1.1k Posts 105 Posters 790.4k Views 98 Watching
  • dbemowskD dbemowsk
    @mfalkvidd I would agree, but when space is cramped, those are not always a workable solution. Great suggestion though.
    #268
    @dbemowsk true. But from the photo sundberg84 posted, there seems to be a lot of space so in his particular case it should work. Needle-nose pliers are also useful. They can't absorb as much heat, but they absorb some (especially if you put them in the freezer first ;-) ) and fit into tight spaces.
      @dbemowsk said in What did you build today (Pictures) ?:
      If anyone can see any problems or have any other suggestions for this design, let me know.
      You had earlier lamented the low refresh rate. If you have the gumption, how about adding an SPI OLED interface such that it can do either I2C or SPI for the OLED? Having that extra option would only cost you at most 2.54mm in the vertical dimension.
      dbemowskD
      dbemowskD
      @neverdie So because of your suggestion, I decided to explore the revision to the main controller board. I have not posted this revision to OpenHardware.io yet. Thought I'd get some feedback here first.
      Some of the minor changes that I made were to the definitions of the headers. The headers now are labaled J1, J2 and J3. One other change was to combine the old J2 and J3 together into one header which is now designated J2. The biggest change was breaking out the MOSI and MISO SPI lines to the new J1 header. All changes are backward compatible with the old switch board hat. Here is the proposed board design. With the SPI bus now broken out, this will now allow the use of SPI capable displays and sensors such as the 128 x 64 OLED display for my current display/keypad board. I will make the changes to that soon.
      The schematic is simple.
        #270
        @dbemowsk I thought they were all on the same board. I hadn't realized that they were separate boards. Also, at least on the schematic, the pinout on your pro-mini looks unusual.
        dbemowskD 1 Reply Last reply
          dbemowskD
          dbemowskD
          @neverdie It was one that I found on EasyEDA that was contributed by a user. Some of the other ones didn't have A4 and A5 for I2C on them. All parts are correct on the board layout though which is what matters.
          My setup for these is 3 boards. Power supply, controller and switch/sensor board with faceplate. This is how the 3 boards stack together.
          0_1514516200715_8066b51f-520f-424c-8038-d3b19afe67f6-1503237722028-upload-e8f52bee-806f-41db-8bd8-7729228df6f2-resized.png
          This setup allows me to build different faceplate boards with various switches, displays and sensors depending on what the needs are.
          • dbemowskD
            dbemowskD
            So here is an updated board layout that with the new controller board layout will allow for either a 6 pin SPI or 4 pin I2C OLED display. J4 through J7 are jumper headers that tell whether you are using a 6 pin SPI or 4 pin I2C display.
              @dbemowsk Or maybe use solder jumpers instead.
              • sundberg84S
                sundberg84S
                #274
                Building some loggers which i might sell later on.
                • sundberg84S
                  sundberg84S
                  And want to make a tip about smd component organisation...
                  Nca78N 1 Reply Last reply
                    dbemowskD
                    dbemowskD
                    @neverdie I thought about adding jumpers, but being that these are in-wall switches which are pretty much permanent, and the fact that because of space the OLED display needs to be soldered in place, there's not much chance of the display getting changed from I2C to SPI or vice versa. I figured that the pads could just be bridged one way or the other depending on configuration.
                    • sundberg84S sundberg84
                      I think we should make another topic for this kind of tips ? We could discuss pros and cons and give reference to online shops to buy items, your boxes are quite nice for DIP components and small breakout boards, where are they from ?
                      For SMDs components I went for the lab supplies on AliExpress, I started to sort my SMD chips using 5ml tubes and 3D printed holders, I need to print more holders to sort by categories as it's a bit messy at the moment. I put a bigger sticker on the side of tubes with more details as top sticker is pretty small :D Same holders can also holder bigger tubes for bigger stuff like here mini/micro USB plugs.
                      For resistors, capacitors, inductances, ... I went for lab tube boxes. I use smaller tubes (1.5 or 2ml) but they can hold probably thousands of 0603 or 0402 and even hundreds of the 0805 and 1206 resistors. I use different colors to differentiate size (and later precision/voltage/... when I'll have more boxes) and put bigger stickers on the lid of the box with information for each color.
                        #278
                        Here, I like using smd books but of course I have a lot of these little boxes, too much though, and not enough!
                        Little boxes are nice but not very handy as you spend your time to reorganize them. Whereas I can have dedicated pages in books for my designs. Sure I could have dedicated boxes, but that takes more place and I don't have to search for a partvalue in hundreds of box.
                        • Nca78N Nca78
                          @nca78 What do you do with the parts that are too big to fit in your test tubes?
                            @neverdie I have plastic boxes from my local supermarket, I put components/breakout boards etc inside in their antistatic bags, then align them on their side in drawers. Less convenient to access but at least it's cleaned and ordered :)
                              I got this set but I haven't used them yet, I still have room in my plastic storage drawers
                              https://www.banggood.com/10Pcs-15-Value-Electronic-Components-Storage-Assortment-Box-p-951597.html
                              • F
                                F
                                fredswed
                                Great fun to see all these build pictures!
                                My pic of the day is a trivial battery powered DHT22 sensor just to try things out with prototyping, programming and connecting to OpenHAB. This is my first project since highschool. (The gw and first sensor is on a breadboard.)
                                It feels great to be soldering again after almost 30 years and I'm really looking forward to step into the MySensors world!
                                • F fredswed
                                  dbemowskD
                                  dbemowskD
                                  @fredswed being a battery operated node, you may want to remove the LED from your pro-mini to save power. You may also want to look at the options for ruining without the pro-mini regulator also to save even more power.
                                    and also get rid of the dht sensor to get a proper one :sweat_smile:
                                    • F
                                      F
                                      fredswed
                                      You are of course both right! It was only intended to get things going so I didn’t want to complicate things. My “production” sensors will be quite different. Maybe I’ll save this one in a frame on the wall :wink:
                                      • R
                                        R
                                        reinhold
                                        Today I finished the coding for my prototype of a laser distance sensor (intended to measure the water level for my automatic in-door flower watering pump). The sensor is connected via I²C and has sleep pin.
                                        The most work was implementing support for the VL52L0X laser distance sensor and for my 128x64 OLED display to NodeManager (PRs submitted as https://github.com/mysensors/NodeManager/pull/244 and https://github.com/mysensors/NodeManager/pull/245).
                                        The OLED is really useful when prototyping sensor nodes. Out of the box, my NodeManager OLED implemention will display the values of all attached sensors without any coding. Simply create the DisplaySSD1306 after all other sensors, and the OLED will pick up and display all sensors automatically...
                                        Once everything works, of course the OLED is not desired for the water level sensor running on batteries...
                                        Nca78N gohanG 2 Replies Last reply
                                        • R reinhold
                                          @reinhold that's an awesome idea ! Ordering new OLED displays right now ;)
                                          And this sensor is great, its precision is putting to shame the APDS and similar sensors.
