  3. MyController.org
  4. Need volunteer to test dualboot OTA with MyController
Scheduled Pinned Locked Moved MyController.org
28 Posts 5 Posters 6.9k Views 6 Watching
    It's ethernet controller on same raspberry pi as the controller. That tx message processing is set to zero. So far I got 3 successful fw updates only, I lost count of the trials.
    tekkaT 1 Reply Last reply
      tekkaT
      tekkaT
      tekka
      @gohan hmm, 10-20 mins is pretty long, indeed. Can you post all logs with rfm69 debug verbose enabled?
      gohanG 1 Reply Last reply
      • tekkaT tekka
        @tekka from the node side?
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          @gohan ideally both, GW and node
            Do I need to enable it in myconfig.h and recompile the rpi gateway?
              tekkaT
              tekkaT
              tekka
              @gohan yes, you can enable/add #define MY_DEBUG_VERBOSE_RFM69 in either myconfig.h or mysgw.cpp and recompile the RPI GW
                this is what I get on the gateway
                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FB03611D231F849F600D211D822F762F6A2F
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-41
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500FA03
                mysgw: RFM69:SWR:SEND,TO=16,RETRY=0
                mysgw: !RFM69:SWR:NACK
                mysgw: RFM69:SWR:SEND,TO=16,RETRY=1
                mysgw: RFM69:SWR:SEND,TO=16,RETRY=2
                mysgw: RFM69:SWR:SEND,TO=16,RETRY=3
                mysgw: RFM69:SWR:SEND,TO=16,RETRY=4
                mysgw: RFM69:SWR:SEND,TO=16,RETRY=5
                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FA03621F839FA00D611D221F749F3327A00D
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-55
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F903
                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500F903829F2227B00DA11D621F739FB00DA11D
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-42
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F803
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=166,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F903829F2227B00DA11D621F739FB00DA11D
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=168,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F803F00DB11DAA1F649F6627B00DA11D661F
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-43
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F703
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=170,RSSI=-51
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=171,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F703629FF001729FBB27F00DB11D639FAA27
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F603
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=173,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F6030E94322070F3959FC1F3950F50E0551F
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-44
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F503
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=175,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F50311F00C940A200C94102011240C945520
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F403
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=177,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F40321200E94132038F00E941A2020F09523
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F303
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=179,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F303A6958FEF811D811D08950E94B01F0C94
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-45
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F203
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=181,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F203232B242B252B21F408950A2609F4A140
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-46
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F103
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=183,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F10398F0621B730B840B950B39F40A2661F0
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-47
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F003
                mysgw: RFM69:SWR:ACK,FROM=16,SEQ=185,RSSI=-51
                mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F0031706E807F907C0F012161306E407F507
                mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-48
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EF03
                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EF030895990F0008550FAA0BE0E8FEEF1616
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EE03
                mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EE03660F771F881FDAF7880F9695879597F9
                mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500ED03
                I guess there is something wrong since the node is 3 meters away
                  tekkaT
                  tekkaT
                  tekka
                  @gohan please also post the full node log + node sketch
                    wrote on last edited by gohan
                    This is node at boot even if I selected to upload firmware
                    0 MCO:BGN:INIT NODE,CP=RPONA--X,VER=2.2.0-beta
                    49 TSM:INIT
                    51 TSF:WUR:MS=10000
                    53 RFM69:INIT
                    53 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                    59 RFM69:PTX:LEVEL=5 dBm
                    61 TSM:INIT:TSP OK
                    63 TSF:SID:OK,ID=16
                    65 TSM:FPAR
                    67 RFM69:SWR:SEND,TO=255,RETRY=0
                    73 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    192 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                    200 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    206 TSF:MSG:FPAR OK,ID=0,D=1
                    405 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                    413 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    2082 TSM:FPAR:OK
                    2082 TSM:ID
                    2084 TSM:ID:OK
                    2086 TSM:UPL
                    2088 RFM69:SWR:SEND,TO=0,RETRY=0
                    2103 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-47
                    2107 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=4
                    2111 RFM69:PTX:LEVEL=4 dBm
                    2113 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2121 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                    2129 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2136 TSF:MSG:PONG RECV,HP=1
                    2138 TSM:UPL:OK
                    2140 TSM:READY:ID=16,PAR=0,DIS=1
                    2144 RFM69:SWR:SEND,TO=0,RETRY=0
                    2355 !RFM69:SWR:NACK
                    2357 RFM69:PTX:LEVEL=5 dBm
                    2400 RFM69:SWR:SEND,TO=0,RETRY=1
                    2609 !RFM69:SWR:NACK
                    2611 RFM69:PTX:LEVEL=6 dBm
                    2654 RFM69:SWR:SEND,TO=0,RETRY=2
                    2863 !RFM69:SWR:NACK
                    2865 RFM69:PTX:LEVEL=7 dBm
                    2899 RFM69:SWR:SEND,TO=0,RETRY=3
                    3108 !RFM69:SWR:NACK
                    3110 RFM69:PTX:LEVEL=8 dBm
                    3121 RFM69:SWR:SEND,TO=0,RETRY=4
                    3330 !RFM69:SWR:NACK
                    3332 RFM69:PTX:LEVEL=9 dBm
                    3375 RFM69:SWR:SEND,TO=0,RETRY=5
                    3457 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-44
                    3461 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
                    3465 RFM69:PTX:LEVEL=8 dBm
                    3467 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
                    3477 RFM69:SWR:SEND,TO=0,RETRY=0
                    3491 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-45
                    3495 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=7
                    3500 RFM69:PTX:LEVEL=7 dBm
                    3502 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    3510 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                    3518 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    3524 RFM69:SWR:SEND,TO=0,RETRY=0
                    3735 !RFM69:SWR:NACK
                    3737 RFM69:PTX:LEVEL=8 dBm
                    3747 RFM69:SWR:SEND,TO=0,RETRY=1
                    3956 !RFM69:SWR:NACK
                    3958 RFM69:PTX:LEVEL=9 dBm
                    4001 RFM69:SWR:SEND,TO=0,RETRY=2
                    4210 !RFM69:SWR:NACK
                    4212 RFM69:PTX:LEVEL=10 dBm
                    4255 RFM69:SWR:SEND,TO=0,RETRY=3
                    4464 !RFM69:SWR:NACK
                    4466 RFM69:PTX:LEVEL=11 dBm
                    4501 RFM69:SWR:SEND,TO=0,RETRY=4
                    4710 !RFM69:SWR:NACK
                    4712 RFM69:PTX:LEVEL=12 dBm
                    4722 RFM69:SWR:SEND,TO=0,RETRY=5
                    4909 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-43
                    4913 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
                    4917 RFM69:PTX:LEVEL=11 dBm
                    4919 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                    4929 RFM69:SWR:SEND,TO=0,RETRY=0
                    4943 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-43
                    4947 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                    4952 RFM69:PTX:LEVEL=10 dBm
                    4954 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    5584 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                    5593 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    5599 RFM69:SWR:SEND,TO=0,RETRY=0
                    5810 !RFM69:SWR:NACK
                    5812 RFM69:PTX:LEVEL=11 dBm
                    5855 RFM69:SWR:SEND,TO=0,RETRY=1
                    6064 !RFM69:SWR:NACK
                    6066 RFM69:PTX:LEVEL=12 dBm
                    6100 RFM69:SWR:SEND,TO=0,RETRY=2
                    6309 !RFM69:SWR:NACK
                    6311 RFM69:PTX:LEVEL=13 dBm
                    6322 RFM69:SWR:SEND,TO=0,RETRY=3
                    6531 !RFM69:SWR:NACK
                    6533 RFM69:PTX:NO ADJ
                    6576 RFM69:SWR:SEND,TO=0,RETRY=4
                    6785 !RFM69:SWR:NACK
                    6787 RFM69:PTX:NO ADJ
                    6830 RFM69:SWR:SEND,TO=0,RETRY=5
                    6950 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-42
                    6955 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=12
                    6961 RFM69:PTX:LEVEL=12 dBm
                    6963 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
                    6971 RFM69:SWR:SEND,TO=0,RETRY=0
                    6985 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-43
                    6989 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
                    6995 RFM69:PTX:LEVEL=11 dBm
                    6998 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                    7006 RFM69:SWR:SEND,TO=0,RETRY=0
                    7020 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-43
                    7024 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                    7030 RFM69:PTX:LEVEL=10 dBm
                    7032 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    7041 RFM69:SWR:SEND,TO=0,RETRY=0
                    7055 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-43
                    7061 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=9
                    7065 RFM69:PTX:LEVEL=9 dBm
                    7067 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                    7075 RFM69:SWR:SEND,TO=0,RETRY=0
                    7090 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-44
                    7096 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
                    7100 RFM69:PTX:LEVEL=8 dBm
                    7102 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                    7110 RFM69:SWR:SEND,TO=0,RETRY=0
                    7127 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
                    7131 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=7
                    7135 RFM69:PTX:LEVEL=7 dBm
                    7139 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                    7145 RFM69:SWR:SEND,TO=0,RETRY=0
                    7163 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-51
                    7168 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=6
                    7172 RFM69:PTX:LEVEL=6 dBm
                    7174 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                    7182 RFM69:SWR:SEND,TO=0,RETRY=0
                    7198 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-45
                    7202 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=5
                    7206 RFM69:PTX:LEVEL=5 dBm
                    7211 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                    7219 MCO:REG:REQ
                    7219 RFM69:SWR:SEND,TO=0,RETRY=0
                    7235 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-49
                    7239 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=4
                    7243 RFM69:PTX:LEVEL=4 dBm
                    7247 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    7254 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                    7262 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    7268 MCO:PIM:NODE REG=1
                    7272 MCO:BGN:STP
                    7784 MCO:BGN:INIT OK,TSP=1
                    7786 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                    7794 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    7800 MCO:PIM:NODE REG=1
                    8804 RFM69:SWR:SEND,TO=0,RETRY=0
                    8822 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-48
                    8826 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=3
                    8833 RFM69:PTX:LEVEL=3 dBm
                    8835 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.62
                    T: 19.62
                    9345 RFM69:SWR:SEND,TO=0,RETRY=0
                    9361 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-51
                    9365 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=2
                    9369 RFM69:PTX:LEVEL=2 dBm
                    9373 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:47.0
                    H: 47
                    9381 RFM69:SWR:SEND,TO=0,RETRY=0
                    9396 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-49
                    9400 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=1
                    9406 RFM69:PTX:LEVEL=1 dBm
                    9408 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-51
                    9916 RFM69:SWR:SEND,TO=0,RETRY=0
                    9934 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-50
                    9938 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=0
                    9943 RFM69:PTX:LEVEL=0 dBm
                    9947 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-52
                    10156 RFM69:SWR:SEND,TO=0,RETRY=0
                    10168 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-51
                    10172 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-1
                    10178 RFM69:PTX:LEVEL=-1 dBm
                    10180 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:58
                    11190 RFM69:SWR:SEND,TO=0,RETRY=0
                    11206 RFM69:SWR:ACK,FROM=0,SEQ=28,RSSI=-51
                    11212 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-2
                    11216 RFM69:PTX:LEVEL=-2 dBm
                    11220 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
                    11229 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                    11235 RFM69:SWR:SEND,TO=0,RETRY=0
                    11253 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-52
                    11257 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-3
                    11261 RFM69:PTX:LEVEL=-3 dBm
                    11266 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                    11450 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                    11458 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                    11776 TSF:TDI:TSL
                    11778 RFM69:RSL
                    Sketch
                    #include <Adafruit_SHT31.h>
                    #include <Adafruit_Sensor.h>
                    #define MY_DEBUG  // Enable debug prints
                    //#define MY_RADIO_NRF24
                    #define MY_RADIO_RFM69
                    #define MY_RFM69_FREQUENCY RFM69_433MHZ
                    #define MY_RFM69_NEW_DRIVER
                    //#define MY_IS_RFM69HW
                    #define MY_TRANSPORT_WAIT_READY_MS 10000
                    //#define MY_NODE_ID 16
                    #define VBAT_VCC
                    //Enable OTA feature
                    #define MY_OTA_FIRMWARE_FEATURE
                    #define MY_OTA_FLASH_JDECID 0x00
                    #define CHILD_ID_HUM 0
                    #define CHILD_ID_TEMP 1
                    #define CHILD_ID_VBAT 201						 // Battery voltage
                    unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
                    #define SKETCH_NAME "TEMP HUM"                // Change to a fancy name you like
                    #define SKETCH_VERSION "1.2"                    // Your version
                    float lastTemp;
                    float lastHum;
                    boolean metric = true;
                    MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE);
                    Adafruit_SHT31 sht31 = Adafruit_SHT31();
                    #ifdef MY_RADIO_RFM69
                    	int rssi;                                    // RSSI RFM69 chip
                    	#define CHILD_ID_RSSI_HIGH  202                // RSSI received signal level
                    	#define CHILD_ID_RSSI_LOW   203                // RSSI background noise level
                      #define CHILD_ID_POWER 204
                    	MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_LEVEL);
                    	MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_LEVEL);
                      MyMessage msgPWR(CHILD_ID_POWER, V_LIGHT_LEVEL);
                    //#define VBAT_PER_BITS 0.005448028                 //
                    #define VMIN 2.8                                  //  Vmin (radio Min Volt)=1.9V (564v)
                    #define VMAX 3.4                                 //  Vmax = (2xAA bat)=3.0V (892v)
                    int batteryPcnt , PwrPcnt = 0;                    // Calc value for battery %
                    #ifdef VBAT_VCC
                    #include <Vcc.h>
                    	const float VccCorrection = 1.0 / 1.0;  // Measured Vcc by multimeter divided by reported Vcc
                    	Vcc vcc(VccCorrection);
                    #endif // VBAT_VCC
                    	// metric = getControllerConfig().isMetric;
                    	if (!sht31.begin(0x44)) {   // Set to 0x45 for alternate i2c addr
                    		Serial.println("Couldn't find SHT31");
                    		//while (1) delay(1);
                    	present(CHILD_ID_HUM, S_HUM);
                    	present(CHILD_ID_RSSI_HIGH, S_SOUND);
                    	present(CHILD_ID_RSSI_LOW, S_SOUND);
                      present(CHILD_ID_POWER, S_LIGHT_LEVEL);
                    	present(CHILD_ID_VBAT, S_MULTIMETER);
                      if (!isFirmwareUpdateOngoing())
                    	// Fetch temperatures from SHT sensor
                    	float temperature = sht31.readTemperature();
                    	//temperature = round(temperature*10)/10; //round to 1 decimal place
                    	if (isnan(temperature)) {
                    		Serial.println("Failed reading temperature from SHT31");
                    	else if (temperature != lastTemp) {
                    		lastTemp = temperature;
                    		send(msgTemp.set(temperature, 2));
                    		Serial.print("T: ");
                    	// Fetch humidity from SHT sensor
                    	uint8_t humidity = sht31.readHumidity();
                    	if (isnan(humidity)) {
                    		Serial.println("Failed reading humidity from SHT");
                    	else if (humidity != lastHum) {
                    		lastHum = humidity;
                    		Serial.print("H: ");
                    		Serial.println(humidity);
                    	rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
                    	send(msgRSSI1.set(rssi));                  // send RSSI level
                    	wait(500);                                 // wait to get idle
                    	rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
                    	send(msgRSSI2.set(rssi));                  // send RSSI level
                     	wait(200);                                 // wait for next send
                      PwrPcnt = RFM69_getTxPowerPercent();      // read TX Power in RFM69
                      send(msgPWR.set(PwrPcnt));            // send TX Power
                    	batM();
                    	smartSleep(SLEEP_TIME); //sleep a bit
                    	delay(500);
                    	float Vbat;
                    	int batteryPcnt;
                      	// Battery monitoring reading
                    #ifdef VBAT_VCC
                    	Vbat = vcc.Read_Volts();
                    	batteryPcnt = vcc.Read_Perc(VMIN, VMAX);
                    	Vbat = (sensorValue * VBAT_PER_BITS) - 0.2 ;
                    	// Calculate the battery in %
                    	batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN))*100.);
                      delay(500);
                    	send(msgVBat.set(Vbat, 2));
                    	//Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
                    	if (batLoop > 2) {
                    		if (batteryPcnt > 100) {
                    			batteryPcnt = 100;
                    		batLoop = 0;
                    		batLoop++;
                      Here is the firmware upload that finally I managed to start, of course I only cut the first part
                      49 TSM:INIT
                      51 TSF:WUR:MS=10000
                      53 RFM69:INIT
                      61 TSM:INIT:TSP OK
                      63 TSF:SID:OK,ID=16
                      65 TSM:FPAR
                      126 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      133 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      139 TSF:MSG:FPAR OK,ID=0,D=1
                      337 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      344 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      2082 TSM:FPAR:OK
                      2082 TSM:ID
                      2084 TSM:ID:OK
                      2086 TSM:UPL
                      2105 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-44
                      2109 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=4
                      2113 RFM69:PTX:LEVEL=4 dBm
                      2117 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                      2123 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      2131 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      2138 TSF:MSG:PONG RECV,HP=1
                      2142 TSM:UPL:OK
                      2144 TSM:READY:ID=16,PAR=0,DIS=1
                      2146 RFM69:SWR:SEND,TO=0,RETRY=0
                      2168 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-43
                      2172 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
                      2177 RFM69:PTX:LEVEL=3 dBm
                      2181 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
                      2191 RFM69:SWR:SEND,TO=0,RETRY=0
                      2205 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-44
                      2209 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
                      2213 RFM69:PTX:LEVEL=2 dBm
                      2217 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      2224 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      2232 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      2240 RFM69:SWR:SEND,TO=0,RETRY=0
                      2258 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-45
                      2263 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=1
                      2269 RFM69:PTX:LEVEL=1 dBm
                      2271 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                      2279 RFM69:SWR:SEND,TO=0,RETRY=0
                      2295 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-71
                      2299 RFM69:ATC:ADJ TXL,cR=-71,tR=-80,TXL=0
                      2304 RFM69:PTX:LEVEL=0 dBm
                      2308 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                      2334 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                      2342 TSF:MSG:READ,0-0-16,s=255,c=4,t=1,pt=6,l=8,sg=0:02000400600466EF
                      2351 OTA:FWP:UPDATE
                      2467 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                      2471 RFM69:SWR:SEND,TO=0,RETRY=0
                      2682 !RFM69:SWR:NACK
                      2684 RFM69:PTX:LEVEL=1 dBm
                      2719 RFM69:SWR:SEND,TO=0,RETRY=1
                      2928 !RFM69:SWR:NACK
                      2930 RFM69:PTX:LEVEL=2 dBm
                      2965 RFM69:SWR:SEND,TO=0,RETRY=2
                      3174 !RFM69:SWR:NACK
                      3176 RFM69:PTX:LEVEL=3 dBm
                      3186 RFM69:SWR:SEND,TO=0,RETRY=3
                      3395 !RFM69:SWR:NACK
                      3397 RFM69:PTX:LEVEL=4 dBm
                      3440 RFM69:SWR:SEND,TO=0,RETRY=4
                      3649 !RFM69:SWR:NACK
                      3651 RFM69:PTX:LEVEL=5 dBm
                      3694 RFM69:SWR:SEND,TO=0,RETRY=5
                      3903 !RFM69:SWR:NACK
                      3905 RFM69:PTX:LEVEL=6 dBm
                      3940 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005F04
                      3948 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      3956 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      3962 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                      3966 RFM69:SWR:SEND,TO=0,RETRY=0
                      4177 !RFM69:SWR:NACK
                      4179 RFM69:PTX:LEVEL=7 dBm
                      4190 RFM69:SWR:SEND,TO=0,RETRY=1
                      4399 !RFM69:SWR:NACK
                      4401 RFM69:PTX:LEVEL=8 dBm
                      4435 RFM69:SWR:SEND,TO=0,RETRY=2
                      4644 !RFM69:SWR:NACK
                      4646 RFM69:PTX:LEVEL=9 dBm
                      4657 RFM69:SWR:SEND,TO=0,RETRY=3
                      4866 !RFM69:SWR:NACK
                      4868 RFM69:PTX:LEVEL=10 dBm
                      4911 RFM69:SWR:SEND,TO=0,RETRY=4
                      5046 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-39
                      5050 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=9
                      5054 RFM69:PTX:LEVEL=9 dBm
                      5058 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005F04
                      5066 RFM69:SWR:SEND,TO=0,RETRY=0
                      5083 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-63
                      5087 RFM69:ATC:ADJ TXL,cR=-63,tR=-80,TXL=8
                      5091 RFM69:PTX:LEVEL=8 dBm
                      5093 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
                      5103 RFM69:SWR:SEND,TO=0,RETRY=0
                      5310 !RFM69:SWR:NACK
                      5312 RFM69:PTX:LEVEL=9 dBm
                      5347 RFM69:SWR:SEND,TO=0,RETRY=1
                      5554 !RFM69:SWR:NACK
                      5556 RFM69:PTX:LEVEL=10 dBm
                      5599 RFM69:SWR:SEND,TO=0,RETRY=2
                      5806 !RFM69:SWR:NACK
                      5808 RFM69:PTX:LEVEL=11 dBm
                      5842 RFM69:SWR:SEND,TO=0,RETRY=3
                      6049 !RFM69:SWR:NACK
                      6051 RFM69:PTX:LEVEL=12 dBm
                      6062 RFM69:SWR:SEND,TO=0,RETRY=4
                      6268 !RFM69:SWR:NACK
                      6270 RFM69:PTX:LEVEL=13 dBm
                      6305 RFM69:SWR:SEND,TO=0,RETRY=5
                      6512 !RFM69:SWR:NACK
                      6514 RFM69:PTX:NO ADJ
                      6549 !TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.2
                      6557 RFM69:SWR:SEND,TO=0,RETRY=0
                      6580 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
                      6584 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                      6588 RFM69:PTX:LEVEL=12 dBm
                      6590 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                      6598 RFM69:SWR:SEND,TO=0,RETRY=0
                      6615 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-37
                      6619 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=11
                      6623 RFM69:PTX:LEVEL=11 dBm
                      6627 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                      6633 RFM69:SWR:SEND,TO=0,RETRY=0
                      6651 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-38
                      6656 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=10
                      6660 RFM69:PTX:LEVEL=10 dBm
                      6662 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                      6670 RFM69:SWR:SEND,TO=0,RETRY=0
                      6686 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-48
                      6692 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=9
                      6696 RFM69:PTX:LEVEL=9 dBm
                      6699 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                      6707 RFM69:SWR:SEND,TO=0,RETRY=0
                      6723 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-48
                      6729 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=8
                      6733 RFM69:PTX:LEVEL=8 dBm
                      6735 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                      6744 RFM69:SWR:SEND,TO=0,RETRY=0
                      6760 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-40
                      6764 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=7
                      6770 RFM69:PTX:LEVEL=7 dBm
                      6772 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                      6780 MCO:REG:REQ
                      6782 RFM69:SWR:SEND,TO=0,RETRY=0
                      6797 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-49
                      6801 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=6
                      6807 RFM69:PTX:LEVEL=6 dBm
                      6809 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                      6817 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                      6825 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      6832 MCO:PIM:NODE REG=1
                      6834 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                      6838 RFM69:SWR:SEND,TO=0,RETRY=0
                      6862 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-42
                      6866 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
                      6871 RFM69:PTX:LEVEL=5 dBm
                      6873 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005F04
                      6883 MCO:BGN:STP
                      7395 MCO:BGN:INIT OK,TSP=1
                      7397 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      7405 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005F04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      7415 OTA:FWP:RECV B=045F
                      7419 OTA:FRQ:FW REQ,T=0002,V=0004,B=045E
                      7424 RFM69:SWR:SEND,TO=0,RETRY=0
                      7440 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-43
                      7446 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
                      7450 RFM69:PTX:LEVEL=4 dBm
                      7452 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005E04
                      7512 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      7520 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005E04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      7530 OTA:FWP:RECV B=045E
                      7534 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                      7538 RFM69:SWR:SEND,TO=0,RETRY=0
                      7555 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-44
                      7561 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                      7565 RFM69:PTX:LEVEL=3 dBm
                      7567 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                      8036 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                      8040 RFM69:SWR:SEND,TO=0,RETRY=0
                      8249 !RFM69:SWR:NACK
                      8251 RFM69:PTX:LEVEL=4 dBm
                      8286 RFM69:SWR:SEND,TO=0,RETRY=1
                      8495 !RFM69:SWR:NACK
                      8497 RFM69:PTX:LEVEL=5 dBm
                      8531 RFM69:SWR:SEND,TO=0,RETRY=2
                      8740 !RFM69:SWR:NACK
                      8742 RFM69:PTX:LEVEL=6 dBm
                      8753 RFM69:SWR:SEND,TO=0,RETRY=3
                      8962 !RFM69:SWR:NACK
                      8964 RFM69:PTX:LEVEL=7 dBm
                      9007 RFM69:SWR:SEND,TO=0,RETRY=4
                      9029 RFM69:SWR:ACK,FROM=0,SEQ=30,RSSI=-41
                      9033 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=6
                      9037 RFM69:PTX:LEVEL=6 dBm
                      9039 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                      9050 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                      9054 RFM69:SWR:SEND,TO=0,RETRY=0
                      9074 RFM69:SWR:ACK,FROM=0,SEQ=31,RSSI=-42
                      9078 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
                      9082 RFM69:PTX:LEVEL=5 dBm
                      9086 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                      9127 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      9136 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9146 OTA:FWP:RECV B=045D
                      9148 OTA:FRQ:FW REQ,T=0002,V=0004,B=045C
                      9152 RFM69:SWR:SEND,TO=0,RETRY=0
                      9172 RFM69:SWR:ACK,FROM=0,SEQ=33,RSSI=-43
                      9177 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
                      9181 RFM69:PTX:LEVEL=4 dBm
                      9183 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005C04
                      9234 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      9242 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9252 OTA:FWP:RECV B=045D
                      9254 !OTA:FWP:WRONG FWB
                      9451 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                      9459 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9469 OTA:FWP:RECV B=045D
                      9472 !OTA:FWP:WRONG FWB
                      9480 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      9488 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005C04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9500 OTA:FWP:RECV B=045C
                      9502 OTA:FRQ:FW REQ,T=0002,V=0004,B=045B
                      9506 RFM69:SWR:SEND,TO=0,RETRY=0
                      9525 RFM69:SWR:ACK,FROM=0,SEQ=37,RSSI=-44
                      9529 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                      9533 RFM69:PTX:LEVEL=3 dBm
                      9537 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005B04
                      9637 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      9646 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005B04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9658 OTA:FWP:RECV B=045B
                      9660 OTA:FRQ:FW REQ,T=0002,V=0004,B=045A
                      9664 RFM69:SWR:SEND,TO=0,RETRY=0
                      9682 RFM69:SWR:ACK,FROM=0,SEQ=39,RSSI=-44
                      9687 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
                      9691 RFM69:PTX:LEVEL=2 dBm
                      9695 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005A04
                      9725 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      9734 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005A04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9744 OTA:FWP:RECV B=045A
                      9746 OTA:FRQ:FW REQ,T=0002,V=0004,B=0459
                      9750 RFM69:SWR:SEND,TO=0,RETRY=0
                      9768 RFM69:SWR:ACK,FROM=0,SEQ=41,RSSI=-46
                      9775 RFM69:ATC:ADJ TXL,cR=-46,tR=-80,TXL=1
                      9779 RFM69:PTX:LEVEL=1 dBm
                      9781 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005904
                      9834 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      9842 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005904FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9854 OTA:FWP:RECV B=0459
                      9857 OTA:FRQ:FW REQ,T=0002,V=0004,B=0458
                      9861 RFM69:SWR:SEND,TO=0,RETRY=0
                      9879 RFM69:SWR:ACK,FROM=0,SEQ=43,RSSI=-48
                      9883 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=0
                      9889 RFM69:PTX:LEVEL=0 dBm
                      9891 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005804
                      9934 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                      9943 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005804FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                      9953 OTA:FWP:RECV B=0458
                      9957 OTA:FRQ:FW REQ,T=0002,V=0004,B=0457
                      9961 RFM69:SWR:SEND,TO=0,RETRY=0
                      9979 RFM69:SWR:ACK,FROM=0,SEQ=45,RSSI=-47
                      9984 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=-1
                      9988 RFM69:PTX:LEVEL=-1 dBm
                      9992 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005704
                      10043 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      10051 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005704250054454D502048554D00312E310000
                      10061 OTA:FWP:RECV B=0457
                      10065 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
                      10070 RFM69:SWR:SEND,TO=0,RETRY=0
                      10280 !RFM69:SWR:NACK
                      10283 RFM69:PTX:LEVEL=0 dBm
                      10317 RFM69:SWR:SEND,TO=0,RETRY=1
                      10526 !RFM69:SWR:NACK
                      10528 RFM69:PTX:LEVEL=1 dBm
                      10530 RFM69:SWR:SEND,TO=0,RETRY=2
                      10741 !RFM69:SWR:NACK
                      10743 RFM69:PTX:LEVEL=2 dBm
                      10786 RFM69:SWR:SEND,TO=0,RETRY=3
                      10995 !RFM69:SWR:NACK
                      10997 RFM69:PTX:LEVEL=3 dBm
                      11040 RFM69:SWR:SEND,TO=0,RETRY=4
                      11249 !RFM69:SWR:NACK
                      11251 RFM69:PTX:LEVEL=4 dBm
                      11294 RFM69:SWR:SEND,TO=0,RETRY=5
                      11468 RFM69:SWR:ACK,FROM=0,SEQ=47,RSSI=-43
                      11472 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
                      11476 RFM69:PTX:LEVEL=3 dBm
                      11481 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
                      11489 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
                      11493 RFM69:SWR:SEND,TO=0,RETRY=0
                      11513 RFM69:SWR:ACK,FROM=0,SEQ=48,RSSI=-87
                      11520 RFM69:ATC:ADJ TXL,cR=-87,tR=-80,TXL=4
                      11524 RFM69:PTX:LEVEL=4 dBm
                      11526 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
                      11536 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      11544 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
                      11554 OTA:FWP:RECV B=0456
                      11558 OTA:FRQ:FW REQ,T=0002,V=0004,B=0455
                      11563 RFM69:SWR:SEND,TO=0,RETRY=0
                      11581 RFM69:SWR:ACK,FROM=0,SEQ=50,RSSI=-44
                      11585 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                      11589 RFM69:PTX:LEVEL=3 dBm
                      11593 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005504
                      11741 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      11749 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
                      11761 OTA:FWP:RECV B=0456
                      11763 !OTA:FWP:WRONG FWB
                      11833 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                      11841 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040055045400483A200042617474657279204176
                      11851 OTA:FWP:RECV B=0455
                      11855 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
                      11859 RFM69:SWR:SEND,TO=0,RETRY=0
                      12070 !RFM69:SWR:NACK
                      12072 RFM69:PTX:LEVEL=4 dBm
                      12083 RFM69:SWR:SEND,TO=0,RETRY=1
                      12294 !RFM69:SWR:NACK
                      12296 RFM69:PTX:LEVEL=5 dBm
                      12339 RFM69:SWR:SEND,TO=0,RETRY=2
                      12548 !RFM69:SWR:NACK
                      12550 RFM69:PTX:LEVEL=6 dBm
                      12593 RFM69:SWR:SEND,TO=0,RETRY=3
                      12802 !RFM69:SWR:NACK
                      12804 RFM69:PTX:LEVEL=7 dBm
                      12847 RFM69:SWR:SEND,TO=0,RETRY=4
                      13056 !RFM69:SWR:NACK
                      13058 RFM69:PTX:LEVEL=8 dBm
                      13092 RFM69:SWR:SEND,TO=0,RETRY=5
                      13273 RFM69:SWR:ACK,FROM=0,SEQ=53,RSSI=-41
                      13277 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=7
                      13283 RFM69:PTX:LEVEL=7 dBm
                      13285 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
                      13293 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
                      13299 RFM69:SWR:SEND,TO=0,RETRY=0
                      13320 RFM69:SWR:ACK,FROM=0,SEQ=54,RSSI=-42
                      13324 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=6
                      13330 RFM69:PTX:LEVEL=6 dBm
                      13332 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
                      13342 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      13350 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
                      13361 OTA:FWP:RECV B=0454
                      13365 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
                      13369 RFM69:SWR:SEND,TO=0,RETRY=0
                      13580 !RFM69:SWR:NACK
                      13582 RFM69:PTX:LEVEL=7 dBm
                      13584 RFM69:SWR:SEND,TO=0,RETRY=1
                      13795 !RFM69:SWR:NACK
                      13797 RFM69:PTX:LEVEL=8 dBm
                      13807 RFM69:SWR:SEND,TO=0,RETRY=2
                      14016 !RFM69:SWR:NACK
                      14018 RFM69:PTX:LEVEL=9 dBm
                      14053 RFM69:SWR:SEND,TO=0,RETRY=3
                      14262 !RFM69:SWR:NACK
                      14264 RFM69:PTX:LEVEL=10 dBm
                      14307 RFM69:SWR:SEND,TO=0,RETRY=4
                      14516 !RFM69:SWR:NACK
                      14518 RFM69:PTX:LEVEL=11 dBm
                      14561 RFM69:SWR:SEND,TO=0,RETRY=5
                      14770 !RFM69:SWR:NACK
                      14772 RFM69:PTX:LEVEL=12 dBm
                      14815 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005304
                      14823 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      14831 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
                      14841 OTA:FWP:RECV B=0454
                      14845 !OTA:FWP:WRONG FWB
                      14848 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
                      14852 RFM69:SWR:SEND,TO=0,RETRY=0
                      15063 !RFM69:SWR:NACK
                      15065 RFM69:PTX:LEVEL=13 dBm
                      15075 RFM69:SWR:SEND,TO=0,RETRY=1
                      15284 !RFM69:SWR:NACK
                      15286 RFM69:PTX:NO ADJ
                      15329 RFM69:SWR:SEND,TO=0,RETRY=2
                      15538 !RFM69:SWR:NACK
                      15540 RFM69:PTX:NO ADJ
                      15583 RFM69:SWR:SEND,TO=0,RETRY=3
                      15792 !RFM69:SWR:NACK
                      15794 RFM69:PTX:NO ADJ
                      15828 RFM69:SWR:SEND,TO=0,RETRY=4
                      16037 !RFM69:SWR:NACK
                      16039 RFM69:PTX:NO ADJ
                      16050 RFM69:SWR:SEND,TO=0,RETRY=5
                      16191 RFM69:SWR:ACK,FROM=0,SEQ=58,RSSI=-39
                      16195 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                      16201 RFM69:PTX:LEVEL=12 dBm
                      16203 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005304
                      16214 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      16222 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
                      16232 OTA:FWP:RECV B=0453
                      16234 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
                      16240 RFM69:SWR:SEND,TO=0,RETRY=0
                      16449 !RFM69:SWR:NACK
                      16451 RFM69:PTX:LEVEL=13 dBm
                      16494 RFM69:SWR:SEND,TO=0,RETRY=1
                      16703 !RFM69:SWR:NACK
                      16705 RFM69:PTX:NO ADJ
                      16740 RFM69:SWR:SEND,TO=0,RETRY=2
                      16949 !RFM69:SWR:NACK
                      16951 RFM69:PTX:NO ADJ
                      16994 RFM69:SWR:SEND,TO=0,RETRY=3
                      17203 !RFM69:SWR:NACK
                      17205 RFM69:PTX:NO ADJ
                      17248 RFM69:SWR:SEND,TO=0,RETRY=4
                      17457 !RFM69:SWR:NACK
                      17459 RFM69:PTX:NO ADJ
                      17502 RFM69:SWR:SEND,TO=0,RETRY=5
                      17625 RFM69:SWR:ACK,FROM=0,SEQ=60,RSSI=-39
                      17631 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                      17635 RFM69:PTX:LEVEL=12 dBm
                      17637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
                      17647 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      17655 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
                      17666 OTA:FWP:RECV B=0453
                      17668 !OTA:FWP:WRONG FWB
                      17672 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
                      17676 RFM69:SWR:SEND,TO=0,RETRY=0
                      17690 RFM69:SWR:ACK,FROM=0,SEQ=62,RSSI=-39
                      17694 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=11
                      17700 RFM69:PTX:LEVEL=11 dBm
                      17702 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
                      17731 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      17739 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
                      17750 OTA:FWP:RECV B=0452
                      17754 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
                      17758 RFM69:SWR:SEND,TO=0,RETRY=0
                      17969 !RFM69:SWR:NACK
                      17971 RFM69:PTX:LEVEL=12 dBm
                      18014 RFM69:SWR:SEND,TO=0,RETRY=1
                      18223 !RFM69:SWR:NACK
                      18225 RFM69:PTX:LEVEL=13 dBm
                      18259 RFM69:SWR:SEND,TO=0,RETRY=2
                      18468 !RFM69:SWR:NACK
                      18470 RFM69:PTX:NO ADJ
                      18481 RFM69:SWR:SEND,TO=0,RETRY=3
                      18690 !RFM69:SWR:NACK
                      18692 RFM69:PTX:NO ADJ
                      18735 RFM69:SWR:SEND,TO=0,RETRY=4
                      18944 !RFM69:SWR:NACK
                      18946 RFM69:PTX:NO ADJ
                      18980 RFM69:SWR:SEND,TO=0,RETRY=5
                      19079 RFM69:SWR:ACK,FROM=0,SEQ=64,RSSI=-39
                      19085 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                      19089 RFM69:PTX:LEVEL=12 dBm
                      19091 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
                      19101 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      19109 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
                      19120 OTA:FWP:RECV B=0452
                      19124 !OTA:FWP:WRONG FWB
                      19126 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
                      19130 RFM69:SWR:SEND,TO=0,RETRY=0
                      19341 !RFM69:SWR:NACK
                      19343 RFM69:PTX:LEVEL=13 dBm
                      19345 RFM69:SWR:SEND,TO=0,RETRY=1
                      19556 !RFM69:SWR:NACK
                      19558 RFM69:PTX:NO ADJ
                      19568 RFM69:SWR:SEND,TO=0,RETRY=2
                      19777 !RFM69:SWR:NACK
                      19779 RFM69:PTX:NO ADJ
                      19822 RFM69:SWR:SEND,TO=0,RETRY=3
                      20031 !RFM69:SWR:NACK
                      20033 RFM69:PTX:NO ADJ
                      20068 RFM69:SWR:SEND,TO=0,RETRY=4
                      20277 !RFM69:SWR:NACK
                      20279 RFM69:PTX:NO ADJ
                      20322 RFM69:SWR:SEND,TO=0,RETRY=5
                      20482 RFM69:SWR:ACK,FROM=0,SEQ=66,RSSI=-39
                      20486 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                      20490 RFM69:PTX:LEVEL=12 dBm
                      20494 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
                      20502 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                      20510 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040051046D70657261747572652066726F6D2053
                      20520 OTA:FWP:RECV B=0451
                      20525 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
                      20529 RFM69:SWR:SEND,TO=0,RETRY=0
                      20740 !RFM69:SWR:NACK
                      20742 RFM69:PTX:LEVEL=13 dBm
                      20785 RFM69:SWR:SEND,TO=0,RETRY=1
                      20994 !RFM69:SWR:NACK
                      20996 RFM69:PTX:NO ADJ
                      21039 RFM69:SWR:SEND,TO=0,RETRY=2
                      21248 !RFM69:SWR:NACK
                      21250 RFM69:PTX:NO ADJ
                      21284 RFM69:SWR:SEND,TO=0,RETRY=3
                      21493 !RFM69:SWR:NACK
                      21495 RFM69:PTX:NO ADJ
                      21538 RFM69:SWR:SEND,TO=0,RETRY=4
                      21747 !RFM69:SWR:NACK
                      21749 RFM69:PTX:NO ADJ
                      21792 RFM69:SWR:SEND,TO=0,RETRY=5
                      21884 RFM69:SWR:ACK,FROM=0,SEQ=68,RSSI=-37
                      21889 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
                      21895 RFM69:PTX:LEVEL=12 dBm
                      21897 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
                      21907 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
                      21911 RFM69:SWR:SEND,TO=0,RETRY=0
                      22122 !RFM69:SWR:NACK
                      22124 RFM69:PTX:LEVEL=13 dBm
                      22159 RFM69:SWR:SEND,TO=0,RETRY=1
                      22368 !RFM69:SWR:NACK
                      22370 RFM69:PTX:NO ADJ
                      22372 RFM69:SWR:SEND,TO=0,RETRY=2
                      22583 !RFM69:SWR:NACK
                      22585 RFM69:PTX:NO ADJ
                      22628 RFM69:SWR:SEND,TO=0,RETRY=3
                      22837 !RFM69:SWR:NACK
                      22839 RFM69:PTX:NO ADJ
                      22882 RFM69:SWR:SEND,TO=0,RETRY=4
                      23091 !RFM69:SWR:NACK
                      23093 RFM69:PTX:NO ADJ
                      23136 RFM69:SWR:SEND,TO=0,RETRY=5
                      23343 RFM69:SWR:ACK,FROM=0,SEQ=69,RSSI=-37
                      23347 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
                      23353 RFM69:PTX:LEVEL=12 dBm
                      23355 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
                      23365 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      23373 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400500461696C65642072656164696E67207465
                      23384 OTA:FWP:RECV B=0450
                      23386 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                      23392 RFM69:SWR:SEND,TO=0,RETRY=0
                      23601 !RFM69:SWR:NACK
                      23603 RFM69:PTX:LEVEL=13 dBm
                      23646 RFM69:SWR:SEND,TO=0,RETRY=1
                      23855 !RFM69:SWR:NACK
                      23857 RFM69:PTX:NO ADJ
                      23891 RFM69:SWR:SEND,TO=0,RETRY=2
                      24100 !RFM69:SWR:NACK
                      24102 RFM69:PTX:NO ADJ
                      24113 RFM69:SWR:SEND,TO=0,RETRY=3
                      24322 !RFM69:SWR:NACK
                      24324 RFM69:PTX:NO ADJ
                      24367 RFM69:SWR:SEND,TO=0,RETRY=4
                      24576 !RFM69:SWR:NACK
                      24578 RFM69:PTX:NO ADJ
                      24612 RFM69:SWR:SEND,TO=0,RETRY=5
                      24758 RFM69:SWR:ACK,FROM=0,SEQ=71,RSSI=-38
                      24762 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                      24766 RFM69:PTX:LEVEL=12 dBm
                      24770 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                      24778 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                      24782 RFM69:SWR:SEND,TO=0,RETRY=0
                      24993 !RFM69:SWR:NACK
                      24995 RFM69:PTX:LEVEL=13 dBm
                      25006 RFM69:SWR:SEND,TO=0,RETRY=1
                      25214 !RFM69:SWR:NACK
                      25217 RFM69:PTX:NO ADJ
                      25251 RFM69:SWR:SEND,TO=0,RETRY=2
                      25460 !RFM69:SWR:NACK
                      25462 RFM69:PTX:NO ADJ
                      25505 RFM69:SWR:SEND,TO=0,RETRY=3
                      25714 !RFM69:SWR:NACK
                      25716 RFM69:PTX:NO ADJ
                      25759 RFM69:SWR:SEND,TO=0,RETRY=4
                      25968 !RFM69:SWR:NACK
                      25970 RFM69:PTX:NO ADJ
                      26005 RFM69:SWR:SEND,TO=0,RETRY=5
                      26183 RFM69:SWR:ACK,FROM=0,SEQ=72,RSSI=-38
                      26189 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                      26193 RFM69:PTX:LEVEL=12 dBm
                      26195 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                      26206 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                      26210 RFM69:SWR:SEND,TO=0,RETRY=0
                      26421 !RFM69:SWR:NACK
                      26423 RFM69:PTX:LEVEL=13 dBm
                      26466 RFM69:SWR:SEND,TO=0,RETRY=1
                      26675 !RFM69:SWR:NACK
                      26677 RFM69:PTX:NO ADJ
                      26720 RFM69:SWR:SEND,TO=0,RETRY=2
                      26929 !RFM69:SWR:NACK
                      26931 RFM69:PTX:NO ADJ
                      26974 RFM69:SWR:SEND,TO=0,RETRY=3
                      27183 !RFM69:SWR:NACK
                      27185 RFM69:PTX:NO ADJ
                      27219 RFM69:SWR:SEND,TO=0,RETRY=4
                      27428 !RFM69:SWR:NACK
                      27430 RFM69:PTX:NO ADJ
                      27441 RFM69:SWR:SEND,TO=0,RETRY=5
                      27555 RFM69:SWR:ACK,FROM=0,SEQ=73,RSSI=-41
                      27561 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=12
                      27566 RFM69:PTX:LEVEL=12 dBm
                      27568 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                      27578 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                      27586 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
                      27596 OTA:FWP:RECV B=044F
                      27600 OTA:FRQ:FW REQ,T=0002,V=0004,B=044E
                      27604 RFM69:SWR:SEND,TO=0,RETRY=0
                      27625 RFM69:SWR:ACK,FROM=0,SEQ=75,RSSI=-42
                      27629 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=11
                      27633 RFM69:PTX:LEVEL=11 dBm
                      27637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004E04
                      27645 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                      27654 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
                      27666 OTA:FWP:RECV B=044F
                      27668 !OTA:FWP:WRONG FWB
                      27742 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                      27750 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004E0400000098196819C8193C1960194C193D
                      27760 OTA:FWP:RECV B=044E
                      27762 OTA:FRQ:FW REQ,T=0002,V=0004,B=044D
                      27768 RFM69:SWR:SEND,TO=0,RETRY=0
                      27789 RFM69:SWR:ACK,FROM=0,SEQ=78,RSSI=-43
                      27793 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                      27797 RFM69:PTX:LEVEL=10 dBm
                      27801 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004D04
                      27850 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                      27858 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004D0400530BC00AEB0A9A0B1C0BFA0A0E0B00
                      27869 OTA:FWP:RECV B=044D
                      27873 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                      27877 RFM69:SWR:SEND,TO=0,RETRY=0
                      28088 !RFM69:SWR:NACK
                      28090 RFM69:PTX:LEVEL=11 dBm
                      28133 RFM69:SWR:SEND,TO=0,RETRY=1
                      28342 !RFM69:SWR:NACK
                      28344 RFM69:PTX:LEVEL=12 dBm
                      28387 RFM69:SWR:SEND,TO=0,RETRY=2
                      28596 !RFM69:SWR:NACK
                      28598 RFM69:PTX:LEVEL=13 dBm
                      28641 RFM69:SWR:SEND,TO=0,RETRY=3
                      28850 !RFM69:SWR:NACK
                      28852 RFM69:PTX:NO ADJ
                      28895 RFM69:SWR:SEND,TO=0,RETRY=4
                      29104 !RFM69:SWR:NACK
                      29106 RFM69:PTX:NO ADJ
                      29140 RFM69:SWR:SEND,TO=0,RETRY=5
                      29233 RFM69:SWR:ACK,FROM=0,SEQ=80,RSSI=-39
                      29237 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                      29241 RFM69:PTX:LEVEL=12 dBm
                      29245 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                      29253 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                      29257 RFM69:SWR:SEND,TO=0,RETRY=0
                      29278 RFM69:SWR:ACK,FROM=0,SEQ=81,RSSI=-45
                      29282 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=11
                      29286 RFM69:PTX:LEVEL=11 dBm
                      29290 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                      29755 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                      29759 RFM69:SWR:SEND,TO=0,RETRY=0
                      29775 RFM69:SWR:ACK,FROM=0,SEQ=82,RSSI=-47
                      29782 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=10
                      29786 RFM69:PTX:LEVEL=10 dBm
                      29790 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                      30025 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                      30033 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004C0407070707070707070707070103000000
                      30044 OTA:FWP:RECV B=044C
                      30048 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
                      30052 RFM69:SWR:SEND,TO=0,RETRY=0
                      30263 !RFM69:SWR:NACK
                      30265 RFM69:PTX:LEVEL=11 dBm
                      30308 RFM69:SWR:SEND,TO=0,RETRY=1
                      30517 !RFM69:SWR:NACK
                      30519 RFM69:PTX:LEVEL=12 dBm
                      30562 RFM69:SWR:SEND,TO=0,RETRY=2
                      30771 !RFM69:SWR:NACK
                      30773 RFM69:PTX:LEVEL=13 dBm
                      30816 RFM69:SWR:SEND,TO=0,RETRY=3
                      31025 !RFM69:SWR:NACK
                      31027 RFM69:PTX:NO ADJ
                      31070 RFM69:SWR:SEND,TO=0,RETRY=4
                      31279 !RFM69:SWR:NACK
                      31281 RFM69:PTX:NO ADJ
                      31315 RFM69:SWR:SEND,TO=0,RETRY=5
                      31449 RFM69:SWR:ACK,FROM=0,SEQ=84,RSSI=-39
                      31453 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                      31457 RFM69:PTX:LEVEL=12 dBm
                      31461 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004B04
                      31469 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
                      31473 RFM69:SWR:SEND,TO=0,RETRY=0
                      31696 !RFM69:SWR:NACK
                      31698 RFM69:PTX:LEVEL=13 dBm
                      31709 RFM69:SWR:SEND,TO=0,RETRY=1
                      31918 !RFM69:SWR:NACK
                      31920 RFM69:PTX:NO ADJ
                      31954 RFM69:SWR:SEND,TO=0,RETRY=2
                      32163 !RFM69:SWR:NACK
                      32165 RFM69:PTX:NO ADJ
                      32176 RFM69:SWR:SEND,TO=0,RETRY=3
                        49 TSM:INIT
                        51 TSF:WUR:MS=10000
                        53 RFM69:INIT
                        61 TSM:INIT:TSP OK
                        63 TSF:SID:OK,ID=16
                        65 TSM:FPAR
                        2082 TSM:FPAR:OK
                        2082 TSM:ID
                        2084 TSM:ID:OK
                        2086 TSM:UPL
                        2142 TSM:UPL:OK
                        2351 OTA:FWP:UPDATE
                        6780 MCO:REG:REQ
                        6883 MCO:BGN:STP
                        tekkaT
                        tekkaT
                        tekka
                        @gohan I suspect an ATC and/or timing issue - could you try this: https://github.com/tekka007/MySensors/tree/RFM69_Update
                        Update GW + node and post the full debug log for further analysis. Thanks
                          I left the myconfig.h file as the one provided but I get no communication
                          Node log
                          18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.2
                          28 TSM:INIT
                          28 TSF:WUR:MS=10000
                          30 RFM69:INIT
                          32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                          36 RFM69:PTX:LEVEL=5 dBm
                          40 TSM:INIT:TSP OK
                          43 TSF:SID:OK,ID=16
                          45 TSM:FPAR
                          45 RFM69:SWR:SEND,TO=255,RETRY=0
                          53 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          2060 !TSM:FPAR:NO REPLY
                          2062 TSM:FPAR
                          2064 RFM69:SWR:SEND,TO=255,RETRY=0
                          2070 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          4079 !TSM:FPAR:NO REPLY
                          4081 TSM:FPAR
                          4083 RFM69:SWR:SEND,TO=255,RETRY=0
                          4089 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          6100 !TSM:FPAR:NO REPLY
                          6103 TSM:FPAR
                          6105 RFM69:SWR:SEND,TO=255,RETRY=0
                          6111 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          8120 !TSM:FPAR:FAIL
                          8122 TSM:FAIL:CNT=1
                          8124 TSM:FAIL:DIS
                          8126 TSF:TDI:TSL
                          8126 RFM69:RSL
                          10031 MCO:BGN:STP
                          10543 MCO:BGN:INIT OK,TSP=0
                          11546 !MCO:SND:NODE NOT REG
                          T: 23.15
                          12052 !MCO:SND:NODE NOT REG
                          H: 47
                          12054 !MCO:SND:NODE NOT REG
                          12558 !MCO:SND:NODE NOT REG
                          12761 !MCO:SND:NODE NOT REG
                          13764 !MCO:SND:NODE NOT REG
                          13766 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                          13772 !MCO:SLP:TNR
                          18130 TSM:FAIL:RE-INIT
                          18132 TSM:INIT
                          18135 RFM69:INIT
                          18137 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                          18141 RFM69:PTX:LEVEL=5 dBm
                          18145 TSM:INIT:TSP OK
                          18147 TSF:SID:OK,ID=16
                          18149 TSM:FPAR
                          18151 RFM69:SWR:SEND,TO=255,RETRY=0
                          18157 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          20166 !TSM:FPAR:NO REPLY
                          20168 TSM:FPAR
                          20170 RFM69:SWR:SEND,TO=255,RETRY=0
                          20176 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          22188 !TSM:FPAR:NO REPLY
                          22190 TSM:FPAR
                          22192 RFM69:SWR:SEND,TO=255,RETRY=0
                          22198 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          23775 MCO:SLP:MS=589999
                          23777 !TSF:SND:TNR
                          24207 !TSM:FPAR:NO REPLY
                          24209 TSM:FPAR
                          24211 RFM69:SWR:SEND,TO=255,RETRY=0
                          24217 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          24279 TSF:TDI:TSL
                          24281 RFM69:RSL
                          GW LOG
                          mysgw: Starting gateway...
                          mysgw: Protocol version - 2.2.0-rc.2
                          mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: RFM69:INIT
                          mysgw: RFM69:INIT:PIN,CS=24,IQP=22,IQN=22
                          mysgw: RFM69:PTX:LEVEL=5 dBm
                          mysgw: TSM:INIT:TSP OK
                          mysgw: TSM:INIT:GW MODE
                          mysgw: MCO:REG:NOT NEEDED
                          mysgw: MCO:BGN:STP
                          mysgw: MCO:BGN:INIT OK,TSP=1
                          and nothing more while the node is looking for parent
                            I have tried on another RPI with the updated branch and still have no communication, if I switch back to normal development branch I get communication back. Anything more I can try?
                              @jkandasa I have managed to get FOTA do an update on the latest 2.2 but with a mod for rfm69 from tekka. I am having difficulties to trigger the OTA update even if a assign a different firmware to the node. Do you have any suggestion about this?
                              J 1 Reply Last reply
                                J
                                J
                                jkandasa
                                @gohan What the issue are you facing? AFAIK, RFM69 supports only for DualOptiboot
                                  I'm using dual optiboot, the problem is that I was only able to trigger an ota on the node the first time I set it, after that the node is no longer starting a new ota transfer
                                    J
                                    J
                                    jkandasa
                                    @gohan Enable node debug log and trigger firmware update. Post node debug log.
                                    A few weeks before, I see an issue with the DualOptiboot firmware update. For some reason, if firmware update failed in between, and when we trigger firmware update once again, node says It is up to date.
                                      17 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.1-alpha
                                      26 TSM:INIT
                                      27 TSF:WUR:MS=10000
                                      29 RFM69:INIT
                                      30 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                      34 RFM69:PTX:LEVEL=5 dBm
                                      36 RFM69:INIT:HWV=36
                                      38 TSM:INIT:TSP OK
                                      40 TSF:SID:OK,ID=16
                                      43 TSM:FPAR
                                      44 RFM69:SWR:SEND,TO=255,RETRY=0
                                      47 RFM69:CSMA:RSSI=-109
                                      51 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      198 RFM69:SAC:SEND ACK,TO=0,RSSI=-44
                                      201 RFM69:CSMA:RSSI=-44
                                      210 RFM69:CSMA:RSSI=-109
                                      215 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      220 TSF:MSG:FPAR OK,ID=0,D=1
                                      2058 TSM:FPAR:OK
                                      2059 TSM:ID
                                      2060 TSM:ID:OK
                                      2062 TSM:UPL
                                      2063 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2066 RFM69:CSMA:RSSI=-109
                                      2074 RFM69:SWR:ACK,FROM=0,SEQ=3,RSSI=-37
                                      2078 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=4
                                      2082 RFM69:PTX:LEVEL=4 dBm
                                      2084 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      2091 RFM69:SAC:SEND ACK,TO=0,RSSI=-105
                                      2095 RFM69:CSMA:RSSI=-105
                                      2099 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      2104 TSF:MSG:PONG RECV,HP=1
                                      2106 TSM:UPL:OK
                                      2108 TSM:READY:ID=16,PAR=0,DIS=1
                                      2111 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2114 RFM69:CSMA:RSSI=-104
                                      2120 RFM69:SWR:ACK,FROM=0,SEQ=5,RSSI=-38
                                      2123 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=3
                                      2127 RFM69:PTX:LEVEL=3 dBm
                                      2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300
                                      2139 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2142 RFM69:CSMA:RSSI=-109
                                      2152 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-36
                                      2155 RFM69:ATC:ADJ TXL,cR=-36,tR=-80,TXL=2
                                      2159 RFM69:PTX:LEVEL=2 dBm
                                      2162 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      2168 RFM69:SAC:SEND ACK,TO=0,RSSI=-104
                                      2172 RFM69:CSMA:RSSI=-104
                                      2176 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      2182 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2185 RFM69:CSMA:RSSI=-89
                                      2196 RFM69:CSMA:RSSI=-105
                                      2398 !RFM69:SWR:NACK
                                      2399 RFM69:SWR:SEND,TO=0,RETRY=1
                                      2403 RFM69:CSMA:RSSI=-104
                                      2607 !RFM69:SWR:NACK
                                      2608 RFM69:SWR:SEND,TO=0,RETRY=2
                                      2612 RFM69:CSMA:RSSI=-107
                                      2816 !RFM69:SWR:NACK
                                      2817 RFM69:SWR:SEND,TO=0,RETRY=3
                                      2821 RFM69:CSMA:RSSI=-103
                                      2852 RFM69:SWR:ACK,FROM=0,SEQ=8,RSSI=-37
                                      2855 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=1
                                      2860 RFM69:PTX:LEVEL=1 dBm
                                      2862 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.2.1-alpha
                                      2870 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2873 RFM69:CSMA:RSSI=-103
                                      2879 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-40
                                      2882 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=0
                                      2886 RFM69:PTX:LEVEL=0 dBm
                                      2889 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      2962 RFM69:SAC:SEND ACK,TO=0,RSSI=-45
                                      2966 RFM69:CSMA:RSSI=-45
                                      2969 RFM69:CSMA:RSSI=-105
                                      2972 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                                      2978 RFM69:SWR:SEND,TO=0,RETRY=0
                                      2981 RFM69:CSMA:RSSI=-106
                                      2990 RFM69:SWR:ACK,FROM=0,SEQ=11,RSSI=-40
                                      2994 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=-1
                                      2997 RFM69:PTX:LEVEL=-1 dBm
                                      3000 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:TEMP HUM dev
                                      3007 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3010 RFM69:CSMA:RSSI=-102
                                      3016 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-39
                                      3020 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=-2
                                      3023 RFM69:PTX:LEVEL=-2 dBm
                                      3026 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
                                      3033 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3036 RFM69:CSMA:RSSI=-106
                                      3043 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-42
                                      3047 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=-3
                                      3050 RFM69:PTX:LEVEL=-3 dBm
                                      3053 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3059 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3062 RFM69:CSMA:RSSI=-109
                                      3069 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-50
                                      3074 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-4
                                      3078 RFM69:PTX:LEVEL=-4 dBm
                                      3080 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3086 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3089 RFM69:CSMA:RSSI=-105
                                      3096 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-50
                                      3100 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-5
                                      3104 RFM69:PTX:LEVEL=-5 dBm
                                      3106 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3112 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3116 RFM69:CSMA:RSSI=-107
                                      3123 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-51
                                      3127 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-6
                                      3131 RFM69:PTX:LEVEL=-6 dBm
                                      3133 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3139 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3142 RFM69:CSMA:RSSI=-107
                                      3149 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-52
                                      3153 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-7
                                      3158 RFM69:PTX:LEVEL=-7 dBm
                                      3160 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3166 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3169 RFM69:CSMA:RSSI=-107
                                      3176 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-53
                                      3180 RFM69:ATC:ADJ TXL,cR=-53,tR=-80,TXL=-8
                                      3184 RFM69:PTX:LEVEL=-8 dBm
                                      3186 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                                      3192 MCO:REG:REQ
                                      3194 RFM69:SWR:SEND,TO=0,RETRY=0
                                      3197 RFM69:CSMA:RSSI=-109
                                      3208 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-54
                                      3212 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=-9
                                      3216 RFM69:PTX:LEVEL=-9 dBm
                                      3218 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      3225 RFM69:SAC:SEND ACK,TO=0,RSSI=-107
                                      3228 RFM69:CSMA:RSSI=-107
                                      3232 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      3237 MCO:PIM:NODE REG=1
                                      3239 MCO:BGN:STP
                                      3751 MCO:BGN:INIT OK,TSP=1
                                      4755 RFM69:SWR:SEND,TO=0,RETRY=0
                                      4758 RFM69:CSMA:RSSI=-103
                                      4767 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-56
                                      4771 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-10
                                      4775 RFM69:PTX:LEVEL=-10 dBm
                                      4777 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.40
                                      T: 20.40
                                      5286 RFM69:SWR:SEND,TO=0,RETRY=0
                                      5289 RFM69:CSMA:RSSI=-110
                                      5296 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-56
                                      5299 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-11
                                      5303 RFM69:PTX:LEVEL=-11 dBm
                                      5306 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.0
                                      H: 41
                                      5312 RFM69:SWR:SEND,TO=0,RETRY=0
                                      5316 RFM69:CSMA:RSSI=-106
                                      5322 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-57
                                      5326 RFM69:ATC:ADJ TXL,cR=-57,tR=-80,TXL=-12
                                      5330 RFM69:PTX:LEVEL=-12 dBm
                                      5334 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-56
                                      5840 RFM69:SWR:SEND,TO=0,RETRY=0
                                      5842 RFM69:CSMA:RSSI=-107
                                      5851 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-58
                                      5855 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-13
                                      5859 RFM69:PTX:LEVEL=-13 dBm
                                      5861 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-44
                                      6068 RFM69:SWR:SEND,TO=0,RETRY=0
                                      6071 RFM69:CSMA:RSSI=-108
                                      6081 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-58
                                      6084 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-14
                                      6088 RFM69:PTX:LEVEL=-14 dBm
                                      6091 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:16
                                      7099 RFM69:SWR:SEND,TO=0,RETRY=0
                                      7101 RFM69:CSMA:RSSI=-105
                                      7109 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-60
                                      7113 RFM69:ATC:ADJ TXL,cR=-60,tR=-80,TXL=-15
                                      7117 RFM69:PTX:LEVEL=-15 dBm
                                      7119 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
                                      7127 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                      7132 RFM69:SWR:SEND,TO=0,RETRY=0
                                      7135 RFM69:CSMA:RSSI=-107
                                      7142 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-61
                                      7146 RFM69:ATC:ADJ TXL,cR=-61,tR=-80,TXL=-16
                                      7150 RFM69:PTX:LEVEL=-16 dBm
                                      7152 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                                      7659 TSF:TDI:TSL
                                      7660 RFM69:RSL
                                        26 TSM:INIT
                                        27 TSF:WUR:MS=10000
                                        29 RFM69:INIT
                                        38 TSM:INIT:TSP OK
                                        40 TSF:SID:OK,ID=16
                                        43 TSM:FPAR
                                        2058 TSM:FPAR:OK
                                        2059 TSM:ID
                                        2060 TSM:ID:OK
                                        2062 TSM:UPL
                                        2106 TSM:UPL:OK
                                        3192 MCO:REG:REQ
                                        3239 MCO:BGN:STP
                                        T: 20.40
                                        H: 41
                                        7659 TSF:TDI:TSL
                                        7660 RFM69:RSL
                                        J
                                        J
                                        jkandasa
                                        @gohan This node looks like sleeping node? Is it. I guess it won't walk up to update the entire firmware.
                                        And I do not see any response for this request 2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300. Is there any firmware assigned for this node in MyController?
                                          There is, I have loaded 5 but none work, besides the first time that actually did started the ota transfer
