  3. MySensors plugin : Cannot send command - communications error
ethernetgateway
20 Posts 8 Posters 11.1k Views 1 Watching
  • B Offline
    B Offline
    BulldogLowell
    It has happened three times now, always when I am away :( and it usually takes about 7 days to happen:
    I know it says v1.4, but that is some kind of glitch, it was compiled and uploaded with v1.4.1.
    Anyone else have this issue?
    Wiznet Shield with Uno.
    Restarting (power-cycling) the gateway reconnects the gateway...
    R 1 Reply Last reply
    • B BulldogLowell
      R Offline
      R Offline
      RJ_Make
      @BulldogLowell I believe the Plugin Version "1.4" is correctly identified. Is there any indication what the Lua Failure is? Is it related to a com failure with the Wiznet Shield?
      I use Serial, so I'm not familiar on how to debug the Wiznet shield hardware.
      RJ_Make
      B 1 Reply Last reply
      • R RJ_Make
        B Offline
        B Offline
        BulldogLowell
        @ServiceXp
        yeah, just like the title of the post:
        I can ping it, however.
        Dan S.D 1 Reply Last reply
        • B BulldogLowell
          @ServiceXp
          Dan S.D Offline
          Dan S.D Offline
          Dan S.
          @BulldogLowell Happend to me recently too, but was a lot longer than 7 days of operation before it happened. Rebooted the gateway and reloaded vera to correct it. Seems like it would be very difficult to track down the cause since it happens so infrequently but the fact that it happens at all is disconcerting.
          • Dan S.D Dan S.
            B Offline
            B Offline
            BulldogLowell
            @Dan-S. I'm thinking it may be power related. The Ethernet shield is a power glutton and the RF takes its share. I'm using a 5V standard USB cable to power but that may drop off too much if both the radio and the ethernet shield are drawing power.
            I'm going to try scoping it with the existing power supply and then try bumping up the power or adding some capacitors to the ethernet shield's power. I tried earlier to power it with 12Volt (1200mA) power supply but the boards just got too damned hot. (that contributes to my worry that the chinese boards i have been buying are really powered correctly).
            I think a 9V power supply may improve the situation... When I'm home I'll post the traces with a few power options. We really should have a definitive reference guide to building and powering these gateways and sensors. It may be difficult though, due to the possible number of varieties available for purchase.
            One thing I really want to focus on for the MySensors extension is reliability. Version 1.4.1 seems to solve the radio problems for me, but I would like to solve my intermittent gateway issues. It doesn't seem to be in software, since so many others don't complain about losing the connection to their ethernet gateway.
            Since so many folks suffer from power issues... this may be a fun thing to focus on so that many can benefit.
            • Dan S.D Offline
              Dan S.D Offline
              Dan S.
              I agree that it is likely a power issue. I am using a 9v regulated power supply for the UNO/Ethernet board combo and a separate standard 5v smartphone power supply (regulated to 3.3v by an AMS117) to power the radio to try to eliminate any power issues. Maybe that's why my setup lasts longer between failures.
              • M Offline
                M Offline
                MagKas
                @BulldogLowell
                I experienced a similar problem a few months ago. The problem is that the MySensors-plugin sets the failure flag (luup.set_failure(true)) and the only way to reset this is to restart/reload Vera. It should be possible and rather simple to implement a reset button in the plugin to restart only the plugin.
                But I wanted the plugin to try to restart by itself and created a keep-alive function to test communication and if that fails even to try to reset the communication. This is done by trying to reopen the connection to the gateway, which only can be done by the plugin.
                I copied and pasted a little from the lua-file and found some other stuff about keep alive-functions/timers on the internet.
                I changed the L_Arduino.lua in the following way:
                Add these lines of code to the end of the startup function just before 'end':
                luup.log('start call_timer keepAlive')
                _G["keepAlive"] = keepAlive
                luup.call_timer("keepAlive", 1, "30m", "", "SomeStuff")
                This will start a timer which after 30 minutes ("30m") calls the function keepAlive.
                Now add the following new function just above the startup function:
                function keepAlive(stuff)
                    luup.log('keepAlive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!')
                    sendCommandWithMessageType("0;0","INTERNAL",0,tonumber(tInternalTypes["VERSION"][1]),"Get Version")
                end
                This will ask the gateway for the Lib version, only for the reason of testing communication. In the end you have to setup the call_timer again to keep it going.
                Now I changed the function sendCommandWithMessageType so that it looks like this:
                function sendCommandWithMessageType(altid, messageType, ack, variableId, value)
                    local cmd = altid..";".. msgType[messageType] .. ";" .. ack .. ";" .. variableId .. ";" .. value
                   log("Sending: " .. cmd)
                    if (luup.io.write(cmd) == false)  then
                    	-- Try to reopen the connection
                    	luup.variable_set("urn:upnp-org:serviceId:VContainer1","Variable5","FEL",18)
                	    openConnectionToGateway()
                	    -- Try to resend commando
                		    task("Cannot send command - communications error", TASK_ERROR)
                		    return false
                	    end
                	    luup.variable_set("urn:upnp-org:serviceId:VContainer1","Variable5","OK",18)
                   end
                   return true
                end
                This function now tries to reopen the connection to the gateway when the plugin can't send a command to the gateway. If even this doesn't work it sets the failure flag as before. NOTICE that I use "Variable5" in my VariableContainer with ID #18. Remove these lines or adjust them to your situation!!
                Last thing you have to do is to add the function openConnectionToGateway which you can put right before sendCommandWithMessageType:
                function openConnectionToGateway()
                    log("openConnectionToGateway()")
                    -- Set the last update in a human readable form for display on the console
                    local timestamp = os.time()
                    local variable = tVeraTypes["LAST_UPDATE"]
                    local unit = luup.variable_get(ARDUINO_SID, "Unit", ARDUINO_DEVICE)
                    local timeFormat = (unit == 'M' and '%H:%M' or '%I:%M %p')
                    luup.variable_set("urn:upnp-org:serviceId:VContainer1","Variable4",os.date(timeFormat, timestamp),18)
                    -- End
                   local ipa = luup.devices[ARDUINO_DEVICE].ip
                    local ipAddress = string.match(ipa, '^(%d%d?%d?%.%d%d?%d?%.%d%d?%d?%.%d%d?%d?)')
                    local ipPort    = string.match(ipa, ':(%d+)$')
                    if (ipAddress ~= nil) then
                       if (ipPort == nil) then ipPort = IP_PORT end
                       log('Using network connection: IP address is '..ipAddress..':'..ipPort)
                       luup.io.open(ARDUINO_DEVICE, ipAddress, ipPort)
                    end
                end
                This function takes care of reopening the connection to the gateway. NOTICE that I use "Variable4" of my VariableContainer with ID #18 to show the moment this function was called. Remove this code or adjust it to your situation!!
                Don't know if this it what you want but it works perfectly for me! Never had to reload Vera because of the gateway loosing connection for a short moment of time!
                Good luck!
                Magnus
                • M MagKas
                  @BulldogLowell
                  end
                  		    return false
                  	    end
                     end
                     return true
                  end
                      -- End
                      end
                  end
                  Good luck!
                  Magnus
                  B Offline
                  B Offline
                  BulldogLowell
                  @MagKas thanks Magnus, I'll have to take a look at this when I'm back.
                  A vera restart does not correct my communication issue, so adding the openConnectionToGateway function will allow it to reconnect? If that works for me, it is a terrific solution!
                  I may come back to you on this, I've learned lua, but the extensions for vera, not so much.
                  I appreciate your assistance...
                  Jim
                  • M Offline
                    M Offline
                    MagKas
                    @BulldogLowell
                    Oh, I'm sorry! I missed the line where you wrote that you have to restart the gateway to get it to work again. In my case it was sufficient to reload Vera. So my solution probably won't help you...
                    Very strange though that you are able to ping the gateway but that there is no communication with the plugin. What happens when you reload Vera? Do you get the error-message immediatly or after some longer time?
                    The only place in the lua-code of the plugin where this error message is set is in the function sendCommandWithMessageType when luup.io.write(cmd) is failing.
                    In theory this should be solved by reloading Vera, unless your communication is still failing.
                    You might want to examine (read: Google) what could be the cause of luup.io.write() to fail.
                    • M MagKas
                      @BulldogLowell
                      B Offline
                      B Offline
                      BulldogLowell
                      @MagKas
                      when I reload vera, it takes some time to come back with the error message.
                      [EDIT] it takes one minute from "loading startup lua" until error...
                      I cannot understand why it will return a ping and yet it doesn't connect.
                      I'll search with your advice...
                      thanks
                      • C Offline
                        C Offline
                        cheesepower
                        I had several times the same problem.
                        Check the IP configuration in the mysensors plugin, the IP adress change for no reason, i have to investigate this.
                        • C cheesepower
                          B Offline
                          B Offline
                          BulldogLowell
                          @cheesepower
                          Thanks. I checked but the ip I'm using matches ok....
                          So far, only a hard reset of the arduino and a vera restart seem to reconnect the two.
                          I'm going to try a ping up the power supply.
                          • S Offline
                            samppa
                            wrote on last edited by samppa
                            I have same error when I am trying to get EthernetGateway (Nano+NRF24L01+w5100) to work with Vera3.
                            The gateway answers to ping in my LAN ip 192.168.100.222
                            And seems to be working well and receives sensor messages as seen in USB serial:
                            0;0;3;0;9;read: 1-1-0 s=4,c=1,t=2,pt=2,l=2:0
                            1;4;1;0;2;0
                            0;0;3;0;9;read: 1-1-0 s=2,c=1,t=0,pt=7,l=5:42.3
                            1;2;1;0;0;42.3
                            0;0;3;0;9;read: 1-1-0 s=3,c=1,t=2,pt=2,l=2:1
                            1;3;1;0;2;1
                            But the vera plugin fails to getVersion:
                            50 01/11/15 21:30:05.658 luup_log:80: Arduino plugin: loading library L_Arduino ... <0x2bf45680>
                            50 01/11/15 21:30:05.687 luup_log:80: Arduino plugin: library L_Arduino loaded LEAK this:163840 start:741376 to 0x10e9000 <0x2bf45680>
                            50 01/11/15 21:30:05.687 luup_log:80: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.4, 80 <0x2bf45680>
                            50 01/11/15 21:30:05.688 luup_log:80: Arduino: Using network connection: IP address is 192.168.100.222:5003 <0x2bf45680>
                            50 01/11/15 21:30:35.040 luup_log:80: Arduino: Sending: 0;0;3;0;2;Get Version <0x2bf45680>
                            02 01/11/15 21:31:05.084 luup_log:80: Arduino: Cannot send command - communications error <0x2bf45680>
                            Restarting luup, reloading UI6 or rebooting vera3 does not help.
                            Any ideas? I'm stuck so please help.
                            • S Offline
                              samppa
                              Just to add that I am using 1.4.1 library and SOFTSPI was defined when compiling the EthernetGateway. And since the EthernetGateway responds to ping and receives sensor values I assumes it is working properly.
                              Is there another way to confirm the proper operation e.g. with telnet to the port 5003 or how to issue similar simulated request that Vera does when calling getVersion?
                              I'm out of home automation before this is solved! :-(
                              • H Offline
                                H Offline
                                I checked in a small update yesterday which changes order of initialization between radio/ethernet. This has helped a few on the forum lately. I have no idea if this is related to your problem though.
                                S 1 Reply Last reply
                                • H hek
                                  samppa
                                  Thanks, but I did that too and it helped to resurrect it since before it did not respond to ping.
                                  Now it does so I think it works, but could it still be something in the node?
                                  In the EthernetGateway wiring instructions it says to connect:
                                  13 SCK
                                  12 MISO/SO
                                  11 MOSI/SI
                                  10 SS/CS
                                  But in the RF24_config.h it reads:
                                  So how should it be? Should I change the RF24_config.h or the wiring?
                                  And by the way the W5100 has label for +5V and not 3.3V as the wiring instructions..
                                  • H Offline
                                    H Offline
                                    wrote on last edited by hek
                                    Follow this:
                                    http://www.mysensors.org/build/ethernet_gateway
                                    A0 = 14
                                    A1 = 15
                                    • H hek
                                      Follow this:
                                      A0 = 14
                                      A1 = 15
                                      samppa
                                      @hek said:
                                      Follow this:
                                      A0 = 14
                                      A1 = 15
                                      Ok the wirings were otherwise correct since it started working once I fed +5V instead of 3.3V to the W5100.
                                      So I am back online with the home automation.. Phew..
                                      • 5546dug5 Offline
                                        5546dug5 Offline
                                        5546dug
                                        ok great thread as I want to also change to an Ethernet gw
                                        But here is the rookie question, after there has been a ping to the gw there is lots of info shown in these dissussions ie unit8 .....
                                        o;0;3;9 read.....
                                        and many others, at this time it is mostly gibberish to me but have looked at the mysensors ver 1.4
                                        I just want to understand and learn what you guys are posting and why.
                                        One silly last question is I am using lib 1.4 is the github download now lib 1.4.1? and do I need to upgrade?
                                        Yes this old dog is still learning!, it is a blast the people are very helpful.
                                        • 5546dug5 5546dug
                                          o;0;3;9 read.....
                                          samppa
                                          @5546dug
                                          Yes I think you need 1.4.1 or latest. The messages you see (0;0;3;9...) are traffic in the wireless sensor network.
                                          My problem appeared again. The EthernetGateway responds to Ping but Vera plugin says:
                                          So perhaps increasing power could help, but how? Is adding capacitors enough?? Like for the radio there already is one..
                                          12.1k
