  3. 💬 MySensors NRF5 Platform
contest2017nrf52mysensorsnrf5nrf51
210 Posts 20 Posters 88.8k Views 18 Watching
    Curiously, I2c does seem to work on a nRF52 DK using the myboard board definition.
      However, it doesn't seem to be working on the nrf51.
        @d00616 You mentioned that it works only with a particular version of GCC. Does that mean I need to have a particular version of the Arduino IDE installed? I'm currently running the latest version of Windows Arduino IDE, which is 1.8.5.
        d00616D
        d00616D
        d00616
        @neverdie said in 💬 MySensors NRF5 Platform:
        The GCC version is part of the arduino-nrf5 distribution.
        Unfortunately, it does not appear that I2C is working.
        I have I2C and serial running with a NRF52832.
        You can try to remove the compat_pin_mapping line and add the 0.1.0 pin map at this place. Then the board definition is nearly the 0.1.0 version.
        I check the NRF51 board. What do you mean with no working?
        NeverDieN 4 Replies Last reply
          I hope that narrows down the likely cause of the problem. The fact that it's working on the nRF52 gives me some hope it can be made to work on the nRF51.
          • d00616D d00616
            The nRF51 can't find the si7021 device, even though it's connected.
            • d00616D d00616
              Yes, it does seem to work on the nRF52832. Just not presently on the nRF51822.
              d00616D 1 Reply Last reply
              • d00616D d00616
                #133
                I'm running the sparkfun si7021 code. When I run it on the nrf52832, it yields:
                Si7021 Found
                Temp:70.51F, Humidity:40.71%
                which is correct, but when I run it on the nRF51822, the result is:
                No Devices Detected
                Temp:-51.85F, Humidity:-5.81%
                which is incorrect.
                  d00616D
                  d00616D
                  d00616
                  wrote on last edited by d00616
                  #134
                  Can you check, if the device works with the "Generic NRF51822" board? You can edit the variant files in the arduino-nrf5\variants directory.
                  C:\Users...\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.4.0\variants\Generic
                  • d00616D d00616
                    I tried, but I guess I'm not doing it right. I couldn't even get it to blink an LED that way.
                    • d00616D d00616
                      So, I take it you are suggesting that in myboardnrf5.cpp, where it says:
                      #ifdef MYBOARDNRF5
                      #include <variant.h>
                      #include <compat_pin_mapping.h>
                      I replace
                      with what exactly? At this point I'm not even sure where 0.1.0 pin-map is, or even what it's called.
                        #137
                        After I modify the generic variant board definition, is there some trick to making it go "live"?
                          #138
                          there is no trick.. it should work.
                          d00616 said, for a test, to not use his defines, the method that you're used to.
                          So change the defines you need in the generic variant file, then in arduino:
                            I think this must be where the disconnect is happening. Where do I find the files or directory for Generic nRF51? The closest I see is a directory called just "Generic":
                            That's the one I tried modifying:
                            and it had no effect. So, I suspect there must be a different "generic nRF51" somewhere which is closely tied with the menu item you show the picture of. However, I don't see where.
                            Nca78N 1 Reply Last reply
                              @neverdie did you check there ?
                                #141
                                I didn't try that one, but it's a similar dilemma:
                                i.e. Does "Generic" do double duty for both "Generic nRF51" and "Generic nRF52"?
                                  #142
                                  Aha! That did it. Thanks @NCA78. It's working now, including the I2C.
                                  I had to switch nodes though. It's possible that the mysensors code does work, as the node I was testing it on may have had a bad si7021 module on it. I'll post again after I retry with this different node.
                                    #143
                                    I'm back with the results. The same node where I2C works using the customized "Generic nRF51" does not have working I2c if using the mysensors "MyBoardnRF5 nRF51822".
                                    So, I think I've taken this as far as I can. Hopefully this info helps you solve whatever the problem is.
                                    I'm grateful I can keep moving along now using a modified "Generic nRF51822". Thanks everybody! :)
                                      #144
                                      Ashes on my head. The mysensors code is working with I2c after all. I confirmed it on the second (alternate) node. I had switched two of the wires in the myboardnrf5 pinout, but hadn't on the generic nRF51 pinout. Correcting for that, it now works.
                                      What threw me completely off was the defective si7021 module on the first node. Well, now everything is sorted. :)
                                        d00616D
                                        d00616D
                                        d00616
                                        Thank you for reporting this. Great news to hear this.
                                        • d00616D d00616
                                          #146
                                          You're welcome, of course. Though it was a little bit of a wild goose chase, at least your code is now pretty well tested and proven to be "known good," so others can start using it without fear. :)
                                          With this now out of the way, please do continue your excellent work!
