  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
  • E
    E
    executivul
    Unfortunately I can not disclose this secret recipe, all I can tell you is that s some cationic surfactant mixed with some dihydrogen peroxide :sunglasses:
    To be honest I don't know the brand, I've first tried liquid soap undiluted but was to thick and was gathering around the bit like a small tornado and splashing everywhere, decided to add some water and went looking for a spray bottle, found one with some handwriting "car shampoo", it is thicker than plain water, but not as thick as liquid soap, so it might be diluted, I still have some for a few more boards then I'll go by trial and error with dish/hand/car wash and water.
    So much better not to have windows open at 0C(32F) and the vacuum howling. Only the 2.0mm endmill still creates dust, normal engraving and drilling do not.
    Don't forget to mill on acrylic/plastic as mdf will swell if wet.
      #129
      Looks like my CNC2418 is on track to be delivered this Monday. It has already cleared customs.
      So, since it will be arriving well ahead of all the various bits and such, I'm guessing that just a few etching bits will be enough to get me started and confirm whether my machine can route 6 mil isolation.
      The kit itself includes 0.1mm bits (Diameter: 3.175mm tip: 0.1mm length: 30mm).
        It arrived!
        YveauxY andrewA 2 Replies Last reply
          It arrived!
          @neverdie Yay! Where can we find the live stream of the build process? ;-)
            It arrived!
            andrewA
            andrewA
            andrew
            @neverdie so, I expect your first boards tomorrow :)
            • andrewA andrew
              #133
              But wait, I'm still waiting for the magic numbers from you. :) Otherwise, I'll be all dressed with nowhere to go.
              andrewA 1 Reply Last reply
                andrewA
                andrewA
                andrew
                wrote on last edited by andrew
                #134
                @neverdie once the assembly is done, you should adjust the stepper drivers' current limiting as well.
                then, it is always good idea to have the basic settings exported from the board, just in case... you can do it by "$$" command sent from the g code sender gui or directly from the serial terminal.
                currently I use the following settings, the machine might be able to create nice results with higher feed rates, but I did not have enough time to test it and I sticked to the current working config.
                isolation routing with 2001 bits:
                • z cut: -0.05mm
                • feed rate: 200
                you can calculate the V carving bit's tool width for the given milling depth with the following formula:
                tan(bit angle/2) * milling depth * 2 + bit's end width
                for excel formula the bit angle should be provided in radians, so it should look like this
                tan(radians(bit angle/2)) * milling depth * 2 + bit's end width
                edge cut or hole milling with the 0.8mm endmill:
                • feed rate: 170
                • z cut: -1.7mm
                • multi depth, depth/pass: 0.2mm
                drilling:
                • feed rate: 130
                • z cut: -1.8
                the spindle should be 1000 everywhere.
                most probably your board will not have a bootloader, so it will not be possible to update the firmware via usb serial connection (with avrdude), but it is worth to try it. for me it did not work, so I traced back the MCU pins to the pin rows and used ISP to upgrade the firmware to grbl v1.1f (the board will come with 0.9j if I remember correctly). do not forget to export the gerber settings before you upgrade the firmware, as it will loose those, and you have to re-assign the given values again, after the update.
                the ISP pinout (from the pin row's top left corner):
                Reset -> pin 2
                SCK -> pin 3
                MISO -> pin 12
                MOSI -> pin 13
                5v -> pin1
                gnd-> bottom row(!) e.g. pin 1
                NeverDieN rmtuckerR B 4 Replies Last reply
                  #135
                  The assembly instructions came as a file on a mini CD. Attached for anyone who is interested.
                  [0_1513463653125_2418-Assembly instructions - English.doc](Uploading 100%)
                  Hmmm.. I guess the forum only lets me upload photos. Sorry.
                    #136
                    I thought that the ER11 would come pre-installed ("shrink fit" onto the spindle), but it arrived as a separate piece and apparently I'm supposed to attach it by hand. That would seem to be a discrepancy with Jack's store advertises for this device, but, oh well.
                    Also, I was a bit surprised to see that most, and maybe all, of the plastic parts were 3D printed.
                    • andrewA andrew
                      • z cut: -0.05mm
                      • feed rate: 200
                      • feed rate: 170
                      • z cut: -1.7mm
                      drilling:
                      • feed rate: 130
                      • z cut: -1.8
                      Reset -> pin 2
                      SCK -> pin 3
                      MISO -> pin 12
                      MOSI -> pin 13
                      5v -> pin1
                      #137
                      Where are the gerber settings, and how do I export them? Are they in EEPROM, so I just do a complete copy of that? Or does the $$ handle it?
                        I finished putting together the first frame. It was a bit frustrating, because the T-slot nuts they use can come out of the groove, and so to prevent that I had to keep constant tension on it while I tightened it down. I do think most of the T-slot nuts should have been the kind that don't slip out that way.
                          andrewA
                          andrewA
                          andrew
                          firmware settings: it is stored in the EEPROM, but nothing guarantees that the same location will be used for the same parameters in case of different versions, so the output of "$$" command should be saved, this contains everything which you can manually set up if necessary.
                          ER11: take extra care during the installation process to not "harm" the motor's axis. usually the ER11 is pretty tight and howtos mention that the motor should be cooled (by the freezer) and the ER11 should be warmed up before putting them together, to help the mounting process and to prevent unwanted distortion.
                          I put the CNC 2418 assembly guide to my share, for ones it is interesting.
                          NeverDieN 3 Replies Last reply
                          • andrewA andrew
                            • z cut: -0.05mm
                            • feed rate: 200
                            • feed rate: 170
                            • z cut: -1.7mm
                            drilling:
                            • feed rate: 130
                            • z cut: -1.8
                            Reset -> pin 2
                            SCK -> pin 3
                            MISO -> pin 12
                            MOSI -> pin 13
                            5v -> pin1
                            rmtuckerR
                            rmtuckerR
                            rmtucker
                            @andrew
                            1000rpm for the spindle seems very slow,is that number correct?
                            • rmtuckerR rmtucker
                              @andrew
                              andrewA
                              andrewA
                              andrew
                              @rmtucker it is not 1000rpm, but the pwm control for the whole spindle speed range. see the details in the official document.
                              once you use the spindle speed with the value of $30 or above, then the controller will drive the spindle with continuous voltage, without pwm, so it will use its maximum rpm.
                              compared to bigger cncs with bigger spindles (e.g. what you can see from @executivul's video above) , 2418's is not that fast (in rpm), on the other hand it should not be "very slow". can you show a video on that?
                              rmtuckerR 1 Reply Last reply
                              • andrewA andrew
                                rmtuckerR
                                rmtuckerR
                                rmtucker
                                @andrew
                                I see.
                                So what would be your best guess at your actual spindle rpm when cutting under your feed/depth of cut examples given above.?
                                • andrewA andrew
                                  Yes, those are exactly the same instructions I received with my kit too.
                                  • andrewA andrew
                                    #144
                                    @andrew
                                    I tried connecting to the Woodpecker board using the Arduino serial terminal at 115200 baud. It greets me by saying:
                                    Grbl 0.9j ['$' for help]
                                    However, if I send it $ I get no response. If I send it $$, I get no response either.
                                    Is this normal?
                                    How do I send it $$ and get it to respond?
                                      @andrew
                                      Is this normal?
                                      andrewA
                                      andrewA
                                      andrew
                                      @neverdie no, that is not normal, but this is most probably just a communication issue. which software is used for the terminal connection? try to change the cr/lf settings, or the flow control options.
                                        @andrew
                                        I see.
                                        andrewA
                                        andrewA
                                        andrew
                                        @rmtucker I did not measure the max rpm for the given spindle, but I use it on "max" (so spindle setting is 1000) for the given jobs.
                                          #147
                                          Ah, nevermind. I changed the terminal to send it a carriage return, and now it works. Here is the output from asking it $ and $$:
                                          $$ (view Grbl settings)
                                          $# (view # parameters)
                                          $G (view parser state)
                                          $I (view build info)
                                          $N (view startup blocks)
                                          $x=value (save Grbl setting)
                                          $Nx=line (save startup block)
                                          $C (check gcode mode)
                                          $X (kill alarm lock)
                                          $H (run homing cycle)
                                          ~ (cycle start)
                                          ! (feed hold)
                                          ? (current status)
                                          ctrl-x (reset Grbl)
                                          ok
                                          $0=10 (step pulse, usec)
                                          $1=25 (step idle delay, msec)
                                          $6=0 (probe pin invert, bool)
                                          $12=0.002 (arc tolerance, mm)
                                          $13=0 (report inches, bool)
                                          $20=0 (soft limits, bool)
                                          $21=0 (hard limits, bool)
                                          $22=0 (homing cycle, bool)
                                          $100=800.000 (x, step/mm)
                                          $101=800.000 (y, step/mm)
                                          $102=800.000 (z, step/mm)
                                          $110=5000.000 (x max rate, mm/min)
                                          $111=5000.000 (y max rate, mm/min)
                                          $112=800.000 (z max rate, mm/min)
                                          $132=200.000 (z max travel, mm)
                                          ok
