1.1k Posts 105 Posters 790.3k Views 98 Watching
  • dbemowskD dbemowsk
    @bjacobse I literally just started using octoprint about a week ago. I am curious how you get the progress data into node-red to send over MQTT?
    bjacobseB
    bjacobseB
    bjacobse
    #240
    @dbemowsk
    hi did you check the link I supplied? I rather discuss the topic in domoticz forum, as it could benefit other Domoticz/octoprint userrs
    https://www.domoticz.com/forum/viewtopic.php?f=21&t=14021&p=162935#p162935
    but I have installed on the octoprint the mqtt plugin, as my domoticz is also running both mosquitto and node-red, I specify the ip adress for domoticz in setup the broker in octoprint plugin mqtt,
    • A
      arnold
      Finalised my indoor weather station with light intensity measurement build around a WeMos D1 mini. The system is using a BME280 module for pressure, humidity and temperature measurement. The light intensity is using a normal plain good old LDR.
      Step down converter to convert input voltage towards 5 Volt.
      Of course using the esp8266 MySensors solution! Great achievement to all involved in building it. Really awesome!
      Case designed in Onshape and printed on a Ultimaker 2+.
      gohanG dbemowskD 2 Replies Last reply
      • A arnold
        @arnold the print quality of that box looks amazing
        A 1 Reply Last reply
          arnold
          @gohan Thank you! Although I have some warping on one of the corners unfortunately.
          • A arnold
            dbemowskD
            dbemowskD
            @arnold So that is a 3D printed case? Curious where you got the knurled screw inserts that you used in the case for the cover? I am a computer tech and deal with a lot of E-waste disposal and on occasion have grabbed some similar ones from old laptop case parts, but those are really small. The ones that you have there are a decent size.
              arnold
              @dbemowsk ], yes it's a fully printed case using PLA material.
              I bought some nice and decent brass knurled from Banggood. Bought directly some M3 bolts made of stainless steel also at Banggood.The bolts you can get in different lengths.
              • A arnold
                #246
                @arnold said in What did you build today (Pictures) ?:
                Nice. And thanks for the links.
                How do you secure the brass knurls in the box? Do you glue them or press fit them or...?
                A dbemowskD 2 Replies Last reply
                  arnold
                  wrote on last edited by arnold
                  #247
                  @neverdie, a very very easy handling. Just heat and melt them in the PLA :)
                  I use longer M3 bolts so that I can heat them up (in a flame of a stove or lighter)
                  and able to position them very accurately into the holes which are already there in the case it self. The knurled inserts have 5mm of diameter and I'm designing the holes @ 4.8 mm. If the inserts are heated you will melt them into the 4.8 mm holes and after cooling down...it solid and fixed in the case.
                    #248
                    Awesome! Thanks.
                      dbemowskD
                      dbemowskD
                      @neverdie The ones that I have done in the past, I just heat up my soldering iron with the knurled piece in the tip for a bit, and then just press them into the holes and let them cool. I have done this too with just plain old nuts, but I like the knurled pieces better.
                        We could make a new topic about making sensor boxes with projects already done and how to make them
                        dbemowskD 1 Reply Last reply
                          dbemowskD
                          dbemowskD
                          @gohan There is the 3D printing category
                          gohanG 1 Reply Last reply
                          • dbemowskD
                            dbemowskD
                            So I have a basic switch plate done. I think I need to increase the font size on the button text a bit.
                              @dbemowsk indeed there is, but nobody uses it 😥
                              • dbemowskD
                                dbemowskD
                                So I now have 4 weather animations designed. Rain, snow, sunny and cloudy. The idea for now is to have the screen switch between 4 screens. Indoor temp, outdoor temp, current weather animation and current time read from my Vera controller. Here is a sample of my 4 weather animations.
                                https://www.youtube.com/watch?v=2oA-DtqI6aY
                                • WoekaW
                                  WoekaW
                                  Woeka
                                  I've build this temperature & humidity node.
                                  It uses a Si7021 for the temperature and humidity, a power converter from a Li-ion cell to 3,3v. Voltage measurement with a voltage divider on pin A0.
                                  I've removed the led and converter from the mini pro and also the power converter from the Si7021 (next time I will buy one for 3.3v instead of 5v). This really prolong your battery time, more then 4 times in my case. Looks like the node can run approximately half a year on a full Li-ion cell, scavenged from an old laptop battery.
                                  Temp-Hum node
                                  WoekaW 1 Reply Last reply
                                  • WoekaW Woeka
                                    Temp-Hum node
                                    WoekaW
                                    WoekaW
                                    Woeka
                                    @woeka .... and the enclosure is from Surtronics.
                                    • dbemowskD
                                      dbemowskD
                                      So I started work on a PCB for my OLED keypad scene controller. While designing it I wanted to make it with a few different switch configuration options. One design is the current layout like I have posted in my pics. One other proposed layout was one with up, down, left, right and select buttons. I designed it with 9 buttons which would allow for both of these configurations and more. Here is the proposed board:
                                      0_1514388440385_307c303b-b1e4-48a4-882e-b7016e620f09-in_wall_scene_controller_OLED_keypad_brd-fb226b6ff44c4a548abe6a358259fe04.png
                                      If anyone can see any problems or have any other suggestions for this design, let me know.
                                        #258
                                        @dbemowsk said in What did you build today (Pictures) ?:
                                        You had earlier lamented the low refresh rate. If you have the gumption, how about adding an SPI OLED interface such that it can do either I2C or SPI for the OLED? Having that extra option would only cost you at most 2.54mm in the vertical dimension.
                                        dbemowskD 3 Replies Last reply
                                        • sundberg84S
                                          sundberg84S
                                          #259
                                          Recieved some PCBs today and one is the HLK-PM01 breakout which I will start working on for a project.
