  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.5k Views 27 Watching
    @andrew
    Since I probably have only one shot at this, how hot should I heat up the ER11 before trying to fit it onto the frozen spindle? Should it be burning hot, or is luke-warm enough?
    andrewA
    andrewA
    andrew
    wrote on last edited by andrew
    #155
    @neverdie unfortunately, as I mentioned, I don't have ER11 (yet), and I just read articles and vendor suggestions on the installation method, so I cannot provide experience based suggestions to that. as far as I remember nor concrete temperature was mentioned, so I would say you should not "overheat" it.
    • andrewA andrew
      #156
      I slipped it on, no problem at all. After freezing the motor overnight, what I did was heat the ER11 with my wife's crafting hot air gun. I held it with an insulated glove as I warmed it up. When it started to become uncomfortable to hold with even the insulated glove, I slipped it on without any resistance.
      Hopefully this info will help you when you receive yours.
      andrewA zboblamontZ 2 Replies Last reply
        andrewA
        andrewA
        andrew
        @neverdie :) nice, so your wife saved the project :)))
        be patient and do not power the spindle for couple of hours, while it is cold, as it could be wet inside which could cause shorts and other issues.
          I seem to be finished with the mechanical assembly:
          However, these washers came with the kit, and I'm not sure what they're for:
          Anyone know? Are they for mounting the woodpecker board to the frame?
          Next I need to do the firmware upgrade and then wire things up.
          andrewA rmtuckerR 2 Replies Last reply
            andrewA
            andrewA
            andrew
            @neverdie yes, it is for "isolating" the pcb from the frame.
              zboblamontZ
              zboblamontZ
              zboblamont
              ER11
              FYI - Was reading on another forum where the user was going to replace the ER11 with a larger version so he could use 8mm bits (fairly standard metric size for wood routing bits, but incredibly strong)...
              Somebody pointed out to the guy that there are collets available for the ER11 specifically for 8mm shafted toolbits...
              https://www.sorotec.de/shop/Spannzange-ER-11---8-00mm-DIN-6499B-4008E-Klasse-II.html
                rmtuckerR
                rmtuckerR
                rmtucker
                @neverdie
                You have gone quiet:relaxed:
                Must be beavering away cutting pcb's?
                • rmtuckerR
                  rmtuckerR
                  rmtucker
                  Carved this on my home made cnc router recently.
                  Bit off topic but good fun.
                  It is about 2ft diameter and 8" thick(old millstone)
                  rmtuckerR 1 Reply Last reply
                  • rmtuckerR rmtucker
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    @rmtucker
                    And this for our lass
                      @neverdie
                      @neverdie
                      No, I've simply misplaced my Dragon AVR programmer for the firmware upgrade, so I need to hunt it down.
                        #165
                        Anyway, once I do get the firmware upgraded and it wired up, what's the best way to start testing it? Do I need to learn GRBL as execuval seems to imply, or are there some simple tests I can run? I imagine some kind of calibration would be the need step, but I haven't read that far ahead because there's nothing to read (well, haven't googled it out yet either).
                        rmtuckerR E 2 Replies Last reply
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          @neverdie
                          Stick some g-code in and press cycle start:grin:
                          • zboblamontZ zboblamont
                            ER11
                            #167
                            Given how it's installed, I don't see how you can get it off. I would assume it's permanent.
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @neverdie From memory the guy got it off with a hub-puller, and a persuader, but the point I was trying to make was that there is a collet assembly for the ER11which takes 8mm...
                                E
                                E
                                executivul
                                First watch the video (now I can't get it out of my head :man-bowing: )
                                https://www.youtube.com/watch?v=UOk6echpeqQ
                                Then, after you update to grbl 0.9j go to chilipeppr.com/grbl, download the SPJS, start it and start playing.
                                  #170
                                  I hope these heatsinks that came with the kit don't short things out. Seems rather dicey.
                                  In any case, until I can find my Dragon, I'm going to limp along with GRBL 0.9j so I can finish up the build. I'll upgrade later after I find it.
                                  andrewA 1 Reply Last reply
                                    andrewA
                                    andrewA
                                    andrew
                                    @neverdie the er-11 should be permanent. this spindle is not powerful enough to handle bigger tools and to mill harder materials.
                                    you can start with grbl 0.9j, but it is worth to upgrade to 1.1f.
                                    to the fw upgrade you can use a simple arduino as ISP programmer as well if you do not find your dragon.
                                    with chilipeppr (in case of grbl 0.9j go for http://chilipeppr.com/grbl , for 1.1.f go for http://chilipeppr.com/jpadie) you can quickly run its default logo engraving path for testing / demo purposes.
                                      Done! Jack was certainly, uh, generous with the length of the wiring. I provisionally tacked it out of the way with the zip ties provided. I'll secure it better after I'm sure it's all working.
                                        andrewA
                                        andrewA
                                        andrew
                                        #173
                                        @neverdie for the cable issue I ordered this cable organizer spiral, although not yet installed it :)
                                        • andrewA andrew
                                          #174
                                          Thanks! That provided exactly what I was looking for. I ran the demo with no etching bit installed, and at first both X and Y seemed to be working, but the adapter coupling eventually loosened on both of them to the point where there was no longer X and Y movement. I've re-tightened tem, and it's working again. I hope it lasts.
                                          Not sure where I should go next from here though.
