly cheap nRF52 modules on Aliexpress:
                                  https://www.aliexpress.com/item/wholesale-Holyiot-TinyBLE-nRF52832-Bluetooth-low-energy-module-BLE-5-0-for-Bluetooth-mesh/32840369737.html?spm=2114.search0204.3.2.eQaXfB&ws_ab_test=searchweb0_0,searchweb201602_4_10152_10065_5000015_10151_10344_10068_10130_10345_10324_10342_10547_10325_10343_51102_10546_10340_10341_10548_10545_5130015_10541_10084_10083_10307_5690015_10539_5080015_10312_10059_10313_10314_10534_100031_10604_10603_10103_10605_10594_5060015_10596_10142_10107,searchweb201603_14,ppcSwitch_4_ppcChannel&algo_expid=f4f4f444-b2af-44da-9380-676cdca3c65f-0&algo_pvid=f4f4f444-b2af-44da-9380-676cdca3c65f&rmStoreLevelAB=0
                                  But how would one solder it? Is solder paste the only option?
                                  Nca78N 1 Reply Last reply
                                    Here's one for the blooper reel:
                                    I blithely put the photoresistor in one of the vacant leak detection slots. Of course, in retrospect, it's an obvious mistake: too close to the LED. So, when the LED lights, the photoresistor thinks it's suddenly bright out. :laughing:
                                      wrote on last edited by Nca78
                                      #1330
                                      I have bought two to check the range but I don't have very high expectations about that :D
                                      For soldering it should work the same way than with qfn chips:
                                      • put a bit of solder on each pad of the module, then use solder wick to remove excess so it's just lightly tinned
                                      • put a bit of solder on PCB pads
                                      • put chip in place, then heat up with hot air gun
                                      Here as it's a module the hot air might unsolder some components, so using regular iron, flux and a bit oversized pads (so you can heat them up with soldering iron) should do the trick. I will try and tell you the result.
                                      • Nca78N Nca78
                                        Toyman
                                        wrote on last edited by Toyman
                                        #1331
                                        @nca78 "At first I was afraid, I was petrified" :-), but then I relialized that if "recepting" pads are long enough even plain soldering iron will do.
                                        The solder will just flow under the module provided module pads are pretinned Ias you recommended)
                                          I received the PCB's a day early. Unfortunately, it's almost total fiction to say that the Linx holder is designed to hold two CR2032's. Instead, it can hold one CR2032 comfortably, or, with finessing, it can hold two CR2025's. With extreme finessing I did get it to hold two CR2032's, but it will be touch-and-go as to whether the solder joints will hold long-term under the strain. Aside from the small footprint, I'm not happy with it. :(
