  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    #135
    The assembly instructions came as a file on a mini CD. Attached for anyone who is interested.
    [0_1513463653125_2418-Assembly instructions - English.doc](Uploading 100%)
    Hmmm.. I guess the forum only lets me upload photos. Sorry.
      #136
      I thought that the ER11 would come pre-installed ("shrink fit" onto the spindle), but it arrived as a separate piece and apparently I'm supposed to attach it by hand. That would seem to be a discrepancy with Jack's store advertises for this device, but, oh well.
      Also, I was a bit surprised to see that most, and maybe all, of the plastic parts were 3D printed.
      • andrewA andrew
        @neverdie once the assembly is done, you should adjust the stepper drivers' current limiting as well.
        then, it is always good idea to have the basic settings exported from the board, just in case... you can do it by "$$" command sent from the g code sender gui or directly from the serial terminal.
        currently I use the following settings, the machine might be able to create nice results with higher feed rates, but I did not have enough time to test it and I sticked to the current working config.
        isolation routing with 2001 bits:
        • z cut: -0.05mm
        • feed rate: 200
        you can calculate the V carving bit's tool width for the given milling depth with the following formula:
        tan(bit angle/2) * milling depth * 2 + bit's end width
        for excel formula the bit angle should be provided in radians, so it should look like this
        tan(radians(bit angle/2)) * milling depth * 2 + bit's end width
        edge cut or hole milling with the 0.8mm endmill:
        • feed rate: 170
        • z cut: -1.7mm
        • multi depth, depth/pass: 0.2mm
        drilling:
        • feed rate: 130
        • z cut: -1.8
        the spindle should be 1000 everywhere.
        most probably your board will not have a bootloader, so it will not be possible to update the firmware via usb serial connection (with avrdude), but it is worth to try it. for me it did not work, so I traced back the MCU pins to the pin rows and used ISP to upgrade the firmware to grbl v1.1f (the board will come with 0.9j if I remember correctly). do not forget to export the gerber settings before you upgrade the firmware, as it will loose those, and you have to re-assign the given values again, after the update.
        the ISP pinout (from the pin row's top left corner):
        Reset -> pin 2
        SCK -> pin 3
        MISO -> pin 12
        MOSI -> pin 13
        5v -> pin1
        gnd-> bottom row(!) e.g. pin 1
        #137
        Where are the gerber settings, and how do I export them? Are they in EEPROM, so I just do a complete copy of that? Or does the $$ handle it?
        andrewA 1 Reply Last reply
          I finished putting together the first frame. It was a bit frustrating, because the T-slot nuts they use can come out of the groove, and so to prevent that I had to keep constant tension on it while I tightened it down. I do think most of the T-slot nuts should have been the kind that don't slip out that way.
            andrewA
            andrewA
            andrew
            firmware settings: it is stored in the EEPROM, but nothing guarantees that the same location will be used for the same parameters in case of different versions, so the output of "$$" command should be saved, this contains everything which you can manually set up if necessary.
            ER11: take extra care during the installation process to not "harm" the motor's axis. usually the ER11 is pretty tight and howtos mention that the motor should be cooled (by the freezer) and the ER11 should be warmed up before putting them together, to help the mounting process and to prevent unwanted distortion.
            I put the CNC 2418 assembly guide to my share, for ones it is interesting.
            NeverDieN 3 Replies Last reply
            • andrewA andrew
              • z cut: -0.05mm
              • feed rate: 200
              • feed rate: 170
              • z cut: -1.7mm
              drilling:
              • feed rate: 130
              • z cut: -1.8
              Reset -> pin 2
              SCK -> pin 3
              MISO -> pin 12
              MOSI -> pin 13
              5v -> pin1
              rmtuckerR
              rmtuckerR
              rmtucker
              @andrew
              1000rpm for the spindle seems very slow,is that number correct?
              • rmtuckerR rmtucker
                @andrew
                andrewA
                andrewA
                andrew
                @rmtucker it is not 1000rpm, but the pwm control for the whole spindle speed range. see the details in the official document.
                once you use the spindle speed with the value of $30 or above, then the controller will drive the spindle with continuous voltage, without pwm, so it will use its maximum rpm.
                compared to bigger cncs with bigger spindles (e.g. what you can see from @executivul's video above) , 2418's is not that fast (in rpm), on the other hand it should not be "very slow". can you show a video on that?
                rmtuckerR 1 Reply Last reply
                • andrewA andrew
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  @andrew
                  I see.
                  So what would be your best guess at your actual spindle rpm when cutting under your feed/depth of cut examples given above.?
                  • andrewA andrew
                    Yes, those are exactly the same instructions I received with my kit too.
                    • andrewA andrew
                      #144
                      @andrew
                      I tried connecting to the Woodpecker board using the Arduino serial terminal at 115200 baud. It greets me by saying:
                      Grbl 0.9j ['$' for help]
                      However, if I send it $ I get no response. If I send it $$, I get no response either.
                      Is this normal?
                      How do I send it $$ and get it to respond?
                        @andrew
                        Is this normal?
                        andrewA
                        andrewA
                        andrew
                        @neverdie no, that is not normal, but this is most probably just a communication issue. which software is used for the terminal connection? try to change the cr/lf settings, or the flow control options.
                          @andrew
                          I see.
                          andrewA
                          andrewA
                          andrew
                          @rmtucker I did not measure the max rpm for the given spindle, but I use it on "max" (so spindle setting is 1000) for the given jobs.
                            #147
                            Ah, nevermind. I changed the terminal to send it a carriage return, and now it works. Here is the output from asking it $ and $$:
                            $$ (view Grbl settings)
                            $# (view # parameters)
                            $G (view parser state)
                            $I (view build info)
                            $N (view startup blocks)
                            $x=value (save Grbl setting)
                            $Nx=line (save startup block)
                            $C (check gcode mode)
                            $X (kill alarm lock)
                            $H (run homing cycle)
                            ~ (cycle start)
                            ! (feed hold)
                            ? (current status)
                            ctrl-x (reset Grbl)
                            ok
                            $0=10 (step pulse, usec)
                            $1=25 (step idle delay, msec)
                            $6=0 (probe pin invert, bool)
                            $12=0.002 (arc tolerance, mm)
                            $13=0 (report inches, bool)
                            $20=0 (soft limits, bool)
                            $21=0 (hard limits, bool)
                            $22=0 (homing cycle, bool)
                            $100=800.000 (x, step/mm)
                            $101=800.000 (y, step/mm)
                            $102=800.000 (z, step/mm)
                            $110=5000.000 (x max rate, mm/min)
                            $111=5000.000 (y max rate, mm/min)
                            $112=800.000 (z max rate, mm/min)
                            $132=200.000 (z max travel, mm)
                            ok
                              Here's the current build status:
                              I'm guessing I'm something more than half-way done.
                              • andrewA andrew
                                #149
                                how exactly? Heat gun?
                                I've put the motor assembly in the freezer....
                                  I'll let it freeze overnight and then try it in the morning.
                                    sundberg84S
                                    sundberg84S
                                    freeze
                                    Why do you want to freeze the motor? :eyes:
                                    mfalkviddM dbemowskD 2 Replies Last reply
                                    • sundberg84S sundberg84
                                      freeze
                                      @sundberg84 see andrew's earlier post.
                                      Freezing the motor axis makes it a bit smaller.
                                        freeze
                                        dbemowskD
                                        dbemowskD
                                        @sundberg84 And heating up the other part makes it expand and get bigger allowing the two to fit together easier. Has to do with tight tolerances.
                                          #154
                                          @andrew
                                          Since I probably have only one shot at this, how hot should I heat up the ER11 before trying to fit it onto the frozen spindle? Should it be burning hot, or is luke-warm enough?
