  3. MyController.org
  4. Need volunteer to test dualboot OTA with MyController
Scheduled Pinned Locked Moved MyController.org
28 Posts 5 Posters 6.9k Views 6 Watching
  • tekkaT tekka
    @gohan hmm, 10-20 mins is pretty long, indeed. Can you post all logs with rfm69 debug verbose enabled?
    @tekka from the node side?
    tekkaT 1 Reply Last reply
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      @gohan ideally both, GW and node
        Do I need to enable it in myconfig.h and recompile the rpi gateway?
          tekkaT
          tekkaT
          tekka
          @gohan yes, you can enable/add #define MY_DEBUG_VERBOSE_RFM69 in either myconfig.h or mysgw.cpp and recompile the RPI GW
            this is what I get on the gateway
            mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FB03611D231F849F600D211D822F762F6A2F
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-41
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500FA03
            mysgw: RFM69:SWR:SEND,TO=16,RETRY=0
            mysgw: !RFM69:SWR:NACK
            mysgw: RFM69:SWR:SEND,TO=16,RETRY=1
            mysgw: RFM69:SWR:SEND,TO=16,RETRY=2
            mysgw: RFM69:SWR:SEND,TO=16,RETRY=3
            mysgw: RFM69:SWR:SEND,TO=16,RETRY=4
            mysgw: RFM69:SWR:SEND,TO=16,RETRY=5
            mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500FA03621F839FA00D611D221F749F3327A00D
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-55
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F903
            mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500F903829F2227B00DA11D621F739FB00DA11D
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-42
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F803
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=166,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F903829F2227B00DA11D621F739FB00DA11D
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=168,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F803F00DB11DAA1F649F6627B00DA11D661F
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-43
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F703
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=170,RSSI=-51
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=171,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F703629FF001729FBB27F00DB11D639FAA27
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F603
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=173,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F6030E94322070F3959FC1F3950F50E0551F
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-44
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F503
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=175,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F50311F00C940A200C94102011240C945520
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F403
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=177,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F40321200E94132038F00E941A2020F09523
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F303
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=179,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F303A6958FEF811D811D08950E94B01F0C94
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-45
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F203
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=181,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F203232B242B252B21F408950A2609F4A140
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-46
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F103
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=183,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F10398F0621B730B840B950B39F40A2661F0
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-47
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500F003
            mysgw: RFM69:SWR:ACK,FROM=16,SEQ=185,RSSI=-51
            mysgw: TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=OK:02000500F0031706E807F907C0F012161306E407F507
            mysgw: RFM69:SAC:SEND ACK,TO=16,RSSI=-48
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EF03
            mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EF030895990F0008550FAA0BE0E8FEEF1616
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500EE03
            mysgw: !TSF:MSG:SEND,0-0-16-16,s=255,c=4,t=3,pt=6,l=22,sg=0,ft=0,st=NACK:02000500EE03660F771F881FDAF7880F9695879597F9
            mysgw: TSF:MSG:READ,16-16-0,s=255,c=4,t=2,pt=6,l=6,sg=0:02000500ED03
            I guess there is something wrong since the node is 3 meters away
              tekkaT
              tekkaT
              tekka
              @gohan please also post the full node log + node sketch
                wrote on last edited by gohan
                This is node at boot even if I selected to upload firmware
                0 MCO:BGN:INIT NODE,CP=RPONA--X,VER=2.2.0-beta
                49 TSM:INIT
                51 TSF:WUR:MS=10000
                53 RFM69:INIT
                53 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                59 RFM69:PTX:LEVEL=5 dBm
                61 TSM:INIT:TSP OK
                63 TSF:SID:OK,ID=16
                65 TSM:FPAR
                67 RFM69:SWR:SEND,TO=255,RETRY=0
                73 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                192 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                200 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                206 TSF:MSG:FPAR OK,ID=0,D=1
                405 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                413 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                2082 TSM:FPAR:OK
                2082 TSM:ID
                2084 TSM:ID:OK
                2086 TSM:UPL
                2088 RFM69:SWR:SEND,TO=0,RETRY=0
                2103 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-47
                2107 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=4
                2111 RFM69:PTX:LEVEL=4 dBm
                2113 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                2121 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                2129 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                2136 TSF:MSG:PONG RECV,HP=1
                2138 TSM:UPL:OK
                2140 TSM:READY:ID=16,PAR=0,DIS=1
                2144 RFM69:SWR:SEND,TO=0,RETRY=0
                2355 !RFM69:SWR:NACK
                2357 RFM69:PTX:LEVEL=5 dBm
                2400 RFM69:SWR:SEND,TO=0,RETRY=1
                2609 !RFM69:SWR:NACK
                2611 RFM69:PTX:LEVEL=6 dBm
                2654 RFM69:SWR:SEND,TO=0,RETRY=2
                2863 !RFM69:SWR:NACK
                2865 RFM69:PTX:LEVEL=7 dBm
                2899 RFM69:SWR:SEND,TO=0,RETRY=3
                3108 !RFM69:SWR:NACK
                3110 RFM69:PTX:LEVEL=8 dBm
                3121 RFM69:SWR:SEND,TO=0,RETRY=4
                3330 !RFM69:SWR:NACK
                3332 RFM69:PTX:LEVEL=9 dBm
                3375 RFM69:SWR:SEND,TO=0,RETRY=5
                3457 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-44
                3461 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
                3465 RFM69:PTX:LEVEL=8 dBm
                3467 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
                3477 RFM69:SWR:SEND,TO=0,RETRY=0
                3491 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-45
                3495 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=7
                3500 RFM69:PTX:LEVEL=7 dBm
                3502 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                3510 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                3518 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                3524 RFM69:SWR:SEND,TO=0,RETRY=0
                3735 !RFM69:SWR:NACK
                3737 RFM69:PTX:LEVEL=8 dBm
                3747 RFM69:SWR:SEND,TO=0,RETRY=1
                3956 !RFM69:SWR:NACK
                3958 RFM69:PTX:LEVEL=9 dBm
                4001 RFM69:SWR:SEND,TO=0,RETRY=2
                4210 !RFM69:SWR:NACK
                4212 RFM69:PTX:LEVEL=10 dBm
                4255 RFM69:SWR:SEND,TO=0,RETRY=3
                4464 !RFM69:SWR:NACK
                4466 RFM69:PTX:LEVEL=11 dBm
                4501 RFM69:SWR:SEND,TO=0,RETRY=4
                4710 !RFM69:SWR:NACK
                4712 RFM69:PTX:LEVEL=12 dBm
                4722 RFM69:SWR:SEND,TO=0,RETRY=5
                4909 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-43
                4913 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
                4917 RFM69:PTX:LEVEL=11 dBm
                4919 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                4929 RFM69:SWR:SEND,TO=0,RETRY=0
                4943 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-43
                4947 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                4952 RFM69:PTX:LEVEL=10 dBm
                4954 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                5584 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                5593 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                5599 RFM69:SWR:SEND,TO=0,RETRY=0
                5810 !RFM69:SWR:NACK
                5812 RFM69:PTX:LEVEL=11 dBm
                5855 RFM69:SWR:SEND,TO=0,RETRY=1
                6064 !RFM69:SWR:NACK
                6066 RFM69:PTX:LEVEL=12 dBm
                6100 RFM69:SWR:SEND,TO=0,RETRY=2
                6309 !RFM69:SWR:NACK
                6311 RFM69:PTX:LEVEL=13 dBm
                6322 RFM69:SWR:SEND,TO=0,RETRY=3
                6531 !RFM69:SWR:NACK
                6533 RFM69:PTX:NO ADJ
                6576 RFM69:SWR:SEND,TO=0,RETRY=4
                6785 !RFM69:SWR:NACK
                6787 RFM69:PTX:NO ADJ
                6830 RFM69:SWR:SEND,TO=0,RETRY=5
                6950 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-42
                6955 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=12
                6961 RFM69:PTX:LEVEL=12 dBm
                6963 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
                6971 RFM69:SWR:SEND,TO=0,RETRY=0
                6985 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-43
                6989 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=11
                6995 RFM69:PTX:LEVEL=11 dBm
                6998 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                7006 RFM69:SWR:SEND,TO=0,RETRY=0
                7020 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-43
                7024 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                7030 RFM69:PTX:LEVEL=10 dBm
                7032 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                7041 RFM69:SWR:SEND,TO=0,RETRY=0
                7055 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-43
                7061 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=9
                7065 RFM69:PTX:LEVEL=9 dBm
                7067 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                7075 RFM69:SWR:SEND,TO=0,RETRY=0
                7090 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-44
                7096 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=8
                7100 RFM69:PTX:LEVEL=8 dBm
                7102 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                7110 RFM69:SWR:SEND,TO=0,RETRY=0
                7127 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
                7131 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=7
                7135 RFM69:PTX:LEVEL=7 dBm
                7139 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                7145 RFM69:SWR:SEND,TO=0,RETRY=0
                7163 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-51
                7168 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=6
                7172 RFM69:PTX:LEVEL=6 dBm
                7174 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                7182 RFM69:SWR:SEND,TO=0,RETRY=0
                7198 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-45
                7202 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=5
                7206 RFM69:PTX:LEVEL=5 dBm
                7211 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                7219 MCO:REG:REQ
                7219 RFM69:SWR:SEND,TO=0,RETRY=0
                7235 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-49
                7239 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=4
                7243 RFM69:PTX:LEVEL=4 dBm
                7247 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                7254 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                7262 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                7268 MCO:PIM:NODE REG=1
                7272 MCO:BGN:STP
                7784 MCO:BGN:INIT OK,TSP=1
                7786 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                7794 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                7800 MCO:PIM:NODE REG=1
                8804 RFM69:SWR:SEND,TO=0,RETRY=0
                8822 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-48
                8826 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=3
                8833 RFM69:PTX:LEVEL=3 dBm
                8835 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:19.62
                T: 19.62
                9345 RFM69:SWR:SEND,TO=0,RETRY=0
                9361 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-51
                9365 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=2
                9369 RFM69:PTX:LEVEL=2 dBm
                9373 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:47.0
                H: 47
                9381 RFM69:SWR:SEND,TO=0,RETRY=0
                9396 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-49
                9400 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=1
                9406 RFM69:PTX:LEVEL=1 dBm
                9408 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-51
                9916 RFM69:SWR:SEND,TO=0,RETRY=0
                9934 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-50
                9938 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=0
                9943 RFM69:PTX:LEVEL=0 dBm
                9947 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-52
                10156 RFM69:SWR:SEND,TO=0,RETRY=0
                10168 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-51
                10172 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-1
                10178 RFM69:PTX:LEVEL=-1 dBm
                10180 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:58
                11190 RFM69:SWR:SEND,TO=0,RETRY=0
                11206 RFM69:SWR:ACK,FROM=0,SEQ=28,RSSI=-51
                11212 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-2
                11216 RFM69:PTX:LEVEL=-2 dBm
                11220 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
                11229 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                11235 RFM69:SWR:SEND,TO=0,RETRY=0
                11253 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-52
                11257 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-3
                11261 RFM69:PTX:LEVEL=-3 dBm
                11266 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                11450 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                11458 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                11776 TSF:TDI:TSL
                11778 RFM69:RSL
                Sketch
                #include <Adafruit_SHT31.h>
                #include <Adafruit_Sensor.h>
                #define MY_DEBUG  // Enable debug prints
                //#define MY_RADIO_NRF24
                #define MY_RADIO_RFM69
                #define MY_RFM69_FREQUENCY RFM69_433MHZ
                #define MY_RFM69_NEW_DRIVER
                //#define MY_IS_RFM69HW
                #define MY_TRANSPORT_WAIT_READY_MS 10000
                //#define MY_NODE_ID 16
                #define VBAT_VCC
                //Enable OTA feature
                #define MY_OTA_FIRMWARE_FEATURE
                #define MY_OTA_FLASH_JDECID 0x00
                #define CHILD_ID_HUM 0
                #define CHILD_ID_TEMP 1
                #define CHILD_ID_VBAT 201						 // Battery voltage
                unsigned long SLEEP_TIME = 600000; // Sleep time between reads (in milliseconds)
                #define SKETCH_NAME "TEMP HUM"                // Change to a fancy name you like
                #define SKETCH_VERSION "1.2"                    // Your version
                float lastTemp;
                float lastHum;
                boolean metric = true;
                MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE);
                Adafruit_SHT31 sht31 = Adafruit_SHT31();
                #ifdef MY_RADIO_RFM69
                	int rssi;                                    // RSSI RFM69 chip
                	#define CHILD_ID_RSSI_HIGH  202                // RSSI received signal level
                	#define CHILD_ID_RSSI_LOW   203                // RSSI background noise level
                  #define CHILD_ID_POWER 204
                	MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_LEVEL);
                	MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_LEVEL);
                  MyMessage msgPWR(CHILD_ID_POWER, V_LIGHT_LEVEL);
                //#define VBAT_PER_BITS 0.005448028                 //
                #define VMIN 2.8                                  //  Vmin (radio Min Volt)=1.9V (564v)
                #define VMAX 3.4                                 //  Vmax = (2xAA bat)=3.0V (892v)
                int batteryPcnt , PwrPcnt = 0;                    // Calc value for battery %
                #ifdef VBAT_VCC
                #include <Vcc.h>
                	const float VccCorrection = 1.0 / 1.0;  // Measured Vcc by multimeter divided by reported Vcc
                	Vcc vcc(VccCorrection);
                #endif // VBAT_VCC
                	// metric = getControllerConfig().isMetric;
                	if (!sht31.begin(0x44)) {   // Set to 0x45 for alternate i2c addr
                		Serial.println("Couldn't find SHT31");
                		//while (1) delay(1);
                	present(CHILD_ID_HUM, S_HUM);
                	present(CHILD_ID_RSSI_HIGH, S_SOUND);
                	present(CHILD_ID_RSSI_LOW, S_SOUND);
                  present(CHILD_ID_POWER, S_LIGHT_LEVEL);
                	present(CHILD_ID_VBAT, S_MULTIMETER);
                  if (!isFirmwareUpdateOngoing())
                	// Fetch temperatures from SHT sensor
                	float temperature = sht31.readTemperature();
                	//temperature = round(temperature*10)/10; //round to 1 decimal place
                	if (isnan(temperature)) {
                		Serial.println("Failed reading temperature from SHT31");
                	else if (temperature != lastTemp) {
                		lastTemp = temperature;
                		send(msgTemp.set(temperature, 2));
                		Serial.print("T: ");
                	// Fetch humidity from SHT sensor
                	uint8_t humidity = sht31.readHumidity();
                	if (isnan(humidity)) {
                		Serial.println("Failed reading humidity from SHT");
                	else if (humidity != lastHum) {
                		lastHum = humidity;
                		Serial.print("H: ");
                		Serial.println(humidity);
                	rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
                	send(msgRSSI1.set(rssi));                  // send RSSI level
                	wait(500);                                 // wait to get idle
                	rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
                	send(msgRSSI2.set(rssi));                  // send RSSI level
                 	wait(200);                                 // wait for next send
                  PwrPcnt = RFM69_getTxPowerPercent();      // read TX Power in RFM69
                  send(msgPWR.set(PwrPcnt));            // send TX Power
                	batM();
                	smartSleep(SLEEP_TIME); //sleep a bit
                	delay(500);
                	float Vbat;
                	int batteryPcnt;
                  	// Battery monitoring reading
                #ifdef VBAT_VCC
                	Vbat = vcc.Read_Volts();
                	batteryPcnt = vcc.Read_Perc(VMIN, VMAX);
                	Vbat = (sensorValue * VBAT_PER_BITS) - 0.2 ;
                	// Calculate the battery in %
                	batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN))*100.);
                  delay(500);
                	send(msgVBat.set(Vbat, 2));
                	//Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
                	if (batLoop > 2) {
                		if (batteryPcnt > 100) {
                			batteryPcnt = 100;
                		batLoop = 0;
                		batLoop++;
                  Here is the firmware upload that finally I managed to start, of course I only cut the first part
                  49 TSM:INIT
                  51 TSF:WUR:MS=10000
                  53 RFM69:INIT
                  61 TSM:INIT:TSP OK
                  63 TSF:SID:OK,ID=16
                  65 TSM:FPAR
                  126 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  133 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  139 TSF:MSG:FPAR OK,ID=0,D=1
                  337 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  344 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  2082 TSM:FPAR:OK
                  2082 TSM:ID
                  2084 TSM:ID:OK
                  2086 TSM:UPL
                  2105 RFM69:SWR:ACK,FROM=0,SEQ=4,RSSI=-44
                  2109 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=4
                  2113 RFM69:PTX:LEVEL=4 dBm
                  2117 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                  2123 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  2131 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  2138 TSF:MSG:PONG RECV,HP=1
                  2142 TSM:UPL:OK
                  2144 TSM:READY:ID=16,PAR=0,DIS=1
                  2146 RFM69:SWR:SEND,TO=0,RETRY=0
                  2168 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-43
                  2172 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
                  2177 RFM69:PTX:LEVEL=3 dBm
                  2181 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:010003000806237A0300
                  2191 RFM69:SWR:SEND,TO=0,RETRY=0
                  2205 RFM69:SWR:ACK,FROM=0,SEQ=7,RSSI=-44
                  2209 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
                  2213 RFM69:PTX:LEVEL=2 dBm
                  2217 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                  2224 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  2232 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  2240 RFM69:SWR:SEND,TO=0,RETRY=0
                  2258 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-45
                  2263 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=1
                  2269 RFM69:PTX:LEVEL=1 dBm
                  2271 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
                  2279 RFM69:SWR:SEND,TO=0,RETRY=0
                  2295 RFM69:SWR:ACK,FROM=0,SEQ=10,RSSI=-71
                  2299 RFM69:ATC:ADJ TXL,cR=-71,tR=-80,TXL=0
                  2304 RFM69:PTX:LEVEL=0 dBm
                  2308 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                  2334 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                  2342 TSF:MSG:READ,0-0-16,s=255,c=4,t=1,pt=6,l=8,sg=0:02000400600466EF
                  2351 OTA:FWP:UPDATE
                  2467 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                  2471 RFM69:SWR:SEND,TO=0,RETRY=0
                  2682 !RFM69:SWR:NACK
                  2684 RFM69:PTX:LEVEL=1 dBm
                  2719 RFM69:SWR:SEND,TO=0,RETRY=1
                  2928 !RFM69:SWR:NACK
                  2930 RFM69:PTX:LEVEL=2 dBm
                  2965 RFM69:SWR:SEND,TO=0,RETRY=2
                  3174 !RFM69:SWR:NACK
                  3176 RFM69:PTX:LEVEL=3 dBm
                  3186 RFM69:SWR:SEND,TO=0,RETRY=3
                  3395 !RFM69:SWR:NACK
                  3397 RFM69:PTX:LEVEL=4 dBm
                  3440 RFM69:SWR:SEND,TO=0,RETRY=4
                  3649 !RFM69:SWR:NACK
                  3651 RFM69:PTX:LEVEL=5 dBm
                  3694 RFM69:SWR:SEND,TO=0,RETRY=5
                  3903 !RFM69:SWR:NACK
                  3905 RFM69:PTX:LEVEL=6 dBm
                  3940 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005F04
                  3948 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  3956 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  3962 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                  3966 RFM69:SWR:SEND,TO=0,RETRY=0
                  4177 !RFM69:SWR:NACK
                  4179 RFM69:PTX:LEVEL=7 dBm
                  4190 RFM69:SWR:SEND,TO=0,RETRY=1
                  4399 !RFM69:SWR:NACK
                  4401 RFM69:PTX:LEVEL=8 dBm
                  4435 RFM69:SWR:SEND,TO=0,RETRY=2
                  4644 !RFM69:SWR:NACK
                  4646 RFM69:PTX:LEVEL=9 dBm
                  4657 RFM69:SWR:SEND,TO=0,RETRY=3
                  4866 !RFM69:SWR:NACK
                  4868 RFM69:PTX:LEVEL=10 dBm
                  4911 RFM69:SWR:SEND,TO=0,RETRY=4
                  5046 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-39
                  5050 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=9
                  5054 RFM69:PTX:LEVEL=9 dBm
                  5058 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005F04
                  5066 RFM69:SWR:SEND,TO=0,RETRY=0
                  5083 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-63
                  5087 RFM69:ATC:ADJ TXL,cR=-63,tR=-80,TXL=8
                  5091 RFM69:PTX:LEVEL=8 dBm
                  5093 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=OK:TEMP HUM
                  5103 RFM69:SWR:SEND,TO=0,RETRY=0
                  5310 !RFM69:SWR:NACK
                  5312 RFM69:PTX:LEVEL=9 dBm
                  5347 RFM69:SWR:SEND,TO=0,RETRY=1
                  5554 !RFM69:SWR:NACK
                  5556 RFM69:PTX:LEVEL=10 dBm
                  5599 RFM69:SWR:SEND,TO=0,RETRY=2
                  5806 !RFM69:SWR:NACK
                  5808 RFM69:PTX:LEVEL=11 dBm
                  5842 RFM69:SWR:SEND,TO=0,RETRY=3
                  6049 !RFM69:SWR:NACK
                  6051 RFM69:PTX:LEVEL=12 dBm
                  6062 RFM69:SWR:SEND,TO=0,RETRY=4
                  6268 !RFM69:SWR:NACK
                  6270 RFM69:PTX:LEVEL=13 dBm
                  6305 RFM69:SWR:SEND,TO=0,RETRY=5
                  6512 !RFM69:SWR:NACK
                  6514 RFM69:PTX:NO ADJ
                  6549 !TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=NACK:1.2
                  6557 RFM69:SWR:SEND,TO=0,RETRY=0
                  6580 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-38
                  6584 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                  6588 RFM69:PTX:LEVEL=12 dBm
                  6590 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                  6598 RFM69:SWR:SEND,TO=0,RETRY=0
                  6615 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-37
                  6619 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=11
                  6623 RFM69:PTX:LEVEL=11 dBm
                  6627 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                  6633 RFM69:SWR:SEND,TO=0,RETRY=0
                  6651 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-38
                  6656 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=10
                  6660 RFM69:PTX:LEVEL=10 dBm
                  6662 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                  6670 RFM69:SWR:SEND,TO=0,RETRY=0
                  6686 RFM69:SWR:ACK,FROM=0,SEQ=20,RSSI=-48
                  6692 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=9
                  6696 RFM69:PTX:LEVEL=9 dBm
                  6699 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                  6707 RFM69:SWR:SEND,TO=0,RETRY=0
                  6723 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-48
                  6729 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=8
                  6733 RFM69:PTX:LEVEL=8 dBm
                  6735 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                  6744 RFM69:SWR:SEND,TO=0,RETRY=0
                  6760 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-40
                  6764 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=7
                  6770 RFM69:PTX:LEVEL=7 dBm
                  6772 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                  6780 MCO:REG:REQ
                  6782 RFM69:SWR:SEND,TO=0,RETRY=0
                  6797 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-49
                  6801 RFM69:ATC:ADJ TXL,cR=-49,tR=-80,TXL=6
                  6807 RFM69:PTX:LEVEL=6 dBm
                  6809 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                  6817 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                  6825 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  6832 MCO:PIM:NODE REG=1
                  6834 OTA:FRQ:FW REQ,T=0002,V=0004,B=045F
                  6838 RFM69:SWR:SEND,TO=0,RETRY=0
                  6862 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-42
                  6866 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
                  6871 RFM69:PTX:LEVEL=5 dBm
                  6873 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005F04
                  6883 MCO:BGN:STP
                  7395 MCO:BGN:INIT OK,TSP=1
                  7397 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  7405 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005F04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  7415 OTA:FWP:RECV B=045F
                  7419 OTA:FRQ:FW REQ,T=0002,V=0004,B=045E
                  7424 RFM69:SWR:SEND,TO=0,RETRY=0
                  7440 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-43
                  7446 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
                  7450 RFM69:PTX:LEVEL=4 dBm
                  7452 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005E04
                  7512 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  7520 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005E04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  7530 OTA:FWP:RECV B=045E
                  7534 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                  7538 RFM69:SWR:SEND,TO=0,RETRY=0
                  7555 RFM69:SWR:ACK,FROM=0,SEQ=29,RSSI=-44
                  7561 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                  7565 RFM69:PTX:LEVEL=3 dBm
                  7567 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                  8036 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                  8040 RFM69:SWR:SEND,TO=0,RETRY=0
                  8249 !RFM69:SWR:NACK
                  8251 RFM69:PTX:LEVEL=4 dBm
                  8286 RFM69:SWR:SEND,TO=0,RETRY=1
                  8495 !RFM69:SWR:NACK
                  8497 RFM69:PTX:LEVEL=5 dBm
                  8531 RFM69:SWR:SEND,TO=0,RETRY=2
                  8740 !RFM69:SWR:NACK
                  8742 RFM69:PTX:LEVEL=6 dBm
                  8753 RFM69:SWR:SEND,TO=0,RETRY=3
                  8962 !RFM69:SWR:NACK
                  8964 RFM69:PTX:LEVEL=7 dBm
                  9007 RFM69:SWR:SEND,TO=0,RETRY=4
                  9029 RFM69:SWR:ACK,FROM=0,SEQ=30,RSSI=-41
                  9033 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=6
                  9037 RFM69:PTX:LEVEL=6 dBm
                  9039 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                  9050 OTA:FRQ:FW REQ,T=0002,V=0004,B=045D
                  9054 RFM69:SWR:SEND,TO=0,RETRY=0
                  9074 RFM69:SWR:ACK,FROM=0,SEQ=31,RSSI=-42
                  9078 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=5
                  9082 RFM69:PTX:LEVEL=5 dBm
                  9086 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005D04
                  9127 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  9136 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9146 OTA:FWP:RECV B=045D
                  9148 OTA:FRQ:FW REQ,T=0002,V=0004,B=045C
                  9152 RFM69:SWR:SEND,TO=0,RETRY=0
                  9172 RFM69:SWR:ACK,FROM=0,SEQ=33,RSSI=-43
                  9177 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=4
                  9181 RFM69:PTX:LEVEL=4 dBm
                  9183 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005C04
                  9234 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  9242 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9252 OTA:FWP:RECV B=045D
                  9254 !OTA:FWP:WRONG FWB
                  9451 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                  9459 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005D04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9469 OTA:FWP:RECV B=045D
                  9472 !OTA:FWP:WRONG FWB
                  9480 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  9488 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005C04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9500 OTA:FWP:RECV B=045C
                  9502 OTA:FRQ:FW REQ,T=0002,V=0004,B=045B
                  9506 RFM69:SWR:SEND,TO=0,RETRY=0
                  9525 RFM69:SWR:ACK,FROM=0,SEQ=37,RSSI=-44
                  9529 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                  9533 RFM69:PTX:LEVEL=3 dBm
                  9537 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005B04
                  9637 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  9646 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005B04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9658 OTA:FWP:RECV B=045B
                  9660 OTA:FRQ:FW REQ,T=0002,V=0004,B=045A
                  9664 RFM69:SWR:SEND,TO=0,RETRY=0
                  9682 RFM69:SWR:ACK,FROM=0,SEQ=39,RSSI=-44
                  9687 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=2
                  9691 RFM69:PTX:LEVEL=2 dBm
                  9695 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005A04
                  9725 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  9734 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005A04FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9744 OTA:FWP:RECV B=045A
                  9746 OTA:FRQ:FW REQ,T=0002,V=0004,B=0459
                  9750 RFM69:SWR:SEND,TO=0,RETRY=0
                  9768 RFM69:SWR:ACK,FROM=0,SEQ=41,RSSI=-46
                  9775 RFM69:ATC:ADJ TXL,cR=-46,tR=-80,TXL=1
                  9779 RFM69:PTX:LEVEL=1 dBm
                  9781 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005904
                  9834 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  9842 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005904FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9854 OTA:FWP:RECV B=0459
                  9857 OTA:FRQ:FW REQ,T=0002,V=0004,B=0458
                  9861 RFM69:SWR:SEND,TO=0,RETRY=0
                  9879 RFM69:SWR:ACK,FROM=0,SEQ=43,RSSI=-48
                  9883 RFM69:ATC:ADJ TXL,cR=-48,tR=-80,TXL=0
                  9889 RFM69:PTX:LEVEL=0 dBm
                  9891 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005804
                  9934 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                  9943 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005804FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                  9953 OTA:FWP:RECV B=0458
                  9957 OTA:FRQ:FW REQ,T=0002,V=0004,B=0457
                  9961 RFM69:SWR:SEND,TO=0,RETRY=0
                  9979 RFM69:SWR:ACK,FROM=0,SEQ=45,RSSI=-47
                  9984 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=-1
                  9988 RFM69:PTX:LEVEL=-1 dBm
                  9992 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005704
                  10043 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  10051 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005704250054454D502048554D00312E310000
                  10061 OTA:FWP:RECV B=0457
                  10065 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
                  10070 RFM69:SWR:SEND,TO=0,RETRY=0
                  10280 !RFM69:SWR:NACK
                  10283 RFM69:PTX:LEVEL=0 dBm
                  10317 RFM69:SWR:SEND,TO=0,RETRY=1
                  10526 !RFM69:SWR:NACK
                  10528 RFM69:PTX:LEVEL=1 dBm
                  10530 RFM69:SWR:SEND,TO=0,RETRY=2
                  10741 !RFM69:SWR:NACK
                  10743 RFM69:PTX:LEVEL=2 dBm
                  10786 RFM69:SWR:SEND,TO=0,RETRY=3
                  10995 !RFM69:SWR:NACK
                  10997 RFM69:PTX:LEVEL=3 dBm
                  11040 RFM69:SWR:SEND,TO=0,RETRY=4
                  11249 !RFM69:SWR:NACK
                  11251 RFM69:PTX:LEVEL=4 dBm
                  11294 RFM69:SWR:SEND,TO=0,RETRY=5
                  11468 RFM69:SWR:ACK,FROM=0,SEQ=47,RSSI=-43
                  11472 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=3
                  11476 RFM69:PTX:LEVEL=3 dBm
                  11481 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
                  11489 OTA:FRQ:FW REQ,T=0002,V=0004,B=0456
                  11493 RFM69:SWR:SEND,TO=0,RETRY=0
                  11513 RFM69:SWR:ACK,FROM=0,SEQ=48,RSSI=-87
                  11520 RFM69:ATC:ADJ TXL,cR=-87,tR=-80,TXL=4
                  11524 RFM69:PTX:LEVEL=4 dBm
                  11526 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005604
                  11536 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  11544 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
                  11554 OTA:FWP:RECV B=0456
                  11558 OTA:FRQ:FW REQ,T=0002,V=0004,B=0455
                  11563 RFM69:SWR:SEND,TO=0,RETRY=0
                  11581 RFM69:SWR:ACK,FROM=0,SEQ=50,RSSI=-44
                  11585 RFM69:ATC:ADJ TXL,cR=-44,tR=-80,TXL=3
                  11589 RFM69:PTX:LEVEL=3 dBm
                  11593 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005504
                  11741 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  11749 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040056046572616765202853656E64293A200020
                  11761 OTA:FWP:RECV B=0456
                  11763 !OTA:FWP:WRONG FWB
                  11833 RFM69:SAC:SEND ACK,TO=0,RSSI=-47
                  11841 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040055045400483A200042617474657279204176
                  11851 OTA:FWP:RECV B=0455
                  11855 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
                  11859 RFM69:SWR:SEND,TO=0,RETRY=0
                  12070 !RFM69:SWR:NACK
                  12072 RFM69:PTX:LEVEL=4 dBm
                  12083 RFM69:SWR:SEND,TO=0,RETRY=1
                  12294 !RFM69:SWR:NACK
                  12296 RFM69:PTX:LEVEL=5 dBm
                  12339 RFM69:SWR:SEND,TO=0,RETRY=2
                  12548 !RFM69:SWR:NACK
                  12550 RFM69:PTX:LEVEL=6 dBm
                  12593 RFM69:SWR:SEND,TO=0,RETRY=3
                  12802 !RFM69:SWR:NACK
                  12804 RFM69:PTX:LEVEL=7 dBm
                  12847 RFM69:SWR:SEND,TO=0,RETRY=4
                  13056 !RFM69:SWR:NACK
                  13058 RFM69:PTX:LEVEL=8 dBm
                  13092 RFM69:SWR:SEND,TO=0,RETRY=5
                  13273 RFM69:SWR:ACK,FROM=0,SEQ=53,RSSI=-41
                  13277 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=7
                  13283 RFM69:PTX:LEVEL=7 dBm
                  13285 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
                  13293 OTA:FRQ:FW REQ,T=0002,V=0004,B=0454
                  13299 RFM69:SWR:SEND,TO=0,RETRY=0
                  13320 RFM69:SWR:ACK,FROM=0,SEQ=54,RSSI=-42
                  13324 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=6
                  13330 RFM69:PTX:LEVEL=6 dBm
                  13332 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005404
                  13342 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  13350 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
                  13361 OTA:FWP:RECV B=0454
                  13365 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
                  13369 RFM69:SWR:SEND,TO=0,RETRY=0
                  13580 !RFM69:SWR:NACK
                  13582 RFM69:PTX:LEVEL=7 dBm
                  13584 RFM69:SWR:SEND,TO=0,RETRY=1
                  13795 !RFM69:SWR:NACK
                  13797 RFM69:PTX:LEVEL=8 dBm
                  13807 RFM69:SWR:SEND,TO=0,RETRY=2
                  14016 !RFM69:SWR:NACK
                  14018 RFM69:PTX:LEVEL=9 dBm
                  14053 RFM69:SWR:SEND,TO=0,RETRY=3
                  14262 !RFM69:SWR:NACK
                  14264 RFM69:PTX:LEVEL=10 dBm
                  14307 RFM69:SWR:SEND,TO=0,RETRY=4
                  14516 !RFM69:SWR:NACK
                  14518 RFM69:PTX:LEVEL=11 dBm
                  14561 RFM69:SWR:SEND,TO=0,RETRY=5
                  14770 !RFM69:SWR:NACK
                  14772 RFM69:PTX:LEVEL=12 dBm
                  14815 !TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=NACK:020004005304
                  14823 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  14831 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400540468756D69646974792066726F6D205348
                  14841 OTA:FWP:RECV B=0454
                  14845 !OTA:FWP:WRONG FWB
                  14848 OTA:FRQ:FW REQ,T=0002,V=0004,B=0453
                  14852 RFM69:SWR:SEND,TO=0,RETRY=0
                  15063 !RFM69:SWR:NACK
                  15065 RFM69:PTX:LEVEL=13 dBm
                  15075 RFM69:SWR:SEND,TO=0,RETRY=1
                  15284 !RFM69:SWR:NACK
                  15286 RFM69:PTX:NO ADJ
                  15329 RFM69:SWR:SEND,TO=0,RETRY=2
                  15538 !RFM69:SWR:NACK
                  15540 RFM69:PTX:NO ADJ
                  15583 RFM69:SWR:SEND,TO=0,RETRY=3
                  15792 !RFM69:SWR:NACK
                  15794 RFM69:PTX:NO ADJ
                  15828 RFM69:SWR:SEND,TO=0,RETRY=4
                  16037 !RFM69:SWR:NACK
                  16039 RFM69:PTX:NO ADJ
                  16050 RFM69:SWR:SEND,TO=0,RETRY=5
                  16191 RFM69:SWR:ACK,FROM=0,SEQ=58,RSSI=-39
                  16195 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                  16201 RFM69:PTX:LEVEL=12 dBm
                  16203 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=1,st=OK:020004005304
                  16214 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  16222 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
                  16232 OTA:FWP:RECV B=0453
                  16234 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
                  16240 RFM69:SWR:SEND,TO=0,RETRY=0
                  16449 !RFM69:SWR:NACK
                  16451 RFM69:PTX:LEVEL=13 dBm
                  16494 RFM69:SWR:SEND,TO=0,RETRY=1
                  16703 !RFM69:SWR:NACK
                  16705 RFM69:PTX:NO ADJ
                  16740 RFM69:SWR:SEND,TO=0,RETRY=2
                  16949 !RFM69:SWR:NACK
                  16951 RFM69:PTX:NO ADJ
                  16994 RFM69:SWR:SEND,TO=0,RETRY=3
                  17203 !RFM69:SWR:NACK
                  17205 RFM69:PTX:NO ADJ
                  17248 RFM69:SWR:SEND,TO=0,RETRY=4
                  17457 !RFM69:SWR:NACK
                  17459 RFM69:PTX:NO ADJ
                  17502 RFM69:SWR:SEND,TO=0,RETRY=5
                  17625 RFM69:SWR:ACK,FROM=0,SEQ=60,RSSI=-39
                  17631 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                  17635 RFM69:PTX:LEVEL=12 dBm
                  17637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
                  17647 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  17655 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004005304004661696C65642072656164696E6720
                  17666 OTA:FWP:RECV B=0453
                  17668 !OTA:FWP:WRONG FWB
                  17672 OTA:FRQ:FW REQ,T=0002,V=0004,B=0452
                  17676 RFM69:SWR:SEND,TO=0,RETRY=0
                  17690 RFM69:SWR:ACK,FROM=0,SEQ=62,RSSI=-39
                  17694 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=11
                  17700 RFM69:PTX:LEVEL=11 dBm
                  17702 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005204
                  17731 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  17739 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
                  17750 OTA:FWP:RECV B=0452
                  17754 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
                  17758 RFM69:SWR:SEND,TO=0,RETRY=0
                  17969 !RFM69:SWR:NACK
                  17971 RFM69:PTX:LEVEL=12 dBm
                  18014 RFM69:SWR:SEND,TO=0,RETRY=1
                  18223 !RFM69:SWR:NACK
                  18225 RFM69:PTX:LEVEL=13 dBm
                  18259 RFM69:SWR:SEND,TO=0,RETRY=2
                  18468 !RFM69:SWR:NACK
                  18470 RFM69:PTX:NO ADJ
                  18481 RFM69:SWR:SEND,TO=0,RETRY=3
                  18690 !RFM69:SWR:NACK
                  18692 RFM69:PTX:NO ADJ
                  18735 RFM69:SWR:SEND,TO=0,RETRY=4
                  18944 !RFM69:SWR:NACK
                  18946 RFM69:PTX:NO ADJ
                  18980 RFM69:SWR:SEND,TO=0,RETRY=5
                  19079 RFM69:SWR:ACK,FROM=0,SEQ=64,RSSI=-39
                  19085 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                  19089 RFM69:PTX:LEVEL=12 dBm
                  19091 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
                  19101 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  19109 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040052044854333100543A2000696E66006F7666
                  19120 OTA:FWP:RECV B=0452
                  19124 !OTA:FWP:WRONG FWB
                  19126 OTA:FRQ:FW REQ,T=0002,V=0004,B=0451
                  19130 RFM69:SWR:SEND,TO=0,RETRY=0
                  19341 !RFM69:SWR:NACK
                  19343 RFM69:PTX:LEVEL=13 dBm
                  19345 RFM69:SWR:SEND,TO=0,RETRY=1
                  19556 !RFM69:SWR:NACK
                  19558 RFM69:PTX:NO ADJ
                  19568 RFM69:SWR:SEND,TO=0,RETRY=2
                  19777 !RFM69:SWR:NACK
                  19779 RFM69:PTX:NO ADJ
                  19822 RFM69:SWR:SEND,TO=0,RETRY=3
                  20031 !RFM69:SWR:NACK
                  20033 RFM69:PTX:NO ADJ
                  20068 RFM69:SWR:SEND,TO=0,RETRY=4
                  20277 !RFM69:SWR:NACK
                  20279 RFM69:PTX:NO ADJ
                  20322 RFM69:SWR:SEND,TO=0,RETRY=5
                  20482 RFM69:SWR:ACK,FROM=0,SEQ=66,RSSI=-39
                  20486 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                  20490 RFM69:PTX:LEVEL=12 dBm
                  20494 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005104
                  20502 RFM69:SAC:SEND ACK,TO=0,RSSI=-48
                  20510 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:0200040051046D70657261747572652066726F6D2053
                  20520 OTA:FWP:RECV B=0451
                  20525 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
                  20529 RFM69:SWR:SEND,TO=0,RETRY=0
                  20740 !RFM69:SWR:NACK
                  20742 RFM69:PTX:LEVEL=13 dBm
                  20785 RFM69:SWR:SEND,TO=0,RETRY=1
                  20994 !RFM69:SWR:NACK
                  20996 RFM69:PTX:NO ADJ
                  21039 RFM69:SWR:SEND,TO=0,RETRY=2
                  21248 !RFM69:SWR:NACK
                  21250 RFM69:PTX:NO ADJ
                  21284 RFM69:SWR:SEND,TO=0,RETRY=3
                  21493 !RFM69:SWR:NACK
                  21495 RFM69:PTX:NO ADJ
                  21538 RFM69:SWR:SEND,TO=0,RETRY=4
                  21747 !RFM69:SWR:NACK
                  21749 RFM69:PTX:NO ADJ
                  21792 RFM69:SWR:SEND,TO=0,RETRY=5
                  21884 RFM69:SWR:ACK,FROM=0,SEQ=68,RSSI=-37
                  21889 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
                  21895 RFM69:PTX:LEVEL=12 dBm
                  21897 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
                  21907 OTA:FRQ:FW REQ,T=0002,V=0004,B=0450
                  21911 RFM69:SWR:SEND,TO=0,RETRY=0
                  22122 !RFM69:SWR:NACK
                  22124 RFM69:PTX:LEVEL=13 dBm
                  22159 RFM69:SWR:SEND,TO=0,RETRY=1
                  22368 !RFM69:SWR:NACK
                  22370 RFM69:PTX:NO ADJ
                  22372 RFM69:SWR:SEND,TO=0,RETRY=2
                  22583 !RFM69:SWR:NACK
                  22585 RFM69:PTX:NO ADJ
                  22628 RFM69:SWR:SEND,TO=0,RETRY=3
                  22837 !RFM69:SWR:NACK
                  22839 RFM69:PTX:NO ADJ
                  22882 RFM69:SWR:SEND,TO=0,RETRY=4
                  23091 !RFM69:SWR:NACK
                  23093 RFM69:PTX:NO ADJ
                  23136 RFM69:SWR:SEND,TO=0,RETRY=5
                  23343 RFM69:SWR:ACK,FROM=0,SEQ=69,RSSI=-37
                  23347 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=12
                  23353 RFM69:PTX:LEVEL=12 dBm
                  23355 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004005004
                  23365 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  23373 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:02000400500461696C65642072656164696E67207465
                  23384 OTA:FWP:RECV B=0450
                  23386 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                  23392 RFM69:SWR:SEND,TO=0,RETRY=0
                  23601 !RFM69:SWR:NACK
                  23603 RFM69:PTX:LEVEL=13 dBm
                  23646 RFM69:SWR:SEND,TO=0,RETRY=1
                  23855 !RFM69:SWR:NACK
                  23857 RFM69:PTX:NO ADJ
                  23891 RFM69:SWR:SEND,TO=0,RETRY=2
                  24100 !RFM69:SWR:NACK
                  24102 RFM69:PTX:NO ADJ
                  24113 RFM69:SWR:SEND,TO=0,RETRY=3
                  24322 !RFM69:SWR:NACK
                  24324 RFM69:PTX:NO ADJ
                  24367 RFM69:SWR:SEND,TO=0,RETRY=4
                  24576 !RFM69:SWR:NACK
                  24578 RFM69:PTX:NO ADJ
                  24612 RFM69:SWR:SEND,TO=0,RETRY=5
                  24758 RFM69:SWR:ACK,FROM=0,SEQ=71,RSSI=-38
                  24762 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                  24766 RFM69:PTX:LEVEL=12 dBm
                  24770 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                  24778 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                  24782 RFM69:SWR:SEND,TO=0,RETRY=0
                  24993 !RFM69:SWR:NACK
                  24995 RFM69:PTX:LEVEL=13 dBm
                  25006 RFM69:SWR:SEND,TO=0,RETRY=1
                  25214 !RFM69:SWR:NACK
                  25217 RFM69:PTX:NO ADJ
                  25251 RFM69:SWR:SEND,TO=0,RETRY=2
                  25460 !RFM69:SWR:NACK
                  25462 RFM69:PTX:NO ADJ
                  25505 RFM69:SWR:SEND,TO=0,RETRY=3
                  25714 !RFM69:SWR:NACK
                  25716 RFM69:PTX:NO ADJ
                  25759 RFM69:SWR:SEND,TO=0,RETRY=4
                  25968 !RFM69:SWR:NACK
                  25970 RFM69:PTX:NO ADJ
                  26005 RFM69:SWR:SEND,TO=0,RETRY=5
                  26183 RFM69:SWR:ACK,FROM=0,SEQ=72,RSSI=-38
                  26189 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=12
                  26193 RFM69:PTX:LEVEL=12 dBm
                  26195 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                  26206 OTA:FRQ:FW REQ,T=0002,V=0004,B=044F
                  26210 RFM69:SWR:SEND,TO=0,RETRY=0
                  26421 !RFM69:SWR:NACK
                  26423 RFM69:PTX:LEVEL=13 dBm
                  26466 RFM69:SWR:SEND,TO=0,RETRY=1
                  26675 !RFM69:SWR:NACK
                  26677 RFM69:PTX:NO ADJ
                  26720 RFM69:SWR:SEND,TO=0,RETRY=2
                  26929 !RFM69:SWR:NACK
                  26931 RFM69:PTX:NO ADJ
                  26974 RFM69:SWR:SEND,TO=0,RETRY=3
                  27183 !RFM69:SWR:NACK
                  27185 RFM69:PTX:NO ADJ
                  27219 RFM69:SWR:SEND,TO=0,RETRY=4
                  27428 !RFM69:SWR:NACK
                  27430 RFM69:PTX:NO ADJ
                  27441 RFM69:SWR:SEND,TO=0,RETRY=5
                  27555 RFM69:SWR:ACK,FROM=0,SEQ=73,RSSI=-41
                  27561 RFM69:ATC:ADJ TXL,cR=-41,tR=-80,TXL=12
                  27566 RFM69:PTX:LEVEL=12 dBm
                  27568 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004F04
                  27578 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                  27586 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
                  27596 OTA:FWP:RECV B=044F
                  27600 OTA:FRQ:FW REQ,T=0002,V=0004,B=044E
                  27604 RFM69:SWR:SEND,TO=0,RETRY=0
                  27625 RFM69:SWR:ACK,FROM=0,SEQ=75,RSSI=-42
                  27629 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=11
                  27633 RFM69:PTX:LEVEL=11 dBm
                  27637 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004E04
                  27645 RFM69:SAC:SEND ACK,TO=0,RSSI=-51
                  27654 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004F04190D0A00322E322E302D626574610046
                  27666 OTA:FWP:RECV B=044F
                  27668 !OTA:FWP:WRONG FWB
                  27742 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                  27750 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004E0400000098196819C8193C1960194C193D
                  27760 OTA:FWP:RECV B=044E
                  27762 OTA:FRQ:FW REQ,T=0002,V=0004,B=044D
                  27768 RFM69:SWR:SEND,TO=0,RETRY=0
                  27789 RFM69:SWR:ACK,FROM=0,SEQ=78,RSSI=-43
                  27793 RFM69:ATC:ADJ TXL,cR=-43,tR=-80,TXL=10
                  27797 RFM69:PTX:LEVEL=10 dBm
                  27801 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004D04
                  27850 RFM69:SAC:SEND ACK,TO=0,RSSI=-52
                  27858 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004D0400530BC00AEB0A9A0B1C0BFA0A0E0B00
                  27869 OTA:FWP:RECV B=044D
                  27873 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                  27877 RFM69:SWR:SEND,TO=0,RETRY=0
                  28088 !RFM69:SWR:NACK
                  28090 RFM69:PTX:LEVEL=11 dBm
                  28133 RFM69:SWR:SEND,TO=0,RETRY=1
                  28342 !RFM69:SWR:NACK
                  28344 RFM69:PTX:LEVEL=12 dBm
                  28387 RFM69:SWR:SEND,TO=0,RETRY=2
                  28596 !RFM69:SWR:NACK
                  28598 RFM69:PTX:LEVEL=13 dBm
                  28641 RFM69:SWR:SEND,TO=0,RETRY=3
                  28850 !RFM69:SWR:NACK
                  28852 RFM69:PTX:NO ADJ
                  28895 RFM69:SWR:SEND,TO=0,RETRY=4
                  29104 !RFM69:SWR:NACK
                  29106 RFM69:PTX:NO ADJ
                  29140 RFM69:SWR:SEND,TO=0,RETRY=5
                  29233 RFM69:SWR:ACK,FROM=0,SEQ=80,RSSI=-39
                  29237 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                  29241 RFM69:PTX:LEVEL=12 dBm
                  29245 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                  29253 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                  29257 RFM69:SWR:SEND,TO=0,RETRY=0
                  29278 RFM69:SWR:ACK,FROM=0,SEQ=81,RSSI=-45
                  29282 RFM69:ATC:ADJ TXL,cR=-45,tR=-80,TXL=11
                  29286 RFM69:PTX:LEVEL=11 dBm
                  29290 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                  29755 OTA:FRQ:FW REQ,T=0002,V=0004,B=044C
                  29759 RFM69:SWR:SEND,TO=0,RETRY=0
                  29775 RFM69:SWR:ACK,FROM=0,SEQ=82,RSSI=-47
                  29782 RFM69:ATC:ADJ TXL,cR=-47,tR=-80,TXL=10
                  29786 RFM69:PTX:LEVEL=10 dBm
                  29790 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004C04
                  30025 RFM69:SAC:SEND ACK,TO=0,RSSI=-46
                  30033 TSF:MSG:READ,0-0-16,s=255,c=4,t=3,pt=6,l=22,sg=0:020004004C0407070707070707070707070103000000
                  30044 OTA:FWP:RECV B=044C
                  30048 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
                  30052 RFM69:SWR:SEND,TO=0,RETRY=0
                  30263 !RFM69:SWR:NACK
                  30265 RFM69:PTX:LEVEL=11 dBm
                  30308 RFM69:SWR:SEND,TO=0,RETRY=1
                  30517 !RFM69:SWR:NACK
                  30519 RFM69:PTX:LEVEL=12 dBm
                  30562 RFM69:SWR:SEND,TO=0,RETRY=2
                  30771 !RFM69:SWR:NACK
                  30773 RFM69:PTX:LEVEL=13 dBm
                  30816 RFM69:SWR:SEND,TO=0,RETRY=3
                  31025 !RFM69:SWR:NACK
                  31027 RFM69:PTX:NO ADJ
                  31070 RFM69:SWR:SEND,TO=0,RETRY=4
                  31279 !RFM69:SWR:NACK
                  31281 RFM69:PTX:NO ADJ
                  31315 RFM69:SWR:SEND,TO=0,RETRY=5
                  31449 RFM69:SWR:ACK,FROM=0,SEQ=84,RSSI=-39
                  31453 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=12
                  31457 RFM69:PTX:LEVEL=12 dBm
                  31461 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=2,pt=6,l=6,sg=0,ft=0,st=OK:020004004B04
                  31469 OTA:FRQ:FW REQ,T=0002,V=0004,B=044B
                  31473 RFM69:SWR:SEND,TO=0,RETRY=0
                  31696 !RFM69:SWR:NACK
                  31698 RFM69:PTX:LEVEL=13 dBm
                  31709 RFM69:SWR:SEND,TO=0,RETRY=1
                  31918 !RFM69:SWR:NACK
                  31920 RFM69:PTX:NO ADJ
                  31954 RFM69:SWR:SEND,TO=0,RETRY=2
                  32163 !RFM69:SWR:NACK
                  32165 RFM69:PTX:NO ADJ
                  32176 RFM69:SWR:SEND,TO=0,RETRY=3
                    49 TSM:INIT
                    51 TSF:WUR:MS=10000
                    53 RFM69:INIT
                    61 TSM:INIT:TSP OK
                    63 TSF:SID:OK,ID=16
                    65 TSM:FPAR
                    2082 TSM:FPAR:OK
                    2082 TSM:ID
                    2084 TSM:ID:OK
                    2086 TSM:UPL
                    2142 TSM:UPL:OK
                    2351 OTA:FWP:UPDATE
                    6780 MCO:REG:REQ
                    6883 MCO:BGN:STP
                    tekkaT
                    tekkaT
                    tekka
                    @gohan I suspect an ATC and/or timing issue - could you try this: https://github.com/tekka007/MySensors/tree/RFM69_Update
                    Update GW + node and post the full debug log for further analysis. Thanks
                      I left the myconfig.h file as the one provided but I get no communication
                      Node log
                      18 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.0-rc.2
                      28 TSM:INIT
                      28 TSF:WUR:MS=10000
                      30 RFM69:INIT
                      32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                      36 RFM69:PTX:LEVEL=5 dBm
                      40 TSM:INIT:TSP OK
                      43 TSF:SID:OK,ID=16
                      45 TSM:FPAR
                      45 RFM69:SWR:SEND,TO=255,RETRY=0
                      53 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      2060 !TSM:FPAR:NO REPLY
                      2062 TSM:FPAR
                      2064 RFM69:SWR:SEND,TO=255,RETRY=0
                      2070 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      4079 !TSM:FPAR:NO REPLY
                      4081 TSM:FPAR
                      4083 RFM69:SWR:SEND,TO=255,RETRY=0
                      4089 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      6100 !TSM:FPAR:NO REPLY
                      6103 TSM:FPAR
                      6105 RFM69:SWR:SEND,TO=255,RETRY=0
                      6111 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      8120 !TSM:FPAR:FAIL
                      8122 TSM:FAIL:CNT=1
                      8124 TSM:FAIL:DIS
                      8126 TSF:TDI:TSL
                      8126 RFM69:RSL
                      10031 MCO:BGN:STP
                      10543 MCO:BGN:INIT OK,TSP=0
                      11546 !MCO:SND:NODE NOT REG
                      T: 23.15
                      12052 !MCO:SND:NODE NOT REG
                      H: 47
                      12054 !MCO:SND:NODE NOT REG
                      12558 !MCO:SND:NODE NOT REG
                      12761 !MCO:SND:NODE NOT REG
                      13764 !MCO:SND:NODE NOT REG
                      13766 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                      13772 !MCO:SLP:TNR
                      18130 TSM:FAIL:RE-INIT
                      18132 TSM:INIT
                      18135 RFM69:INIT
                      18137 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                      18141 RFM69:PTX:LEVEL=5 dBm
                      18145 TSM:INIT:TSP OK
                      18147 TSF:SID:OK,ID=16
                      18149 TSM:FPAR
                      18151 RFM69:SWR:SEND,TO=255,RETRY=0
                      18157 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      20166 !TSM:FPAR:NO REPLY
                      20168 TSM:FPAR
                      20170 RFM69:SWR:SEND,TO=255,RETRY=0
                      20176 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      22188 !TSM:FPAR:NO REPLY
                      22190 TSM:FPAR
                      22192 RFM69:SWR:SEND,TO=255,RETRY=0
                      22198 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      23775 MCO:SLP:MS=589999
                      23777 !TSF:SND:TNR
                      24207 !TSM:FPAR:NO REPLY
                      24209 TSM:FPAR
                      24211 RFM69:SWR:SEND,TO=255,RETRY=0
                      24217 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      24279 TSF:TDI:TSL
                      24281 RFM69:RSL
                      GW LOG
                      mysgw: Starting gateway...
                      mysgw: Protocol version - 2.2.0-rc.2
                      mysgw: MCO:BGN:INIT GW,CP=RPNGL---,VER=2.2.0-rc.2
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: RFM69:INIT
                      mysgw: RFM69:INIT:PIN,CS=24,IQP=22,IQN=22
                      mysgw: RFM69:PTX:LEVEL=5 dBm
                      mysgw: TSM:INIT:TSP OK
                      mysgw: TSM:INIT:GW MODE
                      mysgw: MCO:REG:NOT NEEDED
                      mysgw: MCO:BGN:STP
                      mysgw: MCO:BGN:INIT OK,TSP=1
                      and nothing more while the node is looking for parent
                        I have tried on another RPI with the updated branch and still have no communication, if I switch back to normal development branch I get communication back. Anything more I can try?
                          @jkandasa I have managed to get FOTA do an update on the latest 2.2 but with a mod for rfm69 from tekka. I am having difficulties to trigger the OTA update even if a assign a different firmware to the node. Do you have any suggestion about this?
                          J 1 Reply Last reply
                            J
                            J
                            jkandasa
                            @gohan What the issue are you facing? AFAIK, RFM69 supports only for DualOptiboot
                              I'm using dual optiboot, the problem is that I was only able to trigger an ota on the node the first time I set it, after that the node is no longer starting a new ota transfer
                                J
                                J
                                jkandasa
                                @gohan Enable node debug log and trigger firmware update. Post node debug log.
                                A few weeks before, I see an issue with the DualOptiboot firmware update. For some reason, if firmware update failed in between, and when we trigger firmware update once again, node says It is up to date.
                                  17 MCO:BGN:INIT NODE,CP=RPONA---,VER=2.2.1-alpha
                                  26 TSM:INIT
                                  27 TSF:WUR:MS=10000
                                  29 RFM69:INIT
                                  30 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                  34 RFM69:PTX:LEVEL=5 dBm
                                  36 RFM69:INIT:HWV=36
                                  38 TSM:INIT:TSP OK
                                  40 TSF:SID:OK,ID=16
                                  43 TSM:FPAR
                                  44 RFM69:SWR:SEND,TO=255,RETRY=0
                                  47 RFM69:CSMA:RSSI=-109
                                  51 TSF:MSG:SEND,16-16-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  198 RFM69:SAC:SEND ACK,TO=0,RSSI=-44
                                  201 RFM69:CSMA:RSSI=-44
                                  210 RFM69:CSMA:RSSI=-109
                                  215 TSF:MSG:READ,0-0-16,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                  220 TSF:MSG:FPAR OK,ID=0,D=1
                                  2058 TSM:FPAR:OK
                                  2059 TSM:ID
                                  2060 TSM:ID:OK
                                  2062 TSM:UPL
                                  2063 RFM69:SWR:SEND,TO=0,RETRY=0
                                  2066 RFM69:CSMA:RSSI=-109
                                  2074 RFM69:SWR:ACK,FROM=0,SEQ=3,RSSI=-37
                                  2078 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=4
                                  2082 RFM69:PTX:LEVEL=4 dBm
                                  2084 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                  2091 RFM69:SAC:SEND ACK,TO=0,RSSI=-105
                                  2095 RFM69:CSMA:RSSI=-105
                                  2099 TSF:MSG:READ,0-0-16,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                  2104 TSF:MSG:PONG RECV,HP=1
                                  2106 TSM:UPL:OK
                                  2108 TSM:READY:ID=16,PAR=0,DIS=1
                                  2111 RFM69:SWR:SEND,TO=0,RETRY=0
                                  2114 RFM69:CSMA:RSSI=-104
                                  2120 RFM69:SWR:ACK,FROM=0,SEQ=5,RSSI=-38
                                  2123 RFM69:ATC:ADJ TXL,cR=-38,tR=-80,TXL=3
                                  2127 RFM69:PTX:LEVEL=3 dBm
                                  2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300
                                  2139 RFM69:SWR:SEND,TO=0,RETRY=0
                                  2142 RFM69:CSMA:RSSI=-109
                                  2152 RFM69:SWR:ACK,FROM=0,SEQ=6,RSSI=-36
                                  2155 RFM69:ATC:ADJ TXL,cR=-36,tR=-80,TXL=2
                                  2159 RFM69:PTX:LEVEL=2 dBm
                                  2162 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                  2168 RFM69:SAC:SEND ACK,TO=0,RSSI=-104
                                  2172 RFM69:CSMA:RSSI=-104
                                  2176 TSF:MSG:READ,0-0-16,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                  2182 RFM69:SWR:SEND,TO=0,RETRY=0
                                  2185 RFM69:CSMA:RSSI=-89
                                  2196 RFM69:CSMA:RSSI=-105
                                  2398 !RFM69:SWR:NACK
                                  2399 RFM69:SWR:SEND,TO=0,RETRY=1
                                  2403 RFM69:CSMA:RSSI=-104
                                  2607 !RFM69:SWR:NACK
                                  2608 RFM69:SWR:SEND,TO=0,RETRY=2
                                  2612 RFM69:CSMA:RSSI=-107
                                  2816 !RFM69:SWR:NACK
                                  2817 RFM69:SWR:SEND,TO=0,RETRY=3
                                  2821 RFM69:CSMA:RSSI=-103
                                  2852 RFM69:SWR:ACK,FROM=0,SEQ=8,RSSI=-37
                                  2855 RFM69:ATC:ADJ TXL,cR=-37,tR=-80,TXL=1
                                  2860 RFM69:PTX:LEVEL=1 dBm
                                  2862 TSF:MSG:SEND,16-16-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.2.1-alpha
                                  2870 RFM69:SWR:SEND,TO=0,RETRY=0
                                  2873 RFM69:CSMA:RSSI=-103
                                  2879 RFM69:SWR:ACK,FROM=0,SEQ=9,RSSI=-40
                                  2882 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=0
                                  2886 RFM69:PTX:LEVEL=0 dBm
                                  2889 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                  2962 RFM69:SAC:SEND ACK,TO=0,RSSI=-45
                                  2966 RFM69:CSMA:RSSI=-45
                                  2969 RFM69:CSMA:RSSI=-105
                                  2972 TSF:MSG:READ,0-0-16,s=255,c=3,t=6,pt=0,l=6,sg=0:Metric
                                  2978 RFM69:SWR:SEND,TO=0,RETRY=0
                                  2981 RFM69:CSMA:RSSI=-106
                                  2990 RFM69:SWR:ACK,FROM=0,SEQ=11,RSSI=-40
                                  2994 RFM69:ATC:ADJ TXL,cR=-40,tR=-80,TXL=-1
                                  2997 RFM69:PTX:LEVEL=-1 dBm
                                  3000 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:TEMP HUM dev
                                  3007 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3010 RFM69:CSMA:RSSI=-102
                                  3016 RFM69:SWR:ACK,FROM=0,SEQ=12,RSSI=-39
                                  3020 RFM69:ATC:ADJ TXL,cR=-39,tR=-80,TXL=-2
                                  3023 RFM69:PTX:LEVEL=-2 dBm
                                  3026 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
                                  3033 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3036 RFM69:CSMA:RSSI=-106
                                  3043 RFM69:SWR:ACK,FROM=0,SEQ=13,RSSI=-42
                                  3047 RFM69:ATC:ADJ TXL,cR=-42,tR=-80,TXL=-3
                                  3050 RFM69:PTX:LEVEL=-3 dBm
                                  3053 TSF:MSG:SEND,16-16-0-0,s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3059 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3062 RFM69:CSMA:RSSI=-109
                                  3069 RFM69:SWR:ACK,FROM=0,SEQ=14,RSSI=-50
                                  3074 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-4
                                  3078 RFM69:PTX:LEVEL=-4 dBm
                                  3080 TSF:MSG:SEND,16-16-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3086 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3089 RFM69:CSMA:RSSI=-105
                                  3096 RFM69:SWR:ACK,FROM=0,SEQ=15,RSSI=-50
                                  3100 RFM69:ATC:ADJ TXL,cR=-50,tR=-80,TXL=-5
                                  3104 RFM69:PTX:LEVEL=-5 dBm
                                  3106 TSF:MSG:SEND,16-16-0-0,s=202,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3112 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3116 RFM69:CSMA:RSSI=-107
                                  3123 RFM69:SWR:ACK,FROM=0,SEQ=16,RSSI=-51
                                  3127 RFM69:ATC:ADJ TXL,cR=-51,tR=-80,TXL=-6
                                  3131 RFM69:PTX:LEVEL=-6 dBm
                                  3133 TSF:MSG:SEND,16-16-0-0,s=203,c=0,t=33,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3139 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3142 RFM69:CSMA:RSSI=-107
                                  3149 RFM69:SWR:ACK,FROM=0,SEQ=17,RSSI=-52
                                  3153 RFM69:ATC:ADJ TXL,cR=-52,tR=-80,TXL=-7
                                  3158 RFM69:PTX:LEVEL=-7 dBm
                                  3160 TSF:MSG:SEND,16-16-0-0,s=204,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3166 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3169 RFM69:CSMA:RSSI=-107
                                  3176 RFM69:SWR:ACK,FROM=0,SEQ=18,RSSI=-53
                                  3180 RFM69:ATC:ADJ TXL,cR=-53,tR=-80,TXL=-8
                                  3184 RFM69:PTX:LEVEL=-8 dBm
                                  3186 TSF:MSG:SEND,16-16-0-0,s=201,c=0,t=30,pt=0,l=0,sg=0,ft=0,st=OK:
                                  3192 MCO:REG:REQ
                                  3194 RFM69:SWR:SEND,TO=0,RETRY=0
                                  3197 RFM69:CSMA:RSSI=-109
                                  3208 RFM69:SWR:ACK,FROM=0,SEQ=19,RSSI=-54
                                  3212 RFM69:ATC:ADJ TXL,cR=-54,tR=-80,TXL=-9
                                  3216 RFM69:PTX:LEVEL=-9 dBm
                                  3218 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                  3225 RFM69:SAC:SEND ACK,TO=0,RSSI=-107
                                  3228 RFM69:CSMA:RSSI=-107
                                  3232 TSF:MSG:READ,0-0-16,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                  3237 MCO:PIM:NODE REG=1
                                  3239 MCO:BGN:STP
                                  3751 MCO:BGN:INIT OK,TSP=1
                                  4755 RFM69:SWR:SEND,TO=0,RETRY=0
                                  4758 RFM69:CSMA:RSSI=-103
                                  4767 RFM69:SWR:ACK,FROM=0,SEQ=21,RSSI=-56
                                  4771 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-10
                                  4775 RFM69:PTX:LEVEL=-10 dBm
                                  4777 TSF:MSG:SEND,16-16-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:20.40
                                  T: 20.40
                                  5286 RFM69:SWR:SEND,TO=0,RETRY=0
                                  5289 RFM69:CSMA:RSSI=-110
                                  5296 RFM69:SWR:ACK,FROM=0,SEQ=22,RSSI=-56
                                  5299 RFM69:ATC:ADJ TXL,cR=-56,tR=-80,TXL=-11
                                  5303 RFM69:PTX:LEVEL=-11 dBm
                                  5306 TSF:MSG:SEND,16-16-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:41.0
                                  H: 41
                                  5312 RFM69:SWR:SEND,TO=0,RETRY=0
                                  5316 RFM69:CSMA:RSSI=-106
                                  5322 RFM69:SWR:ACK,FROM=0,SEQ=23,RSSI=-57
                                  5326 RFM69:ATC:ADJ TXL,cR=-57,tR=-80,TXL=-12
                                  5330 RFM69:PTX:LEVEL=-12 dBm
                                  5334 TSF:MSG:SEND,16-16-0-0,s=202,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-56
                                  5840 RFM69:SWR:SEND,TO=0,RETRY=0
                                  5842 RFM69:CSMA:RSSI=-107
                                  5851 RFM69:SWR:ACK,FROM=0,SEQ=24,RSSI=-58
                                  5855 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-13
                                  5859 RFM69:PTX:LEVEL=-13 dBm
                                  5861 TSF:MSG:SEND,16-16-0-0,s=203,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=OK:-44
                                  6068 RFM69:SWR:SEND,TO=0,RETRY=0
                                  6071 RFM69:CSMA:RSSI=-108
                                  6081 RFM69:SWR:ACK,FROM=0,SEQ=25,RSSI=-58
                                  6084 RFM69:ATC:ADJ TXL,cR=-58,tR=-80,TXL=-14
                                  6088 RFM69:PTX:LEVEL=-14 dBm
                                  6091 TSF:MSG:SEND,16-16-0-0,s=204,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:16
                                  7099 RFM69:SWR:SEND,TO=0,RETRY=0
                                  7101 RFM69:CSMA:RSSI=-105
                                  7109 RFM69:SWR:ACK,FROM=0,SEQ=26,RSSI=-60
                                  7113 RFM69:ATC:ADJ TXL,cR=-60,tR=-80,TXL=-15
                                  7117 RFM69:PTX:LEVEL=-15 dBm
                                  7119 TSF:MSG:SEND,16-16-0-0,s=201,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:3.26
                                  7127 MCO:SLP:MS=600000,SMS=1,I1=255,M1=255,I2=255,M2=255
                                  7132 RFM69:SWR:SEND,TO=0,RETRY=0
                                  7135 RFM69:CSMA:RSSI=-107
                                  7142 RFM69:SWR:ACK,FROM=0,SEQ=27,RSSI=-61
                                  7146 RFM69:ATC:ADJ TXL,cR=-61,tR=-80,TXL=-16
                                  7150 RFM69:PTX:LEVEL=-16 dBm
                                  7152 TSF:MSG:SEND,16-16-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                                  7659 TSF:TDI:TSL
                                  7660 RFM69:RSL
                                    26 TSM:INIT
                                    27 TSF:WUR:MS=10000
                                    29 RFM69:INIT
                                    38 TSM:INIT:TSP OK
                                    40 TSF:SID:OK,ID=16
                                    43 TSM:FPAR
                                    2058 TSM:FPAR:OK
                                    2059 TSM:ID
                                    2060 TSM:ID:OK
                                    2062 TSM:UPL
                                    2106 TSM:UPL:OK
                                    3192 MCO:REG:REQ
                                    3239 MCO:BGN:STP
                                    T: 20.40
                                    H: 41
                                    7659 TSF:TDI:TSL
                                    7660 RFM69:RSL
                                    J
                                    J
                                    jkandasa
                                    @gohan This node looks like sleeping node? Is it. I guess it won't walk up to update the entire firmware.
                                    And I do not see any response for this request 2130 TSF:MSG:SEND,16-16-0-0,s=255,c=4,t=0,pt=6,l=10,sg=0,ft=0,st=OK:020005006004A3EB0300. Is there any firmware assigned for this node in MyController?
                                      There is, I have loaded 5 but none work, besides the first time that actually did started the ota transfer
