  3. CNC PCB milling
CNC PCB milling
933 Posts 28 Posters 823.4k Views 27 Watching
    I'll let it freeze overnight and then try it in the morning.
      sundberg84S
      sundberg84S
      freeze
      Why do you want to freeze the motor? :eyes:
      mfalkviddM dbemowskD 2 Replies Last reply
      • sundberg84S sundberg84
        freeze
        @sundberg84 see andrew's earlier post.
        Freezing the motor axis makes it a bit smaller.
          freeze
          dbemowskD
          dbemowskD
          @sundberg84 And heating up the other part makes it expand and get bigger allowing the two to fit together easier. Has to do with tight tolerances.
            #154
            @andrew
            Since I probably have only one shot at this, how hot should I heat up the ER11 before trying to fit it onto the frozen spindle? Should it be burning hot, or is luke-warm enough?
            andrewA 1 Reply Last reply
              @andrew
              andrewA
              andrewA
              andrew
              wrote on last edited by andrew
              #155
              @neverdie unfortunately, as I mentioned, I don't have ER11 (yet), and I just read articles and vendor suggestions on the installation method, so I cannot provide experience based suggestions to that. as far as I remember nor concrete temperature was mentioned, so I would say you should not "overheat" it.
              • andrewA andrew
                #156
                I slipped it on, no problem at all. After freezing the motor overnight, what I did was heat the ER11 with my wife's crafting hot air gun. I held it with an insulated glove as I warmed it up. When it started to become uncomfortable to hold with even the insulated glove, I slipped it on without any resistance.
                Hopefully this info will help you when you receive yours.
                andrewA zboblamontZ 2 Replies Last reply
                  andrewA
                  andrewA
                  andrew
                  @neverdie :) nice, so your wife saved the project :)))
                  be patient and do not power the spindle for couple of hours, while it is cold, as it could be wet inside which could cause shorts and other issues.
                    I seem to be finished with the mechanical assembly:
                    However, these washers came with the kit, and I'm not sure what they're for:
                    Anyone know? Are they for mounting the woodpecker board to the frame?
                    Next I need to do the firmware upgrade and then wire things up.
                    andrewA rmtuckerR 2 Replies Last reply
                      andrewA
                      andrewA
                      andrew
                      @neverdie yes, it is for "isolating" the pcb from the frame.
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        ER11
                        FYI - Was reading on another forum where the user was going to replace the ER11 with a larger version so he could use 8mm bits (fairly standard metric size for wood routing bits, but incredibly strong)...
                        Somebody pointed out to the guy that there are collets available for the ER11 specifically for 8mm shafted toolbits...
                        https://www.sorotec.de/shop/Spannzange-ER-11---8-00mm-DIN-6499B-4008E-Klasse-II.html
                          rmtuckerR
                          rmtuckerR
                          rmtucker
                          @neverdie
                          You have gone quiet:relaxed:
                          Must be beavering away cutting pcb's?
                          • rmtuckerR
                            rmtuckerR
                            rmtucker
                            Carved this on my home made cnc router recently.
                            Bit off topic but good fun.
                            It is about 2ft diameter and 8" thick(old millstone)
                            rmtuckerR 1 Reply Last reply
                            • rmtuckerR rmtucker
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              @rmtucker
                              And this for our lass
                                @neverdie
                                @neverdie
                                No, I've simply misplaced my Dragon AVR programmer for the firmware upgrade, so I need to hunt it down.
                                  #165
                                  Anyway, once I do get the firmware upgraded and it wired up, what's the best way to start testing it? Do I need to learn GRBL as execuval seems to imply, or are there some simple tests I can run? I imagine some kind of calibration would be the need step, but I haven't read that far ahead because there's nothing to read (well, haven't googled it out yet either).
                                  rmtuckerR E 2 Replies Last reply
                                    rmtuckerR
                                    rmtuckerR
                                    rmtucker
                                    @neverdie
                                    Stick some g-code in and press cycle start:grin:
                                    • zboblamontZ zboblamont
                                      ER11
                                      #167
                                      Given how it's installed, I don't see how you can get it off. I would assume it's permanent.
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @neverdie From memory the guy got it off with a hub-puller, and a persuader, but the point I was trying to make was that there is a collet assembly for the ER11which takes 8mm...
                                          E
                                          E
                                          executivul
                                          First watch the video (now I can't get it out of my head :man-bowing: )
                                          https://www.youtube.com/watch?v=UOk6echpeqQ
                                          Then, after you update to grbl 0.9j go to chilipeppr.com/grbl, download the SPJS, start it and start playing.
