1.1k Posts 105 Posters 790.4k Views 98 Watching
  • dbemowskD dbemowsk
    Today's progress on the new switch consists of finishing the basic 3D model of the wall switch plate and working on some of the programming.
    For the wall plate design I do not have buttons as of yet, but the main part of the wall plate turned out good. I did the initial print in yellow because I am out of white at the moment. I am still trying to figure out the best way of printing it. In the video, you will see that the tabs are looking a bit rough. That is because I printed this one face down with supports for the tabs. If I decide to print them that way, it won't be bad because the tabs will be hidden under the wall plate cover. I will try printing them both ways to see which comes out better.
    For the programming, I created a couple bitmap icons and did a sample of those icons animated on the screen. The animations toggle back and forth and each runs for about 10 seconds. One bitmap is a rain drop, and the other is a snow flake. The idea is to use these to display weather conditions. I will probably design some clouds and a sun as well and have 4 possible animated weather displays.
    https://youtu.be/icre7xeprJI
    dbemowskD
    dbemowskD
    Some more sample display layouts.
    • mfalkviddM
      Reverse-engineering a bluetooth battery monitor from Conrad.
      The battery monitor has an Android and iOS app that displays voltage, but I wanted to read the data from an ESP32 (lower right corner of the pic).
      This hack is probably worth a thread on its own, will add that later.
        More info on my ble hack: https://forum.mysensors.org/topic/8773/reverse-engineering-a-gl10-ble-bluetooth-battery-monitor-using-esp32
        • bjacobseB
          bjacobseB
          bjacobse
          Maybe a bit off-topic, but I use octoprint as server for my 3d printer, and use Domoticz as homeautomation server. I want to know when 3D print is done, so I created a node-red flow that connects this via MQTT, so domotics shows print progress...
          https://www.domoticz.com/forum/viewtopic.php?f=21&t=14021&p=162935#p162935
          dbemowskD 1 Reply Last reply
          • bjacobseB bjacobse
            dbemowskD
            dbemowskD
            @bjacobse I literally just started using octoprint about a week ago. I am curious how you get the progress data into node-red to send over MQTT?
            bjacobseB 1 Reply Last reply
              Well.. I didn't build it as it was already assembled, but I did had to some soldering to put it together and also did a mod to the case by adding 2 extra binding posts to the front. Btw it is a DPS5015 with a BT module that I fitted behind the screen
                bjacobseB
                bjacobseB
                bjacobse
                #240
                @dbemowsk
                hi did you check the link I supplied? I rather discuss the topic in domoticz forum, as it could benefit other Domoticz/octoprint userrs
                but I have installed on the octoprint the mqtt plugin, as my domoticz is also running both mosquitto and node-red, I specify the ip adress for domoticz in setup the broker in octoprint plugin mqtt,
                • A
                  arnold
                  Finalised my indoor weather station with light intensity measurement build around a WeMos D1 mini. The system is using a BME280 module for pressure, humidity and temperature measurement. The light intensity is using a normal plain good old LDR.
                  Step down converter to convert input voltage towards 5 Volt.
                  Of course using the esp8266 MySensors solution! Great achievement to all involved in building it. Really awesome!
                  Case designed in Onshape and printed on a Ultimaker 2+.
                  gohanG dbemowskD 2 Replies Last reply
                  • A arnold
                    @arnold the print quality of that box looks amazing
                    A 1 Reply Last reply
                      arnold
                      @gohan Thank you! Although I have some warping on one of the corners unfortunately.
                      • A arnold
                        dbemowskD
                        dbemowskD
                        @arnold So that is a 3D printed case? Curious where you got the knurled screw inserts that you used in the case for the cover? I am a computer tech and deal with a lot of E-waste disposal and on occasion have grabbed some similar ones from old laptop case parts, but those are really small. The ones that you have there are a decent size.
                          arnold
                          @dbemowsk ], yes it's a fully printed case using PLA material.
                          I bought some nice and decent brass knurled from Banggood. Bought directly some M3 bolts made of stainless steel also at Banggood.The bolts you can get in different lengths.
                          • A arnold
                            #246
                            @arnold said in What did you build today (Pictures) ?:
                            Nice. And thanks for the links.
                            How do you secure the brass knurls in the box? Do you glue them or press fit them or...?
                            A dbemowskD 2 Replies Last reply
                              arnold
                              wrote on last edited by arnold
                              #247
                              @neverdie, a very very easy handling. Just heat and melt them in the PLA :)
                              I use longer M3 bolts so that I can heat them up (in a flame of a stove or lighter)
                              and able to position them very accurately into the holes which are already there in the case it self. The knurled inserts have 5mm of diameter and I'm designing the holes @ 4.8 mm. If the inserts are heated you will melt them into the 4.8 mm holes and after cooling down...it solid and fixed in the case.
                                #248
                                Awesome! Thanks.
                                  dbemowskD
                                  dbemowskD
                                  @neverdie The ones that I have done in the past, I just heat up my soldering iron with the knurled piece in the tip for a bit, and then just press them into the holes and let them cool. I have done this too with just plain old nuts, but I like the knurled pieces better.
                                    We could make a new topic about making sensor boxes with projects already done and how to make them
                                      dbemowskD
                                      dbemowskD
                                      @gohan There is the 3D printing category
                                      gohanG 1 Reply Last reply
                                      • dbemowskD
                                        dbemowskD
                                        So I have a basic switch plate done. I think I need to increase the font size on the button text a bit.
                                          @dbemowsk indeed there is, but nobody uses it 😥
